» Members: 9,839
» Latest member: hubetpub
» Forum threads: 4,223
» Forum posts: 20,949
There are currently 385 online users.
» 0 Member(s) | 363 Guest(s)
Amazonbot, Applebot, AwarioBot, Baidu, Bing, Crawl, Facebook, Google, PetalBot, Twitter, bot, facebookexternalhit
8 minutes ago
» Replies: 20
wish
Forum: KC868-A16v3
Last Post: R43
8 hours ago
OLED not found in I2C sca...
Forum: KC868-A6v3
Today, 02:55 AM
"KCS" v3.27 firmware BIN ...
Today, 02:51 AM
ESPHome modbus not functi...
Forum: KC868-A8S
Yesterday, 11:49 PM
KC868-H32B
Yesterday, 10:25 AM
KC868-HA PC software V1.0...
Forum: KC868-HA /HA v2
Yesterday, 08:12 AM
» Replies: 19
Kc868ia
Forum: KC868-AI
Yesterday, 01:26 AM
HAv2 ESPHome
Yesterday, 01:24 AM
Need Help Getting Started...
Yesterday, 01:20 AM
  rpiboot_setup.exe for CM5 USB driver
Posted by: admin - 09-05-2025, 05:22 AM - Forum: Pi5R8 - No Replies
rpiboot_setup.exe for CM5 lite USB driver.
.zip   rpiboot_setup.zip (Size: 32.75 MB / Downloads: 637)
Posted by: admin - 09-05-2025, 05:22 AM - Forum: Pi5M8 - No Replies
.zip   rpiboot_setup.zip (Size: 32.75 MB / Downloads: 594)
Posted by: admin - 09-05-2025, 05:22 AM - Forum: Pi5M16 - No Replies
Posted by: admin - 09-05-2025, 05:22 AM - Forum: Pi5R32 - No Replies
.zip   rpiboot_setup.zip (Size: 32.75 MB / Downloads: 621)
Posted by: admin - 09-05-2025, 05:22 AM - Forum: Pi5M32 - No Replies
.zip   rpiboot_setup.zip (Size: 32.75 MB / Downloads: 619)
  Reset line via GPIO output to 24v Flow meter.
Posted by: Onepointbrewing - 09-05-2025, 01:59 AM - Forum: F16 - Replies (1)
Could you please post a picture of the cct for the GPIOs 13 14 and 40 pls. I will be configuring one of these as an output.
I want to interface it to a 24v Flow meter that has a reset line when pulled low.
Thank you
  DEBUG by JTAG
Posted by: maddoc - 09-04-2025, 10:30 PM - Forum: KC868-A6 - Replies (1)
Hello. can you tell me how I can connect the esprog debugger(jtag) to this board?  I have a problem with pin io15 (TDO), which is powered by 3v all the time, and it seems to me that this is interfering with debugging. Of course, I can cut the track for debugging time. But as a novice developer, I am tormented by the question: How did you debug on this board via JTAG? I don't want to use printf() Smile
If this information is not for general use, then please reply by email or in private messages.
[Image: image.png]
  Technical Consultation - Kincony Controller Selection
Posted by: Jan_W - 09-04-2025, 09:16 PM - Forum: DIY Project - Replies (5)
I am seeking technical advice and consultation on determining which specific Kincony controllers and how many units would be required for my smart home project.
Controllers should be based on ESP32 platform and preferably support the newer Kincony KCS v3 firmware version.
I am looking for a complete system solution to meet my requirements.
PROJECT SPECIFICATIONS:
INPUTS:
- 67× lighting control inputs (momentary/impulse switches)
- 12× shutter control inputs (up + down commands)
- 14× window/door contact sensors
- 10× digital sensor inputs (human presence sensor, valves, etc.)
- 14× temperature sensor inputs (analog, including 4× temperature+humidity sensors, max distance is ~20m; planned DS18B20/DHT22 but the wiring is star-shaped, so can it be done with 1-wire?)
OUTPUTS:
- 34× lighting outputs (AC 230V)
- 10× LED lighting outputs (DC 24V white + dimmers)
- 12× shutter motor outputs
- 12× floor heating electrovalve control outputs
Thank you in advance for your time and expertise.
  Stepper Motor
Posted by: Cityslicker - 09-04-2025, 03:54 PM - Forum: Development - Replies (2)
I have a Kincony KC868 A16 board and want to control a stepper motor with variable speed.
I have connected the board up to the stepper motor driver, software works with another ESP32 board.
But I do not get a pulses out of the GPIO pins.
Do I need to set any other parameters to get the pulses out of the GPIO pins ?
  KC868-A16 integrates Home Assistant via MQTT?
Posted by: annasmith - 09-04-2025, 03:52 AM - Forum: KC868-A series and Uair Smart Controller - Replies (1)
I am using KC868-A16 to control the lighting system and sensors in my house. I see in the documentation that there are instructions on MQTT, but I am not sure if any special configuration (such as firmware adjustment or setting up a separate broker) is required to integrate stably with Home Assistant. In addition, has anyone tested latency or disconnection issues when using MQTT with the KC868-A series?
I hope everyone can share their experiences.
