» Members: 10,057
» Latest member: apkspanda
» Forum threads: 4,253
» Forum posts: 21,064
There are currently 261 online users.
» 0 Member(s) | 240 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, HeadlessChrome, PetalBot, bot, owler
Best way to read from N30
Forum: N30
Last Post: ChrisNZ
7 hours ago
N60/N30/N20/N10 PC softwa...
Forum: N10
9 hours ago
» Replies: 7
getting the A8A inputs to...
Forum: Development
09-24-2026, 11:07 PM
extend KC868-A16v3
Last Post: bitet96717
09-24-2026, 06:41 AM
Las Firmware ?
09-22-2026, 11:15 PM
» Replies: 8
kc868-a6 analog input
09-21-2026, 11:38 PM
A32 pro tuya
Disconnect loop with Home...
Forum: F16
09-21-2026, 01:16 AM
KC-868-A1 linked Home Ass...
Forum: News
config modbus sensor in K...
09-19-2026, 11:52 AM
  [arduino code examples for N10]-03 Ethernet W5500 chip work with TCP Server mode
Posted by: admin - 08-03-2025, 03:18 AM - Forum: N10 - No Replies
* received from a client.
* Hardware connections:
* - CLK: GPIO42
* - MOSI: GPIO43
* - MISO: GPIO44
* - CS: GPIO41
* - RST: GPIO1
* - INT: GPIO2
* Subnet Mask: 255.255.255.0
* Gateway: 192.168.3.1
* DNS: 192.168.3.1
#include <SPI.h>
#include <Ethernet.h>
#define W5500_CS_PIN  41
#define W5500_RST_PIN 1
#define W5500_INT_PIN 2
#define W5500_CLK_PIN 42
#define W5500_MOSI_PIN 43
#define W5500_MISO_PIN 44
EthernetServer server(4196);
  while (!Serial) {
  Ethernet.init(W5500_CS_PIN);
  Serial.print("IP Address: ");
  server.begin();
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        server.write(c);
    client.stop();
arduino ino file download:
.zip   3-Ethernet-W5500.zip (Size: 1.23 KB / Downloads: 608)
.zip   3-Ethernet-W5500.ino.merged.zip (Size: 191.07 KB / Downloads: 652)
  [arduino code examples for N20]-03 Ethernet W5500 chip work with TCP Server mode
Posted by: admin - 08-03-2025, 03:18 AM - Forum: N20 - No Replies
* - CLK: GPIO42
* - MOSI: GPIO43
* - MISO: GPIO44
* - CS: GPIO41
* - RST: GPIO1
* - INT: GPIO2
* DNS: 192.168.3.1
#include <SPI.h>
  while (!Serial) {
  server.begin();
  if (client) {
        server.write(c);
    client.stop();
.zip   3-Ethernet-W5500.zip (Size: 1.23 KB / Downloads: 601)
.zip   3-Ethernet-W5500.ino.merged.zip (Size: 191.07 KB / Downloads: 621)
  [arduino code examples for N30]-03 Ethernet W5500 chip work with TCP Server mode
Posted by: admin - 08-03-2025, 03:18 AM - Forum: N30 - No Replies
* - CLK: GPIO42
* - MOSI: GPIO43
* - MISO: GPIO44
* - CS: GPIO41
* - RST: GPIO1
* - INT: GPIO2
* DNS: 192.168.3.1
#include <SPI.h>
  while (!Serial) {
  server.begin();
  if (client) {
        server.write(c);
    client.stop();
.zip   3-Ethernet-W5500.zip (Size: 1.23 KB / Downloads: 615)
.zip   3-Ethernet-W5500.ino.merged.zip (Size: 191.07 KB / Downloads: 599)
  [arduino code examples for N60]-02 How to use SD Card
Posted by: admin - 08-03-2025, 03:17 AM - Forum: N60 - No Replies
* SD Card File Operations
* Hardware Connections:
* - SCK: GPIO 11
* - MISO: GPIO 12
* - MOSI: GPIO 10
* - CS: GPIO 9
#include "FS.h"
#include "SD.h"
#include "SPI.h"
#define SCK  39
#define MISO 38
#define MOSI 40
#define CS   48
  File file = fs.open(path);
  if (!file) {
    return;
  while (file.available()) {
  file.close();
  if (!file) {
    return;
  if (file.print(message)) {
  file.close();
  if (!file) {
    return;
  file.close();
  if (fs.remove(path)) {
  static uint8_t buf[512];
  size_t len = 0;
  uint32_t start = millis();
  uint32_t end = start;
  if (file) {
    len = file.size();
    size_t flen = len;
    start = millis();
    while (len) {
      size_t toRead = len;
      if (toRead > 512) {
        toRead = 512;
      file.read(buf, toRead);
      len -= toRead;
    end = millis() - start;
    file.close();
  if (!file) {
    return;
  size_t i;
  start = millis();
  for (i = 0; i < 2048; i++) {
    file.write(buf, 512);
  file.close();
  // Initialize SPI and SD card
    return;
  if (cardType == CARD_NONE) {
    return;
  if (cardType == CARD_MMC) {
    Serial.println("MMC");
    Serial.println("SDSC");
    Serial.println("SDHC");
    Serial.println("UNKNOWN");
  delay(2000);
  // Perform file operations
  deleteFile(SD, "/hello.txt");
  readFile(SD, "/hello.txt");
  testFileIO(SD, "/test.txt");
  // No operation in loop
.zip   2-SD.zip (Size: 1.54 KB / Downloads: 604)
.zip   2-SD.ino.merged.zip (Size: 219.15 KB / Downloads: 596)
  [arduino code examples for N10]-02 How to use SD Card
Posted by: admin - 08-03-2025, 03:17 AM - Forum: N10 - No Replies
* - SCK: GPIO 11
* - MISO: GPIO 12
* - MOSI: GPIO 10
* - CS: GPIO 9
#include "FS.h"
#include "SD.h"
#include "SPI.h"
#define SCK  39
#define MISO 38
#define MOSI 40
#define CS   48
  if (!file) {
    return;
  file.close();
  if (!file) {
    return;
  file.close();
  if (!file) {
    return;
  file.close();
  size_t len = 0;
  if (file) {
    len = file.size();
    size_t flen = len;
    start = millis();
    while (len) {
      if (toRead > 512) {
        toRead = 512;
      len -= toRead;
    file.close();
  if (!file) {
    return;
  size_t i;
  start = millis();
  file.close();
    return;
    return;
  delay(2000);
.zip   2-SD.zip (Size: 1.54 KB / Downloads: 613)
.zip   2-SD.ino.merged.zip (Size: 219.15 KB / Downloads: 625)
  [arduino code examples for N20]-02 How to use SD Card
Posted by: admin - 08-03-2025, 03:17 AM - Forum: N20 - No Replies
* - SCK: GPIO 11
* - MISO: GPIO 12
* - MOSI: GPIO 10
* - CS: GPIO 9
#include "FS.h"
#include "SD.h"
#include "SPI.h"
#define SCK  39
#define MISO 38
#define MOSI 40
#define CS   48
  if (!file) {
    return;
  file.close();
  if (!file) {
    return;
  file.close();
  if (!file) {
    return;
  file.close();
  size_t len = 0;
  if (file) {
    len = file.size();
    size_t flen = len;
    start = millis();
    while (len) {
      if (toRead > 512) {
        toRead = 512;
      len -= toRead;
    file.close();
  if (!file) {
    return;
  size_t i;
  start = millis();
  file.close();
    return;
    return;
  delay(2000);
.zip   2-SD.zip (Size: 1.54 KB / Downloads: 645)
.zip   2-SD.ino.merged.zip (Size: 219.15 KB / Downloads: 609)
  [arduino code examples for N30]-02 How to use SD Card
Posted by: admin - 08-03-2025, 03:17 AM - Forum: N30 - No Replies
* - SCK: GPIO 11
* - MISO: GPIO 12
* - MOSI: GPIO 10
* - CS: GPIO 9
#include "FS.h"
#include "SD.h"
#include "SPI.h"
#define SCK  39
#define MISO 38
#define MOSI 40
#define CS   48
  if (!file) {
    return;
  file.close();
  if (!file) {
    return;
  file.close();
  if (!file) {
    return;
  file.close();
  size_t len = 0;
  if (file) {
    len = file.size();
    size_t flen = len;
    start = millis();
    while (len) {
      if (toRead > 512) {
        toRead = 512;
      len -= toRead;
    file.close();
  if (!file) {
    return;
  size_t i;
  start = millis();
  file.close();
    return;
    return;
  delay(2000);
.zip   2-SD.zip (Size: 1.54 KB / Downloads: 647)
.zip   2-SD.ino.merged.zip (Size: 219.15 KB / Downloads: 687)
  [arduino code examples for N60]-01 Read digital input ports state
Posted by: admin - 08-03-2025, 03:15 AM - Forum: N60 - No Replies
  This program reads the digital state of GPIO15 and GPIO16 on an ESP32
  and prints their state (HIGH or LOW) to the serial monitor every 500ms.
#define PIN_GPIO15 15  // Define GPIO15
#define PIN_GPIO16 16  // Define GPIO16
  Serial.begin(115200);               // Initialize serial communication at 115200 baud
  pinMode(PIN_GPIO15, INPUT);         // Set GPIO15 as input
  pinMode(PIN_GPIO16, INPUT);         // Set GPIO16 as input
  Serial.println("ESP32 GPIO15 and GPIO16 State Monitor");
  int state15 = digitalRead(PIN_GPIO15);  // Read state of GPIO15
  int state16 = digitalRead(PIN_GPIO16);  // Read state of GPIO16
  // Print the state to the serial monitor
  Serial.print("GPIO15: ");
  Serial.print(state15 == HIGH ? "HIGH" : "LOW");
  Serial.print("  |  GPIO16: ");
  Serial.println(state16 == HIGH ? "HIGH" : "LOW");
  delay(500);  // Wait for 500 milliseconds before reading again
.zip   1-free-gpio-state.zip (Size: 632 bytes / Downloads: 589)
.zip   1-free-gpio-state.ino.merged.zip (Size: 181.39 KB / Downloads: 609)
  [arduino code examples for N10]-01 Read digital input ports state
Posted by: admin - 08-03-2025, 03:15 AM - Forum: N10 - No Replies
.zip   1-free-gpio-state.zip (Size: 632 bytes / Downloads: 688)
.zip   1-free-gpio-state.ino.merged.zip (Size: 181.39 KB / Downloads: 623)
  [arduino code examples for N20]-01 Read digital input ports state
Posted by: admin - 08-03-2025, 03:15 AM - Forum: N20 - No Replies
.zip   1-free-gpio-state.zip (Size: 632 bytes / Downloads: 612)
.zip   1-free-gpio-state.ino.merged.zip (Size: 181.39 KB / Downloads: 650)
