» Members: 10,074
» Latest member: ReelsOn
» Forum threads: 4,254
» Forum posts: 21,076
There are currently 348 online users.
» 0 Member(s) | 329 Guest(s)
Applebot, Baidu, Bing, Bytespider, Crawl, Google, PetalBot, Semrush, bot
KC868-A6 Analog inputs
Last Post: Tomas4289
5 hours ago
N60/N30/N20/N10 PC softwa...
Forum: N10
5 hours ago
» Replies: 13
getting the A8A inputs to...
Forum: Development
9 hours ago
Best way to read from N30
Forum: N30
Yesterday, 12:20 AM
extend KC868-A16v3
Last Post: bitet96717
09-24-2026, 06:41 AM
Las Firmware ?
09-22-2026, 11:15 PM
» Replies: 8
kc868-a6 analog input
09-21-2026, 11:38 PM
A32 pro tuya
Disconnect loop with Home...
Forum: F16
09-21-2026, 01:16 AM
KC-868-A1 linked Home Ass...
Forum: News
  m16v2 energy meter - calibration issues
Posted by: PapaC - 04-17-2026, 06:04 PM - Forum: KC868-M16 / M1 / MB / M30 - Replies (13)
Hi, hopefully someone can help where I'm having issues calibrating the m16v2 energy meter in the UK which is on 240v with 1 phase.
Currently I am only focusing on CT_15 which is the Grid, I have a Shelly EM using a 120a1v CT clamp which is on the same line as CT_15.
When attempting to calibrate with 2 resistive loads (not at the same time) it just simply falls out of line when then seeing real world usage after, for example I had turned on a 3000w kettle, the Shelly shown the correct load so I then calibrated the figures as recommended in Kincony code, then I tried a 1500w electric heater but instead of the load being somewhat close to the expected reading, it was instead 1900w.
Additionally, when on normal realworld load where the house has typical appliances on which would bring it to about 300w on the Shelly, the m16 instead reports that its 600w.
I can confirm that I have connected the m16 to the consumer unit as recommended so then it shows what the voltage is, which I can confirm is accurate when compared against the Shelly which reports basically the exact same voltage.
All clamps are 1v, and are shown in order of what they're used for along with the amp:
  • 1 - Shower - 50a
  • 2 - Cooker - 50a
  • 3 - Kithcen Ring - 30a
  • 4 - Dish Washer - 30a
  • 5 - Washing Machine - 20a
  • 6 - Tumble Dryer -  30a
  • 7 - Reserved
  • 8 - Reserved
  • 9 - Fridge - 20a
  • 10 - Reserved
  • 11 - Reserved
  • 12 - Reserved
  • 13 - Reserved
  • 14 - General Ring - 30a
  • 15 - Grid - 100a
  • 16 - Reserved
I've attached code currently being used.
ota:
  - platform: esphome
external_components:
  - source:
      type: git
      url: https://github.com/hzkincony/esphome-zmpt101b
      ref: v2.1.0
  encryption:
    key: "D69bY/GXlmjYkovak6WIhgmbOH8vwyqvMxIHBriYoaY="
# Wifi Configuration
wifi:
  ssid: !secret wifi_ssid
  fast_connect: true
  sda: 4
  scl: 5
cd74hc4067:
  - id: cd74hc4067_1
    pin_s0: 32
    pin_s1: 33
    pin_s2: 13
    pin_s3: 16
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
  - platform: adc
    pin: 34
    update_interval: never
    attenuation: 12db
  - platform: adc
    pin: 36
    attenuation: 12db
  - platform: adc
    pin: 39
    attenuation: 12db
  - platform: zmpt101b
    # name: "m16--AI zmpt 34"
    sensor: adc34
    sensitivity: 538
  - platform: adc
    pin: 35
    attenuation: 12db
  - platform: cd74hc4067
    sensor: adc35
    update_interval: 5s
    sensor: adc35
    update_interval: 5s
    sensor: adc35
    update_interval: 5s
    sensor: adc35
    update_interval: 5s
    sensor: adc35
    update_interval: 5s
    sensor: adc35
    update_interval: 5s
    number: 8
    sensor: adc35
    update_interval: 5s
    number: 13
    sensor: adc35
    update_interval: 5s
    number: 14
    sensor: adc35
    update_interval: 5s
  - platform: ct_clamp
    sensor: ai1
    name: "CT 1 Current"
    update_interval: 5s
    filters:
      # 50a 1v CT clamp on a known 8.5kw shower
      - calibrate_linear:
          - 0 -> 0
          - 1 -> 50
      - lambda: if(x < 0.2) return 0; else return x;
  - platform: template
    name: "CT 1 Power"
    lambda: return id(CT_1_Current).state * id(voltage_1).state;
    device_class: power
    unit_of_measurement: "W"
    update_interval: 5s
    sensor: ai2
    name: "CT 2 Current"
    update_interval: 5s
    filters:
      # 50a 1v CT clamp on a cooker
      - calibrate_linear:
          - 0 -> 0
          - 1 -> 50
      - lambda: if(x < 0.25) return 0; else return x;
    name: "CT 2 Power"
    lambda: return id(CT_2_Current).state * id(voltage_1).state;
    device_class: power
    update_interval: 5s
    sensor: ai3
    name: "CT 3 Current"
    update_interval: 5s
    filters:
      - calibrate_linear:
          - 0 -> 0
          - 8.24 -> 11.68
      - lambda: if(x < 0.05) return 0; else return x;
    name: "CT 3 Power"
    lambda: return id(CT_3_Current).state * id(voltage_1).state;
    device_class: power
    update_interval: 5s
    sensor: ai4
    name: "CT 4 Current"
    update_interval: 5s
    filters:
      # 30a 1v CT clamp - Dish Washer
      - calibrate_linear:
          - 0 -> 0
          - 1 -> 30
      - lambda: if(x < 0.1) return 0; else return x;
    name: "CT 4 Power"
    lambda: return id(CT_4_Current).state * id(voltage_1).state;
    device_class: power
    update_interval: 5s
    sensor: ai5
    name: "CT 5 Current"
    update_interval: 5s
    filters:
      # 20a 1v CT clamp - washing machine
      - calibrate_linear:
          - 0 -> 0
          - 1 -> 20
    name: "CT 5 Power"
    lambda: return id(CT_5_Current).state * id(voltage_1).state;
    device_class: power
    update_interval: 5s
    sensor: ai6
    name: "CT 6 Current"
    update_interval: 5s
    filters:
      # 30a 1v CT clamp - tumble dryer
      - calibrate_linear:
          - 0 -> 0
          - 1 -> 30
    name: "CT 6 Power"
    lambda: return id(CT_6_Current).state * id(voltage_1).state;
    device_class: power
    update_interval: 5s
    sensor: ai9
    name: "CT 9 Current"
    update_interval: 5s
    filters:
      # 20a 1v CT clamp - Fridge
      - calibrate_linear:
          - 0 -> 0
          - 1 -> 20
    name: "CT 9 Power"
    lambda: return id(CT_9_Current).state * id(voltage_1).state;
    device_class: power
    update_interval: 5s
    sensor: ai14
    name: "CT 14 Current"
    update_interval: 5s
    filters:
      # 30a 1v CT clamp - General ring
      - calibrate_linear:
          - 0 -> 0
          - 1 -> 30
    name: "CT 14 Power"
    lambda: return id(CT_14_Current).state * id(voltage_1).state;
    device_class: power
    update_interval: 5s
    sensor: ai15
    name: "CT 15 Current"
    update_interval: 5s
    filters:
      - calibrate_linear:
          method: exact
          datapoints:
            - 0.0 -> 0.0
            - 0.016 -> 1.62
            - 4.85 -> 5.88
            - 8.26 -> 13.58
    name: "CT 15 Power"
    lambda: return id(CT_15_Current).state * id(voltage_1).state;
    device_class: power
    update_interval: 5s
  - platform: total_daily_energy
    name: "CT 15 Total Daily Energy"
    power_id: CT_15_Power
    unit_of_measurement: kWh
    accuracy_decimals: 3
    device_class: energy
    state_class: total_increasing
    filters:
      - multiply: 0.001
time:
  - platform: sntp
  B4 Smart Controller Wiring Examples
Posted by: admin - 04-17-2026, 12:05 PM - Forum: B4 - Replies (5)
  Complete Home Assistant configuration.yaml with yaml anchor for mqtt integration A16
Posted by: korl - 04-16-2026, 09:14 PM - Forum: KC868-A16 - Replies (3)
Hello everyone,
I see many people asking for configuration.yaml for A16, A6..etc.
Every person is spending time, building their own yaml-file.
Could you just provide a complete template for each board (A16, A6), that combines all switches, binary_sensors, ADCs, DACs, Temperature sensors... in one text block, combines as one device (with yaml anchor) ready to copy into Home Assistant configuration.yaml?
I think it would make the boards more attractive, if there is an easier start for integration.
Does anyone want to share their configuration.yaml?
Best wishes
  E8v3 PCB layout CAD file
Posted by: admin - 04-15-2026, 09:35 PM - Forum: Schematic & diagram & Dimensions of KinCony PCB layout CAD file - Replies (2)
.zip   KINCONY-E8V3-V1.1.zip (Size: 12.98 MB / Downloads: 379)
  KC868-A16 rev1.6 firmware
Posted by: maurus44 - 04-15-2026, 06:42 PM - Forum: "KCS" v2 firmware system - Replies (5)
I am using a KC868-A16 board (REV: 1.6) and I would like to confirm which firmware is correct for this device.
I have been flashing firmware using the ESP32 Flash Download Tool (v3.9.2). So far, I have tested the following firmware versions:
  • KCS_A16V3_V3.24.3 → I was not able to access the controller after flashing
  • KCS_KC868_A16_V2.2.4 → I could access the controller, but the input table was incomplete / partially missing
At the moment, I am using:
  • KC868_A16_V1.0.10 → this version works, and I can access the controller
My question is:
Am I using the correct firmware for KC868-A16 REV: 1.6, or is there a newer recommended version that is fully compatible?
Thank you in advance for your help!
  Http protocol
Posted by: Saif Kitany - 04-15-2026, 06:03 AM - Forum: News - Replies (18)
If i want to control relay controller by another relay controller with http protocol (for example: controlling B16 by A32 pro ), what i should write in the URL, what i should enable?
I would like if you give full explanation.
  4 - 20 mA adc not giving correct values
Posted by: upstream - 04-14-2026, 10:06 PM - Forum: KC868-AIO - Replies (3)
I am testing the KC868-AIO 4-20 mA analog input with a Fluke 705 Loop Calibrator, but I am not getting correct values.
Source voltage: 24 VDC
Channel AI-16 (see red wire). Black wire is disconnected.
Power source for signal is the same as the source for the AIO board.
Monitor Configuration:
Custom value1: 32
Custom value2: 180
Signal generated: 4.000 mA
value provided: ~52 (it should be 32)
Signal generated: 8.000 mA
value provided: ~79 (it should be 69)
Signal generated: 12.000 mA
value provided: ~104 (it is close to what it should be at 106)
Signal generated: 16.000 mA
value provided: ~131 (it should be 143)
Signal generated: 20.000 mA
value provided: ~167 (it should be 180)
Pictures:
705 Connection Example
Connections Pic
adc settings
adc output
Any idea what is going on?
  N60 Sensor channel label
Posted by: marekd1 - 04-14-2026, 02:44 PM - Forum: N60 - Replies (18)
Is there a way to assign custom label to each channel defining monitoring node function on local N60.
As far as I know I think you can do this on Kincony Cloud page but I am looking to do this at local N60 node level.  Example Chanel 1  Server, Channel 2 Sump, etc...
If not could this be added in the update firmware release?
thank you!
  B4 Smart Controller ESP32 system block diagram
Posted by: admin - 04-14-2026, 12:52 AM - Forum: B4 - No Replies
  "KCS" v3.24.3 firmware BIN file download
Posted by: admin - 04-13-2026, 03:02 AM - Forum: "KCS" v3 firmware - No Replies
v3.24.3 improvement:
1: add debounce capability to digital input ports.
2: support wiegand protocol for access control panel.
3: add RS485 bridge protocol, support TR RS485 device digital input and sensor feedback for MASTER controller's mqtt message.
4: fixed bug when IF conditon have multi DI.
.zip   KCS_A2V3_V3.24.3.zip (Size: 1.17 MB / Downloads: 354)
.zip   KCS_A6V3_V3.24.3.zip (Size: 1.14 MB / Downloads: 382)
.zip   KCS_A8V3_V3.24.3.zip (Size: 1.2 MB / Downloads: 337)
.zip   KCS_A16V3_V3.24.3.zip (Size: 1.21 MB / Downloads: 424)
.zip   KCS_A32PRO_V3.24.3.zip (Size: 1.18 MB / Downloads: 312)
.zip   KCS_AG8_V3.24.3.zip (Size: 1.16 MB / Downloads: 320)
.zip   KCS_AIO_HYBRID_V3.24.3.zip (Size: 1.39 MB / Downloads: 378)
.zip   KCS_ALR_V3.24.3.zip (Size: 1.15 MB / Downloads: 355)
.zip   KCS_B4_V3.24.3.zip (Size: 1.2 MB / Downloads: 318)
.zip   KCS_B4M_V3.24.3.zip (Size: 1.2 MB / Downloads: 376)
.zip   KCS_B8_V3.24.3.zip (Size: 1.2 MB / Downloads: 358)
.zip   KCS_B8M_V3.24.3.zip (Size: 1.2 MB / Downloads: 361)
.zip   KCS_B16_V3.24.3.zip (Size: 1.2 MB / Downloads: 383)
.zip   KCS_B16M_V3.24.3.zip (Size: 1.2 MB / Downloads: 379)
.zip   KCS_B24_V3.24.3.zip (Size: 1.2 MB / Downloads: 365)
.zip   KCS_B24M_V3.24.3.zip (Size: 1.2 MB / Downloads: 309)
.zip   KCS_B32M_V3.24.3.zip (Size: 1.2 MB / Downloads: 320)
.zip   KCS_DM4_V3.24.3.zip (Size: 1.2 MB / Downloads: 352)
.zip   KCS_DM8_V3.24.3.zip (Size: 1.2 MB / Downloads: 304)
.zip   KCS_DM16_V3.24.3.zip (Size: 1.17 MB / Downloads: 316)
.zip   KCS_DM32_V3.24.3.zip (Size: 1.21 MB / Downloads: 300)
.zip   KCS_F4_V3.24.3.zip (Size: 1.2 MB / Downloads: 312)
.zip   KCS_F8_V3.24.3.zip (Size: 1.2 MB / Downloads: 299)
.zip   KCS_F16_V3.24.3.zip (Size: 1.21 MB / Downloads: 317)
.zip   KCS_F24_V3.24.3.zip (Size: 1.21 MB / Downloads: 366)
.zip   KCS_F32_V3.24.3.zip (Size: 1.21 MB / Downloads: 366)
.zip   KCS_G1_V3.24.3.zip (Size: 1.16 MB / Downloads: 339)
.zip   KCS_KC_TA_V3.24.3.zip (Size: 1.16 MB / Downloads: 339)
.zip   KCS_N10_V3.24.3.zip (Size: 1.07 MB / Downloads: 322)
.zip   KCS_N20_V3.24.3.zip (Size: 1.07 MB / Downloads: 367)
.zip   KCS_N30_V3.24.3.zip (Size: 1.07 MB / Downloads: 326)
.zip   KCS_N60_V3.24.3.zip (Size: 1.08 MB / Downloads: 322)
.zip   KCS_T16M_V3.24.3.zip (Size: 1.15 MB / Downloads: 311)
.zip   KCS_T32M_V3.24.3.zip (Size: 1.17 MB / Downloads: 305)
.zip   KCS_T64M_V3.24.3.zip (Size: 1.17 MB / Downloads: 374)
.zip   KCS_T128M_V3.24.3.zip (Size: 1.17 MB / Downloads: 305)
.zip   KCS_TR_V3.24.3.zip (Size: 1.13 MB / Downloads: 333)
.zip   KCS_Z1_V3.24.3.zip (Size: 1.3 MB / Downloads: 348)
