» Members: 10,019
» Latest member: 91Clubcoin
» Forum threads: 4,252
» Forum posts: 21,054
There are currently 159 online users.
» 0 Member(s) | 142 Guest(s)
Amazonbot, Baidu, Bing, Crawl, PetalBot, Semrush, Yandex, bot, owler
Las Firmware ?
Yesterday, 11:15 PM
» Replies: 8
kc868-a6 analog input
09-21-2026, 11:38 PM
A32 pro tuya
Disconnect loop with Home...
Forum: F16
09-21-2026, 01:16 AM
KC-868-A1 linked Home Ass...
Forum: News
config modbus sensor in K...
09-19-2026, 11:52 AM
remember relay state
Forum: KC868-E16T
09-19-2026, 01:42 AM
getting the A8A inputs to...
Forum: Development
09-19-2026, 01:41 AM
Ceiling fan control not w...
09-18-2026, 07:15 AM
» Replies: 11
Output pin protection
Forum: T16M
09-17-2026, 11:44 PM
  Home Assistant
Posted by: foxbru - 06-04-2025, 07:10 PM - Forum: KC868-A16 - Replies (1)
Hello
I have a Kc868 A16 and i use esphome on Home Assistant.
My EPS Home is online but with this yaml file isn't possible to have the control of input digital. ? i shunt the ground of input one ...  no reaction
Thank you for the help
  KC868-A16 with KCS firmware
Posted by: geko - 06-04-2025, 04:29 PM - Forum: KC868-A16 - Replies (3)
hello
I have KC868-A16 board (green pcb, not v3)
To this board I first upload KCS firmware - latest possible V2.2.13
Firmware loaded, first login - no problem
When I put one or all outputs no one light turn on
Why ?
(nothing connected to outputs)
  How to send temperature sensor data via custom protocol
Posted by: sebfromgermany - 06-04-2025, 06:08 AM - Forum: KC868-A16 - Replies (1)
Hello.
I am trying to send the current temperature of a sensor to an external server. In order to do that, I set up a custom HTTP POST protocol with an URL to a PHP webpage which processes the received data.
Unfortunately I am lacking of information of how to send values via HTTP POST. There is a good documententation about how to request data from the board, but I was not able to find information about sending data from the board to an external URL.
It would be great if you could help me.
Kind regards,
Seb
  KC868-A4 Free Sample request
Posted by: bccostin - 06-03-2025, 04:10 PM - Forum: Apply for free sample product - No Replies
I would like to request a KC868-A4 Free Sample to start a new project (B) for a smart home product for clean air.
Thank you.
  Temperature is not send to Loxone
Posted by: kotrmelec - 06-03-2025, 10:39 AM - Forum: T16M - Replies (3)
Hello, over the weekend, I got the T16M module up and running, and I was able to establish communication with my second-generation Loxone miniserver without any problems. Using UDP, I am able to read the on/off states of the DO, etc.
The only thing that isn't working, and I don't know if I'm doing something wrong, is reading the temperature status. I have a standard DS18B20 1-wire temperature sensor connected to the T16M board, I set the sensor in the board configuration and I can see the temperature(channel 1). Everything works without any problems. However, after setting the virtual input in Loxone, nothing happens. I monitored the UDP monitor in Loxone and no UDP command carrying temperature information reaches Loxone. Only commands for reading/controlling DI and DO. Is this a firmware error? Or does something else need to be set/enabled in the configuration for the temperature to be sent to Loxone?
Just to note, I am using the latest version of KCS3 firmware available right now.
Thank you in advance for your help.
  A8S/A8Sv2 home assistant yaml for KCS mqtt digital input and output
Posted by: admin - 06-03-2025, 05:49 AM - Forum: KC868-A8S - No Replies
   - name: 'a8s-kcs-output-1'
     unique_id: a8s-kcs-output-1
     state_topic: 'KC868_A8S/AC1518A88BE0/STATE'
     command_topic: 'KC868_A8S/AC1518A88BE0/SET'
     payload_off: '{"output1":{"value":false}}'
     state_on: true
     state_off: false
   - name: 'a8s-kcs-output-2'
     unique_id: a8s-kcs-output-2
     payload_on:  '{"output2":{"value":true}}'
     payload_off: '{"output2":{"value":false}}'
     state_on: true
     state_off: false
   - name: 'a8s-kcs-output-3'
     unique_id: a8s-kcs-output-3
     payload_on:  '{"output3":{"value":true}}'
     payload_off: '{"output3":{"value":false}}'
     value_template: '{{ value_json.output3.value }}'
     state_on: true
     state_off: false
   - name: 'a8s-kcs-output-4'
     unique_id: a8s-kcs-output-4
     payload_on:  '{"output4":{"value":true}}'
     payload_off: '{"output4":{"value":false}}'
     value_template: '{{ value_json.output4.value }}'
     state_on: true
     state_off: false
   - name: 'a8s-kcs-output-5'
     unique_id: a8s-kcs-output-5
     payload_on:  '{"output5":{"value":true}}'
     payload_off: '{"output5":{"value":false}}'
     value_template: '{{ value_json.output5.value }}'
     state_on: true
     state_off: false
   - name: 'a8s-kcs-output-6'
     unique_id: a8s-kcs-output-6
     payload_on:  '{"output6":{"value":true}}'
     payload_off: '{"output6":{"value":false}}'
     value_template: '{{ value_json.output6.value }}'
     state_on: true
     state_off: false
   - name: 'a8s-kcs-output-7'
     unique_id: a8s-kcs-output-7
     payload_on:  '{"output7":{"value":true}}'
     payload_off: '{"output7":{"value":false}}'
     value_template: '{{ value_json.output7.value }}'
     state_on: true
     state_off: false
   - name: 'a8s-kcs-output-8'
     unique_id: a8s-kcs-output-8
     payload_on:  '{"output8":{"value":true}}'
     payload_off: '{"output8":{"value":false}}'
     value_template: '{{ value_json.output8.value }}'
     state_on: true
     state_off: false
   - name: 'a8s-kcs-input-1'
     unique_id: a8s-kcs-input-1
     payload_on: true
     payload_off: false
   - name: 'a8s-kcs-input-2'
     unique_id: a8s-kcs-input-2
     payload_on: true
     payload_off: false
   - name: 'a8s-kcs-input-3'
     unique_id: a8s-kcs-input-3
     value_template: '{{ value_json.input3.value }}'
     payload_on: true
     payload_off: false
   - name: 'a8s-kcs-input-4'
     unique_id: a8s-kcs-input-4
     value_template: '{{ value_json.input4.value }}'
     payload_on: true
     payload_off: false
   - name: 'a8s-kcs-input-5'
     unique_id: a8s-kcs-input-5
     value_template: '{{ value_json.input5.value }}'
     payload_on: true
     payload_off: false
   - name: 'a8s-kcs-input-6'
     unique_id: a8s-kcs-input-6
     value_template: '{{ value_json.input6.value }}'
     payload_on: true
     payload_off: false
   - name: 'a8s-kcs-input-7'
     unique_id: a8s-kcs-input-7
     value_template: '{{ value_json.input7.value }}'
     payload_on: true
     payload_off: false
   - name: 'a8s-kcs-input-8'
     unique_id: a8s-kcs-input-8
     value_template: '{{ value_json.input8.value }}'
     payload_on: true
     payload_off: false
yaml:
.txt   A8S_KCS_HA_mqtt-input-output.txt (Size: 4.57 KB / Downloads: 416)
  RF433 configure
Posted by: Psyos - 06-02-2025, 10:21 AM - Forum: KC868-Server Raspberry Pi4 local server - Replies (3)
Good morning, how can I use the RF433 on my KinCony Server16 Raspberry Pi IoT gateway?
What do I need to install and configure?
Thank you.
  KC868-AG and RF projector screen
Posted by: seatrope - 06-01-2025, 10:31 PM - Forum: KC868-A series and Uair Smart Controller - Replies (1)
Hi Kincony!
I have been very pleased with the KC868-AG in Home Assistant so far. It's very strong and reliable for IR signals especially when I know the protocol like RC5, or NEC.
I have been struggling to get it working with my projector screen. The projector screen has RF, IR and 12V trigger, I would like to avoid having to wire the 12V trigger. We have generally used the RF 433Mhz as this is very reliable from the handheld controller, but I have tried multiple times to capture the RF signal using either RAW or Pronto format in esphome, and it never works when I send it.
By chance, can you figure out what the native protocol format is from these photos of the remote circuit board?
The manual is here, and you can tell the model also:  https://brochures.onlinebiz.com.au/broch...manual.pdf
I have attached some pictures of the remotes, the control box and the circuit boards for both RF and IR remotes.
I am hoping to get it working with RF 433Mhz with the KC868-AG. Any tips?
Thank you!
  can not login to ifttt
Posted by: henny - 06-01-2025, 10:45 AM - Forum: KC868-HxB series Smart Controller - Replies (1)
hello, as a newbie i recently bought a  kc868-a16 module and i programmed some automation with it,
but now i don't have access to the ifttt module it comes with a login promt but i 'am already logged in.
all other modules are accessible but not the ifttt one.
nothing changed with cables and /or passwords what is wrong with it ?
  Knox
Posted by: Adarrada - 06-01-2025, 01:03 AM - Forum: KC868-HxB series Smart Controller - Replies (12)
Hi
I have KC868-H8B v2.2
I tried to set up my Poole and Deck for the summer again but I can’t connect with the app(Kbox). I checked and see that the board is connected to the Wi-Fi.
I have set the IP address that is shown on the router and the port is 5555. But it does not react to the app.
How can I get this board working again?
