» Members: 9,549
» Latest member: s8vntooday
» Forum threads: 4,183
» Forum posts: 20,805
There are currently 46 online users.
» 0 Member(s) | 35 Guest(s)
Amazonbot, Applebot, Baidu, Bing, Google, PetalBot, bot
CT Clamp Compatibility
3 hours ago
» Replies: 10
KinCony F8 + ESPHome: Una...
Forum: F8
08-08-2026, 11:51 PM
How to get started
08-07-2026, 11:42 PM
» Replies: 39
Questions on the B4M
Forum: B4M
08-07-2026, 11:19 PM
cannot see KC868-A6 in ro...
08-07-2026, 09:59 AM
» Replies: 7
CAN-BUS Transceiver
Forum: T16M
08-07-2026, 09:57 AM
N60 configure yaml for ES...
Forum: N60
Last Post: chuyskywalker
08-06-2026, 07:18 AM
KC868-A16
Last Post: 5310h
08-05-2026, 09:40 PM
» Replies: 9
KC868-A16 UART pins
Last Post: meowdokugame
08-04-2026, 07:40 AM
KC868-A32 Malfunction Aft...
Forum: KC868-A32/A32 Pro
08-04-2026, 06:19 AM
  T16M Output after reset
Posted by: Steen - 09-12-2025, 01:15 PM - Forum: T16M - Replies (8)
Just received myT16M in the mail this morning and I'm performing some test.
I installed the KCS 3.12 firmware and the servers webgui etc came up as expected.
Under the tab System there is this option: "Keep Output After Restart"
With this enabled I expected the outputs to com up in the last known state before restart or powertoggle, but all outputs comes up in a off state
Br Steen from Denmark
  Suitable Hardware Selection for Automating a 10 000 sqr feet greenhouse
Posted by: nikhuge - 09-12-2025, 07:58 AM - Forum: DIY Project - Replies (4)
I am expecting to automate Climate Controlling,Irrigation,Fertigation,Shading in my Greenhouse of 10 000 square feet using kincony Hardwares and Home assistant.Can any one Suggest me What kind of Selections of Kincony Controllers I can use for above Project.(all the crops are grow in grow bags).I have a 20 000. Sqare feet greenhouse too.If this is success I am going to automate that one too.
  Operating WLAN and Ethernet together
Posted by: JuDie07 - 09-10-2025, 07:53 AM - Forum: Getting Started with ESPHome and Home Assistant - Replies (2)
Confused  When I enter WLAN and Ethernet together in ESPHome, I get the following error message:
Can you please provide a code example?
  Getting started with KC-868AG Pro for blinds control with ESPHome/Home Assistant
Posted by: Parallax Abstraction - 09-09-2025, 10:54 PM - Forum: KC868-AG / AG Pro / AG8 / Z1 - Replies (15)
Hey everyone.
First off, a lot of what I'm asking will be novice questions here, but I'm a quick learner.
I have a set of automated blinds that are controlled with a remote on 433.92Mhz. I purchased a KC-868AG Pro in order to be able to automate them using Home Assistant. I did check out some material on the device before I bought it, but it seems a lot of it assumed some basic setup had been done before hand and I'm struggling with that. I am a technical person and work in IT, but haven't done much with these kinds of devices. Clear documentation and firmware is not easy to find on KinCony's web site and after spending quite some time, I'm not sure I'm going down the right path.
I have downloaded and installed the CH431SER driver on Windows 11 and the device does get detected when plugged in with USB. From what I understand, the next step is to install the ESPHome firmware for this device. However, I cannot find it. Every page about firmware on this forum I can find doesn't list one for this model and I can't find anything for it on the main web site. As I understand it, I can't join the device to my wi-fi or start programming it without this, so I'm hoping someone can point me in the right direction. In addition, is USB power all this device needs for what I want to do or will I need a separate power adapter? Since it powers on and it reachable over USB alone, I'm assuming that's all I need for my use case but again, it's unclear. I understand that I also need a default YAML file for ESPHome for Home Assistant to recognize the device. Is this the case and if so, is there somewhere I can grab that as well?
Once I get the basics done, I think I can figure things out from there. I'm just at a loss on these beginning steps.
Thanks for your help, I appreciate it!
Sad Where are the pins led out?
Posted by: JuDie07 - 09-09-2025, 11:50 AM - Forum: KC868-A series and Uair Smart Controller - Replies (5)
PHP Code:
The Board KC868-A8v3
Hello
in the example->  A8v3-HA.txt (Size8.41 KB Downloads152
the following code can be seen:
code]## without resistance on PCB
  platformgpio
    name
"a8v3-5"
    pin
      number5
      inverted
:  false
platformgpio
    name
"a8v3-0"
    pin
      number0
      inverted
:  false[/code]
Question where are the two pins (gpio 0 and 5led out
  [arduino code examples for DM16]-10 Print TEXT on SSD1306 OLED displayer
Posted by: admin - 09-09-2025, 03:36 AM - Forum: DM16 - No Replies
* - SCL (clock) on pin IO18
* - SDA (data) on pin IO8
// Initialize the display using the software I2C method (SCL = IO39, SDA = IO38)
void page1() {
  u8g2.begin();
  do {
    page1();
arduino ino file download:
.zip   10-oled-ssd1306.zip (Size: 1.12 KB / Downloads: 512)
.zip   10-oled-ssd1306.ino.merged.zip (Size: 201.24 KB / Downloads: 510)
  [arduino code examples for DM4]-10 Print TEXT on SSD1306 OLED displayer
Posted by: admin - 09-09-2025, 03:36 AM - Forum: DM4 - No Replies
void page1() {
  u8g2.begin();
  do {
    page1();
.zip   10-oled-ssd1306.zip (Size: 1.12 KB / Downloads: 502)
  [arduino code examples for DM8]-10 Print TEXT on SSD1306 OLED displayer
Posted by: admin - 09-09-2025, 03:36 AM - Forum: DM8 - No Replies
void page1() {
  u8g2.begin();
  do {
    page1();
.zip   10-oled-ssd1306.zip (Size: 1.12 KB / Downloads: 488)
.zip   10-oled-ssd1306.ino.merged.zip (Size: 201.24 KB / Downloads: 506)
  [arduino code examples for DM32]-10 Print TEXT on SSD1306 OLED displayer
Posted by: admin - 09-09-2025, 03:36 AM - Forum: DM32 - No Replies
void page1() {
  u8g2.begin();
  do {
    page1();
.zip   10-oled-ssd1306.zip (Size: 1.12 KB / Downloads: 524)
.zip   10-oled-ssd1306.ino.merged.zip (Size: 201.24 KB / Downloads: 503)
  [arduino code examples for DM16]-09 how to communication with Tuya WiFi module
Posted by: admin - 09-09-2025, 03:34 AM - Forum: DM16 - No Replies
* Functionality:
#include <HardwareSerial.h>
HardwareSerial tuyaSerial(1);
#define TXD_PIN 16
#define RXD_PIN 17
#define BAUD_RATE 9600
  if (tuyaSerial.available()) {
      if (bytesRead < 7) {
          if (bytesRead >= 7) break;
        return;
        Serial.print(" ");
      Serial.println();
        Serial.print(" ");
      Serial.println();
  // Delay to avoid CPU overuse
  delay(100);
    switch(packet[2]) {
      case 0x00:
        break;
      default:
        break;
    Serial.print(packet[i], HEX);
    Serial.print(" ");
  Serial.println();
.zip   9-tuya-wifi-config.zip (Size: 2 KB / Downloads: 498)
.zip   9-tuya-wifi-config.ino.merged.zip (Size: 184.93 KB / Downloads: 486)
