» Members: 10,188
» Latest member: Parke
» Forum threads: 4,264
» Forum posts: 21,144
There are currently 259 online users.
» 0 Member(s) | 247 Guest(s)
Baidu, Bytespider, Crawl, Google, PetalBot, bot
SSD not visible for insta...
Forum: Pi5R16
1 hour ago
» Replies: 9
KC868-A16 and Tuya
Last Post: newdos
Yesterday, 09:33 AM
» Replies: 8
KC868-AI mDNS problem
Forum: KC868-AI
Yesterday, 07:53 AM
remember relay state
Forum: KC868-E16T
Yesterday, 07:51 AM
» Replies: 9
N30 (KCS): energy counter...
Forum: N30
10-09-2026, 11:12 PM
Bricked KC868-A16
10-09-2026, 11:09 PM
» Replies: 7
KinCony G1 ESP32-S3 SIM76...
Forum: News
» Replies: 4
Current direction detecti...
Forum: N30
Last Post: dominique_manas@hotmail.com
10-09-2026, 07:31 AM
» Replies: 4
KC868-A8 on Heat Pump for...
Last Post: marktuan
10-09-2026, 03:17 AM
B32M maximum voltage
Last Post: felixandrea
10-09-2026, 03:14 AM
  F24 work with HAv2 with tuya app ESPHome yaml
Posted by: admin - 10-14-2025, 12:19 AM - Forum: F24 - No Replies
  friendly_name: f24
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
  board: esp32-s3-devkitc-1
external_components:
  - source:
      type: git
      ref: v1.3.0
  - source:
      type: git
      url: https://github.com/hzkincony/esphome-kc868-ha
      ref: v3.0.2
  encryption:
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  interrupt_pin: GPIO2
  reset_pin: GPIO1
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
  - id: 'pcf8574_hub_out_1'  # for output channel 9-24
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_in_1'  # for digital input channel 1-16
    i2c_id: bus_a
    pcf8575: true
  - id: 'pcf8574_hub_out_in_2'  # for output channel 1-8  + (input 17-24)
    i2c_id: bus_a
    address: 0x26
    pcf8575: true
  - id: myuart1
    tx_pin: 16
    rx_pin: 17
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: false
  - id: tuya_mcu_uart
    tx_pin: GPIO39
    rx_pin: GPIO38
    baud_rate: 9600
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: cchos3g1j2ucfbyd
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
kc868_ha:
  uart_id: myuart1
      pcf8574: pcf8574_hub_out_in_2
      number: 12
  - platform: tuya_wifi_mcu
    dp_id: 1
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "f24_output01"
      number: 13
    dp_id: 2
    internal: true
    bind_switch_id: "f24_output02"
      number: 14
    dp_id: 3
    internal: true
    bind_switch_id: "f24_output03"
      number: 15
    dp_id: 4
    internal: true
    bind_switch_id: "f24_output04"
      number: 8
    dp_id: 5
    internal: true
    bind_switch_id: "f24_output05"
      number: 9
    dp_id: 6
    internal: true
    bind_switch_id: "f24_output06"
      number: 10
    dp_id: 101
    internal: true
    bind_switch_id: "f24_output07"
      number: 11
    dp_id: 102
    internal: true
    bind_switch_id: "f24_output08"
      pcf8574: pcf8574_hub_out_1
    dp_id: 103
    internal: true
    bind_switch_id: "f24_output09"
    dp_id: 104
    internal: true
    bind_switch_id: "f24_output10"
    dp_id: 105
    internal: true
    bind_switch_id: "f24_output11"
    dp_id: 106
    internal: true
    bind_switch_id: "f24_output12"
    dp_id: 107
    internal: true
    bind_switch_id: "f24_output13"
    dp_id: 108
    internal: true
    bind_switch_id: "f24_output14"
    dp_id: 109
    internal: true
    bind_switch_id: "f24_output15"
    dp_id: 110
    internal: true
    bind_switch_id: "f24_output16"
      number: 8
    dp_id: 126
    internal: true
    bind_switch_id: "f24_output17"
      number: 9
    dp_id: 129
    internal: true
    bind_switch_id: "f24_output18"
      number: 10
    dp_id: 130
    internal: true
    bind_switch_id: "f24_output19"
      number: 11
    dp_id: 131
    internal: true
    bind_switch_id: "f24_output20"
      number: 12
    dp_id: 132
    internal: true
    bind_switch_id: "f24_output21"
      number: 13
    dp_id: 133
    internal: true
    bind_switch_id: "f24_output22"
      number: 14
    dp_id: 134
    internal: true
    bind_switch_id: "f24_output23"
      number: 15
    dp_id: 135
    internal: true
    bind_switch_id: "f24_output24"
  # The switch is used to control the D1~D6 level output on the KC868 HA board
  # bind_output is required. Corresponds to the BindOutput parameter in HA485_Ctrl software
  # Other parameters refer to: https://esphome.io/components/switch/index.html
  - platform: kc868_ha
    target_relay_controller_addr: 1
    switch_adapter_addr: 10
    bind_output: 1
    bind_output: 2
    bind_output: 3
    bind_output: 4
    bind_output: 5
    bind_output: 6
    dp_id: 111
    bind_binary_sensor_id: f24_input01
    internal: true
    dp_id: 112
    bind_binary_sensor_id: f24_input02
    internal: true
    dp_id: 113
    bind_binary_sensor_id: f24_input03
    internal: true
    dp_id: 114
    bind_binary_sensor_id: f24_input04
    internal: true
    dp_id: 115
    bind_binary_sensor_id: f24_input05
    internal: true
    dp_id: 116
    bind_binary_sensor_id: f24_input06
    internal: true
    dp_id: 117
    bind_binary_sensor_id: f24_input07
    internal: true
    dp_id: 118
    bind_binary_sensor_id: f24_input08
    internal: true
      number: 8
    dp_id: 119
    bind_binary_sensor_id: f24_input09
    internal: true
      number: 9
    dp_id: 120
    bind_binary_sensor_id: f24_input10
    internal: true
      number: 10
    dp_id: 121
    bind_binary_sensor_id: f24_input11
    internal: true
      number: 11
    dp_id: 122
    bind_binary_sensor_id: f24_input12
    internal: true
      number: 12
    dp_id: 123
    bind_binary_sensor_id: f24_input13
    internal: true
      number: 13
    dp_id: 124
    bind_binary_sensor_id: f24_input14
    internal: true
      number: 14
    dp_id: 125
    bind_binary_sensor_id: f24_input15
    internal: true
      number: 15
##pull-up resistance on PCB
      number: 48
      number: 47
      number: 21
      number: 15
## without resistance on PCB
      number: 13
      inverted: false
      number: 14
      inverted:  false
      number: 40
      inverted:  false
  # The binary_sensor corresponds to the state changes generated by K1~K6 on the KC868 HA board
  # Other parameters refer to: https://esphome.io/components/binary_sensor/index.html
    target_relay_controller_addr: 1 # Default value is 1, corresponds to the Target Relay Controller Addr parameter in HA485_Ctrl software
    switch_adapter_addr: 10 # Default value is 10, corresponds to the Switch Adapter Addr parameter in HA485_Ctrl software
    bind_output: 1 # Corresponds to the BindOutput parameter in HA485_Ctrl software
    bind_output: 2
    bind_output: 3
    bind_output: 4
    bind_output: 5
    bind_output: 6
  - platform: adc
    pin: 5
    name: "f24 A1 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
          } else if (x <= 0.15) {
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 7
    name: "f24 A2 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      # - multiply: 1.51515
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 6
    name: "f24 A3 Current"
    update_interval: 5s
    unit_of_measurement: mA
    attenuation: 11db
    filters:
      - multiply: 6.66666666
  - platform: adc
    pin: 4
    name: "f24 A4 Current"
    update_interval: 5s
    attenuation: 11db
    filters:
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "KinCony F24");
esphome yaml download:
.txt   HAv2-F24-Tuya.txt (Size: 20.91 KB / Downloads: 344)
  F24 work with HAv2 without tuya app ESPHome yaml
Posted by: admin - 10-14-2025, 12:18 AM - Forum: F24 - No Replies
  friendly_name: HAv2
    type: esp-idf
  baud_rate: 0
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  reset_pin: GPIO1
  - source:
      type: git
      ref: v3.0.1
  - id: myuart1
    tx_pin: 16
    rx_pin: 17
    baud_rate: 9600
    debug:
      direction: BOTH
kc868_ha:
    bind_output: 2
    bind_output: 3
    bind_output: 4
    bind_output: 5
    bind_output: 6
    bind_output: 1
    bind_output: 2
    bind_output: 3
    bind_output: 4
    bind_output: 5
    bind_output: 6
web_server:
  port: 80
esphome yaml file download:
.txt   HAv2-F24-yaml.txt (Size: 3.04 KB / Downloads: 287)
Bug KC868-HAv2 issue
Posted by: innovation - 10-13-2025, 10:44 AM - Forum: KC868-A16v3 - Replies (1)
when KC868-A16V3 connected to KC868-HAV2 through ESPHOME it shows below error attached
  friendly_name: KINCONY A16 NEW BOARD
    type: esp-idf
# Enable Home Assistant API with encryption
  encryption:
    key: "71EREQeZmQA2vN1bu/ghatHKmh/3t5Ikq5HELUWX7Lc="
  reboot_timeout: 10s  # Adds a timeout for reboots, ensuring it doesn't hang for long if there's an issue.
ota:
  - platform: esphome
    password: "f93558fce51f7a51c03bd2be87fb08fc"
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO15
  reset_pin: GPIO1
  baud_rate: 9600       # Use standard baud rate for more reliable logging
  level: DEBUG            # Enable debug level for better diagnostics
  - source:
      type: git
      ref: v3.0.2
  - id: myuart1
    tx_pin: 16
    rx_pin: 17
    baud_rate: 9600
kc868_ha:
    bind_output: 1
    on_press:
      - switch.toggle: switch_1
    bind_output: 2
    on_press:
      - switch.toggle: switch_2
    bind_output: 3
    on_press:
      - switch.toggle: switch_3
    bind_output: 4
    on_press:
      - switch.toggle: switch_4
    bind_output: 5
    on_press:
      - switch.toggle: switch_5
    bind_output: 6
    on_press:
      - switch.toggle: switch_6
    bind_output: 1
    bind_output: 2
    bind_output: 3
    bind_output: 4
    bind_output: 5
    bind_output: 6
  N30 configure yaml for ESPhome
Posted by: admin - 10-13-2025, 10:24 AM - Forum: N30 - No Replies
  friendly_name: n30
  # baud_rate: 0
ota:
  platform: esphome
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  reset_pin: GPIO1
  rx_pin: 9
  tx_pin: 10
  baud_rate: 115200
  stop_bits: 1
  data_bits: 8
  parity: NONE
web_server:
  port: 80
text_sensor:
  - platform: ethernet_info
    ip_address:
      name: ESP IP Address
      address_0:
        name: ESP IP Address 0
      address_1:
        name: ESP IP Address 1
      address_2:
        name: ESP IP Address 2
      address_3:
        name: ESP IP Address 3
      address_4:
        name: ESP IP Address 4
    dns_address:
      name: ESP DNS Address
    mac_address:
      name: ESP MAC Address
font:
  sda: 18
  scl: 17
display:
    address: 0x3C
    lambda: |-
modbus:
modbus_controller:
  - address: 1
    update_interval: 5s
  - platform: modbus_controller
    address: 100
    register_type: holding
    unit_of_measurement: A
    device_class: current
    accuracy_decimals: 3
    value_type: U_DWORD_R
    filters:
      - multiply: 0.001
    address: 102
    filters:
      - multiply: 0.001
    address: 104
    filters:
      - multiply: 0.001
    address: 106
    filters:
      - multiply: 0.001
    address: 108
    filters:
      - multiply: 0.001
    address: 110
    filters:
      - multiply: 0.001
    address: 112
    filters:
      - multiply: 0.001
    address: 114
    filters:
      - multiply: 0.001
    address: 116
    filters:
      - multiply: 0.001
    address: 118
    filters:
      - multiply: 0.001
    address: 120
    unit_of_measurement: W
    device_class: power
    accuracy_decimals: 1
    filters:
      - multiply: 0.1
    address: 122
    device_class: power
    filters:
      - multiply: 0.1
    address: 124
    device_class: power
    filters:
      - multiply: 0.1
    address: 126
    device_class: power
    filters:
      - multiply: 0.1
    address: 128
    device_class: power
    filters:
      - multiply: 0.1
    address: 130
    device_class: power
    filters:
      - multiply: 0.1
    address: 132
    device_class: power
    filters:
      - multiply: 0.1
    address: 134
    device_class: power
    filters:
      - multiply: 0.1
    address: 136
    device_class: power
    filters:
      - multiply: 0.1
    address: 138
    device_class: power
    filters:
      - multiply: 0.1
    state_class: total_increasing
    device_class: energy
    address: 140
    unit_of_measurement: kWh
    address: 142
    address: 144
    address: 146
    address: 148
    address: 150
    address: 152
    address: 154
    address: 156
    address: 158
    address: 160
    address: 162
    unit_of_measurement: V
    device_class: voltage
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 163
    unit_of_measurement: Hz
    device_class: frequency
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 164
    unit_of_measurement: °C
    device_class: temperature
    value_type: FP32_R
    address: 200
    filters:
    - multiply: 0.001
    address: 202
    filters:
    - multiply: 0.001
    address: 204
    filters:
    - multiply: 0.001
    address: 206
    filters:
    - multiply: 0.001
    address: 208
    filters:
    - multiply: 0.001
    address: 210
    filters:
    - multiply: 0.001
    address: 212
    filters:
    - multiply: 0.001
    address: 214
    filters:
    - multiply: 0.001
    address: 216
    filters:
    - multiply: 0.001
    address: 218
    filters:
    - multiply: 0.001
    address: 220
    device_class: power
    filters:
    - multiply: 0.1
    address: 222
    device_class: power
    filters:
    - multiply: 0.1
    address: 224
    device_class: power
    filters:
    - multiply: 0.1
    address: 226
    device_class: power
    filters:
    - multiply: 0.1
    address: 228
    device_class: power
    filters:
    - multiply: 0.1
    address: 230
    device_class: power
    filters:
    - multiply: 0.1
    address: 232
    device_class: power
    filters:
    - multiply: 0.1
    address: 234
    device_class: power
    filters:
    - multiply: 0.1
    address: 236
    device_class: power
    filters:
    - multiply: 0.1
    address: 238
    device_class: power
    filters:
    - multiply: 0.1
    address: 240
    address: 242
    address: 244
    address: 246
    address: 248
    address: 250
    address: 252
    address: 254
    address: 256
    address: 258
    address: 260
    address: 262
    value_type: U_WORD
    filters:
    - multiply: 0.01
    address: 263
    value_type: U_WORD
    filters:
    - multiply: 0.01
    address: 264
    unit_of_measurement: "°C"
    value_type: FP32_R
    address: 300
    filters:
    - multiply: 0.001
    address: 302
    filters:
    - multiply: 0.001
    address: 304
    filters:
    - multiply: 0.001
    address: 306
    filters:
    - multiply: 0.001
    address: 308
    filters:
    - multiply: 0.001
    address: 310
    filters:
    - multiply: 0.001
    address: 312
    filters:
    - multiply: 0.001
    address: 314
    filters:
    - multiply: 0.001
    address: 316
    filters:
    - multiply: 0.001
    address: 318
    filters:
    - multiply: 0.001
    address: 320
    device_class: power
    filters:
    - multiply: 0.1
    address: 322
    device_class: power
    filters:
    - multiply: 0.1
    address: 324
    device_class: power
    filters:
    - multiply: 0.1
    address: 326
    device_class: power
    filters:
    - multiply: 0.1
    address: 328
    device_class: power
    filters:
    - multiply: 0.1
    address: 330
    device_class: power
    filters:
    - multiply: 0.1
    address: 332
    device_class: power
    filters:
    - multiply: 0.1
    address: 334
    device_class: power
    filters:
    - multiply: 0.1
    address: 336
    device_class: power
    filters:
    - multiply: 0.1
    address: 338
    device_class: power
    filters:
    - multiply: 0.1
    address: 340
    address: 342
    address: 344
    address: 346
    address: 348
    address: 350
    address: 352
    address: 354
    address: 356
    address: 358
    address: 360
    address: 362
    value_type: U_WORD
    filters:
    - multiply: 0.01
    address: 363
    value_type: U_WORD
    filters:
    - multiply: 0.01
    address: 364
    value_type: FP32_R
yaml download:
.txt   N30-HA.txt (Size: 27.53 KB / Downloads: 537)
  N20 configure yaml for ESPhome
Posted by: admin - 10-13-2025, 10:23 AM - Forum: N20 - No Replies
  friendly_name: n20
  # baud_rate: 0
ota:
  platform: esphome
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  reset_pin: GPIO1
  rx_pin: 9
  tx_pin: 10
  baud_rate: 115200
  stop_bits: 1
  data_bits: 8
  parity: NONE
web_server:
  port: 80
text_sensor:
    ip_address:
      address_0:
      address_1:
      address_2:
      address_3:
      address_4:
    dns_address:
    mac_address:
font:
  sda: 18
  scl: 17
display:
    address: 0x3C
    lambda: |-
modbus:
modbus_controller:
  - address: 1
    update_interval: 5s
    address: 100
    filters:
      - multiply: 0.001
    address: 102
    filters:
      - multiply: 0.001
    address: 104
    filters:
      - multiply: 0.001
    address: 106
    filters:
      - multiply: 0.001
    address: 108
    filters:
      - multiply: 0.001
    address: 110
    filters:
      - multiply: 0.001
    address: 112
    filters:
      - multiply: 0.001
    address: 114
    filters:
      - multiply: 0.001
    address: 116
    filters:
      - multiply: 0.001
    address: 118
    filters:
      - multiply: 0.001
    address: 120
    device_class: power
    filters:
      - multiply: 0.1
    address: 122
    device_class: power
    filters:
      - multiply: 0.1
    address: 124
    device_class: power
    filters:
      - multiply: 0.1
    address: 126
    device_class: power
    filters:
      - multiply: 0.1
    address: 128
    device_class: power
    filters:
      - multiply: 0.1
    address: 130
    device_class: power
    filters:
      - multiply: 0.1
    address: 132
    device_class: power
    filters:
      - multiply: 0.1
    address: 134
    device_class: power
    filters:
      - multiply: 0.1
    address: 136
    device_class: power
    filters:
      - multiply: 0.1
    address: 138
    device_class: power
    filters:
      - multiply: 0.1
    address: 140
    address: 142
    address: 144
    address: 146
    address: 148
    address: 150
    address: 152
    address: 154
    address: 156
    address: 158
    address: 160
    address: 162
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 163
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 164
    value_type: FP32_R
    address: 200
    filters:
    - multiply: 0.001
    address: 202
    filters:
    - multiply: 0.001
    address: 204
    filters:
    - multiply: 0.001
    address: 206
    filters:
    - multiply: 0.001
    address: 208
    filters:
    - multiply: 0.001
    address: 210
    filters:
    - multiply: 0.001
    address: 212
    filters:
    - multiply: 0.001
    address: 214
    filters:
    - multiply: 0.001
    address: 216
    filters:
    - multiply: 0.001
    address: 218
    filters:
    - multiply: 0.001
    address: 220
    device_class: power
    filters:
    - multiply: 0.1
    address: 222
    device_class: power
    filters:
    - multiply: 0.1
    address: 224
    device_class: power
    filters:
    - multiply: 0.1
    address: 226
    device_class: power
    filters:
    - multiply: 0.1
    address: 228
    device_class: power
    filters:
    - multiply: 0.1
    address: 230
    device_class: power
    filters:
    - multiply: 0.1
    address: 232
    device_class: power
    filters:
    - multiply: 0.1
    address: 234
    device_class: power
    filters:
    - multiply: 0.1
    address: 236
    device_class: power
    filters:
    - multiply: 0.1
    address: 238
    device_class: power
    filters:
    - multiply: 0.1
    address: 240
    address: 242
    address: 244
    address: 246
    address: 248
    address: 250
    address: 252
    address: 254
    address: 256
    address: 258
    address: 260
    address: 262
    value_type: U_WORD
    filters:
    - multiply: 0.01
    address: 263
    value_type: U_WORD
    filters:
    - multiply: 0.01
    address: 264
    value_type: FP32_R
yaml download:
.txt   N20-HA.txt (Size: 18.78 KB / Downloads: 408)
  N10 configure yaml for ESPhome
Posted by: admin - 10-13-2025, 10:22 AM - Forum: N10 - Replies (7)
  friendly_name: n10
  # baud_rate: 0
ota:
  platform: esphome
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  reset_pin: GPIO1
  rx_pin: 9
  tx_pin: 10
  baud_rate: 115200
  stop_bits: 1
  data_bits: 8
  parity: NONE
web_server:
  port: 80
text_sensor:
    ip_address:
      address_0:
      address_1:
      address_2:
      address_3:
      address_4:
    dns_address:
    mac_address:
font:
  sda: 18
  scl: 17
display:
    address: 0x3C
    lambda: |-
modbus:
modbus_controller:
  - address: 1
    update_interval: 5s
    address: 100
    filters:
      - multiply: 0.001
    address: 102
    filters:
      - multiply: 0.001
    address: 104
    filters:
      - multiply: 0.001
    address: 106
    filters:
      - multiply: 0.001
    address: 108
    filters:
      - multiply: 0.001
    address: 110
    filters:
      - multiply: 0.001
    address: 112
    filters:
      - multiply: 0.001
    address: 114
    filters:
      - multiply: 0.001
    address: 116
    filters:
      - multiply: 0.001
    address: 118
    filters:
      - multiply: 0.001
    address: 120
    device_class: power
    filters:
      - multiply: 0.1
    address: 122
    device_class: power
    filters:
      - multiply: 0.1
    address: 124
    device_class: power
    filters:
      - multiply: 0.1
    address: 126
    device_class: power
    filters:
      - multiply: 0.1
    address: 128
    device_class: power
    filters:
      - multiply: 0.1
    address: 130
    device_class: power
    filters:
      - multiply: 0.1
    address: 132
    device_class: power
    filters:
      - multiply: 0.1
    address: 134
    device_class: power
    filters:
      - multiply: 0.1
    address: 136
    device_class: power
    filters:
      - multiply: 0.1
    address: 138
    device_class: power
    filters:
      - multiply: 0.1
    address: 140
    address: 142
    address: 144
    address: 146
    address: 148
    address: 150
    address: 152
    address: 154
    address: 156
    address: 158
    address: 160
    address: 162
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 163
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 164
    value_type: FP32_R
yaml download:
.txt   N10-HA.txt (Size: 10.03 KB / Downloads: 484)
  N30 Energy RS485 Modbus Protocol
Posted by: admin - 10-13-2025, 02:06 AM - Forum: N30 - Replies (1)
N30 Energy Module Modbus Protocol Specification
1. Overview
This document specifies the Modbus communication protocol for the N30 Energy Module.
The device communicates using the Modbus RTU protocol and provides access to electrical
measurement parameters including current, power, energy consumption, voltage, frequency,
temperature, and power factor from 3 independent energy monitoring chips.
2. Module Characteristics
- Energy Monitoring Chips: 3
- Communication Protocol: Modbus RTU
- Wireless Technology: Not applicable (wired connection)
- Maximum Sensors Supported: 32
- Board Features: Display, Ethernet (W5500), 4G, SD Card support
- GPIO Availability: 2 free GPIOs (pins 15, 16)
3. Communication Parameters
- Protocol: Modbus RTU
- Baud Rate: 38400
- Function Codes:
  * 0x03: Read Holding Registers (for reading data)
  * 0x05: Write Single Coil (for control operations)
  * 0x10: Write Multiple Registers (for configuration)
4. Chip Addressing
The N30 Energy Module contains 3 measurement chips, each with a base address:
| Chip Number | Base Address | Physical Location  |
| Chip 1      | 100          | Main board P1      |
| Chip 2      | 200          | Main board P2      |
| Chip 3      | 300          | Main board P3      |
Aggregate data from all 3 chips is available starting at address 1000.
5. Data Structure
Each chip provides the following data (accessible via Function Code 0x03):
5.1 Current Measurements (RMS) per Chip
| Register Offset| Parameter  | Units | Format | Resolution    |
| 0              | RMS_1      | A     | uint32 | 0.001A/LSB    |
| 2              | RMS_2      | A     | uint32 | 0.001A/LSB    |
| 4              | RMS_3      | A     | uint32 | 0.001A/LSB    |
| 6              | RMS_4      | A     | uint32 | 0.001A/LSB    |
| 8              | RMS_5      | A     | uint32 | 0.001A/LSB    |
| 10             | RMS_6      | A     | uint32 | 0.001A/LSB    |
| 12             | RMS_7      | A     | uint32 | 0.001A/LSB    |
| 14             | RMS_8      | A     | uint32 | 0.001A/LSB    |
| 16             | RMS_9      | A     | uint32 | 0.001A/LSB    |
| 18             | RMS_10     | A     | uint32 | 0.001A/LSB    |
Example: To read RMS_1 from Chip 1, read registers 100 and 101 (2 registers for uint32).
Example: To read RMS_1 from Chip 2, read registers 200 and 201 (2 registers for uint32).
Example: To read RMS_1 from Chip 3, read registers 300 and 301 (2 registers for uint32).
Display: Reading of 5432 represents 5.432A (5432 × 0.001A)
5.2 Power Measurements (WATT) per Chip
| 20             | WATT_1     | W     | uint32 | 0.1W/LSB      |
| 22             | WATT_2     | W     | uint32 | 0.1W/LSB      |
| 24             | WATT_3     | W     | uint32 | 0.1W/LSB      |
| 26             | WATT_4     | W     | uint32 | 0.1W/LSB      |
| 28             | WATT_5     | W     | uint32 | 0.1W/LSB      |
| 30             | WATT_6     | W     | uint32 | 0.1W/LSB      |
| 32             | WATT_7     | W     | uint32 | 0.1W/LSB      |
| 34             | WATT_8     | W     | uint32 | 0.1W/LSB      |
| 36             | WATT_9     | W     | uint32 | 0.1W/LSB      |
| 38             | WATT_10    | W     | uint32 | 0.1W/LSB      |
Example: To read WATT_1 from Chip 1, read registers 120 and 121 (2 registers for uint32).
Example: To read WATT_1 from Chip 2, read registers 220 and 221 (2 registers for uint32).
Example: To read WATT_1 from Chip 3, read registers 320 and 321 (2 registers for uint32).
Display: Reading of 12345 represents 1234.5W (12345 × 0.1W)
5.3 Energy Consumption Measurements per Chip
| 40             | Energy_1    | kWh   | uint32 | 1kWh/LSB            |
| 42             | Energy_2    | kWh   | uint32 | 1kWh/LSB            |
| 44             | Energy_3    | kWh   | uint32 | 1kWh/LSB            |
| 46             | Energy_4    | kWh   | uint32 | 1kWh/LSB            |
| 48             | Energy_5    | kWh   | uint32 | 1kWh/LSB            |
| 50             | Energy_6    | kWh   | uint32 | 1kWh/LSB            |
| 52             | Energy_7    | kWh   | uint32 | 1kWh/LSB            |
| 54             | Energy_8    | kWh   | uint32 | 1kWh/LSB            |
| 56             | Energy_9    | kWh   | uint32 | 1kWh/LSB            |
| 58             | Energy_10   | kWh   | uint32 | 1kWh/LSB            |
| 60             | Energy_Sum  | kWh   | uint32 | 1kWh/LSB            |
Note: The maximum measurable energy per channel is 65535 kWh.
5.4 Other Measurements per Chip
| 62             | RMS_V       | V     | uint16 | 0.01V/LSB           |
| 63             | Period      | Hz    | uint16 | 0.01Hz/LSB          |
| 64             | TPS1        | °C    | float  | 0.1°C/LSB           |
| 66             | PF          | -     | float  | Power Factor (0-1)  |
6. Channel Mapping
Total of 30 energy monitoring channels:
- Channels 1-10: Managed by Chip 1 (base address 100)
- Channels 11-20: Managed by Chip 2 (base address 200)
- Channels 21-30: Managed by Chip 3 (base address 300)
Each chip reports its 10 channels as local channels 1-10 in the register mapping.
7. Control Functions (Function Code 0x05)
The following control registers can be written to using the Modbus function code 0x05:
| Register | Function                     | Description                                |
| 500      | Warm Reset                   | Resets the device                          |
| 501      | Save Parameters to Flash     | Save communication parameters to flash     |
| 503      | Save Coefficients to Flash   | Save calibration coefficients to flash     |
| 504      | Clear Coefficients           | Reset all coefficients to 1.0 (use caution)|
| 510      | Restore Factory Settings     | Restore factory communication parameters   |
8. Energy Clearing Functions (Function Code 0x05)
The following registers clear energy consumption data when written with function code 0x05:
8.1 Clear All Channels on a Chip
| 520      | Clear all energy on Chip 1     |
| 521      | Clear all energy on Chip 2     |
| 522      | Clear all energy on Chip 3     |
8.2 Clear Individual Channels
| Register Range | Function                                       |
| 526-535        | Clear energy on Chip 1, channels 1-10          |
| 536-545        | Clear energy on Chip 2, channels 1-10          |
| 546-555        | Clear energy on Chip 3, channels 1-10          |
| 586            | Clear sum energy on Chip 1                     |
| 587            | Clear sum energy on Chip 2                     |
| 588            | Clear sum energy on Chip 3                     |
9. Calibration Coefficients (Function Code 0x03 to read, 0x10 to write)
All coefficients are stored as floating-point values in CDBA format.
9.1 Current (RMS) Coefficients for Chip 1
| Register | Parameter           | Default |
| 3000     | FACTOR OF RMS1      | 1.0     |
| 3002     | FACTOR OF RMS2      | 1.0     |
| 3004     | FACTOR OF RMS3      | 1.0     |
| 3006     | FACTOR OF RMS4      | 1.0     |
| 3008     | FACTOR OF RMS5      | 1.0     |
| 3010     | FACTOR OF RMS6      | 1.0     |
| 3012     | FACTOR OF RMS7      | 1.0     |
| 3014     | FACTOR OF RMS8      | 1.0     |
| 3016     | FACTOR OF RMS9      | 1.0     |
| 3018     | FACTOR OF RMS10     | 1.0     |
9.2 Power (WATT) Coefficients for Chip 1
| 3020     | FACTOR OF WATT1     | 1.0     |
| 3022     | FACTOR OF WATT2     | 1.0     |
| 3024     | FACTOR OF WATT3     | 1.0     |
| 3026     | FACTOR OF WATT4     | 1.0     |
| 3028     | FACTOR OF WATT5     | 1.0     |
| 3030     | FACTOR OF WATT6     | 1.0     |
| 3032     | FACTOR OF WATT7     | 1.0     |
| 3034     | FACTOR OF WATT8     | 1.0     |
| 3036     | FACTOR OF WATT9     | 1.0     |
| 3038     | FACTOR OF WATT10    | 1.0     |
9.3 Energy Coefficients for Chip 1
| 3040     | FACTOR OF ENERGY1     | 1.0     |
| 3042     | FACTOR OF ENERGY2     | 1.0     |
| 3044     | FACTOR OF ENERGY3     | 1.0     |
| 3046     | FACTOR OF ENERGY4     | 1.0     |
| 3048     | FACTOR OF ENERGY5     | 1.0     |
| 3050     | FACTOR OF ENERGY6     | 1.0     |
| 3052     | FACTOR OF ENERGY7     | 1.0     |
| 3054     | FACTOR OF ENERGY8     | 1.0     |
| 3056     | FACTOR OF ENERGY9     | 1.0     |
| 3058     | FACTOR OF ENERGY10    | 1.0     |
| 3060     | FACTOR OF ENERGY SUM  | 1.0     |
9.4 Other Chip Calibration Coefficient Base Addresses
The calibration coefficients for other chips follow the same structure but start at
different base addresses:
| Chip Number | Base Register |
| Chip 2      | 3064          |
| Chip 3      | 3128          |
10. Data Aggregation
Gateway systems can aggregate data from all three chips:
- Total System Current = Sum of all RMS values from all chips
- Total System Power = Sum of all WATT values from all chips
- Total System Energy = Sum of all Energy values from all chips
- Average System Voltage = Average of RMS_V from all chips
- Average System Frequency = Average of Period from all chips
- Maximum System Temperature = Maximum of TPS1 from all chips
11. Advanced Features
11.1 Load Balancing
N30 devices can implement intelligent load balancing:
- Distribute circuits across three chips for balanced loading
- Monitor per-chip temperature and adjust loads
- Implement chip-level alarming and fault detection
11.2 Fault Tolerance
With three chips, the N30 provides enhanced fault tolerance:
- Continued operation even if one chip fails
- Redundant monitoring of critical circuits
- Automatic failover capabilities
12. Programming Notes
1. After modifying communication parameters, write to register 501 to save them to flash.
2. After modifying calibration coefficients, write to register 503 to save them to flash.
3. Read the entire data structure for a chip by reading 68 registers starting at the
   chip's base address.
4. For 32-bit values (uint32, float), read/write two consecutive registers.
5. When writing float values, use the CDBA format.
6. All energy measurements have a maximum value of 65535 kWh per channel.
7. Monitor all three chips to detect individual chip failures.
8. Implement timeout detection for missing chip data.
13. Installation and Deployment
13.1 Circuit Assignment
Recommended circuit assignment strategy:
- Distribute high-priority circuits across all three chips
- Balance total current load per chip
- Consider thermal management (spread high-power circuits)
- Maintain critical circuit monitoring even if one chip fails
13.2 Monitoring Strategy
For N30 deployment:
- Implement comprehensive monitoring of all three chips
- Set up alarm conditions for chip failures
- Monitor temperature across all chips
- Implement load balancing algorithms
14. Comparison Table
| Feature          | N10             | N20              | N30              | N60              |
| Communication    | Modbus RTU      | Modbus RTU       | Modbus RTU       | Modbus RTU       |
| Energy Chips     | 1               | 2                | 3                | 6                |
| Channels         | 10              | 20               | 30               | 60               |
| Base Addresses   | 100             | 100, 200         | 100, 200, 300    | 100-600          |
| Data Structure   | Standard        | Dual-chip        | Triple-chip      | Six-chip         |
| Installation     | Wired           | Wired            | Wired            | Wired            |
| Fault Tolerance  | Basic           | Enhanced         | High             | Maximum          |
15. Conclusion
The N30 Energy Module provides triple-chip energy monitoring with Modbus RTU
communication, offering the highest monitoring capacity in the N-series while
maintaining protocol compatibility. The device is ideal for large-scale installations
requiring comprehensive electrical measurement and monitoring across many circuits,
with enhanced reliability through triple redundancy.
The N30 represents the pinnacle of the N-series energy monitoring family, providing
30-channel monitoring capability with advanced features like load balancing, fault
tolerance, and intelligent circuit distribution.
Document generated for N30 Energy Module Modbus Protocol
For technical support, please contact Kincony support team.
protocol document download:
.txt   N30_Energy_Modbus_Protocol.txt (Size: 15.55 KB / Downloads: 356)
  N20 Energy RS485 Modbus Protocol
Posted by: admin - 10-13-2025, 02:05 AM - Forum: N20 - Replies (3)
N20 Energy Module Modbus Protocol Specification
1. Overview
This document specifies the Modbus communication protocol for the N20 Energy Module.
temperature, and power factor from 2 independent energy monitoring chips.
- Energy Monitoring Chips: 2
- Baud Rate: 38400
- Function Codes:
4. Chip Addressing
The N20 Energy Module contains 2 measurement chips, each with a base address:
Aggregate data from both chips is available starting at address 1000.
5. Data Structure
6. Channel Mapping
Total of 20 energy monitoring channels:
9.4 Chip 2 Calibration Coefficient Base Address
The calibration coefficients for Chip 2 follow the same structure but start at
base address 3064:
| Chip 2      | 3064          |
Gateway systems can aggregate data from both chips:
- Total System Current = Sum of all RMS values from both chips
- Total System Power = Sum of all WATT values from both chips
- Total System Energy = Sum of all Energy values from both chips
- Average System Voltage = Average of RMS_V from both chips
- Average System Frequency = Average of Period from both chips
11. Programming Notes
7. Monitor both chips to detect individual chip failures.
12. Comparison Table
13. Conclusion
The N20 Energy Module provides dual-chip energy monitoring with Modbus RTU
communication, offering twice the monitoring capacity of the N10 while maintaining
the same communication protocol structure. The device is ideal for medium-scale
installations requiring electrical measurement and monitoring across multiple circuits.
Document generated for N20 Energy Module Modbus Protocol
.txt   N20_Energy_Modbus_Protocol.txt (Size: 13.25 KB / Downloads: 344)
  N10 Energy RS485 Modbus Protocol
Posted by: admin - 10-13-2025, 02:04 AM - Forum: N10 - Replies (1)
N10 Energy Module Modbus Protocol Specification
1. Overview
This document specifies the Modbus communication protocol for the N10 Energy Module.
temperature, and power factor.
- Energy Monitoring Chips: 1
- Baud Rate: 38400
- Function Codes:
4. Chip Addressing
The N10 Energy Module contains 1 measurement chip with base address:
| Chip 1      | 100          | Main board         |
5. Data Structure
The chip provides the following data (accessible via Function Code 0x03):
6. Control Functions (Function Code 0x05)
7. Energy Clearing Functions (Function Code 0x05)
7.1 Clear All Channels on the Chip
7.2 Clear Individual Channels
8. Calibration Coefficients (Function Code 0x03 to read, 0x10 to write)
8.1 Current (RMS) Coefficients for Chip 1
8.2 Power (WATT) Coefficients for Chip 1
8.3 Energy Coefficients for Chip 1
9. Programming Notes
3. Read the entire data structure for the chip by reading 68 registers starting at base
   address 100.
10. Comparison with Other N-Series Modules
11. Conclusion
The N10 Energy Module provides single-chip energy monitoring with Modbus RTU
communication, making it ideal for small-scale installations requiring precise
electrical measurement and monitoring. The device offers 10 channels of current,
power, and energy monitoring with comprehensive calibration and control capabilities.
Document generated for N10 Energy Module Modbus Protocol
.txt   N10_Energy_Modbus_Protocol.txt (Size: 11.62 KB / Downloads: 397)
  N60 Energy RS485 Modbus Protocol
Posted by: admin - 10-13-2025, 02:03 AM - Forum: N60 - Replies (1)
N60 Energy Module Modbus Protocol Specification
1. Overview
This document specifies the Modbus communication protocol for the N60 Energy Module.
2. Communication Parameters
- Baud Rate: 38400
- Function Codes:
3. Chip Addressing
The N60 Energy Module contains 6 measurement chips, each with a base address:
| Chip 1      | 100          | Bottom board P9    |
| Chip 2      | 200          | Bottom board P10   |
| Chip 3      | 300          | Bottom board P11   |
| Chip 4      | 400          | Bottom board P12   |
| Chip 5      | 500          | Bottom board P13   |
| Chip 6      | 600          | Bottom board P14   |
Aggregate data from all 6 chips is available starting at address 1000.
4. Data Structure
4.1 Current Measurements (RMS)
4.2 Power Measurements (WATT)
4.3 Energy Consumption Measurements
4.4 Other Measurements
5. Control Functions (Function Code 0x05)
6. Energy Clearing Functions (Function Code 0x05)
6.1 Clear All Channels on a Chip
| 523      | Clear all energy on Chip 4     |
| 524      | Clear all energy on Chip 5     |
| 525      | Clear all energy on Chip 6     |
6.2 Clear Individual Channels
| 556-565        | Clear energy on Chip 4, channels 1-10          |
| 566-575        | Clear energy on Chip 5, channels 1-10          |
| 576-585        | Clear energy on Chip 6, channels 1-10          |
| 589            | Clear sum energy on Chip 4                     |
| 590            | Clear sum energy on Chip 5                     |
| 591            | Clear sum energy on Chip 6                     |
7. Calibration Coefficients (Function Code 0x03 to read, 0x10 to write)
7.1 Current (RMS) Coefficients for Chip 1
7.2 Power (WATT) Coefficients for Chip 1
7.3 Energy Coefficients for Chip 1
7.4 Other Chip Calibration Coefficient Base Addresses
| Chip 2      | 3064          |
| Chip 3      | 3128          |
| Chip 4      | 3192          |
| Chip 5      | 3256          |
| Chip 6      | 3320          |
8. Programming Notes
Document generated from n60_energy_modbus_protocol.org
.txt   N60_Energy_Modbus_Protocol.txt (Size: 11.84 KB / Downloads: 351)
