» Members: 10,383
» Latest member: sutbongtvchannel
» Forum threads: 4,313
» Forum posts: 21,282
There are currently 95 online users.
» 0 Member(s) | 85 Guest(s)
Amazonbot, Baidu, Crawl, PetalBot, bot, owler
Last Post: viko
10 hours ago
» Replies: 23
Recommended Dimmer for LE...
Yesterday, 08:21 AM
KC868-A16-V3.2: exact wir...
Forum: KC868-A16v3
Yesterday, 12:31 AM
ESPHome modbus not functi...
Forum: KC868-A8S
10-30-2026, 01:02 PM
SSD not visible for insta...
Forum: Pi5R16
10-29-2026, 12:30 PM
» Replies: 20
B32M And new ESPHOME Buil...
Forum: B32M
10-29-2026, 12:29 PM
Forum: T16M
10-29-2026, 08:42 AM
Forum: T16M
10-29-2026, 08:41 AM
B8 – Defective screw term...
Forum: B8
10-28-2026, 11:57 PM
Forum: B2
10-28-2026, 12:53 AM
  LAN8720 DHCP implementaion with mqtt arduino source code
Posted by: jcyu5662 - 01-04-2026, 02:05 PM - Forum: KC868-A2 - Replies (1)
Hi.
I bought KC868-A2 board.
I am tryning to send mqtt message to the mqtt broker through LAN8720 with dhcp configuration.
Any example arduino code on this.
Many Thanks for this wonderfull board. Nice Work!!!
  T16M not responding on USB
Posted by: robarends - 01-04-2026, 12:04 PM - Forum: T16M - Replies (6)
I have 2 T16M.
I am building a Wiegand door lock controller with ESPHome firmware, and am proceeding well.
I am currently using my second T16M with a Wiegand S20 keypad via a 5v - 3v3 logic level shifter.
However when I was using the first T16M, I did not use the 5v - 3v3 logic level shifter.
After some time of development using ESPhome it stopped responding via USB.
I had assumed I damaged the T16M.
You have advised that "you can connect Wiegand D0 and D1 to T16M free GPIOs directly, not need logic convert.", so therefore my assumption was incorrect.
I have seen in another thread that you can reset the T16M using the DW button while power-on.
Using that method has not made the USB work.
What can I do to make the USB work again?
Thanks, Rob.
  T16M ESPHome and EPROM
Posted by: robarends - 01-03-2026, 12:05 PM - Forum: T16M - Replies (1)
In the pin definition for the T16M, it shows the Eprom on the I2c bus.
How can we use the Eprom in ESPHome, and what is the size of the storage?
Thanks, Rob
  Board output not responding to input commands
Posted by: Elgatoguiri - 01-03-2026, 12:02 PM - Forum: KC868-A series and Uair Smart Controller - Replies (3)
Finally I've received the kc868-a16 unit and got it working. Or at least somewhat working. I've flashed the kcs_kc868_a16_v2.2.18 firmware and it seems to be working. The board boots up and I can connect to it through the browser but I can't control it.
In the monitor tab there is the output section and I can click on ALL ON or ALL OFF and the squares go green or gray but the board doesn't do anything. The led indicators don't turn on and checking with a multimeter there isn't anything opening or closing.
I've tried shorting the digital inputs but that doesn't do anything either.
Link for the problem: https://youtube.com/shorts/ekwEwoERshc
Am I missing something? Do I need to set up anything else?
Thanks!
  Wiegand and GPIO on T16M
Posted by: robarends - 01-03-2026, 12:02 PM - Forum: T16M - Replies (3)
I have a T16M (ESPHome), and I need to connect 4 Wiegand keypads (8 GPIO required).  There are 7 GPIO, and 2 RS485 available.
Are the RS485 connections just a UART, and can be used for a Wiegand D0/D1 ?
I have noticed in your videos on Wiegand that you use the UART rx/tx connections on the example boards.
Is that because they are 5v logic, and are required to connect the 5V D0/D1 from the Wiegand keypad?
I assume the ESP32 will be damaged if I connect the D0/D1 to the GPIO connections of an ESP32 based board like the T16M?
Thank you.
Rob
  KC868-COLB Network Connection
Posted by: danielyoud401@gmail.com - 01-03-2026, 01:20 AM - Forum: Development - Replies (5)
My KC868-COLB is no longer visible on my network,
The UDP Blue LED and Server Yellow LED are flashing on and off together for approx 2 sec on, 2 sec off.
I have tried pressing and holding the Ethernet M button as described in the user guide but the LED's are not lighting up to switch modes. Nothing happens when i hold this button in.
Is there a way to do a reset on this board?
  "SmartLife" wifi transmit
Posted by: hinterland - 01-02-2026, 07:03 PM - Forum: TA - Replies (7)
My tiny alarm seems to be transmitting a wifi signal (AP?)  "SmartLife-C886" how do i disable that?
  Server 16 issues
Posted by: podlak - 12-31-2025, 11:15 AM - Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module - Replies (1)
I started working over new home automation project and I bought Server 16 with raspberry pi & nodered. Board is working fine with rs485 sensors, but I'm planning to use relays to control electric circuits and I have two major difficulties :
1) by default I want to have circuits off (NC), I changed settings of all relays in nodered to invert switches, but when board starts it triggers all relays for a moment ON and after moment all goes to OFF. It means that all connected electric equipment will start for a less a second - this is very unwanted behaviour, how to avoid that?
2) I'm planning to use digital inputs to control relays with momentary buttons, but input seams to be connected with relays and input has to be shorted with GND all the time, how to change that, so relay will be toggled wen button is pushed for a moment?  I don't want to use bistable buttons, as relay will be connected with nodered and homeassistant in parallel and wall buttons will have different state than circuit
Beet regards
Podlak
  KCS_N60_N30_N20_N10_V3.18.2 firmware
Posted by: admin - 12-31-2025, 06:45 AM - Forum: N60 - No Replies
1. fixed bug: update energy data to home assistant by MQTT.
.zip   KCS_N10_V3.18.2_beta_20251230-144041.zip (Size: 972.53 KB / Downloads: 453)
.zip   KCS_N20_V3.18.2_beta_20251230-144035.zip (Size: 972.65 KB / Downloads: 382)
.zip   KCS_N30_V3.18.2_beta_20251230-144045.zip (Size: 972.64 KB / Downloads: 441)
.zip   KCS_N60_V3.18.2_beta_20251230-144036.zip (Size: 987.97 KB / Downloads: 470)
  N60 N30 N20 N10 ARM CPU firmware V20_251231
Posted by: admin - 12-31-2025, 06:20 AM - Forum: N60 - Replies (6)
1. fixed bug for energy data and power factor.
you can download by bootloader.exe tool by RS485.
ARM BIN file download:
.zip   N10203060_KU_V20_251231.zip (Size: 13.11 KB / Downloads: 457)
bootloader.exe tool:
.zip   KC868 Controller Bootloader.zip (Size: 8.56 KB / Downloads: 727)
1. set baud rate=38400bps.
2. open com port.
3. power on Nx board, during LED fast blink when the "bootloader Detect" button right now. Then board will go to bootloader mode.
4. open BIN file
5. press "Download" button, begin download firmware, after finished, press "Run" button, ARM CPU begin work.
