» Members: 10,063
» Latest member: mm88baby
» Forum threads: 4,253
» Forum posts: 21,069
There are currently 37 online users.
» 0 Member(s) | 28 Guest(s)
Amazonbot, Applebot, Crawl, PetalBot, bot
N60/N30/N20/N10 PC softwa...
Forum: N10
Yesterday, 06:15 AM
» Replies: 11
Best way to read from N30
Forum: N30
Yesterday, 12:20 AM
getting the A8A inputs to...
Forum: Development
09-24-2026, 11:07 PM
extend KC868-A16v3
Last Post: bitet96717
09-24-2026, 06:41 AM
Las Firmware ?
09-22-2026, 11:15 PM
» Replies: 8
kc868-a6 analog input
09-21-2026, 11:38 PM
A32 pro tuya
Disconnect loop with Home...
Forum: F16
09-21-2026, 01:16 AM
KC-868-A1 linked Home Ass...
Forum: News
config modbus sensor in K...
09-19-2026, 11:52 AM
Photo 433mhz motion sensor
Posted by: Key0nee - 01-12-2024, 12:14 AM - Forum: KC868-A16 - Replies (3)
    I have a KC868-A16 running KCS firmware v2.2.2 and I am thinking of using it to replace my alarm system control board and use a Home Assistant alarm entity...  integrating the KC868 I/O using MQTT was pretty easy However, I also have a few 433mhz motion sensors I'd like to uses and was wondering if it is possible to integrate the 433Mhz Motion sensor into home assistant via the KC868-A16 board?  The KC868 board instantly learn the motion sensor code when triggered, however I am not sure that the 433Mhz events can be passed on to an MQTT or the 433Mhz receiver is ONLY to control the KC868 board?
any help is greatly appreciated
K
  KC868-A2 and SIM7600
Posted by: cillgen - 01-11-2024, 10:03 PM - Forum: KC868-A2 - Replies (5)
Has anyone managed to get a SIM7600 module to work on the  KC868-A2 device ?
ESP32 TX pins shall be PIN34 but this pin in defined as "input only" in ESP32 documentation.
So software crashes on begin function (error "tx_io_num").
Thanks !
Question H32B Pro via Ethernet - no default values in web interface
Posted by: Floeckchen - 01-11-2024, 05:36 PM - Forum: KC868-HxB series Smart Controller - Replies (14)
Dear KinCony Team,
I am trying to use the H32B Pro relay board with Home Assistant via MQTT. First step of the documentation asks to update the firmware.
For that I am following the instructions in the YouTube Video "how to download KC868-H32B Pro firmware by ethernet":
  1. The H32B Pro board is plugged into a router. I changed the IP range of the router to allow for 192.168.1.200 and assigned that IP to the H32B Pro. I allowed all ports on that IP.
  2. My laptop is connected via Wifi to the same router and got the IP 192.168.1.22 (checked via ipconfig)
  3. I downloaded the "NET REMOTE IAP" (https://www.kincony.com/forum/attachment.php?aid=1717)
  4. I downloaded the firmware file (https://www.kincony.com/forum/attachment.php?aid=287), even though I am not sure that is the correct one for the pro board. (a central list of all latest firmware by product would be cool. Did I just not find it?)
  5. The "try to ping device" works fine. The ping is returned.
  6. I restart the H32B Pro and click "Connect" within the first 5 seconds of repowering the board. But I get the following error message that I do not understand:
When I access the board´s IP via Chrome, I can successfully log on to the "net setting", but it does not show any of the values:
When I log on "relay control" I can switch the software buttons, but the relays and LEDs on the board do not change.
What am I doing wrong? Help would be much appreciated. Thank you. 谢谢
Kind regards
Floeckchen
  Which App is best to use with IOS and Android.
Posted by: VaughnVenter - 01-11-2024, 12:37 PM - Forum: KC868-A4 - Replies (8)
We busy developing a system using the A4 board where we need to display the following on the App:
The same app must be available for IOS and Android.
Scaled value of the Analog inputs. ( Read value )
Digital input state ( Read value )
Relay/ Digital output state  ( Read value )
Internal values used as setpoints to triger the Digital outputs. ( Read & Write value )
Thanks.
Vaughn.
  I connected temperature sensor. But the relay doesn't work
Posted by: harryduck - 01-11-2024, 08:56 AM - Forum: "KCS" v2 firmware system - Replies (9)
Hi
I connected a DS18B20 temperature sensor. and bind with output1.
I configured if temperature higher than 20'c then output 1 goes high, if temperature lower than 19'c then output1 goes low.
But output1 doesn't move. What I have to do in this situation?
  Loxone KC868-A8
Posted by: StuffMan - 01-10-2024, 07:39 AM - Forum: KC868-A8 - Replies (10)
Any special firmware for Loxone integration with the KC868-A8 board?
  No DHCP / IP
Posted by: StuffMan - 01-10-2024, 07:28 AM - Forum: KC868-A8 - Replies (3)
Hello, tried to boot up KC868-A8 board bought from AliExpress (order 8180657026527832). But the board does not recieve an IP from DHCP server. After powering up, I hear relays clicking and LEDS light up. The ethernet port is also blinking.
Tried to connect in two different physical network locations, tried resetting, but nothing works. The board does not get an IP, so I cannot access it. I see the Kincony board in my the client list, but recieves no IP.
Next I tried to put latest firmware on board with ESP32 download tool. But the COM port is not shown, so cannot place new firmware also. I powered on board with original 12v power supply and connected USB C to USB adapter to computer.
Problem with board?
  Tuya_ESP32_Adapter virtual switch arduino source code for alexa and Google home speak
Posted by: admin - 01-10-2024, 06:47 AM - Forum: KC868-ATC / Tuya adapter V2 - Replies (4)
firmware BIN file download with address 0x0:
.zip   voice-control_0x0.zip (Size: 116.47 KB / Downloads: 942)
arduino source code:
#include <Arduino.h>
#include <TuyaWifi.h>
TuyaWifi my_device;
/* Current LED status */
unsigned char led_state = 0;
int key_pin = 27;
/* Data point define */
#define DPID_SWITCH_1   1
#define DPID_SWITCH_2   2
#define DPID_SWITCH_3   3
#define DPID_SWITCH_4   4
#define DPID_SWITCH_5   5
#define DPID_SWITCH_6   6
#define DPID_SWITCH_7   113
#define DPID_SWITCH_8   114
#define DPID_SWITCH_9   115
#define DPID_SWITCH_10  116
#define DPID_SWITCH_11  117
#define DPID_SWITCH_12  118
#define DPID_SWITCH_13  119
#define DPID_SWITCH_14  120
#define DPID_SWITCH_15  121
#define DPID_SWITCH_16  122
#define DPID_SWITCH_17  123
#define DPID_SWITCH_18  124
#define DPID_SWITCH_19  125
#define DPID_SWITCH_20  126
#define DPID_SWITCH_21  127
#define DPID_SWITCH_22  128
#define DPID_SWITCH_23  129
#define DPID_SWITCH_24  130
#define DPID_SWITCH_25  131
#define DPID_SWITCH_26  132
#define DPID_SWITCH_27  133
#define DPID_SWITCH_28  134
#define DPID_SWITCH_29  135
#define DPID_SWITCH_30  136
#define DPID_SWITCH_31  137
#define DPID_SWITCH_32  138
#define LED_WiFi  26
#define LED_User  33
unsigned char switch_1_state = 0;
unsigned char switch_2_state = 0;
unsigned char switch_3_state = 0;
unsigned char switch_4_state = 0;
unsigned char switch_5_state = 0;
unsigned char switch_6_state = 0;
unsigned char switch_7_state = 0;
unsigned char switch_8_state = 0;
unsigned char switch_9_state = 0;
unsigned char switch_10_state = 0;
unsigned char switch_11_state = 0;
unsigned char switch_12_state = 0;
unsigned char switch_13_state = 0;
unsigned char switch_14_state = 0;
unsigned char switch_15_state = 0;
unsigned char switch_16_state = 0;
unsigned char switch_17_state = 0;
unsigned char switch_18_state = 0;
unsigned char switch_19_state = 0;
unsigned char switch_20_state = 0;
unsigned char switch_21_state = 0;
unsigned char switch_22_state = 0;
unsigned char switch_23_state = 0;
unsigned char switch_24_state = 0;
unsigned char switch_25_state = 0;
unsigned char switch_26_state = 0;
unsigned char switch_27_state = 0;
unsigned char switch_28_state = 0;
unsigned char switch_29_state = 0;
unsigned char switch_30_state = 0;
unsigned char switch_31_state = 0;
unsigned char switch_32_state = 0;
*                                     dp type(TuyaDefs.h) : DP_TYPE_RAW, DP_TYPE_BOOL, DP_TYPE_VALUE, DP_TYPE_STRING, DP_TYPE_ENUM, DP_TYPE_BITMAP
unsigned char dp_array[][2] =
  {DPID_SWITCH_1, DP_TYPE_BOOL},{DPID_SWITCH_2, DP_TYPE_BOOL},{DPID_SWITCH_3, DP_TYPE_BOOL},{DPID_SWITCH_4, DP_TYPE_BOOL},{DPID_SWITCH_5, DP_TYPE_BOOL},{DPID_SWITCH_6, DP_TYPE_BOOL},
  {DPID_SWITCH_7, DP_TYPE_BOOL},{DPID_SWITCH_8, DP_TYPE_BOOL},{DPID_SWITCH_9, DP_TYPE_BOOL},{DPID_SWITCH_10, DP_TYPE_BOOL},{DPID_SWITCH_11, DP_TYPE_BOOL},{DPID_SWITCH_12, DP_TYPE_BOOL},
  {DPID_SWITCH_13, DP_TYPE_BOOL},{DPID_SWITCH_14, DP_TYPE_BOOL},{DPID_SWITCH_15, DP_TYPE_BOOL},{DPID_SWITCH_16, DP_TYPE_BOOL},{DPID_SWITCH_17, DP_TYPE_BOOL},{DPID_SWITCH_18, DP_TYPE_BOOL},
  {DPID_SWITCH_19, DP_TYPE_BOOL},{DPID_SWITCH_20, DP_TYPE_BOOL},{DPID_SWITCH_21, DP_TYPE_BOOL},{DPID_SWITCH_22, DP_TYPE_BOOL},{DPID_SWITCH_23, DP_TYPE_BOOL},{DPID_SWITCH_24, DP_TYPE_BOOL},
  {DPID_SWITCH_25, DP_TYPE_BOOL},{DPID_SWITCH_26, DP_TYPE_BOOL},{DPID_SWITCH_27, DP_TYPE_BOOL},{DPID_SWITCH_28, DP_TYPE_BOOL},{DPID_SWITCH_29, DP_TYPE_BOOL},{DPID_SWITCH_30, DP_TYPE_BOOL},
{DPID_SWITCH_31, DP_TYPE_BOOL},{DPID_SWITCH_32, DP_TYPE_BOOL},
unsigned char pid[] = {"tsfqvoyi6pxqxq6o"};
/* last time */
unsigned long last_time = 0;
  // Serial with tuyawifi
  Serial.begin(9600,SERIAL_8N1,14,13);
  pinMode(LED_WiFi, OUTPUT);
  digitalWrite(LED_WiFi, LOW);
  pinMode(LED_User, OUTPUT);
  digitalWrite(LED_User, LOW);
  //Initialize networking keys.
  my_device.init(pid, mcu_ver);
  my_device.set_dp_cmd_total(dp_array, 1);
  last_time = millis();
  my_device.uart_service();
  //Enter the connection network mode when Pin7 is pressed.
    delay(80);
      if (led_state == LOW) {
        led_state = HIGH;
        led_state = LOW;
  delay(10);
* @param {unsigned char} dpid
* @return {unsigned char}
  switch(dpid) {
    case DPID_SWITCH_1:
      switch_1_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      //Status changes should be reported.
      my_device.mcu_dp_update(DPID_SWITCH_1, switch_1_state, length);
    break;
    case DPID_SWITCH_2:
      switch_2_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_2, switch_2_state, length);
    break;
    case DPID_SWITCH_3:
      switch_3_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_3, switch_3_state, length);
    break;
    case DPID_SWITCH_4:
      switch_4_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_4, switch_4_state, length);
    break;
    case DPID_SWITCH_5:
      switch_5_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_5, switch_5_state, length);
    break;
    case DPID_SWITCH_6:
      switch_6_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_6, switch_6_state, length);
    break;
    case DPID_SWITCH_7:
      switch_7_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_7, switch_7_state, length);
    break;
    case DPID_SWITCH_8:
      switch_8_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_8, switch_8_state, length);
    break;
    case DPID_SWITCH_9:
      switch_9_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_9, switch_9_state, length);
    break;
    case DPID_SWITCH_10:
      switch_10_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_10, switch_10_state, length);
    break;
    case DPID_SWITCH_11:
      switch_11_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_11, switch_11_state, length);
    break;
    case DPID_SWITCH_12:
      switch_12_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_12, switch_12_state, length);
    break;
    case DPID_SWITCH_13:
      switch_13_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_13, switch_13_state, length);
    break;
    case DPID_SWITCH_14:
      switch_14_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_14, switch_14_state, length);
    break;
    case DPID_SWITCH_15:
      switch_15_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_15, switch_15_state, length);
    break;
    case DPID_SWITCH_16:
      switch_16_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_16, switch_16_state, length);
    break;
    case DPID_SWITCH_17:
      switch_17_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_17, switch_17_state, length);
    break;
    case DPID_SWITCH_18:
      switch_18_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_18, switch_18_state, length);
    break;
    case DPID_SWITCH_19:
      switch_19_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_19, switch_19_state, length);
    break;
    case DPID_SWITCH_20:
      switch_20_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_20, switch_20_state, length);
    break;
    case DPID_SWITCH_21:
      switch_21_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_21, switch_21_state, length);
    break;
    case DPID_SWITCH_22:
      switch_22_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_22, switch_22_state, length);
    break;
    case DPID_SWITCH_23:
      switch_23_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_23, switch_23_state, length);
    break;
    case DPID_SWITCH_24:
      switch_24_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_24, switch_24_state, length);
    break;
    case DPID_SWITCH_25:
      switch_25_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_25, switch_25_state, length);
    break;
    case DPID_SWITCH_26:
      switch_26_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_26, switch_26_state, length);
    break;
    case DPID_SWITCH_27:
      switch_27_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_27, switch_27_state, length);
    break;
    case DPID_SWITCH_28:
      switch_28_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_28, switch_28_state, length);
    break;
    case DPID_SWITCH_29:
      switch_29_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_29, switch_29_state, length);
    break;
    case DPID_SWITCH_30:
      switch_30_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_30, switch_30_state, length);
    break;
    case DPID_SWITCH_31:
      switch_31_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_31, switch_31_state, length);
    break;
    case DPID_SWITCH_32:
      switch_32_state = my_device.mcu_get_dp_download_data(dpid, value, length); /* Get the value of the down DP command */
      my_device.mcu_dp_update(DPID_SWITCH_32, switch_32_state, length);
    break;
    default:break;
  return TY_SUCCESS;
* @param {*}
* @return {*}
void dp_update_all(void)
  my_device.mcu_dp_update(DPID_SWITCH_1, switch_1_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_2, switch_2_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_3, switch_3_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_4, switch_4_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_5, switch_5_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_6, switch_6_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_7, switch_7_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_8, switch_8_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_9, switch_9_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_10, switch_10_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_11, switch_11_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_12, switch_12_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_13, switch_13_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_14, switch_14_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_15, switch_15_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_16, switch_16_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_17, switch_17_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_18, switch_18_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_19, switch_19_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_20, switch_20_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_21, switch_21_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_22, switch_22_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_23, switch_23_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_24, switch_24_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_25, switch_25_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_26, switch_26_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_27, switch_27_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_28, switch_28_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_29, switch_29_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_30, switch_30_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_31, switch_31_state, 1);
  my_device.mcu_dp_update(DPID_SWITCH_32, switch_32_state, 1);
  Measure AC voltage using analog pins in M16 v1 board
Posted by: homeassistant144 - 01-10-2024, 02:44 AM - Forum: KC868-M16 / M1 / MB / M30 - Replies (1)
I am currently using the M16 board to measure current within my house. I would also like to record real time data for 220v AC voltage using this same board. Is it possible to use the analog pins available on this board to measure 220v AC voltage with the help of esphome?
  Unresponsive KC868-A16
Posted by: gigib - 01-09-2024, 10:43 PM - Forum: KC868-A16 - Replies (17)
Hello
I bought a  KC868-A16 recently but that seems unresponsive.
I can see it sends periodic GARP with ip 192.168.1.200, power and Ethernet leds are on,  but It is not detected by KSC firmare tool through serial/USB or UDP SCAN through the network.
Is there any way to change the Ip? does it have a web interface that can I access to do that?
