» Members: 10,382
» Latest member: h13tcom
» Forum threads: 4,313
» Forum posts: 21,282
There are currently 483 online users.
» 0 Member(s) | 462 Guest(s)
Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, PetalBot, Semrush, bot
Last Post: viko
6 hours ago
» Replies: 23
Recommended Dimmer for LE...
11 hours ago
KC868-A16-V3.2: exact wir...
Forum: KC868-A16v3
Today, 12:31 AM
ESPHome modbus not functi...
Forum: KC868-A8S
10-30-2026, 01:02 PM
SSD not visible for insta...
Forum: Pi5R16
10-29-2026, 12:30 PM
» Replies: 20
B32M And new ESPHOME Buil...
Forum: B32M
10-29-2026, 12:29 PM
Forum: T16M
10-29-2026, 08:42 AM
Forum: T16M
10-29-2026, 08:41 AM
B8 – Defective screw term...
Forum: B8
10-28-2026, 11:57 PM
Forum: B2
10-28-2026, 12:53 AM
  DTSU 666 energy meter - any code?
Posted by: marekw - 02-03-2026, 07:13 PM - Forum: KC868-A8S - Replies (1)
I'm trying read from CHINT DTSU-666 meter, but no success. My code below. Anyone can help?
  tx_pin: 17
  rx_pin: 16
  baud_rate: 9600
  parity: NONE
  stop_bits: 1
  data_bits: 8
  debug:
    direction: BOTH
modbus:
  uart_id: mod_bus
  flow_control_pin: 32
modbus_controller:
  address: 0x02
  modbus_id: modbus_hub
  update_interval: 10s
  command_throttle: 500ms
  - platform: modbus_controller
    modbus_controller_id: dtsu666
    name: "Test - Napięcie UA"
    address: 0x2006
    register_type: read
    value_type: FP32
    unit_of_measurement: "V"
    accuracy_decimals: 1
    filters:
      - multiply: 0.1
    name: "Test - Prąd IA"
    address: 0x200C
    register_type: read
    value_type: FP32
    unit_of_measurement: "A"
    accuracy_decimals: 2
    filters:
      - multiply: 0.001
  DM32 ESP32-S3 IO pins define
Posted by: admin - 02-03-2026, 12:35 AM - Forum: DM32 - No Replies
SDA:GPIO8
SCL:GPIO18
PCF8575: (input1-16): i2c address:0x22 by B16-core
P8:input1
P9:input2
P10:input3
P11:input4
P12:input5
P13:input6
P14:input7
P15:input8
P0:input9
P1:input10
P2:input11
P3:input12
P4:input13
P5:input14
P6:input15
P7:input16
PCF8575: (input17-32): i2c address:0x24
P0:input17
P1:input18
P2:input19
P3:input20
P4:input21
P5:input22
P6:input23
P7:input24
P8:input25
P9:input26
P10:input27
P11:input28
P12:input29
P13:input30
P14:input31
P15:input32
Analog input (A1: DC 0-5v)
Analog input (A2: DC 0-5v)
Analog input (A3: DC 4-20mA)
Analog input (A4: DC 4-20mA)
24C02 EPROM i2c address: 0x50
DS3231 RTC i2c address: 0x68
1-wire1:GPIO47
1-wire2:GPIO48
1-wire3:GPIO7
1-wire4:GPIO40
free GPIOs:
GPIO13
GPIO14
GPIO21
Ethernet (W5500) I/O define:
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
interrupt_pin: GPIO43
reset_pin: GPIO44
RS485:
RXD:GPIO38
TXD:GPIO39
Tuya module:
RXD:GPIO17
TXD:GPIO16
ARM CPU TXD:GPIO4
ARM CPU RXD:GPIO6
SD Card:
SPI-MOSI:GPIO10
SPI-SCK:GPIO11
SPI-MISO:GPIO12
SPI-CS:GPIO9
SD-Detect: GPIO5
  [arduino code examples for DM32]-02 Read digital input ports state
Posted by: admin - 02-03-2026, 12:31 AM - Forum: DM32 - No Replies
#include <Wire.h>
#include "PCF8575.h"
#define I2C_SDA 8
#define I2C_SCL 18
PCF8575 pcf8575_IN1(0x22); // DI1–DI16
PCF8575 pcf8575_IN2(0x24); // DI17–DI32
uint8_t pin_order_dm16[16] = {
    8, 9, 10, 11, 12, 13, 14, 15,
    0, 1, 2, 3, 4, 5, 6, 7
uint8_t pin_order_ext[16] = {
    0, 1, 2, 3, 4, 5, 6, 7,
    Wire.begin(I2C_SDA, I2C_SCL);
    pcf8575_IN1.begin();
    pcf8575_IN2.begin();
    Serial.println("DI1–DI32 (0=ON 1=OFF)");
    Serial.print("DI1–DI32: ");
    // DI1–DI16
        Serial.print(pcf8575_IN1.read(pin_order_dm16[i]));
        Serial.print(" ");
    // DI17–DI32
        Serial.print(pcf8575_IN2.read(pin_order_ext[i]));
        Serial.print(" ");
    Serial.println();
    delay(500);
arduino ino file download:
.zip   2-digital-input.zip (Size: 547 bytes / Downloads: 440)
.zip   2-digital-input.ino.merged.zip (Size: 197.89 KB / Downloads: 418)
  [arduino code examples for DM32]-01 32 Channel DAC output by digital input buttons
Posted by: admin - 02-03-2026, 12:30 AM - Forum: DM32 - No Replies
#include <Adafruit_PCF8575.h>
#include <HardwareSerial.h>
// Define Modbus RTU frame format constants
#define MODBUS_READ_COILS 0x01
#define MODBUS_READ_REGISTERS 0x03
#define MODBUS_WRITE_SINGLE_REGISTER 0x06
#define MODBUS_WRITE_MULTIPLE_REGISTERS 0x10
/* Example for 16 input buttons that are connected from the GPIO expander pins to ground.
* Note the buttons must be connected with the other side of the switch to GROUND. There is
* a built in pull-up 'resistor' on each input, but no pull-down resistor capability.
#define DM_NUMS 32 // change for 16, 32 for KinCony DM16, DM32 Smart Dimmer Controller
#define SDA_PIN 8
#define SCL_PIN 18
#define ADDRESS_PCF8575     0x22
#define ADDRESS_PCF8575_2   0x24
#define ST_RX   4 ////ESP32_RCV
#define ST_TX   6 ///ESP32_SEND
typedef enum{KEY_RELEASE=0,KEY_SHORT_PRESSED,KEY_LONG_PRESSED}KEY_STATUS;
typedef struct{
  uint8_t key_index;
  KEY_STATUS key_status;
  long key_time_start;
  long key_time_rec;
  long key_press_time;
  int16_t key_press_cnt; ////Send serial data once every 100 ms
  int16_t key_press_cnt_old;
  float current_light; ///Percentage of 0–4095
}KEY_PRESS_PROP;
KEY_PRESS_PROP key_press_prop[32] = {0};
Adafruit_PCF8575 pcf,pcf2;
HardwareSerial myst_serial(1);
TwoWire myI2c = TwoWire(0);
ushort dm_num = DM_NUMS;
// Modbus CRC16 Calculation function
uint16_t modbus_crc16(uint8_t *data, uint16_t length) {
  uint16_t crc = 0xFFFF;
  for (uint16_t i = 0; i < length; i++) {
    crc ^= data[i];
    for (uint8_t j = 0; j < 8; j++) {
      if (crc & 0x0001) {
        crc = (crc >> 1) ^ 0xA001;
        crc = crc >> 1;
  return crc;
* Send a Modbus RTU frame
* @param serial HardwareSerial object
* @param address Slave address (1-247)
* @param function function code
* @param data
* @param dataLen
void send_modbus_frame(HardwareSerial &serial, uint8_t address, uint8_t function,
                      const uint8_t *data, uint16_t dataLen) {
  // Create a transmit buffer
  uint16_t totalLen = 1 + 1 + dataLen + 2; // address + function code + data + CRC
  uint8_t buffer[totalLen];
  buffer[0] = address;
  buffer[1] = function;
  memcpy(&buffer[2], data, dataLen);
  uint16_t crc = modbus_crc16(buffer, 2 + dataLen);
  // Add CRC (low byte first)
  buffer[2 + dataLen] = crc & 0xFF;      // CRC low byte
  buffer[3 + dataLen] = (crc >> 8) & 0xFF; // CRC high byte
  // Send the complete frame
  for (uint16_t i = 0; i < totalLen; i++) {
    serial.write(buffer[i]);
  // Flush the transmit buffer to ensure all data is sent
  serial.flush();
// Encapsulate commonly used Modbus functions
* Send a Read Holding Registers request
* @param serial
* @param address
* @param startReg
* @param numRegs
void modbus_read_registers(HardwareSerial &serial, uint8_t address,
                          uint16_t startReg, uint16_t numRegs) {
  uint8_t data[4];
  data[0] = (startReg >> 8) & 0xFF; // High byte of the register address
  data[1] = startReg & 0xFF;        // Low byte of the register address
  data[2] = (numRegs >> 8) & 0xFF;  // High byte of the register count
  data[3] = numRegs & 0xFF;         // Low byte of the register count
  send_modbus_frame(serial, address, MODBUS_READ_REGISTERS, data, sizeof(data));
* @param serial
* @param address
* @param regAddress
* @param value
void modbus_write_single_register(HardwareSerial &serial, uint8_t address,
                                uint16_t regAddress, uint16_t value) {
  uint8_t data[4];
  data[0] = (regAddress >> 8) & 0xFF; // High byte of the register address
  data[1] = regAddress & 0xFF;        // Low byte of the register address
  data[2] = (value >> 8) & 0xFF;      // High byte of the data
  data[3] = value & 0xFF;             // Low byte of the
  send_modbus_frame(serial, address, MODBUS_WRITE_SINGLE_REGISTER, data, sizeof(data));
* @param serial
* @param address
* @param startReg
* @param values
* @param numRegs
void modbus_write_multiple_registers(HardwareSerial &serial, uint8_t address,
                                   uint16_t startReg, const uint16_t *values,
                                   uint16_t numRegs) {
  uint8_t byteCount = numRegs * 2;
  uint8_t data[5 + byteCount];
  data[4] = byteCount;
  for (uint8_t i = 0; i < numRegs; i++) {
    data[5 + i*2] = (values[i] >> 8) & 0xFF;
    data[6 + i*2] = values[i] & 0xFF;
  send_modbus_frame(serial, address, MODBUS_WRITE_MULTIPLE_REGISTERS, data, sizeof(data));
  myI2c.begin(SDA_PIN,SCL_PIN,100000);
  myst_serial.begin(115200,SERIAL_8N1,ST_RX,ST_TX);///RXPIN FIRST
  while (!Serial) { delay(10); }
  Serial.println("Adafruit PCF8575 button read test");
  if (!pcf.begin(ADDRESS_PCF8575, &myI2c)) {
    Serial.println("err:DMxx Couldn't find 1_PCF8575!");
    while (1);
  else Serial.println("Find 1_PCF8575!");
  if(dm_num==32)
    if (!pcf2.begin(ADDRESS_PCF8575_2, &myI2c)) {
    Serial.println("DM32 Couldn't find 2_PCF8575");
    else Serial.println("Find 2_PCF8575!");
  for (uint8_t p=0; p<DM_NUMS; p++) {
    pcf.pinMode(p, INPUT_PULLUP);
    if(dm_num==32) pcf2.pinMode(p-16, INPUT_PULLUP);
    key_press_prop[p].key_index = p+1;
    key_press_prop[p].key_status = KEY_RELEASE;
    key_press_prop[p].key_press_time = 0;
  Serial.println("Now, starting!");
static uint16_t input_value_old[2] = {0xffff,0xffff};
uint16_t input_value[2] = {0} ;
int8_t current_operator_key = -1;
int8_t key_index = -1,key_index_last = -1;
int16_t key_press_cnt_old = 0;
uint16_t write_value=0;
static int8_t get_key_press(int8_t chip,uint16_t key_value)
  if(key_value == 0xffff || key_value == 0) return -1;
  for(int16_t i=0;i<16;i++)
    if((key_value & (1<<i) ) == 0)  return (chip==0)?i:i+16;
static uint16_t getKeycode()
  uint16_t input_value = 0,tmp_value;
  uint8_t h_value = 0 ,l_value = 0;
  tmp_value = pcf.digitalReadWord();
  h_value = tmp_value>>8;
  l_value = tmp_value&0xff;
  input_value = (l_value<<8 ) | h_value;
  return input_value;
static uint16_t getKeycode2()
  tmp_value = pcf2.digitalReadWord();
  input_value = (l_value ) | (h_value<<8);
  return input_value;
static void checkKeyPress(int8_t chip);
static uint16_t key_old_arr[2] = {0};
  input_value[0] = getKeycode();
  /*if(key_old_arr[0] != input_value[0] )
    key_old_arr[0] = input_value[0];
    Serial.printf("input0:%d\r\n",input_value[0]);
  checkKeyPress(0);
  if(dm_num == 32)
    delay(10);
    input_value[1] = getKeycode2();
    checkKeyPress(1);
    /*if(key_old_arr[1] != input_value[1] )
      key_old_arr[1] = input_value[1];
      Serial.printf("input1:%d\r\n",input_value[1]);
  delay(10); // a short debounce delay
  uint8_t start_index = (chip==0)?0:16;
  if(input_value_old[chip] != input_value[chip])
    input_value_old[chip] = input_value[chip];
    if(input_value[chip] == 0xffff)
      Serial.printf("key is released!");
      key_index_last = key_index = -1;
      for (uint8_t p=start_index; p<16+start_index; p++) ///all key status init.
        key_press_prop[p].key_time_start = 0;
        key_press_prop[p].key_time_rec = 0;
        key_press_prop[p].key_press_cnt = 0;
        key_press_prop[p].key_press_cnt_old = 0;
    else ///key press
      //Serial.printf("input_value = %04X \r\n",input_value);
      key_index = get_key_press(chip,input_value[chip]);
      if(key_index >= 0)
        key_index_last = key_index;
        Serial.printf("key %02d # is pressed! \r\n",key_index+1);
        current_operator_key = key_index;
        key_press_prop[current_operator_key].key_status = KEY_SHORT_PRESSED;
        key_press_prop[current_operator_key].key_time_start = millis();
        key_press_prop[current_operator_key].key_press_time = 0;
  else
    if(input_value[chip] != 0xffff) ///LONG PRESS!
      //Serial.printf("key long pressed! \r\n");
      if(key_index >= 0 && key_index_last == key_index)
        //Serial.printf("key long pressed! key_index = %d\r\n",key_index);
        key_press_prop[current_operator_key].key_status = KEY_LONG_PRESSED;
        key_press_prop[current_operator_key].key_time_rec = millis();
        key_press_prop[current_operator_key].key_press_time = key_press_prop[current_operator_key].key_time_rec - key_press_prop[current_operator_key].key_time_start;
        key_press_prop[current_operator_key].key_press_cnt = (key_press_prop[current_operator_key].key_press_time % 4080 ) / 100; ////100MS发一次
        //Serial.printf("key long time = %d, cnt = %d \r\n",key_press_prop[current_operator_key].key_press_time,key_press_prop[current_operator_key].key_press_cnt);
        if(key_press_prop[current_operator_key].key_press_cnt_old != key_press_prop[current_operator_key].key_press_cnt)
          key_press_prop[current_operator_key].key_press_cnt_old = key_press_prop[current_operator_key].key_press_cnt;
          /////send st_tx information.
          key_press_prop[current_operator_key].current_light = (float)key_press_prop[current_operator_key].key_press_cnt * 100.0f;
          write_value = (uint16_t) key_press_prop[current_operator_key].current_light;
          Serial.printf("key_long_press_time = %d, current_light = %d \r\n",key_press_prop[current_operator_key].key_press_time,write_value);
          modbus_write_multiple_registers(myst_serial,1,4000+current_operator_key,&write_value,1);
.zip   1-dac-32ch.zip (Size: 2.95 KB / Downloads: 439)
.zip   1-dac-32ch.ino.merged.zip (Size: 205.71 KB / Downloads: 438)
  DM8 DM16 DM32 PC software using USB-RS485 adapter
Posted by: admin - 02-03-2026, 12:27 AM - Forum: DM16 - No Replies
PC software download:
.zip   DMxx_SIMPLE1220.zip (Size: 1.66 MB / Downloads: 427)
Posted by: admin - 02-03-2026, 12:27 AM - Forum: DM8 - No Replies
.zip   DMxx_SIMPLE1220.zip (Size: 1.66 MB / Downloads: 463)
Posted by: admin - 02-03-2026, 12:27 AM - Forum: DM32 - No Replies
.zip   DMxx_SIMPLE1220.zip (Size: 1.66 MB / Downloads: 441)
  DM8 ESP32-S3 IO pins define
Posted by: admin - 02-03-2026, 12:23 AM - Forum: DM8 - No Replies
SDA:GPIO8
SCL:GPIO18
PCF8574: (input1-8): i2c address:0x24
P0:input1
P1:input2
P2:input3
P3:input4
P4:input5
P5:input6
P6:input7
P7:input8
1-wire1:GPIO47
1-wire2:GPIO48
1-wire3:GPIO17
1-wire4:GPIO40
free GPIOs:
GPIO13
GPIO14
GPIO21
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
reset_pin: GPIO44
RS485:
RXD:GPIO38
TXD:GPIO39
Tuya module:
RXD:GPIO15
TXD:GPIO16
SD Card:
SPI-MOSI:GPIO10
SPI-SCK:GPIO11
SPI-MISO:GPIO12
SPI-CS:GPIO9
SD-Detect: GPIO5
ARM CPU TXD:GPIO4
ARM CPU RXD:GPIO6
  [arduino code examples for DM8]-02 Read digital input ports state
Posted by: admin - 02-03-2026, 12:21 AM - Forum: DM8 - No Replies
KeyPressed on PIN1
by Mischianti Renzo <http://www.mischianti.org>
https://www.mischianti.org/2019/01/02/pcf8574-i2c-digital-i-o-expander-fast-easy-usage/
#include "Arduino.h"
#include "PCF8574.h"
// Define I2C pins
#define I2C_SDA 8   // SDA pin
#define I2C_SCL 18  // SCL pin
// Set i2c address
PCF8574 pcf8574(0x24);
unsigned long timeElapsed;
//    pcf8574.pinMode(P0, OUTPUT);
pcf8574.pinMode(P0, INPUT);
pcf8574.pinMode(P1, INPUT);
pcf8574.pinMode(P2, INPUT);
pcf8574.pinMode(P3, INPUT);
pcf8574.pinMode(P4, INPUT);
pcf8574.pinMode(P5, INPUT);
pcf8574.pinMode(P6, INPUT);
pcf8574.pinMode(P7, INPUT);
    if (pcf8574.begin()){
        Serial.println("OK");
    }else{
        Serial.println("KO");
uint8_t val5 = pcf8574.digitalRead(P4);
uint8_t val6 = pcf8574.digitalRead(P5);
uint8_t val7 = pcf8574.digitalRead(P6);
uint8_t val8 = pcf8574.digitalRead(P7);
    delay(300);
.zip   2-digital-input.zip (Size: 719 bytes / Downloads: 460)
.zip   2-digital-input.ino.merged.zip (Size: 199.51 KB / Downloads: 455)
  [arduino code examples for DM8]-01 8 Channel DAC output by digital input buttons
Posted by: admin - 02-03-2026, 12:19 AM - Forum: DM8 - No Replies
#include <Adafruit_PCF8574.h>
#define DM_NUMS 8
#define SDA_PIN 8
#define SCL_PIN 18
#define ADDRESS_PCF8574     0x24   ////A2 A1 A0 :100 = 0x20+4
typedef struct{
  uint8_t key_index;
  long key_time_rec;
}KEY_PRESS_PROP;
KEY_PRESS_PROP key_press_prop[16] = {0};
Adafruit_PCF8574 pcf;
    crc ^= data[i];
      if (crc & 0x0001) {
        crc = crc >> 1;
  return crc;
* @param data
* @param dataLen
  serial.flush();
* @param serial
* @param address
* @param startReg
* @param numRegs
  uint8_t data[4];
* @param serial
* @param address
* @param regAddress
* @param value
  uint8_t data[4];
* @param serial
* @param address
* @param startReg
* @param values
* @param numRegs
                                   uint16_t numRegs) {
  Serial.println("Adafruit PCF8574 button read test");
  if (!pcf.begin(ADDRESS_PCF8574, &myI2c)) {
    Serial.println("err:DMxx Couldn't find PCF8574!");
    while (1);
  else Serial.println("Find PCF8574!");
static uint16_t input_value_old[2] = {0xff,0xff};
  if(key_value == 0xff || key_value == 0) return -1;
  tmp_value = pcf.digitalReadByte();
  //h_value = tmp_value>>8;
// l_value = tmp_value&0xff;
  //input_value = (l_value<<8 ) | h_value;
  input_value = tmp_value;
  return input_value;
  if(key_old_arr[0] != input_value[0])
  checkKeyPress(0);
    if(input_value[chip] == 0xff)
      for (uint8_t p=start_index; p<8+start_index; p++) ///all key status init.
    else ///key press
      if(key_index >= 0)
  else
    if(input_value[chip] != 0xff) ///LONG PRESS!
.zip   1-dac-8ch.zip (Size: 2.83 KB / Downloads: 402)
.zip   1-dac-8ch.ino.merged.zip (Size: 205.65 KB / Downloads: 470)
