» Members: 5,374
» Latest member: zeth
» Forum threads: 2,574
» Forum posts: 13,315
There are currently 53 online users.
» 2 Member(s) | 35 Guest(s)
AhrefsBot, Bytespider, Crawl, Google, PetalBot, Yandex, bot, owler, biofects, jenniferpollak
KC868-A2 configure yaml f...
Forum: KC868-A2
Last Post: elemarek
9 hours ago
» Replies: 15
How can I power multiple ...
10 hours ago
» Replies: 12
how to use AS ESP32-S3 vo...
Forum: KinCony AS
Last Post: biofects
Today, 03:07 AM
» Replies: 13
change wake up name
Forum: KinCony AS
Today, 02:10 AM
» Replies: 13
Problem with IFTTT automa...
Forum: "KCS" firmware system
Yesterday, 11:41 PM
A32 Pro ESPHome yaml incl...
Forum: KC868-A32/A32 Pro
Yesterday, 11:15 PM
» Replies: 18
KC868-A2 ESP32 I/O pin de...
Forum: KC868-A2
Yesterday, 11:12 PM
» Replies: 8
Need help with configurat...
Yesterday, 04:32 AM
» Replies: 32
ESP32 S3 set up issue
Forum: Extender module
12-17-2024, 11:43 PM
» Replies: 10
KC868-A8 Schematic
Forum: KC868-A8
12-17-2024, 11:40 PM
» Replies: 7
  COL + rs485 meter
Posted by: athxp - 05-02-2024, 08:51 PM - Forum: KC868-HxB series Smart Controller - Replies (3)
HI,
I have a Kincony RS-484 meter. I would like to use it to monitor a photovoltaic system and carry out automations with COL.
we are talking about around 6000-6500w of power and currents around 30A. will the meter have problems?
Furthermore, can I program COL using the simple IFTTT rules linked to the meter measurements?
 thanks
  KC868-A4S Analog Inputs
Posted by: DabblerIOT - 05-02-2024, 07:36 PM - Forum: Development - Replies (2)
Hi.   Sorting out analog inputs using esp32home. Thank you for any response, board working well.
Using this right now..
- platform: adc
    pin: 36
    update_interval: 5s
    attenuation: 11db
    filters:
      - lambda: if (x <= 0.15) { return 0; } return x * 1.51;
Several questions:
(1) I saw some example code posted to this forum where about x of 3.1 it used a higher multiplier. Why? This code is going to cause a large increase in output value at 3.111 x. Would a better approach be to read ground and vcc to the esp, and then scale your input readings according to those two readings using those values as 0 and 100% of input span? (0-3.3 after the voltage divider, or 0-5v at the input terminal).
(2) If I want to read a 10k ntc thermistor, it looks like a voltage divider, of 5.1k/10k is already there on the input... so if I power a 10k ntc thermistor with 3.3 volts, wouldn't I be essentially just adding the resistance value of my thermistor onto the 5.1k on-board resistor? (Allowing me to subtract 5.1k from the read value, and then normalizing my reading using the on-board code). My voltage isn't what I expect if this were true. (I am not an expert on the electronics side). Just enough to be dangerous.
Code was here.
https://www.kincony.com/forum/showthread...hlight=adc
- platform: adc
pin: 36
name: "A8S A1 Voltage"
update_interval: 5s
attenuation: 11db
filters:
- lambda:
if (x >= 3.11) {
return x * 1.60256;
} else if (x <= 0.15) {
return 0;
return x * 1.51;
  KC868 A4 for education
Posted by: Sidboudk - 05-01-2024, 06:33 PM - Forum: Apply for free sample product - No Replies
I'm requesting a KC868-A4 equipment for educational purpos. I'm associated professor at Evry-paris saclay university and we want to teach our students microcontroller programming and basic concepts of electricity and electronics.
  E16T IFTTT Limit and Logs
Posted by: ByteCrusader22 - 04-30-2024, 05:08 AM - Forum: "KCS" firmware system - Replies (1)
I'm currently running E16T using E16S KCS Firmware and linked to Tuya APP
1. Is there a limit to how many IFTTT automations can be run on E16T using KCS firmware without running into memory issues and causing instability?
2. Can IFTTT and Tuya automations be run at the same time? If so which will override the other if there are clashes.
3. ⁠Is it possible to check the memory utilisation using the KCS firmware?
4. ⁠Can the device post logs to external databases using IFTTT?
  Wiring diagram KC868-A16
Posted by: Brouk - 04-29-2024, 08:33 PM - Forum: KC868-A16 - Replies (3)
Hello to everybody,
I am planning to buy the module "KC868-A16" to connect with Home Assistant with NodeRed. For proper connection, I need a wiring harness (di. inputs, di. outputs, DS18B20 temperature sensors, etc. Can you please provide me with a wiring diagram?
  KC868-A2 and SIM7600G-H
Posted by: jpinto97 - 04-28-2024, 10:52 PM - Forum: KC868-A2 - Replies (1)
Hello, what are the pins to connect a sim7600g-h module to the KC868-A2-V2.4 board?
  Digital Inputs with 2.2K ohm resistor
Posted by: bruces - 04-28-2024, 04:32 PM - Forum: KC868-AI - Replies (3)
So I need to know if i were to connect a DI to ground through a 2200 ohm resistor would the input trip.
I am trying to replace an old security system and all of the inputs have two states, open circuit or 2200 ohm in the line.
I would just remove the 2200 ohm resistor but most of them are not accessible.
  Smoke Sensor Connected to KC868-AI
Posted by: fdcemb5 - 04-28-2024, 11:19 AM - Forum: KC868-A series and Uair Smart Controller - Replies (1)
I connect the Smoke sensor to the KC868-AI, to input 3, the smoke sensor is constantly turn the input On. The sensor's 2 LED are constantly constantly green. I introduced smoke flame to the sensor but the green light still remains green and the input is turned on. This behavior is wired. Any help what is happening.
The Sensor is connected to pin 1+ve and pin 2 -ve, pin 3 to KCOM, and pin 4 to AI input pin 3.
  [Arduino source code for KC868-ASR]-03 Relay auto ON/OFF by date time
Posted by: admin - 04-28-2024, 05:21 AM - Forum: KC868-ASR - No Replies
This is an arduino sample code for KC868-ASR , auto control relay ON/OFF by date and time. for example ,the demo is every year 4-26 (April 26th) relay will ON, every year 5-2 (May 2nd) relay will OFF. it support command by serial port (USB cable) to send date/time and read date/time.
#include <DS3231.h>
#include <Wire.h>
String serial_cmd_rcv = ""; //serial port receiver
typedef struct
  byte year;// Last two digits of the year, lib will add 2000.
  byte month;
  byte day;
  byte hour ;
  byte minute ;
  byte second ;
}MY_DATE_STR;
#define OPEN_RLY_DATA   26
#define OPEN_RLY_MONTH  4
#define CLOSE_RLY_DATA   2
#define CLOSE_RLY_MONTH   5
#define SDA_PIN   26
#define SCL_PIN   27
#define RLY1_PIN  19
#define RLY2_PIN  5
DS3231  rtc;
bool h12Flag;
bool pmFlag;
static bool bCentury = false;
static bool CompareOpenDate()
  return (rtc.getDate()==OPEN_RLY_DATA)&(rtc.getMonth(bCentury)==OPEN_RLY_MONTH);
static bool CompareCloseDate()
  return (rtc.getDate()==CLOSE_RLY_DATA)&(rtc.getMonth(bCentury)==CLOSE_RLY_MONTH);
static void PrintfCurTime()
  Serial.print("current time is: ");
  Serial.print(year);
  Serial.print("-");
  Serial.print("-");
  // then the date
  Serial.print(" ");
  // and the day of the week
  //Serial.print(rtc.getDoW(), DEC);
  //Serial.print(" ");
  // Finally the hour, minute, and second
  Serial.print(":");
  Serial.print(":");
static void GetSerialCmd()
{ ////format:D2024-04-28T11:50:22
  /*while (Serial.available() > 0)
    delay(5);
  if(Serial.available() > 0)
    delay(100);
    while(num_read--)
  else return;
  serial_cmd_rcv.trim();
  if(serial_cmd_rcv == "current time")
    PrintfCurTime();
    return;
  Serial.print("rcv length:");
  Serial.print("d index:");Serial.print(indexof_d);
  Serial.print(" t index:");Serial.println(indexof_t);
      serial_cmd_rcv.substring(0,1) != "D" ||
      serial_cmd_rcv.substring(11,12) != "T")
    serial_cmd_rcv="";
    return;
  Serial.println("setting is start!");
  my_date_str.year = (byte)serial_cmd_rcv.substring(3,5).toInt();
  my_date_str.month = (byte)serial_cmd_rcv.substring(6,8).toInt();
  my_date_str.day = (byte)serial_cmd_rcv.substring(9,11).toInt();
  my_date_str.hour = (byte)serial_cmd_rcv.substring(12,14).toInt();
  my_date_str.minute = (byte)serial_cmd_rcv.substring(15,17).toInt();
  rtc.setDate(my_date_str.day);
  Serial.println("setting is ending!");
static bool GetEdgeP(bool cur,bool old)  {return (cur & !old);}
static bool bOpen,bClose;
  // Start the I2C interface
  Wire.begin(SDA_PIN,SCL_PIN,40000);
  // Setup Serial connection
  pinMode(RLY1_PIN,OUTPUT);
  pinMode(RLY2_PIN,OUTPUT);
  // Set 12/24h mode. True is 12-h, false is 24-hour.
  rtc.setClockMode(false);////24h
  PrintfCurTime();
  while(Serial.read()>=0){}
  GetSerialCmd();
  bOpen = CompareOpenDate();
  bClose = CompareCloseDate();
  if(GetEdgeP(bOpen,old_level_high)) digitalWrite(RLY1_PIN,HIGH);
  if(GetEdgeP(bClose,old_level_low)) digitalWrite(RLY1_PIN,LOW);
  old_level_high = bOpen;
  old_level_low = bClose;
  //delay (1000);
source code download ZIP file:
.zip   DS3231TST-20240428.zip (Size: 1.53 KB / Downloads: 78)
before use code need install DS3231 arduino library firstly.
download firmware by arduino IDE:
serial port by USB 115200bps
set date and time command example: D2024-04-28T11:50:22
print current date and time: current time
because it's not easy to battery by air plane, so if you want timer work when power off, you can install the CR1220 on KC868-ASR PCB bottom side.
  AK not connecting to controller
Posted by: mutaz - 04-28-2024, 03:23 AM - Forum: KC868-AK - Replies (19)
Hi
My AK board is not connecting to controller. Only one light red showing. It was working before but suddenly stop.
I tried to use a different AK to the same controller but also didn't work.
What should I do?
