» Members: 9,561
» Latest member: Energizer
» Forum threads: 4,183
» Forum posts: 20,807
There are currently 16 online users.
» 0 Member(s) | 7 Guest(s)
Amazonbot, Bing, DataForSeoBot, bot
K868-a32 plastic case
Today, 08:48 AM
CT Clamp Compatibility
Yesterday, 10:32 PM
» Replies: 10
KinCony F8 + ESPHome: Una...
Forum: F8
08-08-2026, 11:51 PM
How to get started
08-07-2026, 11:42 PM
» Replies: 39
Questions on the B4M
Forum: B4M
08-07-2026, 11:19 PM
cannot see KC868-A6 in ro...
08-07-2026, 09:59 AM
» Replies: 7
CAN-BUS Transceiver
Forum: T16M
08-07-2026, 09:57 AM
N60 configure yaml for ES...
Forum: N60
Last Post: chuyskywalker
08-06-2026, 07:18 AM
KC868-A16
Last Post: 5310h
08-05-2026, 09:40 PM
» Replies: 9
KC868-A16 UART pins
Last Post: meowdokugame
08-04-2026, 07:40 AM
  replace resistance for COLB switch analog input from 0-5v signal to 4-20mA
Posted by: admin - 03-24-2026, 02:07 AM - Forum: KC868-HxB series Smart Controller - No Replies
For KC868-COLB customization, to change the 16 channels from 0–5V input to 4–20mA input, the following two types of resistors need to be modified:
Replace (R63, R64, R65, R66, R67, R68, R69, R70, R79, R80, R81, R82, R83, R84, R85, R86) 10K resistors with 150R resistors in 1206 package.
Replace (R57, R58, R59, R60, R61, R62, R55, R56, R71, R72, R73, R74, R75, R76, R77, R78) 5.1K resistors with 0 ohm resistors in 0603 package.
  N60 configure yaml for ESPhome 0.001kwh precision
Posted by: admin - 03-23-2026, 01:58 AM - Forum: N60 - No Replies
note: ARM CPU firmware version should >= V20_260305SP
ARM CPU firmware download: https://www.kincony.com/forum/showthread.php?tid=9107
  friendly_name: n60
  board: esp32-s3-devkitc-1
  # baud_rate: 0
ota:
  platform: esphome
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  interrupt_pin: GPIO2
  reset_pin: GPIO1
  rx_pin: 9
  tx_pin: 10
  baud_rate: 115200
  stop_bits: 1
  data_bits: 8
  parity: NONE
web_server:
  port: 80
text_sensor:
  - platform: ethernet_info
    ip_address:
      name: ESP IP Address
    dns_address:
      name: ESP DNS Address
    mac_address:
      name: ESP MAC Address
font:
  - file: "gfonts://Roboto"
  sda: 18
  scl: 17
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
modbus:
  uart_id: uart_modbus
modbus_controller:
  - id: energy_meter
    modbus_id: mb1
    address: 1
    update_interval: 5s
    command_throttle: 200ms
  # Protocol notes for this PR:
  # - current: U_DWORD_R, scaled by 0.001 A
  # - power:   S_DWORD_R, scaled by 0.1 W
  # - energy:  FP32_R, unit kWh
  # - voltage/frequency remain U_WORD * 0.01
  # - temperature remains FP32_R
  - platform: modbus_controller
    modbus_controller_id: energy_meter
    address: 100
    register_type: holding
    unit_of_measurement: A
    device_class: current
    state_class: measurement
    accuracy_decimals: 3
    value_type: U_DWORD_R
    filters:
      - multiply: 0.001
    address: 102
    filters:
      - multiply: 0.001
    address: 104
    filters:
      - multiply: 0.001
    address: 106
    filters:
      - multiply: 0.001
    address: 108
    filters:
      - multiply: 0.001
    address: 110
    filters:
      - multiply: 0.001
    address: 112
    filters:
      - multiply: 0.001
    address: 114
    filters:
      - multiply: 0.001
    address: 116
    filters:
      - multiply: 0.001
    address: 118
    filters:
      - multiply: 0.001
    address: 120
    unit_of_measurement: W
    device_class: power
    accuracy_decimals: 1
    value_type: S_DWORD_R
    filters:
      - multiply: 0.1
    address: 122
    device_class: power
    filters:
      - multiply: 0.1
    address: 124
    device_class: power
    filters:
      - multiply: 0.1
    address: 126
    device_class: power
    filters:
      - multiply: 0.1
    address: 128
    device_class: power
    filters:
      - multiply: 0.1
    address: 130
    device_class: power
    filters:
      - multiply: 0.1
    address: 132
    device_class: power
    filters:
      - multiply: 0.1
    address: 134
    device_class: power
    filters:
      - multiply: 0.1
    address: 136
    device_class: power
    filters:
      - multiply: 0.1
    address: 138
    device_class: power
    filters:
      - multiply: 0.1
    address: 140
    unit_of_measurement: kWh
    device_class: energy
    state_class: total_increasing
    value_type: FP32_R
    address: 142
    value_type: FP32_R
    address: 144
    value_type: FP32_R
    address: 146
    value_type: FP32_R
    address: 148
    value_type: FP32_R
    address: 150
    value_type: FP32_R
    address: 152
    value_type: FP32_R
    address: 154
    value_type: FP32_R
    address: 156
    value_type: FP32_R
    address: 158
    value_type: FP32_R
    address: 160
    value_type: FP32_R
    address: 162
    unit_of_measurement: V
    device_class: voltage
    accuracy_decimals: 2
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 163
    unit_of_measurement: Hz
    device_class: frequency
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 164
    unit_of_measurement: °C
    device_class: temperature
    value_type: FP32_R
    address: 166
    value_type: FP32_R
    address: 200
    filters:
      - multiply: 0.001
    address: 202
    filters:
      - multiply: 0.001
    address: 204
    filters:
      - multiply: 0.001
    address: 206
    filters:
      - multiply: 0.001
    address: 208
    filters:
      - multiply: 0.001
    address: 210
    filters:
      - multiply: 0.001
    address: 212
    filters:
      - multiply: 0.001
    address: 214
    filters:
      - multiply: 0.001
    address: 216
    filters:
      - multiply: 0.001
    address: 218
    filters:
      - multiply: 0.001
    address: 220
    device_class: power
    filters:
      - multiply: 0.1
    address: 222
    device_class: power
    filters:
      - multiply: 0.1
    address: 224
    device_class: power
    filters:
      - multiply: 0.1
    address: 226
    device_class: power
    filters:
      - multiply: 0.1
    address: 228
    device_class: power
    filters:
      - multiply: 0.1
    address: 230
    device_class: power
    filters:
      - multiply: 0.1
    address: 232
    device_class: power
    filters:
      - multiply: 0.1
    address: 234
    device_class: power
    filters:
      - multiply: 0.1
    address: 236
    device_class: power
    filters:
      - multiply: 0.1
    address: 238
    device_class: power
    filters:
      - multiply: 0.1
    address: 240
    value_type: FP32_R
    address: 242
    value_type: FP32_R
    address: 244
    value_type: FP32_R
    address: 246
    value_type: FP32_R
    address: 248
    value_type: FP32_R
    address: 250
    value_type: FP32_R
    address: 252
    value_type: FP32_R
    address: 254
    value_type: FP32_R
    address: 256
    value_type: FP32_R
    address: 258
    value_type: FP32_R
    address: 260
    value_type: FP32_R
    address: 262
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 263
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 264
    value_type: FP32_R
    address: 266
    value_type: FP32_R
    address: 300
    filters:
      - multiply: 0.001
    address: 302
    filters:
      - multiply: 0.001
    address: 304
    filters:
      - multiply: 0.001
    address: 306
    filters:
      - multiply: 0.001
    address: 308
    filters:
      - multiply: 0.001
    address: 310
    filters:
      - multiply: 0.001
    address: 312
    filters:
      - multiply: 0.001
    address: 314
    filters:
      - multiply: 0.001
    address: 316
    filters:
      - multiply: 0.001
    address: 318
    filters:
      - multiply: 0.001
    address: 320
    device_class: power
    filters:
      - multiply: 0.1
    address: 322
    device_class: power
    filters:
      - multiply: 0.1
    address: 324
    device_class: power
    filters:
      - multiply: 0.1
    address: 326
    device_class: power
    filters:
      - multiply: 0.1
    address: 328
    device_class: power
    filters:
      - multiply: 0.1
    address: 330
    device_class: power
    filters:
      - multiply: 0.1
    address: 332
    device_class: power
    filters:
      - multiply: 0.1
    address: 334
    device_class: power
    filters:
      - multiply: 0.1
    address: 336
    device_class: power
    filters:
      - multiply: 0.1
    address: 338
    device_class: power
    filters:
      - multiply: 0.1
    address: 340
    value_type: FP32_R
    address: 342
    value_type: FP32_R
    address: 344
    value_type: FP32_R
    address: 346
    value_type: FP32_R
    address: 348
    value_type: FP32_R
    address: 350
    value_type: FP32_R
    address: 352
    value_type: FP32_R
    address: 354
    value_type: FP32_R
    address: 356
    value_type: FP32_R
    address: 358
    value_type: FP32_R
    address: 360
    value_type: FP32_R
    address: 362
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 363
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 364
    value_type: FP32_R
    address: 366
    value_type: FP32_R
    address: 400
    filters:
      - multiply: 0.001
    address: 402
    filters:
      - multiply: 0.001
    address: 404
    filters:
      - multiply: 0.001
    address: 406
    filters:
      - multiply: 0.001
    address: 408
    filters:
      - multiply: 0.001
    address: 410
    filters:
      - multiply: 0.001
    address: 412
    filters:
      - multiply: 0.001
    address: 414
    filters:
      - multiply: 0.001
    address: 416
    filters:
      - multiply: 0.001
    address: 418
    filters:
      - multiply: 0.001
    address: 420
    device_class: power
    filters:
      - multiply: 0.1
    address: 422
    device_class: power
    filters:
      - multiply: 0.1
    address: 424
    device_class: power
    filters:
      - multiply: 0.1
    address: 426
    device_class: power
    filters:
      - multiply: 0.1
    address: 428
    device_class: power
    filters:
      - multiply: 0.1
    address: 430
    device_class: power
    filters:
      - multiply: 0.1
    address: 432
    device_class: power
    filters:
      - multiply: 0.1
    address: 434
    device_class: power
    filters:
      - multiply: 0.1
    address: 436
    device_class: power
    filters:
      - multiply: 0.1
    address: 438
    device_class: power
    filters:
      - multiply: 0.1
    address: 440
    value_type: FP32_R
    address: 442
    value_type: FP32_R
    address: 444
    value_type: FP32_R
    address: 446
    value_type: FP32_R
    address: 448
    value_type: FP32_R
    address: 450
    value_type: FP32_R
    address: 452
    value_type: FP32_R
    address: 454
    value_type: FP32_R
    address: 456
    value_type: FP32_R
    address: 458
    value_type: FP32_R
    address: 460
    value_type: FP32_R
    address: 462
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 463
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 464
    value_type: FP32_R
    address: 466
    value_type: FP32_R
    address: 500
    filters:
      - multiply: 0.001
    address: 502
    filters:
      - multiply: 0.001
    address: 504
    filters:
      - multiply: 0.001
    address: 506
    filters:
      - multiply: 0.001
    address: 508
    filters:
      - multiply: 0.001
    address: 510
    filters:
      - multiply: 0.001
    address: 512
    filters:
      - multiply: 0.001
    address: 514
    filters:
      - multiply: 0.001
    address: 516
    filters:
      - multiply: 0.001
    address: 518
    filters:
      - multiply: 0.001
    address: 520
    device_class: power
    filters:
      - multiply: 0.1
    address: 522
    device_class: power
    filters:
      - multiply: 0.1
    address: 524
    device_class: power
    filters:
      - multiply: 0.1
    address: 526
    device_class: power
    filters:
      - multiply: 0.1
    address: 528
    device_class: power
    filters:
      - multiply: 0.1
    address: 530
    device_class: power
    filters:
      - multiply: 0.1
    address: 532
    device_class: power
    filters:
      - multiply: 0.1
    address: 534
    device_class: power
    filters:
      - multiply: 0.1
    address: 536
    device_class: power
    filters:
      - multiply: 0.1
    address: 538
    device_class: power
    filters:
      - multiply: 0.1
    address: 540
    value_type: FP32_R
    address: 542
    value_type: FP32_R
    address: 544
    value_type: FP32_R
    address: 546
    value_type: FP32_R
    address: 548
    value_type: FP32_R
    address: 550
    value_type: FP32_R
    address: 552
    value_type: FP32_R
    address: 554
    value_type: FP32_R
    address: 556
    value_type: FP32_R
    address: 558
    value_type: FP32_R
    address: 560
    value_type: FP32_R
    address: 562
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 563
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 564
    value_type: FP32_R
    address: 566
    value_type: FP32_R
    address: 600
    filters:
      - multiply: 0.001
    address: 602
    filters:
      - multiply: 0.001
    address: 604
    filters:
      - multiply: 0.001
    address: 606
    filters:
      - multiply: 0.001
    address: 608
    filters:
      - multiply: 0.001
    address: 610
    filters:
      - multiply: 0.001
    address: 612
    filters:
      - multiply: 0.001
    address: 614
    filters:
      - multiply: 0.001
    address: 616
    filters:
      - multiply: 0.001
    address: 618
    filters:
      - multiply: 0.001
    address: 620
    device_class: power
    filters:
      - multiply: 0.1
    address: 622
    device_class: power
    filters:
      - multiply: 0.1
    address: 624
    device_class: power
    filters:
      - multiply: 0.1
    address: 626
    device_class: power
    filters:
      - multiply: 0.1
    address: 628
    device_class: power
    filters:
      - multiply: 0.1
    address: 630
    device_class: power
    filters:
      - multiply: 0.1
    address: 632
    device_class: power
    filters:
      - multiply: 0.1
    address: 634
    device_class: power
    filters:
      - multiply: 0.1
    address: 636
    device_class: power
    filters:
      - multiply: 0.1
    address: 638
    device_class: power
    filters:
      - multiply: 0.1
    address: 640
    value_type: FP32_R
    address: 642
    value_type: FP32_R
    address: 644
    value_type: FP32_R
    address: 646
    value_type: FP32_R
    address: 648
    value_type: FP32_R
    address: 650
    value_type: FP32_R
    address: 652
    value_type: FP32_R
    address: 654
    value_type: FP32_R
    address: 656
    value_type: FP32_R
    address: 658
    value_type: FP32_R
    address: 660
    value_type: FP32_R
    address: 662
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 663
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 664
    value_type: FP32_R
    address: 666
    value_type: FP32_R
yaml download:
.txt   n60_esphome.txt (Size: 67.27 KB / Downloads: 204)
  N30 configure yaml for ESPhome 0.001kwh precision
Posted by: admin - 03-23-2026, 01:57 AM - Forum: N30 - No Replies
  friendly_name: n30
  # baud_rate: 0
ota:
  platform: esphome
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  reset_pin: GPIO1
  rx_pin: 9
  tx_pin: 10
  baud_rate: 115200
  stop_bits: 1
  data_bits: 8
  parity: NONE
web_server:
  port: 80
text_sensor:
    ip_address:
    dns_address:
    mac_address:
font:
  sda: 18
  scl: 17
display:
    address: 0x3C
    lambda: |-
modbus:
modbus_controller:
  - id: energy_meter
    modbus_id: mb1
    address: 1
    update_interval: 5s
    address: 100
    filters:
      - multiply: 0.001
    address: 102
    filters:
      - multiply: 0.001
    address: 104
    filters:
      - multiply: 0.001
    address: 106
    filters:
      - multiply: 0.001
    address: 108
    filters:
      - multiply: 0.001
    address: 110
    filters:
      - multiply: 0.001
    address: 112
    filters:
      - multiply: 0.001
    address: 114
    filters:
      - multiply: 0.001
    address: 116
    filters:
      - multiply: 0.001
    address: 118
    filters:
      - multiply: 0.001
    address: 120
    device_class: power
    filters:
      - multiply: 0.1
    address: 122
    device_class: power
    filters:
      - multiply: 0.1
    address: 124
    device_class: power
    filters:
      - multiply: 0.1
    address: 126
    device_class: power
    filters:
      - multiply: 0.1
    address: 128
    device_class: power
    filters:
      - multiply: 0.1
    address: 130
    device_class: power
    filters:
      - multiply: 0.1
    address: 132
    device_class: power
    filters:
      - multiply: 0.1
    address: 134
    device_class: power
    filters:
      - multiply: 0.1
    address: 136
    device_class: power
    filters:
      - multiply: 0.1
    address: 138
    device_class: power
    filters:
      - multiply: 0.1
    address: 140
    value_type: FP32_R
    address: 142
    value_type: FP32_R
    address: 144
    value_type: FP32_R
    address: 146
    value_type: FP32_R
    address: 148
    value_type: FP32_R
    address: 150
    value_type: FP32_R
    address: 152
    value_type: FP32_R
    address: 154
    value_type: FP32_R
    address: 156
    value_type: FP32_R
    address: 158
    value_type: FP32_R
    address: 160
    value_type: FP32_R
    address: 162
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 163
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 164
    value_type: FP32_R
    address: 166
    value_type: FP32_R
    address: 200
    filters:
      - multiply: 0.001
    address: 202
    filters:
      - multiply: 0.001
    address: 204
    filters:
      - multiply: 0.001
    address: 206
    filters:
      - multiply: 0.001
    address: 208
    filters:
      - multiply: 0.001
    address: 210
    filters:
      - multiply: 0.001
    address: 212
    filters:
      - multiply: 0.001
    address: 214
    filters:
      - multiply: 0.001
    address: 216
    filters:
      - multiply: 0.001
    address: 218
    filters:
      - multiply: 0.001
    address: 220
    device_class: power
    filters:
      - multiply: 0.1
    address: 222
    device_class: power
    filters:
      - multiply: 0.1
    address: 224
    device_class: power
    filters:
      - multiply: 0.1
    address: 226
    device_class: power
    filters:
      - multiply: 0.1
    address: 228
    device_class: power
    filters:
      - multiply: 0.1
    address: 230
    device_class: power
    filters:
      - multiply: 0.1
    address: 232
    device_class: power
    filters:
      - multiply: 0.1
    address: 234
    device_class: power
    filters:
      - multiply: 0.1
    address: 236
    device_class: power
    filters:
      - multiply: 0.1
    address: 238
    device_class: power
    filters:
      - multiply: 0.1
    address: 240
    value_type: FP32_R
    address: 242
    value_type: FP32_R
    address: 244
    value_type: FP32_R
    address: 246
    value_type: FP32_R
    address: 248
    value_type: FP32_R
    address: 250
    value_type: FP32_R
    address: 252
    value_type: FP32_R
    address: 254
    value_type: FP32_R
    address: 256
    value_type: FP32_R
    address: 258
    value_type: FP32_R
    address: 260
    value_type: FP32_R
    address: 262
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 263
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 264
    value_type: FP32_R
    address: 266
    value_type: FP32_R
    address: 300
    filters:
      - multiply: 0.001
    address: 302
    filters:
      - multiply: 0.001
    address: 304
    filters:
      - multiply: 0.001
    address: 306
    filters:
      - multiply: 0.001
    address: 308
    filters:
      - multiply: 0.001
    address: 310
    filters:
      - multiply: 0.001
    address: 312
    filters:
      - multiply: 0.001
    address: 314
    filters:
      - multiply: 0.001
    address: 316
    filters:
      - multiply: 0.001
    address: 318
    filters:
      - multiply: 0.001
    address: 320
    device_class: power
    filters:
      - multiply: 0.1
    address: 322
    device_class: power
    filters:
      - multiply: 0.1
    address: 324
    device_class: power
    filters:
      - multiply: 0.1
    address: 326
    device_class: power
    filters:
      - multiply: 0.1
    address: 328
    device_class: power
    filters:
      - multiply: 0.1
    address: 330
    device_class: power
    filters:
      - multiply: 0.1
    address: 332
    device_class: power
    filters:
      - multiply: 0.1
    address: 334
    device_class: power
    filters:
      - multiply: 0.1
    address: 336
    device_class: power
    filters:
      - multiply: 0.1
    address: 338
    device_class: power
    filters:
      - multiply: 0.1
    address: 340
    value_type: FP32_R
    address: 342
    value_type: FP32_R
    address: 344
    value_type: FP32_R
    address: 346
    value_type: FP32_R
    address: 348
    value_type: FP32_R
    address: 350
    value_type: FP32_R
    address: 352
    value_type: FP32_R
    address: 354
    value_type: FP32_R
    address: 356
    value_type: FP32_R
    address: 358
    value_type: FP32_R
    address: 360
    value_type: FP32_R
    address: 362
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 363
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 364
    value_type: FP32_R
    address: 366
    value_type: FP32_R
yaml download:
.txt   n30_esphome.txt (Size: 34.27 KB / Downloads: 218)
  N20 configure yaml for ESPhome 0.001kwh precision
Posted by: admin - 03-23-2026, 01:56 AM - Forum: N20 - No Replies
  friendly_name: n20
  # baud_rate: 0
ota:
  platform: esphome
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  reset_pin: GPIO1
  rx_pin: 9
  tx_pin: 10
  baud_rate: 115200
  stop_bits: 1
  data_bits: 8
  parity: NONE
web_server:
  port: 80
text_sensor:
    ip_address:
    dns_address:
    mac_address:
font:
  sda: 18
  scl: 17
display:
    address: 0x3C
    lambda: |-
modbus:
modbus_controller:
  - id: energy_meter
    modbus_id: mb1
    address: 1
    update_interval: 5s
    address: 100
    filters:
      - multiply: 0.001
    address: 102
    filters:
      - multiply: 0.001
    address: 104
    filters:
      - multiply: 0.001
    address: 106
    filters:
      - multiply: 0.001
    address: 108
    filters:
      - multiply: 0.001
    address: 110
    filters:
      - multiply: 0.001
    address: 112
    filters:
      - multiply: 0.001
    address: 114
    filters:
      - multiply: 0.001
    address: 116
    filters:
      - multiply: 0.001
    address: 118
    filters:
      - multiply: 0.001
    address: 120
    device_class: power
    filters:
      - multiply: 0.1
    address: 122
    device_class: power
    filters:
      - multiply: 0.1
    address: 124
    device_class: power
    filters:
      - multiply: 0.1
    address: 126
    device_class: power
    filters:
      - multiply: 0.1
    address: 128
    device_class: power
    filters:
      - multiply: 0.1
    address: 130
    device_class: power
    filters:
      - multiply: 0.1
    address: 132
    device_class: power
    filters:
      - multiply: 0.1
    address: 134
    device_class: power
    filters:
      - multiply: 0.1
    address: 136
    device_class: power
    filters:
      - multiply: 0.1
    address: 138
    device_class: power
    filters:
      - multiply: 0.1
    address: 140
    value_type: FP32_R
    address: 142
    value_type: FP32_R
    address: 144
    value_type: FP32_R
    address: 146
    value_type: FP32_R
    address: 148
    value_type: FP32_R
    address: 150
    value_type: FP32_R
    address: 152
    value_type: FP32_R
    address: 154
    value_type: FP32_R
    address: 156
    value_type: FP32_R
    address: 158
    value_type: FP32_R
    address: 160
    value_type: FP32_R
    address: 162
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 163
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 164
    value_type: FP32_R
    address: 166
    value_type: FP32_R
    address: 200
    filters:
      - multiply: 0.001
    address: 202
    filters:
      - multiply: 0.001
    address: 204
    filters:
      - multiply: 0.001
    address: 206
    filters:
      - multiply: 0.001
    address: 208
    filters:
      - multiply: 0.001
    address: 210
    filters:
      - multiply: 0.001
    address: 212
    filters:
      - multiply: 0.001
    address: 214
    filters:
      - multiply: 0.001
    address: 216
    filters:
      - multiply: 0.001
    address: 218
    filters:
      - multiply: 0.001
    address: 220
    device_class: power
    filters:
      - multiply: 0.1
    address: 222
    device_class: power
    filters:
      - multiply: 0.1
    address: 224
    device_class: power
    filters:
      - multiply: 0.1
    address: 226
    device_class: power
    filters:
      - multiply: 0.1
    address: 228
    device_class: power
    filters:
      - multiply: 0.1
    address: 230
    device_class: power
    filters:
      - multiply: 0.1
    address: 232
    device_class: power
    filters:
      - multiply: 0.1
    address: 234
    device_class: power
    filters:
      - multiply: 0.1
    address: 236
    device_class: power
    filters:
      - multiply: 0.1
    address: 238
    device_class: power
    filters:
      - multiply: 0.1
    address: 240
    value_type: FP32_R
    address: 242
    value_type: FP32_R
    address: 244
    value_type: FP32_R
    address: 246
    value_type: FP32_R
    address: 248
    value_type: FP32_R
    address: 250
    value_type: FP32_R
    address: 252
    value_type: FP32_R
    address: 254
    value_type: FP32_R
    address: 256
    value_type: FP32_R
    address: 258
    value_type: FP32_R
    address: 260
    value_type: FP32_R
    address: 262
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 263
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 264
    value_type: FP32_R
    address: 266
    value_type: FP32_R
yaml download:
.txt   n20_esphome.txt (Size: 23.27 KB / Downloads: 228)
  N10 configure yaml for ESPhome 0.001kwh precision
Posted by: admin - 03-23-2026, 01:54 AM - Forum: N10 - No Replies
  friendly_name: n10
  # baud_rate: 0
ota:
  platform: esphome
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  reset_pin: GPIO1
  rx_pin: 9
  tx_pin: 10
  baud_rate: 115200
  stop_bits: 1
  data_bits: 8
  parity: NONE
web_server:
  port: 80
text_sensor:
    ip_address:
    dns_address:
    mac_address:
font:
  sda: 18
  scl: 17
display:
    address: 0x3C
    lambda: |-
modbus:
modbus_controller:
  - id: energy_meter
    modbus_id: mb1
    address: 1
    update_interval: 5s
    address: 100
    filters:
      - multiply: 0.001
    address: 102
    filters:
      - multiply: 0.001
    address: 104
    filters:
      - multiply: 0.001
    address: 106
    filters:
      - multiply: 0.001
    address: 108
    filters:
      - multiply: 0.001
    address: 110
    filters:
      - multiply: 0.001
    address: 112
    filters:
      - multiply: 0.001
    address: 114
    filters:
      - multiply: 0.001
    address: 116
    filters:
      - multiply: 0.001
    address: 118
    filters:
      - multiply: 0.001
    address: 120
    device_class: power
    filters:
      - multiply: 0.1
    address: 122
    device_class: power
    filters:
      - multiply: 0.1
    address: 124
    device_class: power
    filters:
      - multiply: 0.1
    address: 126
    device_class: power
    filters:
      - multiply: 0.1
    address: 128
    device_class: power
    filters:
      - multiply: 0.1
    address: 130
    device_class: power
    filters:
      - multiply: 0.1
    address: 132
    device_class: power
    filters:
      - multiply: 0.1
    address: 134
    device_class: power
    filters:
      - multiply: 0.1
    address: 136
    device_class: power
    filters:
      - multiply: 0.1
    address: 138
    device_class: power
    filters:
      - multiply: 0.1
    address: 140
    value_type: FP32_R
    address: 142
    value_type: FP32_R
    address: 144
    value_type: FP32_R
    address: 146
    value_type: FP32_R
    address: 148
    value_type: FP32_R
    address: 150
    value_type: FP32_R
    address: 152
    value_type: FP32_R
    address: 154
    value_type: FP32_R
    address: 156
    value_type: FP32_R
    address: 158
    value_type: FP32_R
    address: 160
    value_type: FP32_R
    address: 162
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 163
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 164
    value_type: FP32_R
    address: 166
    value_type: FP32_R
yaml download:
.txt   n10_esphome.txt (Size: 12.27 KB / Downloads: 208)
  Interface T16M E/S et AIO
Posted by: H_spadacini - 03-21-2026, 09:10 AM - Forum: News - Replies (9)
Carte interface:
pour le t16m , le type de carte d'interfaçage pour Sorties et Entrées :
pour :
- les Sorties NPN ou PNP ??
- les Entrées NPN ou PNP ??
ainsi que pour l AIO
Les entrées NPN ou PNP .
Dsl , c'est pas mon domaine..
Cordialement
  KinCony Cloud Functions
Posted by: Mihai845 - 03-21-2026, 08:44 AM - Forum: Suggestions and feedback on KinCony's products - Replies (1)
Good day,
I would like to suggest adding different views option to the KinCony Cloud devices.
It will improve a lot the user experience if we would be able to expand the Device as a list to see the Status of selected inputs/outputs or to be able to view as split screens different devices in a similar way would monitor security cameras for example.
With present view option it's needed to enter each device separately to view or control the outputs, not being able to see what happens with other devices.
In my case I am using 7 x A16v3, split in 3 Electrical Panels, to control the lights and windows stores in one building and would be much better to be able to see all the selected inputs/outputs combined in one page and also to be able to group or sort them in different views.
Thank you
  SHT30 temp/humidity i2c sensor to Kincony B8
Posted by: zbarothi - 03-20-2026, 09:13 AM - Forum: B8 - Replies (6)
I am trying to connect an SHT30 temperature and humidity i1c sensor to a Kincony B8 using free GPIOs 47 and 48. https://shop.kincony.com/products/sht30-...tion-cable
I have ESPHome firmware on the board with this config:
  - id: bus_b
    sda: GPIO47
    scl: GPIO48
    frequency: 100kHz
  - platform: sht3xd
    i2c_id: bus_b
    address: 0x44
    update_interval: 60s
    temperature:
      device_class: "temperature"
      state_class: "measurement"
    humidity:
      device_class: "humidity"
I have tried many variations, switching the SDA and SCL etc but no luck. The device is not detected. Am I using the correct GPIOs?  (see attached photo)
black -> ground
yellow -> 47
blueish green -> 48
red -> 3V
  E16V3 - Dimensions compatibility with domestic electrical enclosures
Posted by: ldebacker - 03-20-2026, 08:34 AM - Forum: Suggestions and feedback on KinCony's products - Replies (3)
The E16V3 can't be nicely integrated in domestic electrical enclosures.
This forces cutting the plastic of the enclosures, which is not nice.
It would be good to have a cover compatible with those standardized enclosures:
- Width equal to a number of standard module (18mm I think)
- Height of the prominent part = 45 mm.
BRs,
Laurent
  E16V3 - Cover electrical insulation
Posted by: ldebacker - 03-20-2026, 08:22 AM - Forum: Suggestions and feedback on KinCony's products - Replies (1)
The cover of the E16V3 seems to be coated metal.
Rigid or semi-rigid wires are screwed on the terminal block , with the risk that the tip of the wire will touch the cover.
Although the coated layer isolates the cover from the wire, this layer is very thin and the wire could scratch the coating so that the cover could quickly be submitted to high voltage.
There should be additional isolation between the terminal block and the cover, such as a plastic strip glued to the cover.
BRs,
Laurent
