» Members: 9,332
» Latest member: allpurpo
» Forum threads: 4,117
» Forum posts: 20,635
There are currently 78 online users.
» 0 Member(s) | 61 Guest(s)
Bing, Bytespider, Crawl, PetalBot, Scrapy, Semrush, bot
KC868-A8M reading Etherne...
Forum: KC868-A8M
Last Post: hayat
Yesterday, 01:39 PM
» Replies: 10
KinCony F16 work with Con...
Forum: KinCony integrate with Control4 home automation
Yesterday, 07:34 AM
KinCony Driver File For C...
Yesterday, 07:05 AM
KinCony Gateway User Guid...
Yesterday, 07:03 AM
KinCony Contact Driver Us...
Yesterday, 07:03 AM
KinCony Light Driver User...
Yesterday, 07:02 AM
KinCony Relay Driver User...
Yesterday, 07:02 AM
KC868-H32BS V2.14SP firmw...
Forum: News
Yesterday, 03:59 AM
» Replies: 4
ESP system with BTS7960 I...
Last Post: zali
07-05-2026, 08:52 AM
Firmware for KCS 868 A8 v...
07-05-2026, 01:33 AM
  DM8 ESP32-S3 IO pins define
Posted by: admin - 02-03-2026, 12:23 AM - Forum: DM8 - No Replies
SDA:GPIO8
SCL:GPIO18
PCF8574: (input1-8): i2c address:0x24
P0:input1
P1:input2
P2:input3
P3:input4
P4:input5
P5:input6
P6:input7
P7:input8
Analog input (A1: DC 0-5v)
Analog input (A2: DC 0-5v)
Analog input (A3: DC 4-20mA)
Analog input (A4: DC 4-20mA)
24C02 EPROM i2c address: 0x50
DS3231 RTC i2c address: 0x68
1-wire1:GPIO47
1-wire2:GPIO48
1-wire3:GPIO17
1-wire4:GPIO40
free GPIOs:
GPIO13
GPIO14
GPIO21
Ethernet (W5500) I/O define:
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
interrupt_pin: GPIO43
reset_pin: GPIO44
RS485:
RXD:GPIO38
TXD:GPIO39
Tuya module:
RXD:GPIO15
TXD:GPIO16
SD Card:
SPI-MOSI:GPIO10
SPI-SCK:GPIO11
SPI-MISO:GPIO12
SPI-CS:GPIO9
SD-Detect: GPIO5
ARM CPU TXD:GPIO4
ARM CPU RXD:GPIO6
  [arduino code examples for DM8]-02 Read digital input ports state
Posted by: admin - 02-03-2026, 12:21 AM - Forum: DM8 - No Replies
KeyPressed on PIN1
by Mischianti Renzo <http://www.mischianti.org>
https://www.mischianti.org/2019/01/02/pcf8574-i2c-digital-i-o-expander-fast-easy-usage/
#include "Arduino.h"
#include "PCF8574.h"
// Define I2C pins
#define I2C_SDA 8   // SDA pin
#define I2C_SCL 18  // SCL pin
// Set i2c address
PCF8574 pcf8574(0x24);
unsigned long timeElapsed;
    Wire.begin(I2C_SDA, I2C_SCL);
//    pcf8574.pinMode(P0, OUTPUT);
pcf8574.pinMode(P0, INPUT);
pcf8574.pinMode(P1, INPUT);
pcf8574.pinMode(P2, INPUT);
pcf8574.pinMode(P3, INPUT);
pcf8574.pinMode(P4, INPUT);
pcf8574.pinMode(P5, INPUT);
pcf8574.pinMode(P6, INPUT);
pcf8574.pinMode(P7, INPUT);
    if (pcf8574.begin()){
        Serial.println("OK");
    }else{
        Serial.println("KO");
uint8_t val5 = pcf8574.digitalRead(P4);
uint8_t val6 = pcf8574.digitalRead(P5);
uint8_t val7 = pcf8574.digitalRead(P6);
uint8_t val8 = pcf8574.digitalRead(P7);
    delay(300);
arduino ino file download:
.zip   2-digital-input.zip (Size: 719 bytes / Downloads: 205)
.zip   2-digital-input.ino.merged.zip (Size: 199.51 KB / Downloads: 209)
  [arduino code examples for DM8]-01 8 Channel DAC output by digital input buttons
Posted by: admin - 02-03-2026, 12:19 AM - Forum: DM8 - No Replies
#include <Adafruit_PCF8574.h>
#include <HardwareSerial.h>
// Define Modbus RTU frame format constants
#define MODBUS_READ_COILS 0x01
#define MODBUS_READ_REGISTERS 0x03
#define MODBUS_WRITE_SINGLE_REGISTER 0x06
#define MODBUS_WRITE_MULTIPLE_REGISTERS 0x10
/* Example for 16 input buttons that are connected from the GPIO expander pins to ground.
* Note the buttons must be connected with the other side of the switch to GROUND. There is
* a built in pull-up 'resistor' on each input, but no pull-down resistor capability.
#define DM_NUMS 8
#define SDA_PIN 8
#define SCL_PIN 18
#define ADDRESS_PCF8574     0x24   ////A2 A1 A0 :100 = 0x20+4
#define ST_RX   4 ////ESP32_RCV
#define ST_TX   6 ///ESP32_SEND
typedef enum{KEY_RELEASE=0,KEY_SHORT_PRESSED,KEY_LONG_PRESSED}KEY_STATUS;
typedef struct{
  uint8_t key_index;
  KEY_STATUS key_status;
  long key_time_start;
  long key_time_rec;
  long key_press_time;
  int16_t key_press_cnt; ////Send serial data once every 100 ms
  int16_t key_press_cnt_old;
  float current_light; ///Percentage of 0–4095
}KEY_PRESS_PROP;
KEY_PRESS_PROP key_press_prop[16] = {0};
Adafruit_PCF8574 pcf;
HardwareSerial myst_serial(1);
TwoWire myI2c = TwoWire(0);
ushort dm_num = DM_NUMS;
// Modbus CRC16 Calculation function
uint16_t modbus_crc16(uint8_t *data, uint16_t length) {
  uint16_t crc = 0xFFFF;
  for (uint16_t i = 0; i < length; i++) {
    crc ^= data[i];
    for (uint8_t j = 0; j < 8; j++) {
      if (crc & 0x0001) {
        crc = (crc >> 1) ^ 0xA001;
        crc = crc >> 1;
  return crc;
* Send a Modbus RTU frame
* @param serial HardwareSerial object
* @param address Slave address (1-247)
* @param function function code
* @param data
* @param dataLen
void send_modbus_frame(HardwareSerial &serial, uint8_t address, uint8_t function,
                      const uint8_t *data, uint16_t dataLen) {
  // Create a transmit buffer
  uint16_t totalLen = 1 + 1 + dataLen + 2; // address + function code + data + CRC
  uint8_t buffer[totalLen];
  buffer[0] = address;
  buffer[1] = function;
  memcpy(&buffer[2], data, dataLen);
  uint16_t crc = modbus_crc16(buffer, 2 + dataLen);
  // Add CRC (low byte first)
  buffer[2 + dataLen] = crc & 0xFF;      // CRC low byte
  buffer[3 + dataLen] = (crc >> 8) & 0xFF; // CRC high byte
  // Send the complete frame
  for (uint16_t i = 0; i < totalLen; i++) {
    serial.write(buffer[i]);
  // Flush the transmit buffer to ensure all data is sent
  serial.flush();
// Encapsulate commonly used Modbus functions
* Send a Read Holding Registers request
* @param serial
* @param address
* @param startReg
* @param numRegs
void modbus_read_registers(HardwareSerial &serial, uint8_t address,
                          uint16_t startReg, uint16_t numRegs) {
  uint8_t data[4];
  data[0] = (startReg >> 8) & 0xFF; // High byte of the register address
  data[1] = startReg & 0xFF;        // Low byte of the register address
  data[2] = (numRegs >> 8) & 0xFF;  // High byte of the register count
  data[3] = numRegs & 0xFF;         // Low byte of the register count
  send_modbus_frame(serial, address, MODBUS_READ_REGISTERS, data, sizeof(data));
* @param serial
* @param address
* @param regAddress
* @param value
void modbus_write_single_register(HardwareSerial &serial, uint8_t address,
                                uint16_t regAddress, uint16_t value) {
  uint8_t data[4];
  data[0] = (regAddress >> 8) & 0xFF; // High byte of the register address
  data[1] = regAddress & 0xFF;        // Low byte of the register address
  data[2] = (value >> 8) & 0xFF;      // High byte of the data
  data[3] = value & 0xFF;             // Low byte of the
  send_modbus_frame(serial, address, MODBUS_WRITE_SINGLE_REGISTER, data, sizeof(data));
* @param serial
* @param address
* @param startReg
* @param values
* @param numRegs
void modbus_write_multiple_registers(HardwareSerial &serial, uint8_t address,
                                   uint16_t startReg, const uint16_t *values,
                                   uint16_t numRegs) {
  uint8_t byteCount = numRegs * 2;
  uint8_t data[5 + byteCount];
  data[4] = byteCount;
  for (uint8_t i = 0; i < numRegs; i++) {
    data[5 + i*2] = (values[i] >> 8) & 0xFF;
    data[6 + i*2] = values[i] & 0xFF;
  send_modbus_frame(serial, address, MODBUS_WRITE_MULTIPLE_REGISTERS, data, sizeof(data));
  myI2c.begin(SDA_PIN,SCL_PIN,100000);
  myst_serial.begin(115200,SERIAL_8N1,ST_RX,ST_TX);///RXPIN FIRST
  while (!Serial) { delay(10); }
  Serial.println("Adafruit PCF8574 button read test");
  if (!pcf.begin(ADDRESS_PCF8574, &myI2c)) {
    Serial.println("err:DMxx Couldn't find PCF8574!");
    while (1);
  else Serial.println("Find PCF8574!");
  for (uint8_t p=0; p<DM_NUMS; p++) {
    pcf.pinMode(p, INPUT_PULLUP);
    key_press_prop[p].key_index = p+1;
    key_press_prop[p].key_status = KEY_RELEASE;
    key_press_prop[p].key_press_time = 0;
  Serial.println("Now, starting!");
static uint16_t input_value_old[2] = {0xff,0xff};
uint16_t input_value[2] = {0} ;
int8_t current_operator_key = -1;
int8_t key_index = -1,key_index_last = -1;
int16_t key_press_cnt_old = 0;
uint16_t write_value=0;
static int8_t get_key_press(int8_t chip,uint16_t key_value)
  if(key_value == 0xff || key_value == 0) return -1;
  for(int16_t i=0;i<16;i++)
    if((key_value & (1<<i) ) == 0)  return (chip==0)?i:i+16;
static uint16_t getKeycode()
  uint16_t input_value = 0,tmp_value;
  uint8_t h_value = 0 ,l_value = 0;
  tmp_value = pcf.digitalReadByte();
  //h_value = tmp_value>>8;
// l_value = tmp_value&0xff;
  //input_value = (l_value<<8 ) | h_value;
  input_value = tmp_value;
  return input_value;
static void checkKeyPress(int8_t chip);
static uint16_t key_old_arr[2] = {0};
  input_value[0] = getKeycode();
  if(key_old_arr[0] != input_value[0])
    key_old_arr[0] = input_value[0];
    Serial.printf("input0:%d\r\n",input_value[0]);
  checkKeyPress(0);
  delay(10); // a short debounce delay
  uint8_t start_index = (chip==0)?0:16;
  if(input_value_old[chip] != input_value[chip])
    input_value_old[chip] = input_value[chip];
    if(input_value[chip] == 0xff)
      Serial.printf("key is released!");
      key_index_last = key_index = -1;
      for (uint8_t p=start_index; p<8+start_index; p++) ///all key status init.
        key_press_prop[p].key_time_start = 0;
        key_press_prop[p].key_time_rec = 0;
        key_press_prop[p].key_press_cnt = 0;
        key_press_prop[p].key_press_cnt_old = 0;
    else ///key press
      //Serial.printf("input_value = %04X \r\n",input_value);
      key_index = get_key_press(chip,input_value[chip]);
      if(key_index >= 0)
        key_index_last = key_index;
        Serial.printf("key %02d # is pressed! \r\n",key_index+1);
        current_operator_key = key_index;
        key_press_prop[current_operator_key].key_status = KEY_SHORT_PRESSED;
        key_press_prop[current_operator_key].key_time_start = millis();
        key_press_prop[current_operator_key].key_press_time = 0;
  else
    if(input_value[chip] != 0xff) ///LONG PRESS!
      //Serial.printf("key long pressed! \r\n");
      if(key_index >= 0 && key_index_last == key_index)
        //Serial.printf("key long pressed! key_index = %d\r\n",key_index);
        key_press_prop[current_operator_key].key_status = KEY_LONG_PRESSED;
        key_press_prop[current_operator_key].key_time_rec = millis();
        key_press_prop[current_operator_key].key_press_time = key_press_prop[current_operator_key].key_time_rec - key_press_prop[current_operator_key].key_time_start;
        key_press_prop[current_operator_key].key_press_cnt = (key_press_prop[current_operator_key].key_press_time % 4080 ) / 100; ////100MS发一次
        //Serial.printf("key long time = %d, cnt = %d \r\n",key_press_prop[current_operator_key].key_press_time,key_press_prop[current_operator_key].key_press_cnt);
        if(key_press_prop[current_operator_key].key_press_cnt_old != key_press_prop[current_operator_key].key_press_cnt)
          key_press_prop[current_operator_key].key_press_cnt_old = key_press_prop[current_operator_key].key_press_cnt;
          /////send st_tx information.
          key_press_prop[current_operator_key].current_light = (float)key_press_prop[current_operator_key].key_press_cnt * 100.0f;
          write_value = (uint16_t) key_press_prop[current_operator_key].current_light;
          Serial.printf("key_long_press_time = %d, current_light = %d \r\n",key_press_prop[current_operator_key].key_press_time,write_value);
          modbus_write_multiple_registers(myst_serial,1,4000+current_operator_key,&write_value,1);
.zip   1-dac-8ch.zip (Size: 2.83 KB / Downloads: 175)
.zip   1-dac-8ch.ino.merged.zip (Size: 205.65 KB / Downloads: 196)
  DM4 ESPHome yaml for home assistant without tuya
Posted by: admin - 02-03-2026, 12:17 AM - Forum: DM4 - No Replies
  friendly_name: dm4
  board: esp32-s3-devkitc-1
ota:
  platform: esphome
web_server:
  port: 80
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  reset_pin: GPIO44
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
text_sensor:
  - platform: ethernet_info
    ip_address:
      name: ESP IP Address
      address_0:
        name: ESP IP Address 0
      address_1:
        name: ESP IP Address 1
      address_2:
        name: ESP IP Address 2
      address_3:
        name: ESP IP Address 3
      address_4:
        name: ESP IP Address 4
    dns_address:
      name: ESP DNS Address
    mac_address:
      name: ESP MAC Address
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 38
    rx_pin: 39
  - platform: uart
    uart_id: uart_1
    i2c_id: bus_a
    pcf8575: false
##pull-up resistance on PCB
      number: 48
      number: 47
      number: 40
      number: 17
## without resistance on PCB
      number: 13
      inverted: false
      number: 14
      inverted:  false
      number: 21
      inverted:  false
      inverted:  false
ads1115:
  - address: 0x48
  - platform: ads1115
    multiplexer: 'A0_GND'
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A1_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A2_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A3_GND'
    gain: 6.144
    update_interval: 5s
mcp4728:
  - id: dac_output
output:
- platform: mcp4728
  mcp4728_id: dac_output
  channel: A
  vref: internal
- platform: mcp4728
  channel: B
  vref: internal
- platform: mcp4728
  channel: C
  vref: internal
- platform: mcp4728
  channel: D
  vref: internal
light:
  - platform: monochromatic
    output: ac_dimmer_1
    gamma_correct: 1.0
    output: ac_dimmer_2
    gamma_correct: 1.0
    output: ac_dimmer_3
    gamma_correct: 1.0
    output: ac_dimmer_4
    gamma_correct: 1.0
esphome yaml file download:
.txt   DM4-HA-without Tuya.txt (Size: 4.4 KB / Downloads: 160)
  DM4 ESP32-S3 IO pins define
Posted by: admin - 02-03-2026, 12:15 AM - Forum: DM4 - No Replies
SDA:GPIO8
SCL:GPIO18
PCF8574: (input1-4): i2c address:0x24
P0:input1
P1:input2
P2:input3
P3:input4
MCP4728 DAC i2c address: 0x60
1-wire1:GPIO47
1-wire2:GPIO48
1-wire3:GPIO17
1-wire4:GPIO40
free GPIOs:
GPIO13
GPIO14
GPIO21
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
reset_pin: GPIO44
RS485:
RXD:GPIO38
TXD:GPIO39
Tuya module:
RXD:GPIO15
TXD:GPIO16
SD Card:
SPI-MOSI:GPIO10
SPI-SCK:GPIO11
SPI-MISO:GPIO12
SPI-CS:GPIO9
SD-Detect: GPIO5
  [arduino code examples for DM4]-05 Read free GPIO state
Posted by: admin - 02-03-2026, 12:12 AM - Forum: DM4 - No Replies
* GPIO Status Monitoring
* GPIO Pins Monitored:
* - GPIO 40
* - GPIO 7
* - GPIO 48
* - GPIO 47
* - GPIO 13
* - GPIO 14
* - GPIO 21
* - GPIO 0
* Hardware Requirements:
#define GPIO_PIN_40 40
#define GPIO_PIN_7 7
#define GPIO_PIN_48 48
#define GPIO_PIN_47 47
#define GPIO_PIN_13 13
#define GPIO_PIN_14 14
#define GPIO_PIN_21 21
#define GPIO_PIN_0 0
bool prevState[8] = {false, false, false, false, false, false, false, false};
  pinMode(GPIO_PIN_40, INPUT);
  pinMode(GPIO_PIN_7, INPUT);
  pinMode(GPIO_PIN_48, INPUT);
  pinMode(GPIO_PIN_47, INPUT);
  pinMode(GPIO_PIN_13, INPUT);
  pinMode(GPIO_PIN_14, INPUT);
  pinMode(GPIO_PIN_21, INPUT);
  pinMode(GPIO_PIN_0, INPUT);
  bool currentState[8];
  currentState[0] = digitalRead(GPIO_PIN_40);
  currentState[1] = digitalRead(GPIO_PIN_7);
  currentState[2] = digitalRead(GPIO_PIN_48);
  currentState[3] = digitalRead(GPIO_PIN_47);
  currentState[4] = digitalRead(GPIO_PIN_13);
  currentState[5] = digitalRead(GPIO_PIN_14);
  currentState[6] = digitalRead(GPIO_PIN_21);
  currentState[7] = digitalRead(GPIO_PIN_0);
  for (int i = 0; i < 8; i++) {
      Serial.print("GPIO ");
      Serial.print(i == 0 ? GPIO_PIN_40 :
                   i == 1 ? GPIO_PIN_7 :
                   i == 2 ? GPIO_PIN_48 :
                   i == 3 ? GPIO_PIN_47 :
                   i == 4 ? GPIO_PIN_13 :
                   i == 5 ? GPIO_PIN_14 :
                   i == 6 ? GPIO_PIN_21 : GPIO_PIN_0);
      Serial.print(" changed to ");
      // Update the previous state
.zip   5-free-gpio-state.zip (Size: 1.04 KB / Downloads: 178)
.zip   5-free-gpio-state.ino.merged.zip (Size: 179.57 KB / Downloads: 184)
  [arduino code examples for DM8]-05 Read free GPIO state
Posted by: admin - 02-03-2026, 12:12 AM - Forum: DM8 - No Replies
* - GPIO 40
* - GPIO 7
* - GPIO 48
* - GPIO 47
* - GPIO 13
* - GPIO 14
* - GPIO 21
* - GPIO 0
.zip   5-free-gpio-state.zip (Size: 1.04 KB / Downloads: 198)
.zip   5-free-gpio-state.ino.merged.zip (Size: 179.57 KB / Downloads: 172)
  [arduino code examples for DM4]-02 Read digital input ports state
Posted by: admin - 02-03-2026, 12:09 AM - Forum: DM4 - No Replies
KeyPressed on PIN1
// Define I2C pins
// Set i2c address
    }else{
    delay(300);
.zip   2-digital-input.zip (Size: 667 bytes / Downloads: 175)
.zip   2-digital-input.ino.merged.zip (Size: 199.38 KB / Downloads: 175)
  [arduino code examples for DM4]-01 4 Channel DAC output by digital input buttons
Posted by: admin - 02-03-2026, 12:08 AM - Forum: DM4 - No Replies
// Basic demo for configuring the MCP4728 4-Channel 12-bit I2C DAC
#include <Adafruit_MCP4728.h>
#include <Wire.h>
Adafruit_MCP4728 mcp;
TwoWire MYI2C = TwoWire(0);
void setup(void)
  while (!Serial)
    delay(10); // will pause Zero, Leonardo, etc until serial console opens
  Serial.println("Adafruit MCP4728 test!");
  MYI2C.begin(I2C_SDA, I2C_SCL,100000);
  // Try to initialize!
  if (!mcp.begin(MCP4728_I2CADDR_DEFAULT,&MYI2C)) {
    Serial.println("Failed to find MCP4728 chip");
    while (1) {
      delay(10);
  mcp.setChannelValue(MCP4728_CHANNEL_A, 4095);
  mcp.setChannelValue(MCP4728_CHANNEL_B, 2048);
  mcp.setChannelValue(MCP4728_CHANNEL_C, 1024);
  mcp.setChannelValue(MCP4728_CHANNEL_D, 0);
void loop() { delay(1000); }
.zip   1-dac-4ch.zip (Size: 596 bytes / Downloads: 164)
.zip   1-dac-4ch.ino.merged.zip (Size: 198.77 KB / Downloads: 179)
  connecting sensors
Posted by: skench - 02-02-2026, 11:07 PM - Forum: KC868-A8 - Replies (5)
Good afternoon, can you tell me how to connect a temperature and humidity sensor to the A8 or A16 boards? I have several different sensors
An AM2120 temperature and humidity sensor https://ali.click/klm2yz
There is also a BME280 pressure and temperature sensor. https://ali.click/zmm2ye
And I also bought a DHT22 temperature and humidity sensor. https://ali.click/mom2y9 there's a problem with everyone, with the latest DHT22, I don't understand where to get the 5v from, which vcc pin to connect to to get the 5v? I'm acting on the picture https://www.kincony.com/forum/showthread.php?tid=3194 I tried to connect the AM2120 in different ways, both to the ds18b20 and to other neighboring ports and tried the settings in the sensors tab, as well as different firmware ksc v2, I thought there might be a problem with the firmware, but I also failed.
