» Members: 10,080
» Latest member: sarahmitchell123
» Forum threads: 4,254
» Forum posts: 21,077
There are currently 231 online users.
» 0 Member(s) | 210 Guest(s)
Amazonbot, Applebot, Baidu, Bytespider, Crawl, DuckDuckGo, Facebook, Google, PetalBot, Twitter, bot, facebookexternalhit, owler
KC868-HAv2 phantom press ...
Forum: KC868-HA /HA v2
Last Post: phrfpeixoto
8 hours ago
KC868-A6 Analog inputs
Last Post: Tomas4289
Yesterday, 12:57 PM
N60/N30/N20/N10 PC softwa...
Forum: N10
Yesterday, 12:49 PM
» Replies: 13
getting the A8A inputs to...
Forum: Development
Yesterday, 08:38 AM
Best way to read from N30
Forum: N30
09-27-2026, 12:20 AM
extend KC868-A16v3
Last Post: bitet96717
09-24-2026, 06:41 AM
Las Firmware ?
09-22-2026, 11:15 PM
» Replies: 8
kc868-a6 analog input
09-21-2026, 11:38 PM
A32 pro tuya
Disconnect loop with Home...
Forum: F16
09-21-2026, 01:16 AM
  how to install home assistant for Pi5R32 beginner guide
Posted by: admin - 07-24-2026, 07:56 AM - Forum: Pi5R32 - No Replies
1. make home assistant OS SD card or SSD disk for KinCony Pi5R32.
download  https://www.raspberrypi.com/software/
2. enable i2c for home assistant.
Add files to enable I2C
In the root of the hassos-boot partition, add a new folder called CONFIG.
In the CONFIG folder, add another new folder called modules.
Inside the modules folder add a text file called rpi-i2c.conf with the following content:
i2c-dev
In the root of the hassos-boot partition, edit the file called config.txt at last add two lines to it:
dtparam=i2c_arm=on
dtoverlay=i2c1-pi5,pins_2_3
Note: if you using Windows OS computer, you can use "DiskGenius.exe" free software to modify the files. Because Linux format file not visable on windows OS.
3. install HACS addon
https://hacs.xyz/docs/use/download/downl...supervised
4. MCP23017 implementation for Home Assistant (HA)
https://github.com/jpcornil-git/HA-mcp23017
5. KinCony SSD1306 I2C Display implementation for Home Assistant
https://github.com/hzkincony/hass-ssd1306
6. KinCony ADS1115 ADC Sensor  implementation for Home Assistant
https://github.com/hzkincony/hass-ads1115
7. config yaml for MCP23017, ADS1115
install "file edit" add-on for HA , then config configuration.yaml
https://www.kincony.com/forum/showthread.php?tid=9664
  MCP23017 i2c address for OUTPUT and DIGITAL INPUT
Posted by: admin - 07-24-2026, 07:52 AM - Forum: Pi5R32 - No Replies
MCP23017 output1-16: 0x22
MCP23017 output17-32: 0x21
MCP23017 input1-16: 0x20
MCP23017 input17-32: 0x24
Posted by: admin - 07-24-2026, 07:52 AM - Forum: Pi5M32 - No Replies
  KC868-A6 Lora
Posted by: Armsp0 - 07-23-2026, 07:46 AM - Forum: KC868-A6 - Replies (3)
I have a KC868-6 V1.3 board. I live in New Zealand where AS923 requires 915Mhz frequency. Can the SX1262 board be used in place of the SX1278 module? Pinouts may be different firmware might need modification?
  KinCony for Crestron package release file
Posted by: admin - 07-23-2026, 07:26 AM - Forum: KinCony integrate with Crestron home automation - No Replies
.zip   Release.zip (Size: 26.56 MB / Downloads: 158)
  Kincony Device plugin file for Crestron
Posted by: admin - 07-23-2026, 07:08 AM - Forum: KinCony integrate with Crestron home automation - No Replies
.zip   DEMO_PROG_RMC3_compiled.zip (Size: 2.46 MB / Downloads: 111)
  KinCony Controller GUI for Crestron XPanel
Posted by: admin - 07-23-2026, 07:06 AM - Forum: KinCony integrate with Crestron home automation - No Replies
GUI file and source code:
.zip   Gui.zip (Size: 21.58 MB / Downloads: 134)
  Kincony Module For Crestron SIMPL Windows Integration & Signal guide
Posted by: admin - 07-23-2026, 07:00 AM - Forum: KinCony integrate with Crestron home automation - No Replies
.pdf   Kincony_Module_Documentation_260720.pdf (Size: 49.85 KB / Downloads: 125)
  Relay state after power restore?
Posted by: LoganParker - 07-22-2026, 07:57 AM - Forum: "KCS" v2 firmware system - Replies (1)
Hi everyone,
I'm using the KCS v2 firmware and would like each relay to restore its last state automatically after a power outage. Right now, all relays switch to OFF every time the controller reboots.
Is there a built-in setting in KCS v2 to save the relay state in flash memory and restore it after startup, or does this need to be handled through MQTT or Home Assistant? If anyone has configured this successfully, could you share the required settings or steps?
Thanks!
  IFFT Settings Do Not Save After Reset
Posted by: Guero - 07-21-2026, 03:55 AM - Forum: KC868-AG / AG Pro / AG8 / Z1 - Replies (1)
Hey KinCony,
Having issues whenever the controller restarts or looses power for a minute the IFTTT Settings do not save. I do not see any options that would fix this. Any help is appreciated!
I'm currently on firmware version 3.25.4
