» Members: 9,966
» Latest member: Gamblezen
» Forum threads: 4,245
» Forum posts: 21,029
There are currently 135 online users.
» 0 Member(s) | 116 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, PetalBot, bot
Modbus 485 extender kcs V...
Forum: N30
6 hours ago
» Replies: 11
N10 with L1 and L2 suppor...
Forum: N10
Yesterday, 11:34 PM
KC868-A16v3 PCB layout CA...
Yesterday, 11:33 PM
Ceiling fan control not w...
09-15-2026, 11:11 PM
» Replies: 9
Case
Forum: KC868-A16S
09-15-2026, 02:26 AM
KC868-A16S PCB layout CAD...
09-14-2026, 11:23 PM
flash kc868-a4
09-14-2026, 11:18 PM
» Replies: 25
KC868-A16 – Using AI3/AI4...
09-14-2026, 08:27 AM
Questions on CO16
09-13-2026, 01:26 PM
RED DIP switch function
Forum: Pi5M32
09-12-2026, 11:50 PM
  [arduino code examples for B8]-05 Read free GPIO state
Posted by: admin - 06-23-2025, 04:48 AM - Forum: B8 - No Replies
* ESP32 GPIO State Reader
* Reads the state of GPIO47, GPIO48, GPIO7, GPIO40, GPIO0, and GPIO5
* and prints the results to the serial monitor.
#define GPIO_13  13
#define GPIO_40  40
#define GPIO_14  14
#define GPIO_48  48
#define GPIO_0   0
#define GPIO_47  47
#define GPIO_7  7
#define GPIO_21  21
    // Set GPIOs as input
    pinMode(GPIO_13, INPUT);
    pinMode(GPIO_40, INPUT);
    pinMode(GPIO_14, INPUT);
    pinMode(GPIO_48, INPUT);
    pinMode(GPIO_0, INPUT);
    pinMode(GPIO_47, INPUT);
    pinMode(GPIO_7, INPUT);
    pinMode(GPIO_21, INPUT);
    // Read GPIO states
    int state_13 = digitalRead(GPIO_13);
    int state_40 = digitalRead(GPIO_40);
    int state_14  = digitalRead(GPIO_14);
    int state_48 = digitalRead(GPIO_48);
    int state_0  = digitalRead(GPIO_0);
    int state_47 = digitalRead(GPIO_47);
    int state_7 = digitalRead(GPIO_7);
    int state_21 = digitalRead(GPIO_21);
    // Print GPIO states to the serial monitor
    Serial.printf("GPIO13: %d, GPIO40: %d, GPIO14: %d, GPIO48: %d, GPIO0: %d, GPIO47: %d, GPIO7: %d, GPIO21: %d\n",
                  state_13, state_40, state_14, state_48, state_0, state_47, state_7, state_21);
    delay(1000); // Read GPIO states every second
arduino ino file download:
.zip   5-free-gpio-state.zip (Size: 682 bytes / Downloads: 640)
.zip   5-free-gpio-state.ino.merged.zip (Size: 181.54 KB / Downloads: 611)
  [arduino code examples for B8]-04 RS485 communication test
Posted by: admin - 06-23-2025, 04:43 AM - Forum: B8 - No Replies
* RS485 Communication Test
#include <HardwareSerial.h>
// Define RS485 pins
#define RS485_RXD 38
#define RS485_TXD 39
  while (!Serial);
  // Send a test message
  rs485Serial.println("Hello from KinCony B8M!");
  // Wait for a short period
    String receivedMessage = "";
      char c = rs485Serial.read();
      receivedMessage += c;
    // Print the received message
    Serial.print("Received: ");
  delay(2000);
.zip   4-RS485-Test.zip (Size: 763 bytes / Downloads: 619)
.zip   4-RS485-Test.ino.merged.zip (Size: 186.52 KB / Downloads: 609)
  [arduino code examples for B8]-03 Read ADS1115 analog input ports value
Posted by: admin - 06-23-2025, 04:40 AM - Forum: B8 - No Replies
#define SDA_PIN 8
#define SCL_PIN 18
DFRobot_ADS1115 ads(&Wire);
void setup(void)
    Wire.begin(SDA_PIN, SCL_PIN);
    ads.setGain(eGAIN_TWOTHIRDS);
    ads.setMode(eMODE_SINGLE);
    ads.setRate(eRATE_128);
    ads.init();
void loop(void)
    if (ads.checkADS1115())
        adc0 = ads.readVoltage(0);
        Serial.print("A0:");
        Serial.print(adc0);
        adc1 = ads.readVoltage(1);
        Serial.print("A1:");
        Serial.print(adc1);
        adc2 = ads.readVoltage(2);
        Serial.print("A2:");
        Serial.print(adc2);
        adc3 = ads.readVoltage(3);
        Serial.print("A3:");
        Serial.print(adc3);
    else
.zip   3-ads1115_adc.zip (Size: 1.2 KB / Downloads: 593)
.zip   3-ads1115_adc.ino.merged.zip (Size: 192.69 KB / Downloads: 650)
  [arduino code examples for B8]-02 Read digital input ports state
Posted by: admin - 06-23-2025, 04:36 AM - Forum: B8 - No Replies
* Description:
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* - PCF8575 I2C Address: 0x22
#include "Arduino.h"
#include "PCF8575.h"
// Define I2C pins
// Set I2C address
    Serial.println("KinCony B8M 8 channel input state 0:ON  1:OFF");
    uint16_t state = 0;
    for (int pin = 0; pin < 8; pin++) {
        if (pcf8575_IN1.read(pin)) {
    delay(500); // Delay 500ms
.zip   2-digital-input.zip (Size: 837 bytes / Downloads: 570)
.zip   2-digital-input.ino.merged.zip (Size: 192.29 KB / Downloads: 627)
  [arduino code examples for B8]-01 Turn ON/OFF OUTPUT
Posted by: admin - 06-23-2025, 04:31 AM - Forum: B8 - No Replies
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* Delay Time:
#define SDA 8           // Define the SDA pin
#define SCL 18          // Define the SCL pin
#define I2C_ADDRESS 0x22 // I2C address of the PCF8575 module
  pcf8575_R1.begin();
.zip   1-output.zip (Size: 927 bytes / Downloads: 619)
.zip   1-output.ino.merged.zip (Size: 192.06 KB / Downloads: 644)
  B8 ESPHome yaml for home assistant with tuya
Posted by: admin - 06-23-2025, 04:28 AM - Forum: B8 - No Replies
  friendly_name: b8
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
  board: esp32-s3-devkitc-1
external_components:
  - source:
      type: git
      ref: v1.1.0
# logger:
#   hardware_uart: USB_SERIAL_JTAG
  encryption:
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  interrupt_pin: GPIO43
  reset_pin: GPIO44
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
  - id: 'pcf8574_hub_out_1'  # for output channel 0-7| input channel 8-15
    i2c_id: bus_a
    pcf8575: true
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 39
    rx_pin: 38
  - id: tuya_mcu_uart
    tx_pin: GPIO16
    rx_pin: GPIO17
    baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: tugmdoiviinh13kv
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
  - platform: uart
    uart_id: uart_1
      pcf8574: pcf8574_hub_out_1
      number: 8
  - platform: tuya_wifi_mcu
    dp_id: 1
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "b8_output01"
      number: 9
    dp_id: 2
    internal: true
    bind_switch_id: "b8_output02"
      number: 10
    dp_id: 3
    internal: true
    bind_switch_id: "b8_output03"
      number: 11
    dp_id: 4
    internal: true
    bind_switch_id: "b8_output04"
      number: 12
    dp_id: 5
    internal: true
    bind_switch_id: "b8_output05"
      number: 13
    dp_id: 6
    internal: true
    bind_switch_id: "b8_output06"
      number: 14
    dp_id: 101
    internal: true
    bind_switch_id: "b8_output07"
      number: 15
    dp_id: 102
    internal: true
    bind_switch_id: "b8_output08"
    dp_id: 111
    bind_binary_sensor_id: b8_input01
    internal: true
    dp_id: 112
    bind_binary_sensor_id: b8_input02
    internal: true
    dp_id: 113
    bind_binary_sensor_id: b8_input03
    internal: true
    dp_id: 114
    bind_binary_sensor_id: b8_input04
    internal: true
    dp_id: 115
    bind_binary_sensor_id: b8_input05
    internal: true
    dp_id: 116
    bind_binary_sensor_id: b8_input06
    internal: true
    dp_id: 117
    bind_binary_sensor_id: b8_input07
    internal: true
    dp_id: 118
    bind_binary_sensor_id: b8_input08
    internal: true
##pull-up resistance on PCB
      number: 47
      number: 48
      number: 40
## without resistance on PCB
      number: 13
      inverted:  false
      number: 14
      inverted:  false
      number: 21
      inverted:  false
      inverted:  false
ads1115:
  - address: 0x48
  - platform: ads1115
    multiplexer: 'A0_GND'
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A1_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A2_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A3_GND'
    gain: 6.144
    update_interval: 5s
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "KinCony b8");
download yaml file:
.txt   B8-HA.txt (Size: 8.35 KB / Downloads: 489)
  B8 ESP32-S3 IO pins define
Posted by: admin - 06-23-2025, 04:19 AM - Forum: B8 - No Replies
IIC Bus:
SDA:GPIO8
SCL:GPIO18
PCF8575: i2c address:0x22
PCF8575->P0 (digital input-1)
PCF8575->P1 (digital input-2)
PCF8575->P2 (digital input-3)
PCF8575->P3 (digital input-4)
PCF8575->P4 (digital input-5)
PCF8575->P5 (digital input-6)
PCF8575->P6 (digital input-7)
PCF8575->P7 (digital input-8)
PCF8575->P8 (relay1)
PCF8575->P9 (relay2)
PCF8575->P10 (relay3)
PCF8575->P11 (relay4)
PCF8575->P12 (relay5)
PCF8575->P13 (relay6)
PCF8575->P14 (relay7)
PCF8575->P15 (relay8)
24C02 EPROM i2c address: 0x50
DS3231 RTC i2c address: 0x68
Analog input (A1: DC 0-5v)
Analog input (A2: DC 0-5v)
Analog input (A3: DC 4-20mA)
Analog input (A4: DC 4-20mA)
1-wire GPIOs (with pull-up resistance on PCB):
1-wire-1:GPIO47
1-wire-2:GPIO48
1-wire-3:GPIO7
1-wire-4:GPIO40
GPIO13
GPIO14
GPIO21
Ethernet (W5500) I/O define:
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
reset_pin: GPIO44
RS485:
RXD:GPIO38
TXD:GPIO39
Tuya module:
RXD:GPIO17
TXD:GPIO16
SD Card:
SPI-MOSI:GPIO10
SPI-SCK:GPIO11
SPI-MISO:GPIO12
SPI-CS:GPIO9
SPI-CD:GPIO5
  IFTTT DI OnDelay
Posted by: job-systems - 06-22-2025, 01:41 AM - Forum: "KCS" v2 firmware system - Replies (2)
Hi, hope you are all fine.
Is it possible to have a Digital In (DI) to be true or ON for a fix number of seconds on the IF section before going to the THEN section and enabling a Digital Out (DO).
Example: I have laser barrier that flying insects pass by and activate it, I would like to not have false positives, and for example, ensure the DI is ON for 3 seconds fixed before activating the DO.
Thank you.
  KC868-A2 watchdog
Posted by: apps4check - 06-21-2025, 05:11 PM - Forum: KC868-A2 - Replies (1)
Hello. Does KC868-A2 (with "KCS" firmware) have a hardware or software watchdog?
  KinCony B8M ESP32-S3 Smart Controller released
Posted by: admin - 06-21-2025, 04:07 AM - Forum: News - No Replies
KinCony B8M ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 8 channel MOSFET output, 4 channel 1-wire GPIOs, 3 free GPIOs, 4 channel ADS1115 16bit analog input ports. One SD card using SPI bus. B8M include DS3231 high precision RTC clock chip. LCD display will show wifi and ethernet IP address and Tuya connection state. B8M have I2C bus extender and RS485 port. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. B8M use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. B8M support Apple HomeKit, easy to use directly. Support save state LOG to SD Card. It use by local RTC clock, use timer work without internet. B8M support to use KinCony cloud server service, so that you can remote control and monitor your device by internet using mobile phone or computer web browser. note: (buy from KinCony Official Shop have KinCony cloud server 2 years free)
[Image: B8M_1.jpg]
Model No. KinCony B8M
Description: KinCony 8 Channel ESP32-S3 Smart Controller – B8M
Power supply: 12-24V DC
Size:
SD Card: SPI bus
Installation method: DIN RAIL
LCD: SSD1306 I2C display
Outputs:
8CH MOSFET Outputs, every channel use MAX 10A driver IC
Inputs:
[Image: B8M_6.jpg]
