» Members: 9,817
» Latest member: dawtaylor
» Forum threads: 4,218
» Forum posts: 20,917
There are currently 396 online users.
» 0 Member(s) | 376 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, HeadlessChrome, PetalBot, bot
Last Post: viko
3 hours ago
» Replies: 11
No ethernet communication
5 hours ago
» Replies: 8
N60 Loss of kWh on reset
Forum: N60
Last Post: chuyskywalker
Yesterday, 03:58 AM
» Replies: 12
CT Sensor Direction
Forum: N60
09-03-2026, 12:51 PM
Request for Type B Projec...
Last Post: lemanat
09-03-2026, 08:47 AM
KinCony CO16 ESP32S3 16 C...
Forum: News
09-02-2026, 01:51 AM
08-31-2026, 12:16 AM
08-31-2026, 12:11 AM
08-31-2026, 12:09 AM
08-31-2026, 12:08 AM
Photo Module sim7670C cannot send messages, cannot call, nor receive messages or calls! Ple
Posted by: Tchip - 01-04-2024, 02:14 PM - Forum: Development - Replies (7)
Hi everybody! I'm new to the 7670C sim module and currently I still don't know how to configure it to receive, send messages and calls.
I sent AT commands to it and it responded OK. But when I send messages and calls, it cannot make or receive calls and messages. Look forward to the help. Thank you so much!
  It is possible a hardware modification?
Posted by: tamibandy - 01-04-2024, 10:59 AM - Forum: KC868-A8 - Replies (1)
Is there possibility to do A8 custom board?
Board with nextion HMI connector 5VDC, GND, STX, RTX? Instead of 433 radio control.
Ethernet not needed if WiFi is available and those GPIO pins could be freed up.
  KNX/RS485
Posted by: jeftevag - 01-03-2024, 11:55 PM - Forum: KC868-E16S/E16P - Replies (1)
Do you have a RS485/KNX command list for the relays on the KC868-E16P?
  Power supply for KC868-A8 (DRC-60)
Posted by: baracha - 01-03-2024, 08:57 PM - Forum: KC868-A series and Uair Smart Controller - Replies (3)
I want to use MeanWell DRC-60 with an integrated 12V battery for powering my KC868-A8.
The output voltage supposed to be adjustable (12-15V), but is over 13V at least this is what I see on my multimeter.
Is it safe to use it?
  KC868-M16v2 Ethernet Problem
Posted by: Roni - 01-03-2024, 07:25 AM - Forum: KC868-M16 / M1 / MB / M30 - Replies (1)
Hello ,
I have KC868-M16v2. I try the ethernet connection, but i have a problem
this is my ethernet setting
#include <ETH.h>
#include <WebServer_WT32_ETH01.h>
//#define DEBUG_ETHERNET_WEBSERVER_PORT      Serial
//#define _ETHERNET_WEBSERVER_LOGLEVEL_      3
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN  18
void config_ethernet()
  if(s_enable_ethernet=="1")
    WT32_ETH01_onEvent();
  //bool begin(uint8_t phy_addr=ETH_PHY_ADDR, int power=ETH_PHY_POWER, int mdc=ETH_PHY_MDC, int mdio=ETH_PHY_MDIO,
  //          eth_phy_type_t type=ETH_PHY_TYPE, eth_clock_mode_t clk_mode=ETH_CLK_MODE);
    ETH.begin(ETH_PHY_ADDR, ETH_PHY_POWER, ETH_PHY_MDC, ETH_PHY_MDIO, ETH_PHY_TYPE, ETH_CLK_MODE);
    ETH.begin(ETH_PHY_ADDR, ETH_PHY_POWER);
    status_ethernet();
    //Serial.println("ethernet mac: "+ ETH.macAddress());
    //Serial.println("ethernet ip: "+ ETH.localIP().toString());
This is Error in serial
ETH Connected
ETH Disconnected
ETH Connected
ETH Disconnected
ETH Connected
ETH Disconnected
ETH Connected
ETH Disconnected
ETH Connected
ETH Disconnected
ETH Connected
ETH Disconnected
  Cant make E16P work with apple homekit
Posted by: Nikolas Protopapas - 01-02-2024, 09:25 PM - Forum: KC868-E16S/E16P - Replies (1)
Hello, so have bought an E16P esp32 board, too the file offer from the forum added them to Arduino IDE.
First issue was the <pcf8574.h> had to be in capitals in order to include the library.
Second and current issue am having is, error code: the list is way longer just added the first 2
In file included from C:\Users\nicol\OneDrive\Desktop\RealPushButtons\RealPushButtons.ino:7:
C:\Users\nicol\OneDrive\Desktop\RealPushButtons\DEV_LED.h: In function 'void PCF_WRITE(int, boolean)':
C:\Users\nicol\OneDrive\Desktop\RealPushButtons\DEV_LED.h:59:18: error: cannot convert 'PCF8574' to 'uint8_t' {aka 'unsigned char'}
    digitalWrite(pcfOUT_1, mPin - 1, !value);      //digitalWrite(ex1, (mPin-1), value);
In file included from C:\Users\nicol\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\cores\esp32/esp32-hal.h:83,
                from C:\Users\nicol\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\cores\esp32/Arduino.h:36,
                from C:\Users\nicol\AppData\Local\Temp\arduino\sketches\B825BA561FA7215E1D76DE33C6DE7CC9\sketch\RealPushButtons.ino.cpp:1:
C:\Users\nicol\AppData\Local\Arduino15\packages\esp32\hardware\esp32\2.0.11\cores\esp32/esp32-hal-gpio.h:75:27: note:  initializing argument 1 of 'void digitalWrite(uint8_t, uint8_t)'
void digitalWrite(uint8_t pin, uint8_t val);
.zip   RealPushButtons.zip (Size: 2.49 KB / Downloads: 742)
  Roller shutter in Home Assistant
Posted by: lendy - 01-02-2024, 05:02 PM - Forum: KC868-E16S/E16P - Replies (1)
I would like to ask if it is possible to use KC868-E16P as relay for controlling 8 roller shutters in Home Assistant? How it can be calibrated/configured for up/down positions?
Thank you
  Home assistant 2023 sur CM4 sur ssd disque
Posted by: raaga - 01-02-2024, 11:10 AM - Forum: KinCony Server-Mini / Server-16 Raspberry Pi4 relay module - Replies (1)
Salut
comment utiliser les ports USB pour demarrer home assistant 2023 ?
j'ai un mini serveur kincony Pi cm4 et un disque ssd S3+ 512GO
NB : home assistant est flashé sur le ssd
  Advise me on the simplest
Posted by: Lamri - 01-02-2024, 10:58 AM - Forum: KC868-A16S - Replies (1)
I am a beginner, and I am struggling to configure my 2 kc868-A16S modules. I have managed to configure the home assistant and integrate Tuya on esphome and it works very well.
Unfortunately, I cannot keep the 2 frameworks (home assistant and web page via the IP address). For this, I simply want to keep access to the interface via the IP address so that I can create ifttt and RF scenes, SMS and calls simply and Tuya, but I want voice command either by Alexa or Google Home. Advise me on the simplest, I will buy a module to run Alexa or Google Home to connect with my 2 A16S modules or it is possible to configure Alexa using node red without losing access to the kincony web page via the IP address.
Thank you.
  KC868-Ax - Attivazione NOTIFICHE su TUYA SMART LIFE
Posted by: Pask media_king - 01-02-2024, 10:49 AM - Forum: Customer project example - Replies (5)
Saluti a tutti e auguri.
Sono nuovo del forum e chiedo aiuto per attivare le notifiche della variazione degli ingressi su
 una KC868-A4 con licenza TUYA.
Puoi aiutarmi gentilmente?
Grazie in anticipo a tutti coloro che risponderanno.
