» Members: 10,112
» Latest member: EoN
» Forum threads: 4,257
» Forum posts: 21,086
There are currently 248 online users.
» 0 Member(s) | 225 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, PetalBot, Photon/, bot
Update to latest esphome
Today, 10:54 AM
m16v2 energy meter - cali...
Yesterday, 11:50 AM
» Replies: 15
oCBot: KC868-A6/A16 as a ...
Last Post: oCBot
10-01-2026, 01:32 PM
N20 Energy RS485 Modbus P...
Forum: N20
10-01-2026, 12:43 PM
Getting inconsistent/wron...
10-01-2026, 12:40 PM
KC868-HAv2 phantom press ...
Forum: KC868-HA /HA v2
Last Post: phrfpeixoto
09-29-2026, 01:57 AM
KC868-A6 Analog inputs
Last Post: Tomas4289
09-28-2026, 12:57 PM
N60/N30/N20/N10 PC softwa...
Forum: N10
09-28-2026, 12:49 PM
» Replies: 13
getting the A8A inputs to...
Forum: Development
09-28-2026, 08:38 AM
Best way to read from N30
Forum: N30
09-27-2026, 12:20 AM
  RTC Battery Holder
Posted by: molelightn - 10-05-2025, 07:33 AM - Forum: B16 - Replies (1)
may a stupid question, but what kind of cell i do have to use for KinCony B16 in the battery holder for the RTC Clock?
Tested some small different ones but none of them fit really good.
br mole
  Which CT clamps for the N30 or other boards N10/N20
Posted by: Vega - 10-04-2025, 03:41 PM - Forum: N30 - Replies (3)
Which CT clamps are for the N30 or N20/N10
Looking for CT clamp for 25A and 50A
  Z1 firmware Issues
Posted by: kz1user - 10-03-2025, 04:18 PM - Forum: KC868-AG / AG Pro / AG8 / Z1 - Replies (3)
hi, I recently received the Z1 device.
I have noticed a few issues in the Zigbee firmware. I am using the firmware 3.12
1. the Zigbee devices looses the name (label) given.
2. the device state on/off is reported wrongly.
3. the Zigbee devices removed still show up in the monitor.
4. need more time zones.
5. Zigbee tuneable driver not getting properly recognized. only show on and off. no slider for CCT and dimmer
6. sometimes losses the state with MQTT(HA). HA Reports wrong state.
Question Modbus register map
Posted by: nortien - 10-03-2025, 08:32 AM - Forum: KC868-HA /HA v2 - Replies (1)
Hello.
What protocol does the Modbus module use? Modbus RTU?
I need to understand how to connect this module to my non-Kincony controller.
Do you have a Modbus register map? Do you have technical documentation? Please share.
  KC868-32 arduino ide
Posted by: martin - 10-03-2025, 08:28 AM - Forum: KC868-A32/A32 Pro - Replies (8)
I have a new KC868-32. With USB connection, I loaded the exemple"01-control-one-relay" code from arduino ide. On the serial monitor I get the correct responses: "open relay 2 success" . But nothing happen on the board in reality. The relay is not switching. Do you know what could be the reason?  Thank you very much indeed
  F16 Support/warranty
Posted by: Onepointbrewing - 10-03-2025, 01:33 AM - Forum: F16 - Replies (1)
Dear Sir,
I need some technical support/warranty help with a F16. I have sent you an email to web@kincony.com
Could you please advise based on the contents of my email.
Thank you very much.
  KinCony N30 ESP32S3 LoRa Energy Meter released
Posted by: admin - 10-02-2025, 10:54 PM - Forum: News - No Replies
We have designed 30 Channel ESP32 energy monitor board – N30 (ESP32 30 Channel CT Clamp Energy Monitor) for home automation project. It based on ESP32-S3-WROOM-1U (N16R8) wifi chip. The hardware have 30CH CT Clamp sensor INPUT ports + 3CH ZMPT101B voltage sensor + SD card + LoRa module + OLED display + free GPIOs. Ethernet+RS485+i2c extender 30CH high-accuracy energy meter ic-BL0910 with CT clamp. You can write any code by Arduino IDE / Micro Python / ESP-IDF development tool to ESP32-S3 module. We will supply Arduino demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant for smart home automation DIY. N30 use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support KinCony cloud service (official shop customer free 2 years), remote monitor and control device by webpage in anywhere. KCS v3 support KinCony board integrate to Loxone Miniserver. Support Apple HomeKit for Siri.
[Image: N30-1.jpg]
Model No. KinCony N30
Description: KinCony 30 Channel AC Energy Meter – N30
Power supply: 12-24V DC
interfaces: Ethernet(RJ45)-LAN 100Mbps IPv4/IPv6,WiFi,RS485,Bluetooth,LoRa,USB-C,i2c extender
Installation method: DIN RAIL
CT Clamp: 30 channel 2000:1 CT clamp “voltage” sensor
3 channel AC voltage: AC 0-380v
Button-DL: ESP32S3 download
Button-EN: ESP32S3 reset
Button-RST: RESET for ARM CPU
LED:
D5: power LED
D7: error LED
D6: running LED
Free GPIOs: GPIO15,GPIO16
[Image: N30-2.jpg]
  RS485 communicattion
Posted by: SixSixOne - 10-02-2025, 08:57 AM - Forum: G1 - Replies (5)
Hello again,
I have one KC868-G1 and one KC868-AI could you please assit on how to connect each other with RS485 connection and use the G1 to read all digital inputs from the AI in home assistant.
The reason I need RS485 is for redundancy in case network drops.
Thank tou
Dimitris
  KinCony N20 ESP32S3 LoRa Energy Meter released
Posted by: admin - 10-02-2025, 05:37 AM - Forum: News - No Replies
We have designed 20 Channel ESP32 energy monitor board – N20 (ESP32 30 Channel CT Clamp Energy Monitor) for home automation project. It based on ESP32-S3-WROOM-1U (N16R8) wifi chip. The hardware have 20CH CT Clamp sensor INPUT ports + 2CH ZMPT101B voltage sensor + SD card + LoRa module + OLED display + free GPIOs. Ethernet+RS485+i2c extender 20CH high-accuracy energy meter ic-BL0910 with CT clamp. You can write any code by Arduino IDE / Micro Python / ESP-IDF development tool to ESP32-S3 module. We will supply Arduino demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant for smart home automation DIY. N20 use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support KinCony cloud service (official shop customer free 2 years), remote monitor and control device by webpage in anywhere. KCS v3 support KinCony board integrate to Loxone Miniserver. Support Apple HomeKit for Siri.
[Image: N20-1.jpg]
Model No. KinCony N20
Description: KinCony 20 Channel AC Energy Meter – N20
CT Clamp: 20 channel 2000:1 CT clamp "voltage" sensor
2 channel AC voltage: AC 0-380v
LED:
D5: power LED
D7: error LED
D6: running LED
[Image: N20-2.jpg]
  Digital Input B8M Voltage Range?
Posted by: coconut - 10-01-2025, 05:02 PM - Forum: B8M - Replies (6)
is it ok to directly attach 14V Signals (from car) to the digital inputs of B8M? If not, can I reduce the signal with a voltage-divider to <5V and then attach to DI1-8?
Thanks from switzerland!
