» Members: 10,157
» Latest member: Dextra Labs
» Forum threads: 4,260
» Forum posts: 21,106
There are currently 367 online users.
» 0 Member(s) | 346 Guest(s)
Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, PetalBot, Semrush, bot
Bricked KC868-A16
19 minutes ago
remember relay state
Forum: KC868-E16T
Yesterday, 08:40 AM
It looks like it's broken...
Yesterday, 08:36 AM
Bidirectional reading
Forum: N10
10-05-2026, 11:35 PM
Update to latest esphome
10-05-2026, 12:05 PM
KC868-A16 ethernet work w...
10-04-2026, 11:43 PM
» Replies: 31
B32M maximum voltage
10-04-2026, 11:52 AM
» Replies: 4
m16v2 energy meter - cali...
10-02-2026, 11:50 AM
» Replies: 15
oCBot: KC868-A6/A16 as a ...
Last Post: oCBot
10-01-2026, 01:32 PM
N20 Energy RS485 Modbus P...
Forum: N20
10-01-2026, 12:43 PM
  CO16 ESP32-S3 IO pins define
Posted by: admin - 08-30-2026, 11:45 PM - Forum: CO16 - No Replies
IIC Bus:
SDA:GPIO8
SCL:GPIO18
PCF8575: (relay1-16): i2c address:0x22
XL9555: (input1-16): i2c address:0x24
24C02 EPROM i2c address: 0x50
DS3231 RTC i2c address: 0x68
ST7789 SPI display:
  SCK: GPIO11
  MOSI: GPIO10
  MISO: GPIO12
  CS: GPIO4
  DC: GPIO0
  RESET: GPIO5
  Back light: GPIO40
ADC (DC 0-10v/4-20mA set by jumper):
jumper: short UP: set for DC 0-10V signal.
jumper: short DOWN: set for DC 4-20mA signal.
ADS1115-1 (U35) adc CH1-CH4: i2c address:0x48
ADS1115-2 (U7): adc CH5-CH8:i2c address:0x49
ADS1115-3 (U15): adc CH9-CH12:i2c address:0x4B
ADS1115-4 (U19): adc CH13-CH16:i2c address:0x4A
NX3L4051:
S1:GPIO7
S2:GPIO21
SPI bus for MAX31865
SPI-MOSI: GPIO10
SPI-SCK: GPIO11
SPI-MISO: GPIO12
PTC_CS: GPIO14
PTC_RDY: GPIO21
LoRa_RST: GPIO5
LoRa_INT: GPIO40
LoRa_CS:GPIO13
Ethernet (W5500) I/O define:
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
interrupt_pin: GPIO43
reset_pin: GPIO44
RS485:
RXD:GPIO38
TXD:GPIO39
Tuya module:
RXD:GPIO17
TXD:GPIO16
SD Card:
SPI-MOSI:GPIO10
SPI-SCK:GPIO11
SPI-MISO:GPIO12
SD-CS:GPIO9
433MHz RF receiver: GPIO6
4G SIM7600/KNX RXD: GPIO47
4G SIM7600/KNX TXD: GPIO48
  CR battery
Posted by: apps4check - 08-29-2026, 09:28 PM - Forum: KC868-A2v3 - Replies (1)
Hi! Can I use a CR1225 battery or only a CR1220?
  N60 Loss of kWh on reset
Posted by: chuyskywalker - 08-28-2026, 04:28 AM - Forum: N60 - Replies (12)
I've had the N60 up and running for about a week now and something on it went sideways (stopped reporting to home assistant; not really sure what went wrong) so I turned it off and back on again. It rebooted and came back online, but all the kWh values had been reset to zero.
I thought the system saved these values to flash and would reload them at boot so that kWh remains continuous across reboots. Is that understanding wrong?
The reason I ask is because when an ESPHome device reports values of the type "total_increasing" to home assistant, values that go backwards are handled oddly. Worse, values that go to zero are considered reseting the sensor. It's all a bit quirky, but ideally the device would retain those values and restore them. If that's not the case, I'll figure out something.
Thanks!
  kc868-A16S3 v3.2
Posted by: 5310h - 08-26-2026, 08:59 PM - Forum: Development - Replies (3)
I have a KC868-A16 V3.2 (ESP32-S3) board powered from the supplied 12 V KinCony adapter. I successfully flashed the official A16V3 ESPHome YAML from this forum.
In the ESPHome web page, outputs 1 and 2 show ON (and I also tried all outputs ON), but none of the 16 on-board output indicator LEDs light. No load is connected.
With output 1 ON, I also measure 0 V between output terminal 1 and the red
+12/24V
terminal for the 1–8 bank.
Please confirm the exact required power wiring for both output banks on V3.2, and whether the output LEDs should light with only the board powered and an output switched ON. I can provide photos if needed.
  SSD1306 with case
Posted by: hans-martijn - 08-26-2026, 07:39 AM - Forum: KC868-A16v3 - Replies (3)
Is there a template to cut a hole in the A16v3 case to be able to show the contents of the SSD1306 screen? Or do you have a see-through case to be able to make the screen visible?
Currently, it doesn't make sense to add a screen under the cover, since you have to undo four screws to be able to see it.
Thanks in advance!
-hans-martijn
  N60 power supply - power cosumption
Posted by: buttom3 - 08-25-2026, 03:00 PM - Forum: N60 - Replies (1)
What is the maximum power consumption of the N60?
What power supply does it require, and how many watts are needed?
Is a 12 V DC, 1.25 A (15 W) power supply sufficient to run it reliably?
What power supply are you using to keep your N60 stable?
  KCS VERSUS ESPHOME
Posted by: EDVALDO DE MARINGA - 08-20-2026, 03:21 PM - Forum: "KCS" v3 firmware - Replies (2)
I just bought a KinCony 32 Pro to control basically the lighting in my house. This was a retrofit: I replaced an old automation system with the KinCony on a DIY basis.
My plan is to use Home Assistant to control everything. Today, the KinCony A32 Pro physically controls the lights ON/OFF. Now I need to install the firmware, and the big question is: ESPHome or KCS?
I asked ChatGPT, Gemini, and Copilot, and they gave contradictory answers.
What ChatGPT said
ChatGPT initially recommended KCS + Home Assistant, arguing that KCS can integrate the A32 Pro through MQTT and MQTT Auto Discovery, and that I would not need ESPHome.
It cited KinCony’s forum, including a discussion where the administrator said that KCS and ESPHome cannot run simultaneously and recommended KCS v3 for users who do not know how to configure ESPHome.
It also cited the KinCony forum thread “A32 pro lost control”, where a user had flashed ESPHome and lost KCS. The administrator explained that KCS and ESPHome cannot coexist, and suggested enabling MQTT Auto Discovery in KCS to integrate the A32 Pro with Home Assistant.
Based on this, ChatGPT concluded:
  • I do not need ESPHome.
  • I can install KCS and integrate it with Home Assistant.
  • KCS + MQTT Auto Discovery is the simpler solution for my case.
What Copilot said
Copilot strongly disagreed and said Gemini was right and ChatGPT was wrong.
Its main argument is that KCS does not expose all 32 digital inputs of the A32 Pro to Home Assistant.
According to Copilot, KCS exposes:
  • Relays through MQTT
  • Basic sensors
  • Some internal states
But it does not expose DI1–DI32.
This is critical for my application because I want to use physical inputs/dry contacts to trigger automations such as:
Quote:Press a button → turn on one, two, or three lights.
Copilot says that without the digital inputs being available in Home Assistant, this type of automation cannot work as intended.
It also claims that KinCony has stated on its forum that if you want all inputs and outputs in Home Assistant, you should use ESPHome.
Copilot's other arguments are:
  1. KCS + MQTT Auto Discovery does not automatically expose the 32 digital inputs.
  2. Saying that KCS is simpler may be true for some smaller KinCony controllers, but not necessarily for the A32 Pro.
  3. The A32 Pro uses multiple I/O expanders, and ESPHome provides a more complete mapping of its inputs and outputs to Home Assistant.
My questions
I do not want a generic comparison between ESPHome and KCS. I want the answer specifically for the KinCony KC868-A32 Pro + Home Assistant, considering that my primary objective is to control lighting and use the physical digital inputs for automations.
1. Who is technically correct: Gemini/Copilot or ChatGPT?
More specifically: Does KCS v3 with MQTT Auto Discovery expose all 32 digital inputs of the A32 Pro to Home Assistant, or do I need ESPHome for that?
2. If I need ESPHome on the KinCony A32 Pro:
Where is the latest official A32 Pro ESPHome YAML/configuration for Home Assistant?
Is this KinCony forum thread the correct/latest source?
https://www.kincony.com/forum/showthread.php?tid=5520
3. If KCS should be installed instead:
Is this the latest KCS version/configuration for the A32 Pro, including MQTT Auto Discovery?
https://www.kincony.com/forum/showthread...3#pid25773
I want to resolve the contradiction before flashing the controller, because KCS and ESPHome cannot coexist, so choosing the wrong firmware means having to reflash the device.
Please base the answer on the current KinCony A32 Pro documentation/forum information, not on assumptions about other KinCony models.
Summary: I need to decide between KCS + MQTT Auto Discovery and ESPHome for an A32 Pro whose relays control my lights and whose digital inputs will be used by Home Assistant for physical-button/dry-contact automations. The key question is whether KCS exposes the 32 digital inputs to Home Assistant.
  KC868-AGv3
Posted by: zalaking - 08-19-2026, 08:45 PM - Forum: Getting Started with ESPHome and Home Assistant - Replies (5)
Hi Kincony and community.
I've just received my KC868-AGv3 RF/IR Smart Controller..
is there an example ESPHome configuration posted anywhere - I've been searching for some time and cannot find a an example I can use to get me started... I've installed a base ESP32 config on it and I see it on my network etc.. but keen to get it fully worked with all the RF/IR/Buzzer features..
Many thanks in advance.
  KinCony B2 Smart Controller released
Posted by: admin - 08-17-2026, 01:07 PM - Forum: News - No Replies
KinCony B2 ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 2 channel relay output, 4 channel 1-wire GPIOs, 4 channel ADS1115 16bit analog input ports. One SD card using SPI bus. B2 include DS3231 high precision RTC clock chip. LCD display will show wifi and ethernet IP address and Tuya connection state. B2 have I2C bus extender and RS485 port. B2 support use SIM7600E 4G module. You can write any code by Arduino IDE / MicroPython / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. B2 use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support KinCony cloud service (official shop customer free 2 years), remote monitor and control device by webpage in anywhere. KCS v3 support KinCony board integrate to Loxone Miniserver. Support Apple HomeKit for Siri.
[Image: B2-2.jpg]
Model No. KinCony B2
Description: KinCony 2 Channel ESP32-S3 Smart Relay Controller – B2
Power supply: 12-24V DC
interfaces: Ethernet(RJ45)-LAN 100Mbps IPv4/IPv6,WiFi,RS485,Bluetooth,USB-C,LCD,I2C,Tuya Module, 4G SIM7600
SD Card: SPI bus
Installation method: DIN RAIL
LCD: SSD1306 I2C display
Outputs:
2CH relay Outputs, every relay use by MAX AC270V/10A
Inputs:
2CH dry contact inputs (optocoupler isolation, long distance circuit for MAX 500 meters cable)
[Image: B2-1.jpg]
  KC868-A8v3 PCB layout CAD file
Posted by: admin - 08-17-2026, 08:44 AM - Forum: Schematic & diagram & Dimensions of KinCony PCB layout CAD file - No Replies
.zip   KC868_A8v3.1.zip (Size: 1.57 MB / Downloads: 183)
