» Members: 10,449
» Latest member: LouisMartin
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 641 online users.
» 0 Member(s) | 618 Guest(s)
AhrefsBot, Amazonbot, Applebot, AwarioBot, Baidu, Bing, Crawl, Google, HeadlessChrome, PetalBot, Yandex, bot
kc868-a6 analog input
Yesterday, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
Yesterday, 07:25 AM
Forum: F24
Yesterday, 05:35 AM
Forum: F24
Yesterday, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Yesterday, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  Product idea: A Series output only board
Posted by: spacerunner - 03-14-2023, 02:26 PM - Forum: Suggestions and feedback on KinCony's products - Replies (15)
It would be nice to have the opposite of a KC868-AI board but for outputs only.  Call it KC868-AO Smile.
Maybe for 32 / 64 channels, without extras like inputs. Just the MOSFET driver lines, ESP32, ethernet RJ45 and maybe I2C, RS485 or some other serial header.
Just ordered a KC868-A128 because I wanted the output flexibility of Mosfets, but the entire loaded board is actually too much.
Having Inputs and Outputs separated and both driven by ESP32s would be awesome. It eliminates single points of failure a bit and you could physically spread I/O across wider locations by simply using ethernet.
  "KCS" v1.0.19 firmware BIN file download
Posted by: admin - 03-14-2023, 01:05 PM - Forum: "KCS" v2 firmware system - Replies (2)
How to download and use, online guide: https://www.kincony.com/kcs-firmware-esp32-board.html
v1.0.19 improment:
fixed bugs with mqtt
fxied bugs with KC868-A16's digital input sequence.
.zip   KCS_KC868_A4_V1.0.19.zip (Size: 736.8 KB / Downloads: 1039)
.zip   KCS_KC868_A6_V1.0.19.zip (Size: 743.89 KB / Downloads: 932)
.zip   KCS_KC868_A8_V1.0.19.zip (Size: 747.82 KB / Downloads: 1066)
.zip   KCS_KC868_A8S_V1.0.19.zip (Size: 754.99 KB / Downloads: 974)
.zip   KCS_KC868_A16_V1.0.19.zip (Size: 755.24 KB / Downloads: 1006)
.zip   KCS_KC868_A32_V1.0.19.zip (Size: 755.28 KB / Downloads: 848)
.zip   KCS_KC868_A64_V1.0.19.zip (Size: 755.24 KB / Downloads: 867)
.zip   KCS_KC868_A128_V1.0.19.zip (Size: 755.43 KB / Downloads: 884)
.zip   KCS_KC868_AI_V1.0.19.zip (Size: 749.7 KB / Downloads: 944)
.zip   KCS_KC868_AK_V1.0.19.zip (Size: 737.64 KB / Downloads: 921)
.zip   KCS_KC868_E16S_V1.0.19.zip (Size: 755.25 KB / Downloads: 974)
  input sensors
Posted by: briansmit6@gmail.com - 03-14-2023, 07:54 AM - Forum: KC868-A8S - Replies (4)
Hello everyone,
i would like to connect more than 1 sensor to the board. But in the description i read "1 connector for connecting temperature and other sensors"
Did someone tried to connect more than 1 sensor to it or is there a multiplex module available ?
  client ONLINE/OFFLINE status
Posted by: shivdoke39 - 03-14-2023, 07:44 AM - Forum: KC868-A8 - Replies (5)
I am using kincony A8 board with my local mqtt broker..i have successfully connected board with mqtt and tested relay output using mqtt commands.....
   is there any way to check my device is online or offline ??? online /offline status of kincony A8 client .....??
  KS868-A Series multiple questions
Posted by: spacerunner - 03-14-2023, 07:14 AM - Forum: KC868-A series and Uair Smart Controller - Replies (7)
just a fest questions about different A-Series ESP32 controllers:
1. Are the dry contact inputs of the KCS868-AI the same as on the KC868-A16/64/128 ? (anti-interference, ling range etc)
2. Can the dry contact inputs of KCS868-AI or KC868-A16/64/128 also be driven by external voltage, such as +5V or +12V?
3. Can the MOSFET outputs of KC868-A16/64/128 also drive +5V instead of 12V/24V?
4. Can the MOSFET outputs of KC868-A16/64/128 drive different voltages per 8-PIN-Block? For example 12V output on A1-A8, 24V output on B9-B16, 5V output on B73-B80?
  KC868-A4 dht22 problem
Posted by: Joseph.o - 03-13-2023, 11:19 PM - Forum: KC868-A4 - Replies (9)
i'm using a dht22 and input 1 and output1.
i made a simple code where i'm showing the dht22 value in the serial monitoring and  when the intput1 is colsed i made the output1 in the ON state, and if the input1 is open the ouptput1 is OFF.
in the simulation everting work fine and the value of the dht22 sonsor is correct.
but when i add an lamp in the output1 and turn it on and off the value of the dht22 becomes null.
i tried to modify the code like add a delay... but no result. dht22 becomes null.
 here is my simple source code:
#define output1 4
#define input1   36
#include "DHT.h"
#define DHTPIN 13     // Digital pin connected to the DHT sensor
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
int temperatureSonde=0;
  Serial.begin(9600);
dht.begin();
pinMode(output1,OUTPUT);
pinMode(input1,INPUT);
int loading=0;
if (digitalRead(input1)==0 && digitalRead(output1)==0){digitalWrite(output1,1);
//delay(100);
else if(digitalRead(input1)==1 && digitalRead(output1)==1){digitalWrite(output1,0);
//delay(100);
/*********************humidity***************************/
// Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very s0 sensor)
  float h = dht.readHumidity();
  // Check if any reads failed and exit early (to try again).
  if (isnan(h) ) {
      Serial.println("Failed to read from DHT sensor!");
  Serial.print(F("Humidity: "));
  Serial.println(int(dht.readHumidity()));
delay(100);
}// end loop()
Photo kc868-A6 relay module RS485 communication
Posted by: Joseph.o - 03-13-2023, 10:59 PM - Forum: KC868-A6 - Replies (1)
hello,
i want to connect the kc868-A6 with a 8 input 8 output rs485 relay.
is there any source code that can use it or start with?
[Image: DC-12V-24V-Multifunction-RS485-IO-Board-....jpg_.webp]
  Strange Behavior
Posted by: Philadam - 03-13-2023, 10:32 PM - Forum: KC868-A16 - Replies (5)
I have a 4 gang momentary switch connected to input positions 1-4 and GND on my A16. When I push the buttons I would expect outputs 1-4 to be triggered, instead outputs 9-12 are triggered. Plus, if I push the buttons fast, the A16 seems to get confused and the outputs either freeze or aren't triggered.
I have the latest KCS firmware installed  v1.0.15.
Any ideas on why this is happening.
I have attached pictures.
  Homekit firmware for KC868-A32
Posted by: krokodilik - 03-13-2023, 07:44 PM - Forum: KC868-A series and Uair Smart Controller - Replies (15)
Hi guys,
i have bought KC868-A32 board, and my plan is to use relays on board to control some devices using apple homekit environment.
I am not going to implement or develop any software. I just need to flash firmware for this board and then add it to homekit.
However i am struggling what firmware/software/bin to use, or how to do it. I have successfully flashed KCS firmware but it is not supporting homekit.
I found that homespan package in ArduinoIDE would help, but as i said i am not going to develop software based on examples.
i want to automate devices within homekit.
Please advice how to make relays in KC868-A32 board visible in homekit. Is some homekit firmware available and ready for use like for HB32-PRO?
Actually i bought this board because it was stated that it supports homekit.
Thank you.
Miroslav
  Help - Did I Buy The Wrong Device
Posted by: shrub100 - 03-13-2023, 06:10 PM - Forum: KC868-AG / AG Pro / AG8 / Z1 - Replies (7)
Hi, I bought one of Kincony KC868-AG IR RF Transmitter / Recievers from AlliExpress hoping that it would integrate better with my Home Assistant set-up vs my current transmitter / receiver which only works via Tuya SmartLife. The adverts looked like a device that was 'ready to go' but I am starting to understand that this is not the case and that there is a reasonable amount of coding and configuration etc required to get this to work or am I missing something? Out of the box there were no instructions or any guidance on how this works. So far I managed:
1. Set-up ESP Home on Home Asistant
2. Connect to the device and load the configuration including wifi; HA api / passwords etc
3. I now have an entity for firmware updates, but that is it.
I can see some of the suggestions on setting up the Yaml to start to get the receivers to work but have had limited success and am getting multiple errors and the yaml from the post KC868-UAIR ESPHOME Config for IR and RF (kincony.com) isnt really complete and fully working as far as I can tell. Here are my errors:
  • IR Reciever - ERROR [inverted] is an invalid option for [1]. Please check the indentation. I did add some indentation and just got another error.
  • Buzzer - commented out as I have a warning about pin4 being a strapping pin
  • Entity - is not a valid domain - not sure what to select for a buzzer though!
So questions:
1. is there any way to get this working with some ready-made firmware? I want to be able to read IR / RF signals and then create some buttons to send them to my blinds; garage door; and a few other items.
2. if there is nothing out of the box... can someone just post a working YAML for this device with all the receivers/transmitters and buzzers? Equally, maybe a couple of examples of devices would be useful. Surely it is more work to continuously respond to questions about getting this working than to just write a few lines of code once and be done with it?
3. Once I have the yaml working... then what? How do I actually use this to record and transmit via home assistant? Is there another plugin or something that makes this work in HA ideally with a GUI?
Sorry for all the newb questions. I would not have bought this item if I knew that the software embedded was missing and that I would have to find / build everything myself. I get that this works for some hardcore users, and whilst I am happy tinkering I also have kids and work to worry about  Wink
My Yaml so far.
  friendly_name: "ESP Remote IR / RF Remote"
  encryption:
    key: "**********"
ota:
  password: "**********"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "esp_remote_ir_rf_remote"
#Remote Reciver
remote_receiver:
  - id: RF_Receiver
    pin: 13
    dump:
      - rc_switch
    tolerance: 50%
    filter: 250us
    idle: 4ms
#IR Reciever - ERROR [inverted] is an invalid option for [1]. Please check the indentation.
  - id: IR_Receiver - commented out as
    pin: 23
    inverted: True
    dump: all
#Buzzer - commented out as I have a warning about pin4 being a strapping pin.
#output:
#  - platform: gpio
#    id: "buzzer"
#    pin: 4
#entity: -  Also entity isnt a valid domain apparently - what should I use for a buzzer then?
#  - platform: binary
#    output: "buzzer"
#    name: "IR-RF-Remote-Buzzer"
