» Members: 9,812
» Latest member: myaichats
» Forum threads: 4,218
» Forum posts: 20,909
There are currently 355 online users.
» 0 Member(s) | 335 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, HeadlessChrome, PetalBot, bot
N60 Loss of kWh on reset
Forum: N60
Last Post: chuyskywalker
7 hours ago
» Replies: 12
Yesterday, 09:03 PM
CT Sensor Direction
Forum: N60
Yesterday, 12:51 PM
Request for Type B Projec...
Last Post: lemanat
Yesterday, 08:47 AM
No ethernet communication
09-02-2026, 06:31 AM
KinCony CO16 ESP32S3 16 C...
Forum: News
09-02-2026, 01:51 AM
08-31-2026, 12:16 AM
08-31-2026, 12:11 AM
08-31-2026, 12:09 AM
08-31-2026, 12:08 AM
  KinCony Pi5R8 – Raspberry Pi CM5 IoT Gateway released
Posted by: admin - 06-11-2026, 04:32 AM - Forum: News - No Replies
KinCony Pi5R8 – Raspberry Pi CM5 DIN Rail Relay Controller for Smart Home & Industrial Automation
[Image: Pi5R8-1.jpg]
Product Overview
KinCony Pi5R8 is a powerful Raspberry Pi-based IoT gateway designed for smart home automation and industrial control applications. Powered by the Raspberry Pi Compute Module 5 (CM5), it integrates relay outputs, optocoupler-isolated digital inputs, analog inputs, RS232/RS485 communication interfaces, PWM outputs, and expansion interfaces into a compact DIN rail aluminum enclosure.
The Raspberry Pi CM5 directly manages relay outputs, digital inputs, analog inputs, PWM outputs, and communication interfaces, making it easy to deploy automation solutions using Home Assistant, Node-RED, MQTT, Modbus, Docker, Python, and other Linux-based software.
Pi5R8 is an ideal platform for smart homes, industrial automation, energy management systems, and IoT edge computing applications.
[Image: Pi5R8-5.jpg]
Key Features
  • Powered by Raspberry Pi Compute Module 5 (CM5)
  • 8-channel industrial relay outputs
  • 8 optocoupler-isolated digital inputs
  • Supports Home Assistant and Node-RED
  • RS232 and RS485 communication interfaces
  • 2-channel PWM outputs
  • 2 × DC 0-5V analog inputs
  • 2 × 4-20mA analog inputs
  • 20 free GPIO expansion pins
  • Gigabit Ethernet support
  • M.2 PCIe expansion socket
  • SSD1306 OLED display
  • Industrial aluminum DIN rail enclosure
  • Ideal for smart home and industrial automation projects
  How to enable 2 IIC buses at the same time?
Posted by: ronpsc - 06-11-2026, 02:54 AM - Forum: KC868-A128 - Replies (1)
Dear Sir,
May I know how to enable both IIC buses for DI and DO at the same time for KC868-A128 in Arduino IDE?
I can only enable one each time, so that I cannot program the board to trigger outputs when inputs changed.
Thanks,
Ron
  Enable 2 I2C buses at the same time
Posted by: ronpsc - 06-11-2026, 02:49 AM - Forum: KC868-A128 - Replies (1)
Dear Sir,
I would like to know how to enable both buses for DI and DO in Arduino IDE of KC868-A128 at the same time?
I can only enable one bus each time, so I cannot program the board to trigger the output when input changed.
Thanks,
Ron
  Automatic water Level Controller
Posted by: unais - 06-10-2026, 01:46 PM - Forum: Apply for free sample product - No Replies
Hi Team
I'm currently researching for a Water Controller System. So i need a main controller to research. If it works better, useful for the community.
This is a fully automated water level controller and monitoring system with advanced systems. So if you support me, i can build a solution for that.
  M16v2 and SCT013-050
Posted by: SixSixOne - 06-10-2026, 10:20 AM - Forum: KC868-M16 / M1 / MB / M30 - Replies (5)
Dear Sir,
I have bought a M16v2 recently and try to make it work with SCT013-050 50A/1V sensors (https://www.aliexpress.com/item/10050092...1802lqJyc9) with the jumper positioned in the "V" measurement on the board.
I've used the last yaml code you provided (also attached) however it is not measuring anything.
My house has 3 phases and I have already checked all 3 phases as they are coming from teh grid as well as from a socket.
I've never received any measurement the Amperage is always 0A and the RAW measurements 0.11A, 0.12A, 0.13A
Any idea what is going on?
Tks a lot
.txt   Kincony-m16-v2.txt (Size: 9.86 KB / Downloads: 101)
Wink Single-family home automation
Posted by: Jan_W - 06-09-2026, 01:53 PM - Forum: DIY Project - Replies (3)
I'll show off a project that's currently underway - full home automation:
- lighting (including dimmable LEDs)
- blinds, multi device control: fans, pumps
- energy measurement,
- temperature and humidity sensors
- and much more Smile
3x B32M
1x DM16
1x G1
1x N20
[Image: tqglEM0.jpeg]
  connect 2 KC868 to homeassistant with mqtt broker Mosquitto
Posted by: guycaluwaerts - 06-09-2026, 08:33 AM - Forum: KC868-A16 - Replies (5)
Dear,
I try to integrate 2 Kincony boards ( KC868-A16 an KC868-AP) in Homeassistant by mqtt broker Mosquitto.
For the board kc868-A16 I made the correct settings I think.
Mqtt : enable
broker address : mqtt://192.168.0.157
broker port : 1883
broker username : mqtt
broker password : 123
In the screen ' monitor' : status mqtt : connected.
My problem is the integration in homeassistant. I followed your tutorial, but at step 3, I don't understand how you imported the yaml files of your boards in the file editor.
Is it possible to explain how to import the yaml files for the boards KC868-A16 and KC868-AP ?
Second question : When I connect the secondboard ( KC868-AP), can I use the same settings for the mqtt broker ?
Image(s)
  KC868-A8 OpenPLC Function Blocks for Digital input
Posted by: admin - 06-09-2026, 12:00 AM - Forum: KC868-A8 - No Replies
#include <Arduino.h>
//#include <Wire.h>
#include <PCF8574.h>
// PCF8574 input address
#define I2C_INPUTS_ADR 0x22
PCF8574 pcf_in(I2C_INPUTS_ADR);
    // ESP32 KC868 default I2C pins
    Wire.begin(4, 5); // SDA, SCL
    // Initialize PCF8574
    pcf_in.begin();
    // Configure PCF8574 pins as inputs
    pcf_in.pinMode(P0, INPUT);
    pcf_in.pinMode(P1, INPUT);
    pcf_in.pinMode(P2, INPUT);
    pcf_in.pinMode(P3, INPUT);
    pcf_in.pinMode(P4, INPUT);
    pcf_in.pinMode(P5, INPUT);
    pcf_in.pinMode(P6, INPUT);
    pcf_in.pinMode(P7, INPUT);
    // KC868 inputs are active LOW
    IN_0 = (pcf_in.digitalRead(P0) == LOW);
    IN_1 = (pcf_in.digitalRead(P1) == LOW);
    IN_2 = (pcf_in.digitalRead(P2) == LOW);
    IN_3 = (pcf_in.digitalRead(P3) == LOW);
    IN_4 = (pcf_in.digitalRead(P4) == LOW);
    IN_5 = (pcf_in.digitalRead(P5) == LOW);
    IN_6 = (pcf_in.digitalRead(P6) == LOW);
    IN_7 = (pcf_in.digitalRead(P7) == LOW);
  INCREMENTAL ENCODER
Posted by: fabuena - 06-08-2026, 10:04 PM - Forum: KC868-A8 - Replies (3)
I want to connect a CALT GHW38 incremental encoder with a built-in measuring wheel to my KC 868-A8 in the simplest way possible.
Should I get an NPN, PNP, or 5V line driver encoder?
Dispositivo de Medición de Longitud CALT GHW38, Codificador Rotatorio con Salida de Pulso, con Rueda Antideslizante de 200 mm/300 mm de Circunferencia - AliExpress
Which inputs do I connect signals A and B to?
  "KCS" v3 Nx energy meter RS485 TCP/IP Modbus protocol document
Posted by: admin - 06-07-2026, 01:39 AM - Forum: "KCS" v3 firmware - No Replies
"KCS" v3 Nx energy meter RS485 TCP/IP Modbus protocol document:
.txt   n10_energy_modbus_protocol_20260324.txt (Size: 11.98 KB / Downloads: 124)
.txt   n20_energy_modbus_protocol_20260324.txt (Size: 13.6 KB / Downloads: 132)
.txt   n30_energy_modbus_protocol_20260324.txt (Size: 15.9 KB / Downloads: 114)
.txt   n60_energy_modbus_protocol_20260324.txt (Size: 12.18 KB / Downloads: 109)
