» Members: 9,896
» Latest member: jasoncamp
» Forum threads: 4,232
» Forum posts: 20,982
There are currently 126 online users.
» 0 Member(s) | 113 Guest(s)
AhrefsBot, Amazonbot, Baidu, Bing, Google, PetalBot, bot
Pi5R8 Bundle B (CM5 Lite)...
Forum: Pi5R8
Last Post: jasoncamp
36 minutes ago
Modbus 485 extender kcs V...
Forum: N30
2 hours ago
"KCS" v3.27.2 firmware BI...
Yesterday, 02:40 AM
N10 - ESPHome - ARM CPU s...
Forum: N10
09-10-2026, 11:49 PM
extend KC868-A16v3
09-10-2026, 11:48 PM
"KCS" v2.2.21 firmware BI...
09-10-2026, 12:13 PM
KC868-A16 Outputs Y01-Y16...
09-09-2026, 11:15 PM
wish
Forum: KC868-A16v3
09-09-2026, 01:14 PM
Last Post: viko
09-09-2026, 11:39 AM
» Replies: 22
B32M maximum voltage
Last Post: velifetime
09-08-2026, 07:01 AM
Wink if you want to DIY smart home,how to do plan?
Posted by: admin - 10-28-2020, 03:46 AM - Forum: DIY Project - Replies (2)
[b]1. What function do you want?[/b]
[b]A. Light[/b]
[Image: KC868-H32-diagram-light.jpg]
How to Diagram:
  1. KC868-Hx relay controller output series connect with light.
  2. Wall switch panel connect with switch terminal board.Set the switch terminal board work mode for “light”.
  3. Switch terminal board connect with KC868-Hx relay controller by RS232 cable.
  4. Such as you can use any two line button, there have two line, when short , light will be ON, short again, light will be OFF, just repeat. If short K1 two line, turn ON/OFF light1, if short K2 two line, turn ON/OFF light2…. If use a 4 key switch panel, you need connect 4+1=5 line from wall swith panel with switch terminal board. If use a 6 key switch panel, you need connect 7+1=8 line from wall swith panel with switch terminal board. +1 line means “COM” line. So you can use CAT5 network cable for wall switch use, wall switch panel not need power supply.
[b]B. Curtain or blind[/b]
[Image: KC868-H32-diagram-motor.jpg]
How to Diagram:
  1. KC868-Hx relay controller output connect with curtain or blind motor. The motor should be work with AC220V. Every curtain motor need two relay output port used. Such as curtain1 use relay1 and relay2, curtain2 use relay3 and relay4…..
  2. Wall switch panel connect with switch terminal board.Set the switch terminal board work mode for “curtain”.
  4. You can define one button for curtain “UP”, another button for curtain “DOWN”
[b]C. Garage[/b]
[b]D. Air conditioner[/b]
[b]E. TV, DVD,STB and other multimedia equipment[/b]
[b]F. Power socket[/b]
[b]G. Fountain water flow[/b]
[b]H. Swimming pool[/b]
[b]I. Water pump[/b]
[b]J. high-power device (like water heater, air conditioner)[/b]
[b]K. CCTV IPCameras[/b]
[b]L. Security sensor[/b]
[b]2. Which products to chose?[/b]
https://www.kincony.com/how-to-diy-your-smart-home.html
  KC868-H32B V3.1 new firmware released
Posted by: admin - 10-28-2020, 01:30 AM - Forum: News - Replies (1)
improvement:
1. Integration WiFi network and Ethernet network setting in one webpage,easy to set.
2. automatically switch the Ethernet / WiFi line to keep the communication with the cloud server smooth.
3. add Ethernet TCP Server and TCP Client work mode auto connect function when disconnected.
If you want to update your firmware of KC868-H32B, you can leave Email, we will send firmware file.
  NodeRed Disconnected Randomly
Posted by: subas - 10-27-2020, 01:45 PM - Forum: Development - Replies (2)
Dear Support.
Is the away to ensure that NodeRed is running at all time?
Is there any changes i need to make on my laptop that will re-connect the NodeRed when it disconnect?
This is because once NodeRed stops the nodes are not able to update the IOS devices until the NodeRed is up and running again?
I have created a task schedule to automatically run NodeRed when the laptops starts but I notice once NodeRed disconnect it does not want to reconnect until i go into the schedule and re-run the task.
Will it be more stable if  I use Raspberry Pi?
  Unable to Turn "Off" or "ON" via KC868 CON and 32 Relay board Controller via RS232
Posted by: subas - 10-27-2020, 12:30 PM - Forum: Development - Replies (11)
Dear Sir.
I need some help.
The videos shown on all the YouTube are connected directly to either Relay Board Controller Hx or Directly to The KC868 CON.
I have connected the H32 Relay Controller via a RS232 to the KC868 CON. When I use your Application as per below screenshot and click the Relay it works well as it turns on the relay at the Relay Board H32.
But when I use NodeRed and connect it and follow your video on how to control a switch to switch on a light or off it does not work. I have set the NodeRed based on the YouTube video. When I press the button on the iPhone I can see that on the debug message shows  payload "On" or "Of" are sent and I have placed the debug after the "Function" node to see if the payloads get to the TCP OUT node.
Based on the Debug after the "Function" node, there are payloads coming but it does not turn the Relay "On" or "Off" via the KC868 CON to the 32 Relay Controller Board via RS232.
The difference is I have a KC868 Controller connected to the 32 relay board via a RS232 cable compared to your video where you only have the RedNode connected to the 32 Relay Controller Board.
Please advise why I cannot connect to the 32 Relay Controller via the KC868 CON controlling from RedNode?
Regards
Subas
  NodeRed for Android Phone
Posted by: subas - 10-27-2020, 09:05 AM - Forum: Development - Replies (2)
Dear All.
If i wanted to create a Node based on IOS I need to load "node-red contrib-homekit" and this is meant for IOS devices.
What do I need to load if I want to use Android phone to control a switch or read a sensor using NodeRed?
Thank You
  if you want to use our hardware control by your software
Posted by: admin - 10-27-2020, 07:17 AM - Forum: Development - No Replies
if you are a engineer or want to developing to control our controller hardware by your software, we open protocol and have demo source code:
  1. KC868-Hx controller’s protocol :
    https://www.kincony.com/smart-controller-development-protocol.html
  2. C++ development tool demo source code for PC :
    https://www.kincony.com/tcp-server-client-debugger.html
  3. Android phone app demo source code :
    https://github.com/hzkincony/KBOX-Smart-Home-Android-App-LAN-Not-Need-Internet
  4. iOS iPhone app demo source code :
    https://github.com/hzkincony/KBOX-Smart-Home-iOS-App-LAN-Not-Need-Internet
  5. Many others demo source code (such as Visual Basic,Delphi…) on KinCony’s Github:
  Home Automation 32 Channel Distribution Board DIY
Posted by: admin - 10-27-2020, 07:13 AM - Forum: DIY Project - Replies (5)
Here is the Smart Home Tech Tour for 32 Channel Distribution Board DIY used by KC868-H32B Smart Controller.
  KC868-H32B smart controller FAQ
Posted by: admin - 10-27-2020, 07:11 AM - Forum: KC868-HxB series Smart Controller - Replies (5)
1. What types of device control by KC868-H32B?
2. How many output channel for KC868-H32B?
It supports 32 channel output. If need more output channel ,just add KC868-H32B controller.
3. How many input channel for KC868-H32B?
It supports 6 channel input. If need more output channel ,just add KC868-H32B controller.
4. What kind of relay is used in KC868-H32B?
277VAC/10A relay.
5. Which control ways does KC868-H32B support?
6. What are the network access modes of KC868-H32B?
7. If there is no Internet, can we use KC868-H32B?
8. How can KC868-H32B be used in both local LAN and Internet WAN?
KC868-H32B adopts dual core network communication module. Ethernet and WiFi can be configured to work in different network environment modes at the same time.One is work in local network , another is work for remote connect with cloud server.
9. How to ensure the reliability of KC868-H32B network?
For example, both Ethernet and WiFi are set to Internet UDP mode to connect to the cloud server. When the cable network is disconnected or WiFi is disconnected, KC868-H32B will automatically switch the Ethernet / WiFi line to keep the communication with the cloud server smooth.
10. If house power failure, will relay output state of KC868-H32B be automatically restored?
KC868-H32B will automatically restore the relay state before power failure. For example: before the power failure, 1-3 lights are ON; when power on again, the 1-3 lights will be turned ON automatically.
11. If there is power failure at home and power supply is restored, do you need to restart KC868-H32B?
Without restart, KC868-H32B will automatically work without manually reboot.
12. How to use multiple KC868-H32B?
Multiple KC868-H32B only need to be connected to the router for network. Multiple KC868-H32B can be added to one mobile app account.
13. Can multiple people use KC868-H32B at the same time?
The administrator can authorize multiple people to use one or more KC868-H32B.
14. Does KC868-H32B support developers in software for development?
KC868-H32B open protocol, support use your own software to control relay and read state and provide demo source code.
15. Does KC868-H32B support Raspberry Pi and Ardiuno?
16. Does KC868-H32B support third-party open source smart home platforms such as Node-Red and Home Assistant?
Smile KC868-COL have integrate to home assistant successfully
Posted by: admin - 10-27-2020, 06:57 AM - Forum: News - Replies (20)
we have make the Node-Red nodes and flows with home assistant, now all input sensor can be used in home assistant.
[Image: ha-col.jpg]
