» Members: 9,869
» Latest member: kuy88xyz
» Forum threads: 4,227
» Forum posts: 20,964
There are currently 83 online users.
» 0 Member(s) | 72 Guest(s)
Amazonbot, Applebot, Baidu, Crawl, Google, PetalBot, bot
"KCS" v2.2.21 firmware BI...
Last Post: PaPiTo
4 hours ago
wish
Forum: KC868-A16v3
8 hours ago
Last Post: viko
10 hours ago
» Replies: 22
N10 - ESPHome - ARM CPU s...
Forum: N10
11 hours ago
B32M maximum voltage
Last Post: velifetime
Yesterday, 07:01 AM
KNX ETS software project ...
Yesterday, 03:44 AM
"KCS" v3.27.1 firmware BI...
Yesterday, 03:24 AM
OLED not found in I2C sca...
Forum: KC868-A6v3
09-07-2026, 02:55 AM
"KCS" v3.27 firmware BIN ...
09-07-2026, 02:51 AM
ESPHome modbus not functi...
Forum: KC868-A8S
09-06-2026, 11:49 PM
  "KCS" v3.25.0 firmware BIN file download
Posted by: admin - 05-16-2026, 05:13 AM - Forum: "KCS" v3 firmware - Replies (9)
new version improvement:
1. Daylight saving time adaptation (add DST configuration to firmware system + IFTTT automatic adjustment to new time)
2. Multi-channel configuration support for the Wiegand protocol
3. Display cumulative online duration on the web page (web + MQTT + HA)
4. Support for third-party sensor integration using the standard Modbus protocol
5. add send IR signal to ALL GPIO channels
6. add mqtt "force update" option for home assistant
.zip   KCS_A2V3_V3.25.0.zip (Size: 1.18 MB / Downloads: 324)
.zip   KCS_A6V3_V3.25.0.zip (Size: 1.15 MB / Downloads: 297)
.zip   KCS_A8V3_V3.25.0.zip (Size: 1.21 MB / Downloads: 352)
.zip   KCS_A16V3_V3.25.0.zip (Size: 1.22 MB / Downloads: 324)
.zip   KCS_A32PRO_V3.25.0.zip (Size: 1.19 MB / Downloads: 251)
.zip   KCS_AG8_V3.25.0.zip (Size: 1.17 MB / Downloads: 232)
.zip   KCS_AGV3_V3.25.0.zip (Size: 1.12 MB / Downloads: 291)
.zip   KCS_AIO_HYBRID_V3.25.0.zip (Size: 1.4 MB / Downloads: 284)
.zip   KCS_ALR_V3.25.0.zip (Size: 1.16 MB / Downloads: 266)
.zip   KCS_B4_V3.25.0.zip (Size: 1.21 MB / Downloads: 228)
.zip   KCS_B4M_V3.25.0.zip (Size: 1.21 MB / Downloads: 249)
.zip   KCS_B8_V3.25.0.zip (Size: 1.21 MB / Downloads: 230)
.zip   KCS_B8M_V3.25.0.zip (Size: 1.21 MB / Downloads: 276)
.zip   KCS_B16_V3.25.0.zip (Size: 1.21 MB / Downloads: 267)
.zip   KCS_B16M_V3.25.0.zip (Size: 1.21 MB / Downloads: 320)
.zip   KCS_B24_V3.25.0.zip (Size: 1.21 MB / Downloads: 283)
.zip   KCS_B24M_V3.25.0.zip (Size: 1.21 MB / Downloads: 238)
.zip   KCS_B32M_V3.25.0.zip (Size: 1.21 MB / Downloads: 244)
.zip   KCS_DM4_V3.25.0.zip (Size: 1.22 MB / Downloads: 228)
.zip   KCS_DM8_V3.25.0.zip (Size: 1.22 MB / Downloads: 257)
.zip   KCS_DM16_V3.25.0.zip (Size: 1.19 MB / Downloads: 288)
.zip   KCS_DM32_V3.25.0.zip (Size: 1.22 MB / Downloads: 250)
.zip   KCS_F4_V3.25.0.zip (Size: 1.21 MB / Downloads: 227)
.zip   KCS_F8_V3.25.0.zip (Size: 1.21 MB / Downloads: 289)
.zip   KCS_F16_V3.25.0.zip (Size: 1.22 MB / Downloads: 279)
.zip   KCS_F24_V3.25.0.zip (Size: 1.22 MB / Downloads: 233)
.zip   KCS_F32_V3.25.0.zip (Size: 1.22 MB / Downloads: 234)
.zip   KCS_G1_V3.25.0.zip (Size: 1.17 MB / Downloads: 233)
.zip   KCS_KC_TA_V3.25.0.zip (Size: 1.17 MB / Downloads: 261)
.zip   KCS_N10_V3.25.0.zip (Size: 1.08 MB / Downloads: 233)
.zip   KCS_N20_V3.25.0.zip (Size: 1.08 MB / Downloads: 252)
.zip   KCS_N30_V3.25.0.zip (Size: 1.08 MB / Downloads: 266)
.zip   KCS_N60_V3.25.0.zip (Size: 1.09 MB / Downloads: 259)
.zip   KCS_T16M_V3.25.0.zip (Size: 1.16 MB / Downloads: 246)
.zip   KCS_T32M_V3.25.0.zip (Size: 1.18 MB / Downloads: 249)
.zip   KCS_T64M_V3.25.0.zip (Size: 1.18 MB / Downloads: 229)
.zip   KCS_T128M_V3.25.0.zip (Size: 1.18 MB / Downloads: 261)
.zip   KCS_TR_V3.25.0.zip (Size: 1.14 MB / Downloads: 256)
.zip   KCS_Z1_V3.25.0.zip (Size: 1.31 MB / Downloads: 260)
Big Grin Reset Total Energy only works per chip
Posted by: GWS - 05-14-2026, 07:00 PM - Forum: N30 - Replies (1)
I have made some changes to my setup and one of the reasons is that the calculations were not correct.
Tried to reset the BL0910 chips  but Clear all does not seem to clear the Total Energy values Confused . Just found out that "Clear Energy 1/2/3" so per chip did actually work.  Smile
  Factor settings and calculations
Posted by: GWS - 05-14-2026, 09:27 AM - Forum: "KCS" v3 firmware - Replies (2)
I see some weird bahavior on my N30 that I do not understand:
Using CT with factor 1000:1 and after measering the actual curren with MID approved device I found that factor 2.1 was the best.
When I save the factor 2.1 it results in 2.0999... etc and that might very well be because of how the factor is binary processed in the chip.
So initially I started with setting all factors to 2.1 (for testing I have now set CH01 to factor 2 and CH02 to 1)
But on Channel 2 (first 901 chip) I got strange values and the Power Factor keeps changing in the header of the dat for that chip.
On the other two chips it stays on 1.0000 and the data looked correct.
When I move the CT connector for 1..10 to the position of the 11..20 I see that CH12 is displaying the expected values.
Looks like CHIP 1 is behaving differtent from CHIP 2&3.
Any idea what could cause this?
Related to this I would like to know how to best set the factors I it necessary to set all columns with same factor? (Please provide a field for the default setting for all columns)
Power = Voltage * Current
Energy = Power over time accumulated. It is not fully clear if I need the factor (2.1) there also, or should it be 1 since the power is already corrected.
Thanks,
GWS
  N30 - Modbus-TCP
Posted by: GWS - 05-14-2026, 08:57 AM - Forum: "KCS" v3 firmware - Replies (4)
I am trying to get the N30 to work as a modbus device that I can read from via TCP on port 502. Could not get it to work on the IP address of the N30
Hooked up a Hi-Flying EW11 TCP to modbus converter to the RS485 port in modbus mode and that does work. Can see all the registers for chips on address 100/200/300
I was assuming that the setting
TCP Server: enable
Protocol:     Modbus
local port:   502
modbus local addr 1
Would be sufficient to read the registers via the N30 IP address on port 502
Whatever I try I do get a time-out
Port 502 is open if I test with ModbusDoctor or Powershell I get connected but no readings at the expected adresses.
Also tried with setting Modbus-RTU-v2 and a virtual COM port without any responce. Please provide instructions if this should work and if so how?
Thanks,
GWS
  N30 no Energy (kWh)
Posted by: alexlans - 05-13-2026, 07:46 PM - Forum: "KCS" v3 firmware - Replies (13)
I have buy 3 N30 to monitor energy.
I use latest software
Board Model
N30
Software Version
v3.24.5
Build Date
Apr 29 2026 05:26:42
Serial Number
D0CF13020568
I connect 1,2,3 voltage and connect 3 phase conditionner to CH2
Energy Monitor 1
CH 2
Energy Monitor 2
CH 2
Energy Monitor 3
CH 2
and other 1 pahse load to other ports.
How make to get Energy (kWh)?
  Python and arduino code
Posted by: Saif Kitany - 05-08-2026, 09:34 AM - Forum: News - Replies (1)
I would like to have a video of explaining how to write arduino or python code for A32 pro.
  RTC DS3231 yaml code
Posted by: Fred - 05-05-2026, 10:10 AM - Forum: KC868-A16v3 - Replies (1)
Do you have any suggestion to use the DS3231 RTC clock through ESPHome on this KC868-a16 v3 board? Do you have any yaml code to suggest?
Thanks a lot,
Best regards,
Fred
  T64M PCB layout CAD file
Posted by: admin - 05-05-2026, 08:08 AM - Forum: Schematic & diagram & Dimensions of KinCony PCB layout CAD file - No Replies
.zip   KINCONY-T64M-V1.0.zip (Size: 441.39 KB / Downloads: 298)
  T16M PCB layout CAD file
Posted by: admin - 05-05-2026, 08:07 AM - Forum: Schematic & diagram & Dimensions of KinCony PCB layout CAD file - No Replies
.zip   KINCONY-T16M-V1.1.zip (Size: 154.94 KB / Downloads: 263)
  24V Pulse input
Posted by: Onepointbrewing - 05-04-2026, 09:34 AM - Forum: F16 - Replies (3)
I have a IFM SM7000 flow meter that is set to nPn pulse output for measuring the flow unit.
It is a 24V unit (both the F16 and the flow meter)
What input on the F16 can I wire this to in order to count the pulses..... Will the standard digital inputs work?
