» Members: 9,830
» Latest member: comhosp
» Forum threads: 4,219
» Forum posts: 20,937
There are currently 278 online users.
» 1 Member(s) | 249 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, HeadlessChrome, PetalBot, Yandex, bot, coccoc, curl, viko
KC868-HA PC software V1.0...
Forum: KC868-HA /HA v2
1 hour ago
» Replies: 19
2 hours ago
» Replies: 16
Kc868ia
Forum: KC868-AI
8 hours ago
HAv2 ESPHome
8 hours ago
Need Help Getting Started...
8 hours ago
KC868-H32B
8 hours ago
No ethernet communication
Yesterday, 10:56 AM
» Replies: 10
N60 Loss of kWh on reset
Forum: N60
Last Post: chuyskywalker
09-04-2026, 03:58 AM
» Replies: 12
CT Sensor Direction
Forum: N60
09-03-2026, 12:51 PM
Request for Type B Projec...
Last Post: lemanat
09-03-2026, 08:47 AM
  N10 ESP32 I/O pin define
Posted by: admin - 08-02-2025, 12:58 AM - Forum: N10 - No Replies
Ethernet (W5500) I/O define:
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
interrupt_pin: GPIO2
reset_pin: GPIO1
IIC BUS:
SDA:18
SCL:17
SPI BUS (LoRa):
SCK:13
MOSI:12
MISO:11
CS: 14
RST: 21
DIO0:47
ARM CPU TXD:9
ARM CPU RXD:10
free GPIO (without pull up resistance):
GPIO15
GPIO16
SD Card:
SPI-MOSI:GPIO40
SPI-SCK:GPIO39
SPI-MISO:GPIO38
SPI-CS:GPIO48
SPI-CD:GPIO8
  N20 ESP32 I/O pin define
Posted by: admin - 08-02-2025, 12:58 AM - Forum: N20 - Replies (2)
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
reset_pin: GPIO1
IIC BUS:
SDA:18
SCL:17
SPI BUS (LoRa):
SCK:13
MOSI:12
MISO:11
CS: 14
RST: 21
DIO0:47
ARM CPU TXD:9
ARM CPU RXD:10
GPIO15
GPIO16
SD Card:
SPI-MOSI:GPIO40
SPI-SCK:GPIO39
SPI-MISO:GPIO38
SPI-CS:GPIO48
SPI-CD:GPIO8
  N30 ESP32 I/O pin define
Posted by: admin - 08-02-2025, 12:58 AM - Forum: N30 - No Replies
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
reset_pin: GPIO1
IIC BUS:
SDA:18
SCL:17
SPI BUS (LoRa):
SCK:13
MOSI:12
MISO:11
CS: 14
RST: 21
DIO0:47
ARM CPU TXD:9
ARM CPU RXD:10
GPIO15
GPIO16
SD Card:
SPI-MOSI:GPIO40
SPI-SCK:GPIO39
SPI-MISO:GPIO38
SPI-CS:GPIO48
SPI-CD:GPIO8
  USB Cable
Posted by: bob_tm - 08-01-2025, 12:06 PM - Forum: KC868-A16v3 - No Replies
For everyone, who spend hours to get first flash.
Modern type-c to type-c cables do not work with this board! Cheap or expensive - mine do not work at all.
I cut some cheap type c cable and measure connection between data lines and ESP contacts - only one line is connected. Other data line goes to unsoldered pin in type c socket! But in old big USB - both lines going to ESP32.
The only option that works for me - type C / type A cable with type A / type C adapter.
Hope this save time for somebody.
  KinCony T64M Tiny ESP32 Smart Controller released
Posted by: admin - 08-01-2025, 04:56 AM - Forum: News - Replies (2)
KinCony T64M tiny ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 64 channel MOSFET output, 4 channel 1-wire GPIOs, 3 channel free GPIOs. T64M have RS485 port. You can write any code by Arduino IDE / Micro Python / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. T64M use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support KinCony cloud service (official shop customer free 2 years), remote monitor and control device by webpage in anywhere. KCS v3 support KinCony board integrate to Loxone Miniserver. Support Apple HomeKit for Siri.
[Image: T64M-1.jpg]
Model No. KinCony T64M
Description: KinCony 64 Channel Tiny ESP32-S3 Smart Controller – T64M
Power supply: 12-24V DC
interfaces: Ethernet(RJ45)-LAN 100Mbps IPv4/IPv6,WiFi,RS485,Bluetooth,USB-C
Installation method: DIN RAIL
Outputs:
64CH MOSFET Outputs, every channel use MAX 4A driver IC
Inputs:
64CH dry contact inputs (optocoupler isolation, long distance circuit for MAX 500 meters cable)
free GPIO: 3CH (connect with ESP32S3 pin directly)
[Image: T64M-2.jpg]
  Tasmota Template
Posted by: bob_tm - 07-31-2025, 12:43 PM - Forum: KC868-A16v3 - Replies (4)
How to convert this information to Tasmota components
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO15
  reset_pin: GPIO1
  [arduino code examples for B24M]-11 digital INPUT trigger OUTPUT directly
Posted by: admin - 07-31-2025, 07:08 AM - Forum: B24M - No Replies
* This program reads 24 input states from two PCF8575 I/O expanders and
* controls a corresponding 24-channel relay module.
* When an input pin is LOW, the corresponding relay is turned ON (LOW means ON for the relay).
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* - Input I2C Address 1 (inputs 1-16): 0x24
* - Input/Relay I2C Address 2 (inputs 17-24 and relays 1-8): 0x26
* - Relay I2C Address 3 (relays 9-24): 0x25
#include <PCF8575.h>     // Library to control the PCF8575 I/O expander
// Define I2C pins
#define SDA 8            // SDA pin
#define SCL 18           // SCL pin
// I2C addresses for the PCF8575 modules
#define INPUT_I2C_ADDRESS_1 0x22   // I2C address for the first input PCF8575 module (inputs 1-16)
#define INPUT_RELAY_I2C_ADDRESS_2 0x25   // I2C address for inputs 17-24 and relays 1-8
#define RELAY_I2C_ADDRESS_3 0x24   // I2C address for relays 9-24
PCF8575 pcf8575_IN1(INPUT_I2C_ADDRESS_1);    // Create an object for the first input PCF8575 (inputs 1-16)
PCF8575 pcf8575_IN2(INPUT_RELAY_I2C_ADDRESS_2);    // Create an object for the second input PCF8575 (inputs 17-24 and relays 1-8)
PCF8575 pcf8575_RL(RELAY_I2C_ADDRESS_3);    // Create an object for the relay PCF8575 (relays 9-24)
  Wire.begin(SDA, SCL);
  pcf8575_IN1.begin();  // For inputs 1-16
  pcf8575_IN2.begin();  // For inputs 17-24 and relays 1-8
  pcf8575_RL.begin();   // For relays 9-24
  // Turn off all relays at the start (LOW means OFF)
    pcf8575_IN2.write(i, HIGH);  // Turn off relays 1-8
    pcf8575_RL.write(i, HIGH);  // Turn off relays 9-24
  Serial.println("System started: Input state controlling 24 relays");
if (pcf8575_IN1.read(8)==0) pcf8575_IN2.write(8, LOW); else pcf8575_IN2.write(8, HIGH);
if (pcf8575_IN1.read(9)==0) pcf8575_IN2.write(9, LOW); else pcf8575_IN2.write(9, HIGH);
if (pcf8575_IN1.read(10)==0) pcf8575_IN2.write(10, LOW); else pcf8575_IN2.write(10, HIGH);
if (pcf8575_IN1.read(11)==0) pcf8575_IN2.write(11, LOW); else pcf8575_IN2.write(11, HIGH);
if (pcf8575_IN1.read(12)==0) pcf8575_IN2.write(12, LOW); else pcf8575_IN2.write(12, HIGH);
if (pcf8575_IN1.read(13)==0) pcf8575_IN2.write(13, LOW); else pcf8575_IN2.write(13, HIGH);
if (pcf8575_IN1.read(14)==0) pcf8575_IN2.write(14, LOW); else pcf8575_IN2.write(14, HIGH);
if (pcf8575_IN1.read(15)==0) pcf8575_IN2.write(15, LOW); else pcf8575_IN2.write(15, HIGH);
if (pcf8575_IN1.read(0)==0) pcf8575_RL.write(0, LOW); else pcf8575_RL.write(0, HIGH);
if (pcf8575_IN1.read(1)==0) pcf8575_RL.write(1, LOW); else pcf8575_RL.write(1, HIGH);
if (pcf8575_IN1.read(2)==0) pcf8575_RL.write(2, LOW); else pcf8575_RL.write(2, HIGH);
if (pcf8575_IN1.read(3)==0) pcf8575_RL.write(3, LOW); else pcf8575_RL.write(3, HIGH);
if (pcf8575_IN1.read(4)==0) pcf8575_RL.write(4, LOW); else pcf8575_RL.write(4, HIGH);
if (pcf8575_IN1.read(5)==0) pcf8575_RL.write(5, LOW); else pcf8575_RL.write(5, HIGH);
if (pcf8575_IN1.read(6)==0) pcf8575_RL.write(6, LOW); else pcf8575_RL.write(6, HIGH);
if (pcf8575_IN1.read(7)==0) pcf8575_RL.write(7, LOW); else pcf8575_RL.write(7, HIGH);
if (pcf8575_IN2.read(0)==0) pcf8575_RL.write(8, LOW); else pcf8575_RL.write(8, HIGH);
if (pcf8575_IN2.read(1)==0) pcf8575_RL.write(9, LOW); else pcf8575_RL.write(9, HIGH);
if (pcf8575_IN2.read(2)==0) pcf8575_RL.write(10, LOW); else pcf8575_RL.write(10, HIGH);
if (pcf8575_IN2.read(3)==0) pcf8575_RL.write(11, LOW); else pcf8575_RL.write(11, HIGH);
if (pcf8575_IN2.read(4)==0) pcf8575_RL.write(12, LOW); else pcf8575_RL.write(12, HIGH);
if (pcf8575_IN2.read(5)==0) pcf8575_RL.write(13, LOW); else pcf8575_RL.write(13, HIGH);
if (pcf8575_IN2.read(6)==0) pcf8575_RL.write(14, LOW); else pcf8575_RL.write(14, HIGH);
if (pcf8575_IN2.read(7)==0) pcf8575_RL.write(15, LOW); else pcf8575_RL.write(15, HIGH);
  // Delay for 500 milliseconds
  delay(200);
arduino ino file download:
.zip   11-input-trigger-output.zip (Size: 1.18 KB / Downloads: 579)
.zip   11-input-trigger-output.ino.merged.zip (Size: 192.44 KB / Downloads: 601)
  [arduino code examples for B24]-11 digital INPUT trigger OUTPUT directly
Posted by: admin - 07-31-2025, 07:08 AM - Forum: B24 - No Replies
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
// Define I2C pins
  delay(200);
.zip   11-input-trigger-output.zip (Size: 1.18 KB / Downloads: 573)
.zip   11-input-trigger-output.ino.merged.zip (Size: 192.44 KB / Downloads: 602)
  [arduino code examples for B32M]-11 digital INPUT trigger OUTPUT directly
Posted by: admin - 07-31-2025, 07:08 AM - Forum: B32M - No Replies
* This program reads 32 input states from two PCF8575 I/O expanders and
* controls a corresponding 32-channel relay module.
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
// Define I2C pins
#define INPUT_RELAY_I2C_ADDRESS_2 0x25   // I2C address for inputs 17-24 and relays 9-16
#define RELAY_I2C_ADDRESS_3 0x24   // I2C address for relays 17-32
#define RELAY_I2C_ADDRESS_4 0x26   // I2C address for relays 1-8
PCF8575 pcf8575_IN2(INPUT_RELAY_I2C_ADDRESS_2);    // Create an object for the second input PCF8575 (inputs 17-24 and relays 9-16)
PCF8575 pcf8575_RL(RELAY_I2C_ADDRESS_3);    // Create an object for the relay PCF8575 (relays 17-32)
PCF8575 pcf8575_RL2(RELAY_I2C_ADDRESS_4);    // Create an object for the relay PCF8575 (relays 1-8)
  pcf8575_RL2.begin();   // For relays 25-32
    pcf8575_RL2.write(i, HIGH);  // Turn off relays 1-8
    pcf8575_IN2.write(i, HIGH);  // Turn off relays 9-16
    pcf8575_RL.write(i, HIGH);  // Turn off relays 17-32
  Serial.println("System started: Input state controlling 32 relays");
if (pcf8575_IN1.read(8)==0) pcf8575_RL2.write(8, LOW); else pcf8575_RL2.write(8, HIGH);
if (pcf8575_IN1.read(9)==0) pcf8575_RL2.write(9, LOW); else pcf8575_RL2.write(9, HIGH);
if (pcf8575_IN1.read(10)==0) pcf8575_RL2.write(10, LOW); else pcf8575_RL2.write(10, HIGH);
if (pcf8575_IN1.read(11)==0) pcf8575_RL2.write(11, LOW); else pcf8575_RL2.write(11, HIGH);
if (pcf8575_IN1.read(12)==0) pcf8575_RL2.write(12, LOW); else pcf8575_RL2.write(12, HIGH);
if (pcf8575_IN1.read(13)==0) pcf8575_RL2.write(13, LOW); else pcf8575_RL2.write(13, HIGH);
if (pcf8575_IN1.read(14)==0) pcf8575_RL2.write(14, LOW); else pcf8575_RL2.write(14, HIGH);
if (pcf8575_IN1.read(15)==0) pcf8575_RL2.write(15, LOW); else pcf8575_RL2.write(15, HIGH);
if (pcf8575_IN1.read(0)==0) pcf8575_IN2.write(8, LOW); else pcf8575_IN2.write(8, HIGH);
if (pcf8575_IN1.read(1)==0) pcf8575_IN2.write(9, LOW); else pcf8575_IN2.write(9, HIGH);
if (pcf8575_IN1.read(2)==0) pcf8575_IN2.write(10, LOW); else pcf8575_IN2.write(10, HIGH);
if (pcf8575_IN1.read(3)==0) pcf8575_IN2.write(11, LOW); else pcf8575_IN2.write(11, HIGH);
if (pcf8575_IN1.read(4)==0) pcf8575_IN2.write(12, LOW); else pcf8575_IN2.write(12, HIGH);
if (pcf8575_IN1.read(5)==0) pcf8575_IN2.write(13, LOW); else pcf8575_IN2.write(13, HIGH);
if (pcf8575_IN1.read(6)==0) pcf8575_IN2.write(14, LOW); else pcf8575_IN2.write(14, HIGH);
if (pcf8575_IN1.read(7)==0) pcf8575_IN2.write(15, LOW); else pcf8575_IN2.write(15, HIGH);
if (pcf8575_IN2.read(0)==0) pcf8575_RL.write(0, LOW); else pcf8575_RL.write(0, HIGH);
if (pcf8575_IN2.read(1)==0) pcf8575_RL.write(1, LOW); else pcf8575_RL.write(1, HIGH);
if (pcf8575_IN2.read(2)==0) pcf8575_RL.write(2, LOW); else pcf8575_RL.write(2, HIGH);
if (pcf8575_IN2.read(3)==0) pcf8575_RL.write(3, LOW); else pcf8575_RL.write(3, HIGH);
if (pcf8575_IN2.read(4)==0) pcf8575_RL.write(4, LOW); else pcf8575_RL.write(4, HIGH);
if (pcf8575_IN2.read(5)==0) pcf8575_RL.write(5, LOW); else pcf8575_RL.write(5, HIGH);
if (pcf8575_IN2.read(6)==0) pcf8575_RL.write(6, LOW); else pcf8575_RL.write(6, HIGH);
if (pcf8575_IN2.read(7)==0) pcf8575_RL.write(7, LOW); else pcf8575_RL.write(7, HIGH);
if (pcf8575_RL2.read(0)==0) pcf8575_RL.write(8, LOW); else pcf8575_RL.write(8, HIGH);
if (pcf8575_RL2.read(1)==0) pcf8575_RL.write(9, LOW); else pcf8575_RL.write(9, HIGH);
if (pcf8575_RL2.read(2)==0) pcf8575_RL.write(10, LOW); else pcf8575_RL.write(10, HIGH);
if (pcf8575_RL2.read(3)==0) pcf8575_RL.write(11, LOW); else pcf8575_RL.write(11, HIGH);
if (pcf8575_RL2.read(4)==0) pcf8575_RL.write(12, LOW); else pcf8575_RL.write(12, HIGH);
if (pcf8575_RL2.read(5)==0) pcf8575_RL.write(13, LOW); else pcf8575_RL.write(13, HIGH);
if (pcf8575_RL2.read(6)==0) pcf8575_RL.write(14, LOW); else pcf8575_RL.write(14, HIGH);
if (pcf8575_RL2.read(7)==0) pcf8575_RL.write(15, LOW); else pcf8575_RL.write(15, HIGH);
  delay(200);
.zip   11-input-trigger-output.zip (Size: 1.28 KB / Downloads: 303)
.zip   11-input-trigger-output.ino.merged.zip (Size: 198.08 KB / Downloads: 302)
  [arduino code examples for B24M]-10 Print TEXT on SSD1306 OLED displayer
Posted by: admin - 07-31-2025, 07:06 AM - Forum: B24M - Replies (4)
* - SCL (clock) on pin IO18
* - SDA (data) on pin IO8
void page1() {
  u8g2.begin();
  do {
    page1();
.zip   10-oled-ssd1306.zip (Size: 1.11 KB / Downloads: 618)
.zip   10-oled-ssd1306.ino.merged.zip (Size: 202.58 KB / Downloads: 596)
