» Members: 9,271
» Latest member: quservices
» Forum threads: 4,107
» Forum posts: 20,587
There are currently 91 online users.
» 0 Member(s) | 84 Guest(s)
Amazonbot, Bing, Mediapartners-Google, bot
How to get started
Last Post: Lomagno
1 hour ago
» Replies: 15
ESP32 Smart Controller – ...
6 hours ago
KC868-COLB Tuya Integrati...
Forum: Development
Last Post: namalumfard
Yesterday, 01:42 PM
» Replies: 11
N30 power supply
Forum: N30
06-27-2026, 11:55 PM
Force sensitive sensor wi...
Last Post: Elgatoguiri
06-27-2026, 11:51 AM
G1 powerup issue
Forum: G1
06-27-2026, 06:47 AM
DM16 output not turning o...
Forum: DM16
06-26-2026, 01:11 PM
» Replies: 26
A Project in Saudi Arabia...
Last Post: Maxsys249
06-26-2026, 07:56 AM
KinCony Pi5M32 – Raspberr...
Forum: News
06-25-2026, 10:40 AM
RS485 issue
Forum: B4M
06-25-2026, 02:04 AM
  B32M ESPHome yaml for home assistant without tuya
Posted by: admin - 03-05-2026, 01:32 AM - Forum: B32M - No Replies
  friendly_name: b32m
  board: esp32-s3-devkitc-1
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  interrupt_pin: GPIO43
  reset_pin: GPIO44
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 39
    rx_pin: 38
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
    i2c_id: bus_a
    pcf8575: true
  - id: 'pcf8574_hub_in_out_1'  # for digital input channel 17-24 & output 1-8
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_out_1'  # for output channel 9-24
    i2c_id: bus_a
    pcf8575: true
  - id: 'pcf8574_hub_in_out_2'  # for digital input channel 25--32 & output 25--32
    i2c_id: bus_a
    address: 0x26
    pcf8575: true
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_in_out_1
      pcf8574: pcf8574_hub_in_out_2
##pull-up resistance on PCB
      number: 48
      number: 47
      number: 40
## without resistance on PCB
      number: 13
      inverted: false
      number: 14
      inverted:  false
      number: 21
      inverted:  false
      inverted:  false
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_1
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
  - platform: uart
    uart_id: uart_1
ads1115:
  - address: 0x48
  - platform: ads1115
    multiplexer: 'A0_GND'
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A1_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A2_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A3_GND'
    gain: 6.144
    update_interval: 5s
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "KinCony b32");
download yaml file:
.txt   B32M-HA-without-Tuya.txt (Size: 13.81 KB / Downloads: 155)
  B32M ESPHome yaml for home assistant with tuya
Posted by: admin - 03-05-2026, 01:31 AM - Forum: B32M - No Replies
  friendly_name: b32m
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
external_components:
  - source:
      type: git
      ref: v1.3.1
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  reset_pin: GPIO44
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      after:
        timeout: 10ms
    tx_pin: 39
    rx_pin: 38
  - id: tuya_mcu_uart
    tx_pin: GPIO16
    rx_pin: GPIO17
    baud_rate: 9600
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
    i2c_id: bus_a
    pcf8575: true
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
    i2c_id: bus_a
    pcf8575: true
    i2c_id: bus_a
    address: 0x26
    pcf8575: true
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: zutoqag0cwczmwma
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
      number: 8
  - platform: tuya_wifi_mcu
    dp_id: 111
    bind_binary_sensor_id: b32_input01
    internal: true
      number: 9
    dp_id: 112
    bind_binary_sensor_id: b32_input02
    internal: true
      number: 10
    dp_id: 113
    bind_binary_sensor_id: b32_input03
    internal: true
      number: 11
    dp_id: 114
    bind_binary_sensor_id: b32_input04
    internal: true
      number: 12
    dp_id: 115
    bind_binary_sensor_id: b32_input05
    internal: true
      number: 13
    dp_id: 116
    bind_binary_sensor_id: b32_input06
    internal: true
      number: 14
    dp_id: 117
    bind_binary_sensor_id: b32_input07
    internal: true
      number: 15
    dp_id: 118
    bind_binary_sensor_id: b32_input08
    internal: true
      number: 48
      number: 47
      number: 40
      number: 13
      inverted: false
      number: 14
      inverted:  false
      number: 21
      inverted:  false
      inverted:  false
      number: 8
    dp_id: 1
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "b32_output01"
      number: 9
    dp_id: 2
    internal: true
    bind_switch_id: "b32_output02"
      number: 10
    dp_id: 3
    internal: true
    bind_switch_id: "b32_output03"
      number: 11
    dp_id: 4
    internal: true
    bind_switch_id: "b32_output04"
      number: 12
    dp_id: 5
    internal: true
    bind_switch_id: "b32_output05"
      number: 13
    dp_id: 6
    internal: true
    bind_switch_id: "b32_output06"
      number: 14
    dp_id: 101
    internal: true
    bind_switch_id: "b32_output07"
      number: 15
    dp_id: 102
    internal: true
    bind_switch_id: "b32_output08"
      number: 8
    dp_id: 103
    internal: true
    bind_switch_id: "b32_output09"
      number: 9
    dp_id: 104
    internal: true
    bind_switch_id: "b32_output10"
      number: 10
    dp_id: 105
    internal: true
    bind_switch_id: "b32_output11"
      number: 11
    dp_id: 106
    internal: true
    bind_switch_id: "b32_output12"
      number: 12
    dp_id: 107
    internal: true
    bind_switch_id: "b32_output13"
      number: 13
    dp_id: 108
    internal: true
    bind_switch_id: "b32_output14"
      number: 14
    dp_id: 109
    internal: true
    bind_switch_id: "b32_output15"
      number: 15
    dp_id: 110
    internal: true
    bind_switch_id: "b32_output16"
    dp_id: 126
    internal: true
    bind_switch_id: "b32_output17"
    dp_id: 129
    internal: true
    bind_switch_id: "b32_output18"
    dp_id: 130
    internal: true
    bind_switch_id: "b32_output19"
    dp_id: 131
    internal: true
    bind_switch_id: "b32_output20"
    dp_id: 132
    internal: true
    bind_switch_id: "b32_output21"
    dp_id: 133
    internal: true
    bind_switch_id: "b32_output22"
    dp_id: 134
    internal: true
    bind_switch_id: "b32_output23"
    dp_id: 135
    internal: true
    bind_switch_id: "b32_output24"
      number: 8
    dp_id: 136
    internal: true
    bind_switch_id: "b32_output25"
      number: 9
    dp_id: 137
    internal: true
    bind_switch_id: "b32_output26"
      number: 10
    dp_id: 138
    internal: true
    bind_switch_id: "b32_output27"
      number: 11
    dp_id: 139
    internal: true
    bind_switch_id: "b32_output28"
      number: 12
    dp_id: 140
    internal: true
    bind_switch_id: "b32_output29"
      number: 13
    dp_id: 141
    internal: true
    bind_switch_id: "b32_output30"
      number: 14
    dp_id: 142
    internal: true
    bind_switch_id: "b32_output31"
      number: 15
    dp_id: 143
    internal: true
    bind_switch_id: "b32_output32"
  - platform: uart
    uart_id: uart_1
ads1115:
  - address: 0x48
  - platform: ads1115
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    gain: 6.144
    update_interval: 5s
web_server:
  port: 80
font:
display:
    i2c_id: bus_a
    address: 0x3C
    lambda: |-
download yaml file:
.txt   B32M-HA-with-Tuya.txt (Size: 21.65 KB / Downloads: 133)
  B32M ESP32-S3 IO pins define
Posted by: admin - 03-05-2026, 01:29 AM - Forum: B32M - No Replies
IIC Bus:
SDA:GPIO8
SCL:GPIO18
PCF8575: (input1-16): i2c address:0x22 by B16-core
P8:input1
P9:input2
P10:input3
P11:input4
P12:input5
P13:input6
P14:input7
P15:input8
P0:input9
P1:input10
P2:input11
P3:input12
P4:input13
P5:input14
P6:input15
P7:input16
U4: PCF8575 i2c address:0x25
P0:input17
P1:input18
P2:input19
P3:input20
P4:input21
P5:input22
P6:input23
P7:input24
P8:output9
P9:output10
P10:output11
P11:output12
P12:output13
P13:output14
P14:output15
P15:output16
U2: PCF8575 i2c address:0x24
P0:output17
P1:output18
P2:output19
P3:output20
P4:output21
P5:output22
P6:output23
P7:output24
P8:output25
P9:output26
P10:output27
P11:output28
P12:output29
P13:output30
P14:output31
P15:output32
U65: PCF8575 i2c address:0x26
P0:input25
P1:input26
P2:input27
P3:input28
P4:input29
P5:input30
P6:input31
P7:input32
P8:output1
P9:output2
P10:output3
P11:output4
P12:output5
P13:output6
P14:output7
P15:output8
24C02 EPROM i2c address: 0x50
DS3231 RTC i2c address: 0x68
Analog input (A1: DC 0-5v)
Analog input (A2: DC 0-5v)
Analog input (A3: DC 4-20mA)
Analog input (A4: DC 4-20mA)
GPIO13
GPIO14
GPIO21
free GPIOs (with pull-up resistance on PCB):
GPIO40
GPIO48
GPIO47
GPIO7
Ethernet (W5500) I/O define:
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
reset_pin: GPIO44
RS485:
RXD:GPIO38
TXD:GPIO39
Tuya module:
RXD:GPIO17
TXD:GPIO16
SD Card:
SPI-MOSI:GPIO10
SPI-SCK:GPIO11
SPI-MISO:GPIO12
SPI-CS:GPIO9
  Multiple phase L1,L2,L3
Posted by: tombueng - 03-04-2026, 02:43 PM - Forum: N20 - Replies (7)
do the L1,L2 Input need to correlate to the current measured?
I.e., when attaching L1 to Block 1 and L2 to Block 2,
must i only measure L1 currents on CT #1-10 and L2 on CT #2-20?
Or is the L1,L2 only used for voltage measurement to be able to calculate P=U*I from that?
Or can I mix this? e.g. measaure L1,L2,L3 (e.g. for the oven) with Inputs #1,#2 and #3?
BR
Thomas
  A18v2 MQTT Connected in Config but Shows "Disconnected" on Device Monitor – Not Detec
Posted by: kaobeiker - 03-04-2026, 02:53 AM - Forum: KC868-A16 - Replies (1)
The A18v2 is configured with MQTT, but the device's own monitor shows the MQTT status as disconnected, and Home Assistant does not recognize the device.
  Change in Web Interface?
Posted by: Borg357 - 03-03-2026, 08:13 PM - Forum: Development - Replies (1)
I was wondering about a slight change in the User Interface to your RF Settings screens?
For each IR or RF thats learned, can you place in a field that will let us "nickname" the learned code command?   For example, I might have 100+ IR commands, and I would have to write down what #32 IR is..  But if you let me put in input on this line at number 32.. I could place in "Front room Fan, Turn ON".
This would eliminate me having to create a spreadsheet just to find which one is my command..
Thank you
  N10 port modbus
Posted by: R43 - 03-03-2026, 10:41 AM - Forum: N10 - Replies (13)
There's no way to change the speed and port using Modbus. Please fix this or send me a firmware update with port 4 instead of the default 1. Thank you.
  "KCS" v3.22.0 firmware BIN file download
Posted by: admin - 03-02-2026, 10:56 PM - Forum: "KCS" v3 firmware - No Replies
v3.22.0 improvement:
1: add "import" and "export" function for backup.
2: fixed bug copied IR command can't send out issue.
.zip   KCS_A6V3_V3.22.0.zip (Size: 1.08 MB / Downloads: 166)
.zip   KCS_A2V3_V3.22.0.zip (Size: 1.11 MB / Downloads: 140)
.zip   KCS_A8V3_V3.22.0.zip (Size: 1.13 MB / Downloads: 165)
.zip   KCS_A16V3_V3.22.0.zip (Size: 1.15 MB / Downloads: 170)
.zip   KCS_A32PRO_V3.22.0.zip (Size: 1.11 MB / Downloads: 157)
.zip   KCS_AG8_V3.22.0.zip (Size: 1.09 MB / Downloads: 154)
.zip   KCS_AIO_HYBRID_V3.22.0.zip (Size: 1.32 MB / Downloads: 147)
.zip   KCS_ALR_V3.22.0.zip (Size: 1.08 MB / Downloads: 185)
.zip   KCS_B4_V3.22.0.zip (Size: 1.14 MB / Downloads: 158)
.zip   KCS_B4M_V3.22.0.zip (Size: 1.14 MB / Downloads: 141)
.zip   KCS_B8_V3.22.0.zip (Size: 1.14 MB / Downloads: 156)
.zip   KCS_B8M_V3.22.0.zip (Size: 1.14 MB / Downloads: 137)
.zip   KCS_B16_V3.22.0.zip (Size: 1.14 MB / Downloads: 162)
.zip   KCS_B16M_V3.22.0.zip (Size: 1.14 MB / Downloads: 177)
.zip   KCS_B24_V3.22.0.zip (Size: 1.14 MB / Downloads: 130)
.zip   KCS_B24M_V3.22.0.zip (Size: 1.14 MB / Downloads: 157)
.zip   KCS_B32M_V3.22.0.zip (Size: 1.14 MB / Downloads: 163)
.zip   KCS_DM16_V3.22.0.zip (Size: 1.11 MB / Downloads: 145)
.zip   KCS_F4_V3.22.0.zip (Size: 1.13 MB / Downloads: 164)
.zip   KCS_F8_V3.22.0.zip (Size: 1.13 MB / Downloads: 156)
.zip   KCS_F16_V3.22.0.zip (Size: 1.14 MB / Downloads: 163)
.zip   KCS_F24_V3.22.0.zip (Size: 1.14 MB / Downloads: 168)
.zip   KCS_F32_V3.22.0.zip (Size: 1.14 MB / Downloads: 161)
.zip   KCS_G1_V3.22.0.zip (Size: 1.1 MB / Downloads: 154)
.zip   KCS_KC_TA_V3.22.0.zip (Size: 1.09 MB / Downloads: 158)
.zip   KCS_N10_V3.22.0.zip (Size: 1 MB / Downloads: 147)
.zip   KCS_N20_V3.22.0.zip (Size: 1 MB / Downloads: 147)
.zip   KCS_N30_V3.22.0.zip (Size: 1 MB / Downloads: 176)
.zip   KCS_N60_V3.22.0.zip (Size: 1.02 MB / Downloads: 150)
.zip   KCS_T16M_V3.22.0.zip (Size: 1.09 MB / Downloads: 162)
.zip   KCS_T32M_V3.22.0.zip (Size: 1.11 MB / Downloads: 161)
.zip   KCS_T64M_V3.22.0.zip (Size: 1.11 MB / Downloads: 145)
.zip   KCS_T128M_V3.22.0.zip (Size: 1.11 MB / Downloads: 141)
.zip   KCS_TR_V3.22.0.zip (Size: 1.06 MB / Downloads: 156)
.zip   KCS_Z1_V3.22.0.zip (Size: 1.24 MB / Downloads: 140)
  LED dimmer but not 0-10V but PWM
Posted by: Jan_W - 03-01-2026, 09:26 AM - Forum: Suggestions and feedback on KinCony's products - Replies (3)
Could You consider making ESP32-S3 LED dimmer module but not with 0-10V outputs (like DM16), but MOSFET with PWM Analog Outputs?
0-10V is great, but it makes everything more complicated when I just want to dimm multiple individual LEDs from single DC source - additional multiple dimmable drivers etc.
We have nice product from Polish manufacturer - boneIO ESP DImmer LED gen 2 with 8x PWM outputs. It costs 110$ and is great, I just wanted to have all from Kincony and cannot find anything like this Smile
https://store.boneio.eu/product/boneio-d...8404204e3d
Please consider making product like this. I think it will be very popular on the Polish market (this boneIO is almost always sold out).
Thanks!
  I2c Scan and Sensor Page Help
Posted by: RichCNY - 02-28-2026, 11:36 PM - Forum: "KCS" v3 firmware - Replies (5)
I'm trying to hook up an SHT30 sensor to the I2c connector and from what I'm reading the default address is 0x44 (or 0x45) but I'm not getting an readings on the monitor page when set that way (after I add it in the sensor page). Is there any way to scan the I2c bus within KCS V3 so determine the address for certain ?
Also I assume the sensor address on the sensor page its looking for the last 2 numbers of the address as 0x44 does it save correctly, its wiped out after save, but I can type 44 and save without issues ?
Thanks in advance for any assistance,
Rich
