» Members: 9,981
» Latest member: bboett
» Forum threads: 4,247
» Forum posts: 21,036
There are currently 191 online users.
» 0 Member(s) | 165 Guest(s)
AhrefsBot, Amazonbot, Applebot, AwarioBot, Baidu, Google, HeadlessChrome, Sogou web, bot, curl, python-requests
remember relay state
Forum: KC868-E16T
Last Post: greeryan
3 hours ago
Ceiling fan control not w...
Yesterday, 07:15 AM
» Replies: 11
Output pin protection
Forum: T16M
09-17-2026, 11:44 PM
Modbus 485 extender kcs V...
Forum: N30
09-17-2026, 08:10 AM
» Replies: 11
N10 with L1 and L2 suppor...
Forum: N10
09-16-2026, 11:34 PM
KC868-A16v3 PCB layout CA...
09-16-2026, 11:33 PM
Case
Forum: KC868-A16S
09-15-2026, 02:26 AM
KC868-A16S PCB layout CAD...
09-14-2026, 11:23 PM
flash kc868-a4
09-14-2026, 11:18 PM
» Replies: 25
KC868-A16 – Using AI3/AI4...
09-14-2026, 08:27 AM
  N60/N30/N20/N10 PC software for RS485 modbus connection
Posted by: admin - 08-03-2025, 03:07 AM - Forum: N20 - Replies (3)
connect PC to N60 by USB-RS485 adapter.
pc software download:
.zip   N60_APP.zip (Size: 1.66 MB / Downloads: 692)
Posted by: admin - 08-03-2025, 03:07 AM - Forum: N30 - Replies (5)
.zip   N60_APP.zip (Size: 1.66 MB / Downloads: 688)
  Problem with ds18b20 on Port 1-3
Posted by: ubfox - 08-02-2025, 12:44 PM - Forum: KC868-A16v3 - Replies (1)
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 21
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
DeviceAddress addr;
  Serial.println("Starte Sensor-Test...");
  delay(500);
  sensors.begin();
  delay(5000);
  int count = sensors.getDeviceCount();
  Serial.printf("Gefundene Sensoren: %d\n", count);
  if (count == 0) {
    Serial.println("Keine Sensoren gefunden.");
    return;
  for (int i = 0; i < count; i++) {
    if (sensors.getAddress(addr, i)) {
      Serial.print("Sensor-Adresse: ");
      for (uint8_t j = 0; j < 8; j++) {
        Serial.printf("%02X", addr[j]);
      Serial.println();
      Serial.printf("Sensor %d: Adresse nicht lesbar\n", i);
  Serial.println("Starte Sensor-Test1...");
  delay(5000);
This dos not work - why
; PlatformIO Project Configuration File
;  Build options: build flags, source filter
;  Upload options: custom upload port, speed and extra flags
;  Library options: dependencies, extra library storages
;  Advanced options: extra scripting
; Please visit documentation for the other options and examples
; https://docs.platformio.org/page/projectconf.html
[env:esp32-s3-devkitm-1]
platform = espressif32
board = esp32-s3-devkitm-1
framework = arduino
monitor_speed = 115200
monitor_auto = yes
monitor_rts = 0
monitor_dtr = 0
build_flags =
  -D ARDUINO_USB_MODE=1
  -D ARDUINO_USB_CDC_ON_BOOT=1
lib_deps =
  # RECOMMENDED
  # Accept new functionality in a backwards compatible manner and patches
  ;pstolarz/OneWireNg @ ^0.13.3
  paulstoffregen/OneWire @ ^2.3.8
  milesburton/DallasTemperature @ ^4.0.4
  KC868_E16S dimentions
Posted by: jeftevag - 08-02-2025, 10:27 AM - Forum: Schematic & diagram & Dimensions of KinCony PCB layout CAD file - Replies (9)
I need dimentions for this board, making a front panel. What is the spacing between switches and LED's? Can you publish a PDF-drawing with dimentions for this board?
  binary sensor board with rj45 connectors instead of screw terminals?
Posted by: flatulentflamingo - 08-02-2025, 05:54 AM - Forum: Suggestions and feedback on KinCony's products - Replies (8)
Could you build a binary sensor board with screw terminals replaced by female rj45 connectors?
I am very happy about the KC868-AI I bought. It does what it promises. I use it as the central smart home sensor controller for all (dual) light switches at our summer house. Only the physical wiring could be easier for simple binary sensors.
Here's what I built:
[Image: 4QD93cv.png]
Here is what I would want:
[Image: 3ubAsGS.png]
This would allow to make a common scenario stupidly simple on the hardware front. Just plug standard cat5e cable between central patch panel and Kincony board, for dual binary sensors per cable. (With some cleverness, even dual 1-wire should be possible using two unused extra strands from the cat5e cable, but I digress...)
And please do keep adding PoE support to your existing boards! That is great functionality, and it would be a great addition to this style of board!
  KC868-a16 XY-MD02 SHT20
Posted by: silver_kruf - 08-02-2025, 05:45 AM - Forum: News - Replies (4)
Good day. I ordered a temperature and humidity sensor, I'm trying to connect it, but the sensor doesn't respond. Maybe I'm doing something wrong. I connected it via USB, and also via KC868-a16
  N60 configure yaml for ESPhome
Posted by: admin - 08-02-2025, 01:00 AM - Forum: N60 - Replies (7)
  friendly_name: n60
  board: esp32-s3-devkitc-1
  # baud_rate: 0
  encryption:
    key: "8G0kVEA0/DqgAavgKNyy9EYUrWo6pEZM38JVMAryJv8="
ota:
  platform: esphome
  password: "2a26484203d80a83798414c879541760"
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  interrupt_pin: GPIO2
  reset_pin: GPIO1
  rx_pin: 9
  tx_pin: 10
  baud_rate: 115200
  stop_bits: 1
  data_bits: 8
  parity: NONE
web_server:
  port: 80
text_sensor:
  - platform: ethernet_info
    ip_address:
      name: ESP IP Address
      address_0:
        name: ESP IP Address 0
      address_1:
        name: ESP IP Address 1
      address_2:
        name: ESP IP Address 2
      address_3:
        name: ESP IP Address 3
      address_4:
        name: ESP IP Address 4
    dns_address:
      name: ESP DNS Address
    mac_address:
      name: ESP MAC Address
font:
  - file: "gfonts://Roboto"
  sda: 18
  scl: 17
display:
  - platform: ssd1306_i2c
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
modbus:
modbus_controller:
  - address: 1
    update_interval: 5s
  - platform: modbus_controller
    address: 100
    register_type: holding
    unit_of_measurement: A
    device_class: current
    accuracy_decimals: 3
    value_type: U_DWORD_R
    filters:
      - multiply: 0.001
    address: 102
    filters:
      - multiply: 0.001
    address: 104
    filters:
      - multiply: 0.001
    address: 106
    filters:
      - multiply: 0.001
    address: 108
    filters:
      - multiply: 0.001
    address: 110
    filters:
      - multiply: 0.001
    address: 112
    filters:
      - multiply: 0.001
    address: 114
    filters:
      - multiply: 0.001
    address: 116
    filters:
      - multiply: 0.001
    address: 118
    filters:
      - multiply: 0.001
    address: 120
    unit_of_measurement: W
    device_class: power
    accuracy_decimals: 1
    filters:
      - multiply: 0.1
    address: 122
    device_class: power
    filters:
      - multiply: 0.1
    address: 124
    device_class: power
    filters:
      - multiply: 0.1
    address: 126
    device_class: power
    filters:
      - multiply: 0.1
    address: 128
    device_class: power
    filters:
      - multiply: 0.1
    address: 130
    device_class: power
    filters:
      - multiply: 0.1
    address: 132
    device_class: power
    filters:
      - multiply: 0.1
    address: 134
    device_class: power
    filters:
      - multiply: 0.1
    address: 136
    device_class: power
    filters:
      - multiply: 0.1
    address: 138
    device_class: power
    filters:
      - multiply: 0.1
    state_class: total_increasing
    device_class: energy
    address: 140
    unit_of_measurement: kWh
    address: 142
    address: 144
    address: 146
    address: 148
    address: 150
    address: 152
    address: 154
    address: 156
    address: 158
    address: 160
    address: 162
    unit_of_measurement: V
    device_class: voltage
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 163
    unit_of_measurement: Hz
    device_class: frequency
    value_type: U_WORD
    filters:
      - multiply: 0.01
    address: 164
    unit_of_measurement: °C
    device_class: temperature
    value_type: FP32_R
    address: 200
    filters:
    - multiply: 0.001
    address: 202
    filters:
    - multiply: 0.001
    address: 204
    filters:
    - multiply: 0.001
    address: 206
    filters:
    - multiply: 0.001
    address: 208
    filters:
    - multiply: 0.001
    address: 210
    filters:
    - multiply: 0.001
    address: 212
    filters:
    - multiply: 0.001
    address: 214
    filters:
    - multiply: 0.001
    address: 216
    filters:
    - multiply: 0.001
    address: 218
    filters:
    - multiply: 0.001
    address: 220
    device_class: power
    filters:
    - multiply: 0.1
    address: 222
    device_class: power
    filters:
    - multiply: 0.1
    address: 224
    device_class: power
    filters:
    - multiply: 0.1
    address: 226
    device_class: power
    filters:
    - multiply: 0.1
    address: 228
    device_class: power
    filters:
    - multiply: 0.1
    address: 230
    device_class: power
    filters:
    - multiply: 0.1
    address: 232
    device_class: power
    filters:
    - multiply: 0.1
    address: 234
    device_class: power
    filters:
    - multiply: 0.1
    address: 236
    device_class: power
    filters:
    - multiply: 0.1
    address: 238
    device_class: power
    filters:
    - multiply: 0.1
    address: 240
    address: 242
    address: 244
    address: 246
    address: 248
    address: 250
    address: 252
    address: 254
    address: 256
    address: 258
    address: 260
    address: 262
    value_type: U_WORD
    filters:
    - multiply: 0.01
    address: 263
    value_type: U_WORD
    filters:
    - multiply: 0.01
    address: 264
    unit_of_measurement: "\xB0C"
    value_type: FP32_R
    address: 300
    filters:
    - multiply: 0.001
    address: 302
    filters:
    - multiply: 0.001
    address: 304
    filters:
    - multiply: 0.001
    address: 306
    filters:
    - multiply: 0.001
    address: 308
    filters:
    - multiply: 0.001
    address: 310
    filters:
    - multiply: 0.001
    address: 312
    filters:
    - multiply: 0.001
    address: 314
    filters:
    - multiply: 0.001
    address: 316
    filters:
    - multiply: 0.001
    address: 318
    filters:
    - multiply: 0.001
    address: 320
    device_class: power
    filters:
    - multiply: 0.1
    address: 322
    device_class: power
    filters:
    - multiply: 0.1
    address: 324
    device_class: power
    filters:
    - multiply: 0.1
    address: 326
    device_class: power
    filters:
    - multiply: 0.1
    address: 328
    device_class: power
    filters:
    - multiply: 0.1
    address: 330
    device_class: power
    filters:
    - multiply: 0.1
    address: 332
    device_class: power
    filters:
    - multiply: 0.1
    address: 334
    device_class: power
    filters:
    - multiply: 0.1
    address: 336
    device_class: power
    filters:
    - multiply: 0.1
    address: 338
    device_class: power
    filters:
    - multiply: 0.1
    address: 340
    address: 342
    address: 344
    address: 346
    address: 348
    address: 350
    address: 352
    address: 354
    address: 356
    address: 358
    address: 360
    address: 362
    value_type: U_WORD
    filters:
    - multiply: 0.01
    address: 363
    value_type: U_WORD
    filters:
    - multiply: 0.01
    address: 364
    value_type: FP32_R
    address: 400
    filters:
    - multiply: 0.001
    address: 402
    filters:
    - multiply: 0.001
    address: 404
    filters:
    - multiply: 0.001
    address: 406
    filters:
    - multiply: 0.001
    address: 408
    filters:
    - multiply: 0.001
    address: 410
    filters:
    - multiply: 0.001
    address: 412
    filters:
    - multiply: 0.001
    address: 414
    filters:
    - multiply: 0.001
    address: 416
    filters:
    - multiply: 0.001
    address: 418
    filters:
    - multiply: 0.001
    address: 420
    device_class: power
    filters:
    - multiply: 0.1
    address: 422
    device_class: power
    filters:
    - multiply: 0.1
    address: 424
    device_class: power
    filters:
    - multiply: 0.1
    address: 426
    device_class: power
    filters:
    - multiply: 0.1
    address: 428
    device_class: power
    filters:
    - multiply: 0.1
    address: 430
    device_class: power
    filters:
    - multiply: 0.1
    address: 432
    device_class: power
    filters:
    - multiply: 0.1
    address: 434
    device_class: power
    filters:
    - multiply: 0.1
    address: 436
    device_class: power
    filters:
    - multiply: 0.1
    address: 438
    device_class: power
    filters:
    - multiply: 0.1
    address: 440
    address: 442
    address: 444
    address: 446
    address: 448
    address: 450
    address: 452
    address: 454
    address: 456
    address: 458
    address: 460
    address: 462
    value_type: U_WORD
    filters:
    - multiply: 0.01
    address: 463
    value_type: U_WORD
    filters:
    - multiply: 0.01
    address: 464
    value_type: FP32_R
    address: 500
    filters:
    - multiply: 0.001
    address: 502
    filters:
    - multiply: 0.001
    address: 504
    filters:
    - multiply: 0.001
    address: 506
    filters:
    - multiply: 0.001
    address: 508
    filters:
    - multiply: 0.001
    address: 510
    filters:
    - multiply: 0.001
    address: 512
    filters:
    - multiply: 0.001
    address: 514
    filters:
    - multiply: 0.001
    address: 516
    filters:
    - multiply: 0.001
    address: 518
    filters:
    - multiply: 0.001
    address: 520
    device_class: power
    filters:
    - multiply: 0.1
    address: 522
    device_class: power
    filters:
    - multiply: 0.1
    address: 524
    device_class: power
    filters:
    - multiply: 0.1
    address: 526
    device_class: power
    filters:
    - multiply: 0.1
    address: 528
    device_class: power
    filters:
    - multiply: 0.1
    address: 530
    device_class: power
    filters:
    - multiply: 0.1
    address: 532
    device_class: power
    filters:
    - multiply: 0.1
    address: 534
    device_class: power
    filters:
    - multiply: 0.1
    address: 536
    device_class: power
    filters:
    - multiply: 0.1
    address: 538
    device_class: power
    filters:
    - multiply: 0.1
    address: 540
    address: 542
    address: 544
    address: 546
    address: 548
    address: 550
    address: 552
    address: 554
    address: 556
    address: 558
    address: 560
    address: 562
    value_type: U_WORD
    filters:
    - multiply: 0.01
    address: 563
    value_type: U_WORD
    filters:
    - multiply: 0.01
    address: 564
    value_type: FP32_R
    address: 600
    filters:
    - multiply: 0.001
    address: 602
    filters:
    - multiply: 0.001
    address: 604
    filters:
    - multiply: 0.001
    address: 606
    filters:
    - multiply: 0.001
    address: 608
    filters:
    - multiply: 0.001
    address: 610
    filters:
    - multiply: 0.001
    address: 612
    filters:
    - multiply: 0.001
    address: 614
    filters:
    - multiply: 0.001
    address: 616
    filters:
    - multiply: 0.001
    address: 618
    filters:
    - multiply: 0.001
    address: 620
    device_class: power
    filters:
    - multiply: 0.1
    address: 622
    device_class: power
    filters:
    - multiply: 0.1
    address: 624
    device_class: power
    filters:
    - multiply: 0.1
    address: 626
    device_class: power
    filters:
    - multiply: 0.1
    address: 628
    device_class: power
    filters:
    - multiply: 0.1
    address: 630
    device_class: power
    filters:
    - multiply: 0.1
    address: 632
    device_class: power
    filters:
    - multiply: 0.1
    address: 634
    device_class: power
    filters:
    - multiply: 0.1
    address: 636
    device_class: power
    filters:
    - multiply: 0.1
    address: 638
    device_class: power
    filters:
    - multiply: 0.1
    address: 640
    address: 642
    address: 644
    address: 646
    address: 648
    address: 650
    address: 652
    address: 654
    address: 656
    address: 658
    address: 660
    address: 662
    value_type: U_WORD
    filters:
    - multiply: 0.01
    address: 663
    value_type: U_WORD
    filters:
    - multiply: 0.01
    address: 664
    value_type: FP32_R
yaml download:
.txt   N60-HA.txt (Size: 53.91 KB / Downloads: 394)
  N60 ESP32 I/O pin define
Posted by: admin - 08-02-2025, 12:58 AM - Forum: N60 - No Replies
Ethernet (W5500) I/O define:
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
reset_pin: GPIO1
IIC BUS:
SDA:18
SCL:17
SPI BUS (LoRa):
SCK:13
MOSI:12
MISO:11
CS: 14
RST: 21
DIO0:47
ARM CPU TXD:9
ARM CPU RXD:10
free GPIO (without pull up resistance):
GPIO15
GPIO16
SD Card:
SPI-MOSI:GPIO40
SPI-SCK:GPIO39
SPI-MISO:GPIO38
SPI-CS:GPIO48
SPI-CD:GPIO8
  N10 ESP32 I/O pin define
Posted by: admin - 08-02-2025, 12:58 AM - Forum: N10 - No Replies
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
reset_pin: GPIO1
IIC BUS:
SDA:18
SCL:17
SPI BUS (LoRa):
SCK:13
MOSI:12
MISO:11
CS: 14
RST: 21
DIO0:47
ARM CPU TXD:9
ARM CPU RXD:10
GPIO15
GPIO16
SD Card:
SPI-MOSI:GPIO40
SPI-SCK:GPIO39
SPI-MISO:GPIO38
SPI-CS:GPIO48
SPI-CD:GPIO8
  N20 ESP32 I/O pin define
Posted by: admin - 08-02-2025, 12:58 AM - Forum: N20 - Replies (2)
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
reset_pin: GPIO1
IIC BUS:
SDA:18
SCL:17
SPI BUS (LoRa):
SCK:13
MOSI:12
MISO:11
CS: 14
RST: 21
DIO0:47
ARM CPU TXD:9
ARM CPU RXD:10
GPIO15
GPIO16
SD Card:
SPI-MOSI:GPIO40
SPI-SCK:GPIO39
SPI-MISO:GPIO38
SPI-CS:GPIO48
SPI-CD:GPIO8
