» Members: 10,108
» Latest member: vf555ttattoo
» Forum threads: 4,257
» Forum posts: 21,085
There are currently 175 online users.
» 0 Member(s) | 157 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, PetalBot, bot
Update to latest esphome
Last Post: Elgatoguiri
6 hours ago
m16v2 energy meter - cali...
Yesterday, 11:50 AM
» Replies: 15
oCBot: KC868-A6/A16 as a ...
Last Post: oCBot
10-01-2026, 01:32 PM
N20 Energy RS485 Modbus P...
Forum: N20
10-01-2026, 12:43 PM
Getting inconsistent/wron...
10-01-2026, 12:40 PM
KC868-HAv2 phantom press ...
Forum: KC868-HA /HA v2
Last Post: phrfpeixoto
09-29-2026, 01:57 AM
KC868-A6 Analog inputs
Last Post: Tomas4289
09-28-2026, 12:57 PM
N60/N30/N20/N10 PC softwa...
Forum: N10
09-28-2026, 12:49 PM
» Replies: 13
getting the A8A inputs to...
Forum: Development
09-28-2026, 08:38 AM
Best way to read from N30
Forum: N30
09-27-2026, 12:20 AM
  [arduino code examples for B8M]-03 Read ADS1115 analog input ports value
Posted by: admin - 06-21-2025, 03:52 AM - Forum: B8M - No Replies
#define SDA_PIN 8
#define SCL_PIN 18
DFRobot_ADS1115 ads(&Wire);
void setup(void)
    Wire.begin(SDA_PIN, SCL_PIN);
    ads.setGain(eGAIN_TWOTHIRDS);
    ads.setMode(eMODE_SINGLE);
    ads.setRate(eRATE_128);
    ads.init();
void loop(void)
    if (ads.checkADS1115())
        adc0 = ads.readVoltage(0);
        Serial.print("A0:");
        Serial.print(adc0);
        adc1 = ads.readVoltage(1);
        Serial.print("A1:");
        Serial.print(adc1);
        adc2 = ads.readVoltage(2);
        Serial.print("A2:");
        Serial.print(adc2);
        adc3 = ads.readVoltage(3);
        Serial.print("A3:");
        Serial.print(adc3);
    else
arduino ino file download:
.zip   3-ads1115_adc.zip (Size: 1.2 KB / Downloads: 617)
.zip   3-ads1115_adc.ino.merged.zip (Size: 190.05 KB / Downloads: 602)
  [arduino code examples for B8M]-02 Read digital input ports state
Posted by: admin - 06-21-2025, 03:51 AM - Forum: B8M - No Replies
* Description:
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* - PCF8575 I2C Address: 0x22
#include "Arduino.h"
#include "PCF8575.h"
// Define I2C pins
// Set I2C address
    Serial.println("KinCony B8M 8 channel input state 0:ON  1:OFF");
    uint16_t state = 0;
    for (int pin = 8; pin < 16; pin++) {
        if (pcf8575_IN1.read(pin)) {
    delay(500); // Delay 500ms
.zip   2-digital-input.zip (Size: 839 bytes / Downloads: 633)
.zip   2-digital-input.ino.merged.zip (Size: 189.5 KB / Downloads: 639)
  [arduino code examples for B8M]-01 Turn ON/OFF OUTPUT
Posted by: admin - 06-21-2025, 03:49 AM - Forum: B8M - No Replies
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* Delay Time:
#define SDA 8           // Define the SDA pin
#define SCL 18          // Define the SCL pin
#define I2C_ADDRESS 0x22 // I2C address of the PCF8575 module
  pcf8575_R1.begin();
  for (int i = 0; i < 8; i++) {
.zip   1-output.zip (Size: 925 bytes / Downloads: 634)
.zip   1-output.ino.merged.zip (Size: 189.23 KB / Downloads: 603)
  B8M ESPHome yaml for home assistant with tuya
Posted by: admin - 06-21-2025, 03:47 AM - Forum: B8M - No Replies
  friendly_name: b8m
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
  board: esp32-s3-devkitc-1
external_components:
  - source:
      type: git
      ref: v1.1.0
# logger:
#   hardware_uart: USB_SERIAL_JTAG
  encryption:
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  interrupt_pin: GPIO43
  reset_pin: GPIO44
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
  - id: 'pcf8574_hub_out_1'  # for output channel 0-7| input channel 8-15
    i2c_id: bus_a
    pcf8575: true
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 39
    rx_pin: 38
  - id: tuya_mcu_uart
    tx_pin: GPIO16
    rx_pin: GPIO17
    baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: mje1l6yi62hlljcn
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
  - platform: uart
    uart_id: uart_1
      pcf8574: pcf8574_hub_out_1
  - platform: tuya_wifi_mcu
    dp_id: 1
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "b8m_output01"
    dp_id: 2
    internal: true
    bind_switch_id: "b8m_output02"
    dp_id: 3
    internal: true
    bind_switch_id: "b8m_output03"
    dp_id: 4
    internal: true
    bind_switch_id: "b8m_output04"
    dp_id: 5
    internal: true
    bind_switch_id: "b8m_output05"
    dp_id: 6
    internal: true
    bind_switch_id: "b8m_output06"
    dp_id: 101
    internal: true
    bind_switch_id: "b8m_output07"
    dp_id: 102
    internal: true
    bind_switch_id: "b8m_output08"
      number: 8
    dp_id: 111
    bind_binary_sensor_id: b8m_input01
    internal: true
      number: 9
    dp_id: 112
    bind_binary_sensor_id: b8m_input02
    internal: true
      number: 10
    dp_id: 113
    bind_binary_sensor_id: b8m_input03
    internal: true
      number: 11
    dp_id: 114
    bind_binary_sensor_id: b8m_input04
    internal: true
      number: 12
    dp_id: 115
    bind_binary_sensor_id: b8m_input05
    internal: true
      number: 13
    dp_id: 116
    bind_binary_sensor_id: b8m_input06
    internal: true
      number: 14
    dp_id: 117
    bind_binary_sensor_id: b8m_input07
    internal: true
      number: 15
    dp_id: 118
    bind_binary_sensor_id: b8m_input08
    internal: true
##pull-up resistance on PCB
      number: 47
      number: 48
      number: 40
## without resistance on PCB
      number: 13
      inverted:  false
      number: 14
      inverted:  false
      number: 21
      inverted:  false
      inverted:  false
ads1115:
  - address: 0x48
  - platform: ads1115
    multiplexer: 'A0_GND'
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A1_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A2_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A3_GND'
    gain: 6.144
    update_interval: 5s
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "KinCony B8M");
download yaml file:
.txt   B8M-HA.txt (Size: 8.42 KB / Downloads: 481)
  B8M ESP32-S3 IO pins define
Posted by: admin - 06-21-2025, 03:46 AM - Forum: B8M - No Replies
IIC Bus:
SDA:GPIO8
SCL:GPIO18
PCF8575: i2c address:0x22
PCF8575->P0 (relay1)
PCF8575->P1 (relay2)
PCF8575->P2 (relay3)
PCF8575->P3 (relay4)
PCF8575->P4 (relay5)
PCF8575->P5 (relay6)
PCF8575->P6 (relay7)
PCF8575->P7 (relay8)
PCF8575->P8 (DI1)
PCF8575->P9 (DI2)
PCF8575->P10 (DI3)
PCF8575->P11 (DI4)
PCF8575->P12 (DI5)
PCF8575->P13 (DI6)
PCF8575->P14 (DI7)
PCF8575->P15 (DI8)
24C02 EPROM i2c address: 0x50
DS3231 RTC i2c address: 0x68
Analog input (A1: DC 0-5v)
Analog input (A2: DC 0-5v)
Analog input (A3: DC 4-20mA)
Analog input (A4: DC 4-20mA)
1-wire GPIOs (with pull-up resistance on PCB):
1-wire-1:GPIO47
1-wire-2:GPIO48
1-wire-3:GPIO7
1-wire-4:GPIO40
GPIO13
GPIO14
GPIO21
Ethernet (W5500) I/O define:
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
reset_pin: GPIO44
RS485:
RXD:GPIO38
TXD:GPIO39
Tuya module:
RXD:GPIO17
TXD:GPIO16
SD Card:
SPI-MOSI:GPIO10
SPI-SCK:GPIO11
SPI-MISO:GPIO12
SPI-CS:GPIO9
SPI-CD:GPIO5
  IFTTT
Posted by: jeftevag - 06-20-2025, 02:19 PM - Forum: "KCS" v2 firmware system - Replies (4)
Delay function in IFTTT for 4 hours (14400 seconds) do not work. 3600 seconds work fine.
DI1 SINGLE CLICK,  DO OUTPUT 1 ON,  DELAY 14400 SECONDS,  DO OUTPUT 1 OFF
So, how do i get 4 hours delay?
  KC868-A8 TCP -Server
Posted by: Dm81 - 06-19-2025, 04:03 PM - Forum: KC868-A series and Uair Smart Controller - Replies (25)
Hello
I configured a KC868-A8 as a TCP Server and I am having the following problem
if I send the command to turn ON and OFF a relay for 8 or 9 times (some times only 3 or 4 times) it works but after that the server does not respond anymore
firmware is v2.2.13
power supply is original
I also tried to check the communication with wireshark and when the communication stops wireshark shows as in the attached figure
kc868-A8 ip is 192.168.1.64
suggestions?
thank you in advance
  Troubles using I2C/IIC bus
Posted by: ksarz - 06-19-2025, 10:18 AM - Forum: KC868-A6 - Replies (23)
I am having troubles using I2C interface on KC868-A6-V1. Programming using Arduino IDE 2.3.6
So I tried running programmes for digital inputs, relays and the built-in "Wire Scan" example with a sensor connected and none of them work. Here are the error texts:
Wire Scan:
"EScanning for I2C devices ...
E (522034) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up
Error 5 at address 0x01
E (522094) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up
Error 5 at address 0x02
(all the other adresses)
(529474) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up
Error 5 at address 0x7D
E (529534) i2c.master: probe device timeout. Please check if xfer_timeout_ms and pull-ups are correctly set up
Error 5 at address 0x7E
No I2C devices found"
Relays:
"E(76561) i2c.master: I2C hardware NACK detected
E (76561) i2c.master: I2C transaction unexpected nack detected
E (76561) i2c.master: s_i2c_synchronous_transaction(924): I2C transaction failed
E (76567) i2c.master: i2c_master_multi_buffer_transmit(1186): I2C transaction failed"
Digital inputs:
"E (9060) i2c.master: I2C hardware NACK detected
E (9060) i2c.master: I2C transaction unexpected nack detected
E (9060) i2c.master: s_i2c_synchronous_transaction(924): I2C transaction failed
E (9066) i2c.master: i2c_master_receive(1240): I2C transaction failed
KEY1 PRESSED
KEY2 PRESSED
KEY3 PRESSED
KEY4 PRESSED
KEY5 PRESSED
KEY6 PRESSED
KEY7 PRESSED
KEY8 PRESSED"
  server16-tuya control
Posted by: Saif Kitany - 06-19-2025, 02:01 AM - Forum: News - Replies (17)
Hello suppoert team,
i have kincony server 16, and i did all the steps configurations to control it by tuya app,
but when i scan the QR code by the app, it show that the device is offline.
- I added Kincony Tuya Mqtt component to home assistant by HACS
- I copied and pasted the yaml file
- I chaned device Id as the same as i got from kincony
- I chaned device secret as the same as i got from kincony
- I changed the Region
what could i have missed?
  868-a16 or a32 Poe question
Posted by: wchpikus - 06-18-2025, 08:43 PM - Forum: KC868-A series and Uair Smart Controller - Replies (3)
Could I connect this board to passie Poe switch?
Some devices has terminator resistors and do not like Poe power..
Second question is, lan is connector with Poe (not used) or not?
I like to add Poe power adaptor.
