» Members: 10,004
» Latest member: vedikexchange
» Forum threads: 4,251
» Forum posts: 21,048
There are currently 278 online users.
» 0 Member(s) | 255 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, PetalBot, Semrush, bot
A32 pro tuya
Last Post: Saif Kitany
50 minutes ago
Las Firmware ?
Last Post: oxedgar
1 hour ago
Disconnect loop with Home...
Forum: F16
Today, 01:16 AM
KC-868-A1 linked Home Ass...
Forum: News
Today, 01:16 AM
config modbus sensor in K...
09-19-2026, 11:52 AM
remember relay state
Forum: KC868-E16T
09-19-2026, 01:42 AM
getting the A8A inputs to...
Forum: Development
09-19-2026, 01:41 AM
Ceiling fan control not w...
09-18-2026, 07:15 AM
» Replies: 11
Output pin protection
Forum: T16M
09-17-2026, 11:44 PM
Modbus 485 extender kcs V...
Forum: N30
09-17-2026, 08:10 AM
» Replies: 11
  [arduino code examples for B8M]-07 how to DS3231 RTC clock
Posted by: admin - 06-21-2025, 03:58 AM - Forum: B8M - No Replies
* DS3231 RTC with Arduino
* Hardware Connections:
* - SDA: GPIO 8
* - SCL: GPIO 18
#include <DS3231.h>
#include <Wire.h>
typedef struct
  byte month;
  byte day;
  byte hour;
  byte minute;
  byte second;
} MY_DATE_STR;
#define OPEN_RLY_DATA    26
#define OPEN_RLY_MONTH   4
#define CLOSE_RLY_DATA   2
#define CLOSE_RLY_MONTH  5
// Define pin connections
#define SDA_PIN   8
#define SCL_PIN   18
bool h12Flag;
bool pmFlag;
static bool bCentury = false;
static void PrintfCurTime()
  Serial.print(year);
  Serial.print("-");
  Serial.print("-");
  Serial.print(" ");
  Serial.print(":");
  Serial.print(":");
static void GetSerialCmd()
  if (Serial.available() > 0)
    delay(100);
    while (num_read--)
  else return;
  serial_cmd_rcv.trim();
    PrintfCurTime();
    return;
  Serial.print("D index: ");
  Serial.print(indexof_d);
  Serial.print(" T index: ");
  Serial.println(indexof_t);
    return;
  rtc.setDate(my_date_str.day);
  Serial.println("Time set.");
  PrintfCurTime();
  while (Serial.read() >= 0) {}
  GetSerialCmd();
arduino ino file download:
.zip   7-DS3231-RTC.zip (Size: 1.56 KB / Downloads: 635)
.zip   7-DS3231-RTC.ino.merged.zip (Size: 191.08 KB / Downloads: 662)
  [arduino code examples for B8M]-06 How to use SD Card
Posted by: admin - 06-21-2025, 03:56 AM - Forum: B8M - No Replies
* SD Card File Operations
* - SCK: GPIO 11
* - MISO: GPIO 12
* - MOSI: GPIO 10
* - CS: GPIO 9
#include "FS.h"
#include "SD.h"
#include "SPI.h"
#define SCK  11
#define MISO 12
#define MOSI 10
#define CS   9
  File file = fs.open(path);
  if (!file) {
    return;
  while (file.available()) {
  file.close();
  if (!file) {
    return;
  if (file.print(message)) {
  file.close();
  if (!file) {
    return;
  file.close();
  if (fs.remove(path)) {
  static uint8_t buf[512];
  size_t len = 0;
  uint32_t start = millis();
  uint32_t end = start;
  if (file) {
    len = file.size();
    size_t flen = len;
    start = millis();
    while (len) {
      size_t toRead = len;
      if (toRead > 512) {
        toRead = 512;
      file.read(buf, toRead);
      len -= toRead;
    end = millis() - start;
    file.close();
  if (!file) {
    return;
  size_t i;
  start = millis();
  for (i = 0; i < 2048; i++) {
    file.write(buf, 512);
  file.close();
  // Initialize SPI and SD card
    return;
  if (cardType == CARD_NONE) {
    return;
  if (cardType == CARD_MMC) {
    Serial.println("MMC");
    Serial.println("SDSC");
    Serial.println("SDHC");
    Serial.println("UNKNOWN");
  delay(2000);
  // Perform file operations
  deleteFile(SD, "/hello.txt");
  readFile(SD, "/hello.txt");
  testFileIO(SD, "/test.txt");
  // No operation in loop
.zip   6-SD.zip (Size: 1.53 KB / Downloads: 627)
.zip   6-SD.ino.merged.zip (Size: 221.25 KB / Downloads: 627)
  [arduino code examples for B8M]-05 Read free GPIO state
Posted by: admin - 06-21-2025, 03:55 AM - Forum: B8M - No Replies
* ESP32 GPIO State Reader
* Reads the state of GPIO47, GPIO48, GPIO7, GPIO40, GPIO0, and GPIO5
* and prints the results to the serial monitor.
#define GPIO_13  13
#define GPIO_40  40
#define GPIO_14  14
#define GPIO_48  48
#define GPIO_0   0
#define GPIO_47  47
#define GPIO_7  7
#define GPIO_21  21
    // Set GPIOs as input
    pinMode(GPIO_13, INPUT);
    pinMode(GPIO_40, INPUT);
    pinMode(GPIO_14, INPUT);
    pinMode(GPIO_48, INPUT);
    pinMode(GPIO_0, INPUT);
    pinMode(GPIO_47, INPUT);
    pinMode(GPIO_7, INPUT);
    pinMode(GPIO_21, INPUT);
    // Read GPIO states
    int state_13 = digitalRead(GPIO_13);
    int state_40 = digitalRead(GPIO_40);
    int state_14  = digitalRead(GPIO_14);
    int state_48 = digitalRead(GPIO_48);
    int state_0  = digitalRead(GPIO_0);
    int state_47 = digitalRead(GPIO_47);
    int state_7 = digitalRead(GPIO_7);
    int state_21 = digitalRead(GPIO_21);
    // Print GPIO states to the serial monitor
    Serial.printf("GPIO13: %d, GPIO40: %d, GPIO14: %d, GPIO48: %d, GPIO0: %d, GPIO47: %d, GPIO7: %d, GPIO21: %d\n",
                  state_13, state_40, state_14, state_48, state_0, state_47, state_7, state_21);
    delay(1000); // Read GPIO states every second
.zip   5-free-gpio-state.zip (Size: 682 bytes / Downloads: 671)
.zip   5-free-gpio-state.ino.merged.zip (Size: 179.41 KB / Downloads: 633)
  [arduino code examples for B8M]-04 RS485 communication test
Posted by: admin - 06-21-2025, 03:54 AM - Forum: B8M - No Replies
* RS485 Communication Test
#include <HardwareSerial.h>
// Define RS485 pins
#define RS485_RXD 38
#define RS485_TXD 39
  while (!Serial);
  // Send a test message
  rs485Serial.println("Hello from KinCony B8M!");
  // Wait for a short period
    String receivedMessage = "";
      char c = rs485Serial.read();
      receivedMessage += c;
    // Print the received message
    Serial.print("Received: ");
  delay(2000);
.zip   4-RS485-Test.zip (Size: 763 bytes / Downloads: 615)
.zip   4-RS485-Test.ino.merged.zip (Size: 184.35 KB / Downloads: 652)
  [arduino code examples for B8M]-03 Read ADS1115 analog input ports value
Posted by: admin - 06-21-2025, 03:52 AM - Forum: B8M - No Replies
#define SDA_PIN 8
#define SCL_PIN 18
DFRobot_ADS1115 ads(&Wire);
void setup(void)
    Wire.begin(SDA_PIN, SCL_PIN);
    ads.setGain(eGAIN_TWOTHIRDS);
    ads.setMode(eMODE_SINGLE);
    ads.setRate(eRATE_128);
    ads.init();
void loop(void)
    if (ads.checkADS1115())
        adc0 = ads.readVoltage(0);
        Serial.print("A0:");
        Serial.print(adc0);
        adc1 = ads.readVoltage(1);
        Serial.print("A1:");
        Serial.print(adc1);
        adc2 = ads.readVoltage(2);
        Serial.print("A2:");
        Serial.print(adc2);
        adc3 = ads.readVoltage(3);
        Serial.print("A3:");
        Serial.print(adc3);
    else
.zip   3-ads1115_adc.zip (Size: 1.2 KB / Downloads: 606)
.zip   3-ads1115_adc.ino.merged.zip (Size: 190.05 KB / Downloads: 593)
  [arduino code examples for B8M]-02 Read digital input ports state
Posted by: admin - 06-21-2025, 03:51 AM - Forum: B8M - No Replies
* Description:
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* - PCF8575 I2C Address: 0x22
#include "Arduino.h"
#include "PCF8575.h"
// Define I2C pins
// Set I2C address
    Serial.println("KinCony B8M 8 channel input state 0:ON  1:OFF");
    uint16_t state = 0;
    for (int pin = 8; pin < 16; pin++) {
        if (pcf8575_IN1.read(pin)) {
    delay(500); // Delay 500ms
.zip   2-digital-input.zip (Size: 839 bytes / Downloads: 623)
.zip   2-digital-input.ino.merged.zip (Size: 189.5 KB / Downloads: 630)
  [arduino code examples for B8M]-01 Turn ON/OFF OUTPUT
Posted by: admin - 06-21-2025, 03:49 AM - Forum: B8M - No Replies
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* Delay Time:
#define SDA 8           // Define the SDA pin
#define SCL 18          // Define the SCL pin
#define I2C_ADDRESS 0x22 // I2C address of the PCF8575 module
  pcf8575_R1.begin();
  for (int i = 0; i < 8; i++) {
.zip   1-output.zip (Size: 925 bytes / Downloads: 626)
.zip   1-output.ino.merged.zip (Size: 189.23 KB / Downloads: 595)
  B8M ESPHome yaml for home assistant with tuya
Posted by: admin - 06-21-2025, 03:47 AM - Forum: B8M - No Replies
  friendly_name: b8m
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
  board: esp32-s3-devkitc-1
external_components:
  - source:
      type: git
      ref: v1.1.0
# logger:
#   hardware_uart: USB_SERIAL_JTAG
  encryption:
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  interrupt_pin: GPIO43
  reset_pin: GPIO44
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
  - id: 'pcf8574_hub_out_1'  # for output channel 0-7| input channel 8-15
    i2c_id: bus_a
    pcf8575: true
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 39
    rx_pin: 38
  - id: tuya_mcu_uart
    tx_pin: GPIO16
    rx_pin: GPIO17
    baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: mje1l6yi62hlljcn
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
  - platform: uart
    uart_id: uart_1
      pcf8574: pcf8574_hub_out_1
  - platform: tuya_wifi_mcu
    dp_id: 1
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "b8m_output01"
    dp_id: 2
    internal: true
    bind_switch_id: "b8m_output02"
    dp_id: 3
    internal: true
    bind_switch_id: "b8m_output03"
    dp_id: 4
    internal: true
    bind_switch_id: "b8m_output04"
    dp_id: 5
    internal: true
    bind_switch_id: "b8m_output05"
    dp_id: 6
    internal: true
    bind_switch_id: "b8m_output06"
    dp_id: 101
    internal: true
    bind_switch_id: "b8m_output07"
    dp_id: 102
    internal: true
    bind_switch_id: "b8m_output08"
      number: 8
    dp_id: 111
    bind_binary_sensor_id: b8m_input01
    internal: true
      number: 9
    dp_id: 112
    bind_binary_sensor_id: b8m_input02
    internal: true
      number: 10
    dp_id: 113
    bind_binary_sensor_id: b8m_input03
    internal: true
      number: 11
    dp_id: 114
    bind_binary_sensor_id: b8m_input04
    internal: true
      number: 12
    dp_id: 115
    bind_binary_sensor_id: b8m_input05
    internal: true
      number: 13
    dp_id: 116
    bind_binary_sensor_id: b8m_input06
    internal: true
      number: 14
    dp_id: 117
    bind_binary_sensor_id: b8m_input07
    internal: true
      number: 15
    dp_id: 118
    bind_binary_sensor_id: b8m_input08
    internal: true
##pull-up resistance on PCB
      number: 47
      number: 48
      number: 40
## without resistance on PCB
      number: 13
      inverted:  false
      number: 14
      inverted:  false
      number: 21
      inverted:  false
      inverted:  false
ads1115:
  - address: 0x48
  - platform: ads1115
    multiplexer: 'A0_GND'
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A1_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A2_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A3_GND'
    gain: 6.144
    update_interval: 5s
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "KinCony B8M");
download yaml file:
.txt   B8M-HA.txt (Size: 8.42 KB / Downloads: 473)
  B8M ESP32-S3 IO pins define
Posted by: admin - 06-21-2025, 03:46 AM - Forum: B8M - No Replies
IIC Bus:
SDA:GPIO8
SCL:GPIO18
PCF8575: i2c address:0x22
PCF8575->P0 (relay1)
PCF8575->P1 (relay2)
PCF8575->P2 (relay3)
PCF8575->P3 (relay4)
PCF8575->P4 (relay5)
PCF8575->P5 (relay6)
PCF8575->P6 (relay7)
PCF8575->P7 (relay8)
PCF8575->P8 (DI1)
PCF8575->P9 (DI2)
PCF8575->P10 (DI3)
PCF8575->P11 (DI4)
PCF8575->P12 (DI5)
PCF8575->P13 (DI6)
PCF8575->P14 (DI7)
PCF8575->P15 (DI8)
24C02 EPROM i2c address: 0x50
DS3231 RTC i2c address: 0x68
Analog input (A1: DC 0-5v)
Analog input (A2: DC 0-5v)
Analog input (A3: DC 4-20mA)
Analog input (A4: DC 4-20mA)
1-wire GPIOs (with pull-up resistance on PCB):
1-wire-1:GPIO47
1-wire-2:GPIO48
1-wire-3:GPIO7
1-wire-4:GPIO40
GPIO13
GPIO14
GPIO21
Ethernet (W5500) I/O define:
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
reset_pin: GPIO44
RS485:
RXD:GPIO38
TXD:GPIO39
Tuya module:
RXD:GPIO17
TXD:GPIO16
SD Card:
SPI-MOSI:GPIO10
SPI-SCK:GPIO11
SPI-MISO:GPIO12
SPI-CS:GPIO9
SPI-CD:GPIO5
  IFTTT
Posted by: jeftevag - 06-20-2025, 02:19 PM - Forum: "KCS" v2 firmware system - Replies (4)
Delay function in IFTTT for 4 hours (14400 seconds) do not work. 3600 seconds work fine.
DI1 SINGLE CLICK,  DO OUTPUT 1 ON,  DELAY 14400 SECONDS,  DO OUTPUT 1 OFF
So, how do i get 4 hours delay?
