» Members: 10,070
» Latest member: nairobiglow
» Forum threads: 4,254
» Forum posts: 21,076
There are currently 73 online users.
» 1 Member(s) | 57 Guest(s)
Amazonbot, Baidu, Crawl, HeadlessChrome, PetalBot, Semrush, bot, admin
KC868-A6 Analog inputs
Last Post: Tomas4289
1 hour ago
N60/N30/N20/N10 PC softwa...
Forum: N10
1 hour ago
» Replies: 13
getting the A8A inputs to...
Forum: Development
5 hours ago
Best way to read from N30
Forum: N30
Yesterday, 12:20 AM
extend KC868-A16v3
Last Post: bitet96717
09-24-2026, 06:41 AM
Las Firmware ?
09-22-2026, 11:15 PM
» Replies: 8
kc868-a6 analog input
09-21-2026, 11:38 PM
A32 pro tuya
Disconnect loop with Home...
Forum: F16
09-21-2026, 01:16 AM
KC-868-A1 linked Home Ass...
Forum: News
Question Dimming with Zigbee and KC868-AG/AG Pro with KCS Firmware?
Posted by: iwzr - 03-21-2024, 09:59 PM - Forum: KC868-AG / AG Pro / AG8 / Z1 - Replies (3)
Is there a possibility to control Zigbee Dimmers with KCS Firmware on KC868-AG/AG Pro?
The Dimmer controller KC868-D8 is great, but I was not able to find a Din-Rail AC Triac dimmer like:
[Image: zigbee-dimmer-dinrail.png]
Therefore the question if KC868-AG/AG Pro could be used instead?
  KCS DI/DO not working
Posted by: LTDU - 03-20-2024, 01:58 PM - Forum: "KCS" v2 firmware system - Replies (14)
Dear team,
the KCS 2.2.2 is not working for me.
- DI are at random and not changing when making a connection with GND.
- DO can't be switched either.
- Note this is only with the KCS firmware, my own code works fine.
- Maybe it is to be noted that the I2C addresses do not match the standard for my board, as stated here: https://www.kincony.com/forum/showthread...67#pid6767
Please advise.
  Time control not working
Posted by: kyxap - 03-20-2024, 06:21 AM - Forum: "KCS" v2 firmware system - Replies (24)
Hi everyone,
I am having trouble configuring my device.
I want to set the relay to turn on at a specific time and perform several functions.
Here is a screenshot, but unfortunately it is not working.
Please help and advice.
  KC868-D16 question
Posted by: blackygego - 03-19-2024, 10:45 PM - Forum: KC868-HxB series Smart Controller - Replies (1)
Hi, two question,
1.) Do I use input K1 to control output 1+,1-; input K2 controls output 2+,2-; and so on..I am interested in the following, if I can use the K3 input to control the output 14+,14-?
2.) What is the difference between LED Dimmable Driver 0-10V and LED Dimmable Driver 1-10V?
Thank you very much!
  Tuya adapter V2 arduino source code - 32CH virtual switch
Posted by: admin - 03-19-2024, 02:03 AM - Forum: KC868-ATC / Tuya adapter V2 - Replies (3)
#include <Arduino.h>
#include <TuyaWifi.h>
#include "HardwareSerial.h"
TuyaWifi my_device;
/* Current LED status */
unsigned char led_state = 0;
int key_pin = 25;
/* Data point define */
#define DPID_SWITCH_1   1
#define DPID_SWITCH_2   2
#define DPID_SWITCH_3   3
#define DPID_SWITCH_4   4
#define DPID_SWITCH_5   5
#define DPID_SWITCH_6   6
#define DPID_SWITCH_7   113
#define DPID_SWITCH_8   114
#define DPID_SWITCH_9   115
#define DPID_SWITCH_10  116
#define DPID_SWITCH_11  117
#define DPID_SWITCH_12  118
#define DPID_SWITCH_13  119
#define DPID_SWITCH_14  120
#define DPID_SWITCH_15  121
#define DPID_SWITCH_16  122
#define DPID_SWITCH_17  123
#define DPID_SWITCH_18  124
#define DPID_SWITCH_19  125
#define DPID_SWITCH_20  126
#define DPID_SWITCH_21  127
#define DPID_SWITCH_22  128
#define DPID_SWITCH_23  129
#define DPID_SWITCH_24  130
#define DPID_SWITCH_25  131
#define DPID_SWITCH_26  132
#define DPID_SWITCH_27  133
#define DPID_SWITCH_28  134
#define DPID_SWITCH_29  135
#define DPID_SWITCH_30  136
#define DPID_SWITCH_31  137
#define DPID_SWITCH_32  138
#define LED_WiFi  26
//#define LED_User  33
unsigned char switch_1_state = 0;
unsigned char switch_2_state = 0;
unsigned char switch_3_state = 0;
unsigned char switch_4_state = 0;
unsigned char switch_5_state = 0;
unsigned char switch_6_state = 0;
unsigned char switch_7_state = 0;
unsigned char switch_8_state = 0;
unsigned char switch_9_state = 0;
unsigned char switch_10_state = 0;
unsigned char switch_11_state = 0;
unsigned char switch_12_state = 0;
unsigned char switch_13_state = 0;
unsigned char switch_14_state = 0;
unsigned char switch_15_state = 0;
unsigned char switch_16_state = 0;
unsigned char switch_17_state = 0;
unsigned char switch_18_state = 0;
unsigned char switch_19_state = 0;
unsigned char switch_20_state = 0;
unsigned char switch_21_state = 0;
unsigned char switch_22_state = 0;
unsigned char switch_23_state = 0;
unsigned char switch_24_state = 0;
unsigned char switch_25_state = 0;
unsigned char switch_26_state = 0;
unsigned char switch_27_state = 0;
unsigned char switch_28_state = 0;
unsigned char switch_29_state = 0;
unsigned char switch_30_state = 0;
unsigned char switch_31_state = 0;
unsigned char switch_32_state = 0;
*                                     dp type(TuyaDefs.h) : DP_TYPE_RAW, DP_TYPE_BOOL, DP_TYPE_VALUE, DP_TYPE_STRING, DP_TYPE_ENUM, DP_TYPE_BITMAP
unsigned char dp_array[][2] =
  {DPID_SWITCH_1, DP_TYPE_BOOL},{DPID_SWITCH_2, DP_TYPE_BOOL},{DPID_SWITCH_3, DP_TYPE_BOOL},{DPID_SWITCH_4, DP_TYPE_BOOL},{DPID_SWITCH_5, DP_TYPE_BOOL},{DPID_SWITCH_6, DP_TYPE_BOOL},
  {DPID_SWITCH_7, DP_TYPE_BOOL},{DPID_SWITCH_8, DP_TYPE_BOOL},{DPID_SWITCH_9, DP_TYPE_BOOL},{DPID_SWITCH_10, DP_TYPE_BOOL},{DPID_SWITCH_11, DP_TYPE_BOOL},{DPID_SWITCH_12, DP_TYPE_BOOL},
  {DPID_SWITCH_13, DP_TYPE_BOOL},{DPID_SWITCH_14, DP_TYPE_BOOL},{DPID_SWITCH_15, DP_TYPE_BOOL},{DPID_SWITCH_16, DP_TYPE_BOOL},{DPID_SWITCH_17, DP_TYPE_BOOL},{DPID_SWITCH_18, DP_TYPE_BOOL},
  {DPID_SWITCH_19, DP_TYPE_BOOL},{DPID_SWITCH_20, DP_TYPE_BOOL},{DPID_SWITCH_21, DP_TYPE_BOOL},{DPID_SWITCH_22, DP_TYPE_BOOL},{DPID_SWITCH_23, DP_TYPE_BOOL},{DPID_SWITCH_24, DP_TYPE_BOOL},
  {DPID_SWITCH_25, DP_TYPE_BOOL},{DPID_SWITCH_26, DP_TYPE_BOOL},{DPID_SWITCH_27, DP_TYPE_BOOL},{DPID_SWITCH_28, DP_TYPE_BOOL},{DPID_SWITCH_29, DP_TYPE_BOOL},{DPID_SWITCH_30, DP_TYPE_BOOL},
{DPID_SWITCH_31, DP_TYPE_BOOL},{DPID_SWITCH_32, DP_TYPE_BOOL},
unsigned char pid[] = {"3ocztklfu3q32jab"};
/* last time */
unsigned long last_time = 0;
  // Serial with tuyawifi
  Serial.begin(9600,SERIAL_8N1,22,19);
  Serial2.begin(9600,SERIAL_8N1,32,33);
  Serial2.println("RS485 SEND is OK!!");
  pinMode(LED_WiFi, OUTPUT);
  digitalWrite(LED_WiFi, LOW);
/*  pinMode(LED_User, OUTPUT);
  digitalWrite(LED_User, LOW);*/
  //Initialize networking keys.
  my_device.init(pid, mcu_ver);
  my_device.set_dp_cmd_total(dp_array, 1);
  last_time = millis();
  while(Serial2.available()>0){
    Serial2.print((char)Serial2.read());
  my_device.uart_service();
  //Enter the connection network mode when Pin7 is pressed.
    delay(80);
      if (led_state == LOW) {
        led_state = HIGH;
        led_state = LOW;
  delay(10);
* @param {unsigned char} dpid
* @return {unsigned char}
  switch(dpid) {
    case DPID_SWITCH_1:
      switch_1_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      //Status changes should be reported.
      my_device.mcu_dp_update(DPID_SWITCH_1, switch_1_state, length);
    break;
    case DPID_SWITCH_2:
      switch_2_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_2, switch_2_state, length);
    break;
    case DPID_SWITCH_3:
      switch_3_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_3, switch_3_state, length);
    break;
    case DPID_SWITCH_4:
      switch_4_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_4, switch_4_state, length);
    break;
    case DPID_SWITCH_5:
      switch_5_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_5, switch_5_state, length);
    break;
    case DPID_SWITCH_6:
      switch_6_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_6, switch_6_state, length);
    break;
    case DPID_SWITCH_7:
      switch_7_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_7, switch_7_state, length);
    break;
    case DPID_SWITCH_8:
      switch_8_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_8, switch_8_state, length);
    break;
    case DPID_SWITCH_9:
      switch_9_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_9, switch_9_state, length);
    break;
    case DPID_SWITCH_10:
      switch_10_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_10, switch_10_state, length);
    break;
    case DPID_SWITCH_11:
      switch_11_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_11, switch_11_state, length);
    break;
    case DPID_SWITCH_12:
      switch_12_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_12, switch_12_state, length);
    break;
    case DPID_SWITCH_13:
      switch_13_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_13, switch_13_state, length);
    break;
    case DPID_SWITCH_14:
      switch_14_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_14, switch_14_state, length);
    break;
    case DPID_SWITCH_15:
      switch_15_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_15, switch_15_state, length);
    break;
    case DPID_SWITCH_16:
      switch_16_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_16, switch_16_state, length);
    break;
    case DPID_SWITCH_17:
      switch_17_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_17, switch_17_state, length);
    break;
    case DPID_SWITCH_18:
      switch_18_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_18, switch_18_state, length);
    break;
    case DPID_SWITCH_19:
      switch_19_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_19, switch_19_state, length);
    break;
    case DPID_SWITCH_20:
      switch_20_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_20, switch_20_state, length);
    break;
    case DPID_SWITCH_21:
      switch_21_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_21, switch_21_state, length);
    break;
    case DPID_SWITCH_22:
      switch_22_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_22, switch_22_state, length);
    break;
    case DPID_SWITCH_23:
      switch_23_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_23, switch_23_state, length);
    break;
    case DPID_SWITCH_24:
      switch_24_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_24, switch_24_state, length);
    break;
    case DPID_SWITCH_25:
      switch_25_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_25, switch_25_state, length);
    break;
    case DPID_SWITCH_26:
      switch_26_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_26, switch_26_state, length);
    break;
    case DPID_SWITCH_27:
      switch_27_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_27, switch_27_state, length);
    break;
    case DPID_SWITCH_28:
      switch_28_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_28, switch_28_state, length);
    break;
    case DPID_SWITCH_29:
      switch_29_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_29, switch_29_state, length);
    break;
    case DPID_SWITCH_30:
      switch_30_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_30, switch_30_state, length);
    break;
    case DPID_SWITCH_31:
      switch_31_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_31, switch_31_state, length);
    break;
    case DPID_SWITCH_32:
      switch_32_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_32, switch_32_state, length);
    break;
    default:break;
  return TY_SUCCESS;
* @param {*}
* @return {*}
void dp_update_all(void)
  my_device.mcu_dp_update(DPID_SWITCH_1, switch_1_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_2, switch_2_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_3, switch_3_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_4, switch_4_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_5, switch_5_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_6, switch_6_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_7, switch_7_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_8, switch_8_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_9, switch_9_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_10, switch_10_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_11, switch_11_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_12, switch_12_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_13, switch_13_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_14, switch_14_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_15, switch_15_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_16, switch_16_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_17, switch_17_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_18, switch_18_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_19, switch_19_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_20, switch_20_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_21, switch_21_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_22, switch_22_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_23, switch_23_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_24, switch_24_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_25, switch_25_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_26, switch_26_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_27, switch_27_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_28, switch_28_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_29, switch_29_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_30, switch_30_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_31, switch_31_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_32, switch_32_state, 1);
arduino source code download:
.zip   voice-control.ino.zip (Size: 2.31 KB / Downloads: 864)
esp32 board need V1.0.6 verision:
tuya arduino library config file set to "0". because use ESP32's GPIO for BUTTON and LED with Tuya network function, just set as photo:
  Tuya adapter V2 ESP32 I/O pin define
Posted by: admin - 03-19-2024, 01:58 AM - Forum: KC868-ATC / Tuya adapter V2 - No Replies
RS485:
RXD: 32
TXD: 33
Tuya module:
RXD: 22
TXD: 19
Tuya Reset button: 25
Tuya network LED: 26
  ADR - ESP32 AC 220v dimmer arduino demo source code and library
Posted by: admin - 03-19-2024, 01:55 AM - Forum: KC868-AP / ADR - No Replies
#include <myADR.h>    ////RBDdimmer.h /////RBDmcuESP32.h
//Parameters
int zeroCrossPin  = 25;
int acdPin  = 33;
int add_pin = 15;
int dec_pin = 4;
int MIN_POWER  = 0;
int MAX_POWER  = 80;
int POWER_STEP  = 2;
//Variables
int power  = 0;
//Objects
dimmerLamp acd(acdPin,zeroCrossPin);
void setup(){
  //Init Serial USB
  Serial.println(F("Initialize System"));
  acd.begin(NORMAL_MODE, ON);
  acd.setPower(10); // setPower(0-100%);
  Serial.print("lampValue -> ");
  Serial.print(acd.getPower());
  Serial.println("%");
  pinMode(add_pin,INPUT_PULLUP);
  pinMode(dec_pin,INPUT_PULLUP);
void loop(){
  testDimmer();
int value = 0;
void testDimmer(){/* function testDimmer */
  int add = digitalRead(add_pin);
  int dec = digitalRead(dec_pin);
  if(add == LOW) value += 1;
  if(dec == LOW) value -= 1;
  if(value <= MIN_POWER)  value = MIN_POWER;
  else if(value>MAX_POWER) value = MAX_POWER;
  acd.setPower(value);
  delay(100);
////Sweep light power to test dimmer
/*  for(power=MIN_POWER;power<=MAX_POWER;power+=POWER_STEP){
    acd.setPower(power); // setPower(0-100%);
    delay(100);
for(power=MAX_POWER;power>=MIN_POWER;power-=POWER_STEP){
    delay(100);
.zip   tst_dimmer.zip (Size: 744 bytes / Downloads: 936)
AC dimmer arduino library file download:
.zip   ac-dimmer.zip (Size: 5.68 KB / Downloads: 1042)
  ADR ESPHome demo config for home assistant
Posted by: admin - 03-19-2024, 01:49 AM - Forum: KC868-AP / ADR - No Replies
  friendly_name: ADR
  encryption:
    key: "ZWeLIQ6pHBi8F7iz8oU50b5e4pOntKh7crgfrRpT0NQ="
ota:
  password: "0d1fac93b813af333e08eee312020918"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Adr Fallback Hotspot"
    password: "GOSjJDSsz6Z5"
captive_portal:
output:
  - platform: ac_dimmer
    gate_pin: 33
    zero_cross_pin:
      number: 25
      mode:
        input: true
      inverted: no
    min_power: 35%
light:
  - platform: monochromatic
    output: dimmer1
    default_transition_length: 100ms
.txt   ADR_HA_ESP32.txt (Size: 840 bytes / Downloads: 629)
  ADR ESP32 I/O pin define
Posted by: admin - 03-19-2024, 01:46 AM - Forum: KC868-AP / ADR - Replies (2)
DI1: GPIO15
DI2: GPIO4
RS485:
TXD: GPIO27
RXD: GPIO26
Tuya:
TXD: GPIO14
RXD: GPIO13
analog input: GPIO36
zero_cross_pin:  GPIO25
gate_pin: GPIO33
P8 jumper:
R32 short with GND: analog input use for 4-20mA signal
R33 short with GND: analog input use for dc 0-10v signal
Question DC motor controller
Posted by: nickdd - 03-18-2024, 09:52 PM - Forum: KC868-AM - Replies (3)
Would this board be suitable to control a small DC motor (I want to automate the chicken coop door).
Which motor controller would be suitable and can I just connect it to the GPIO pins in the green terminals?
Can I also connect Hall effect sensor to detect open/closed state of the door?
I believe ESP32 has built-in support for hall effect?
sorry, still quite new to electronics/esp32 but therefore I'm looking at this nice board instead of starting from scratch.
Appreciate the advice.
Regards,
Nick
