» Members: 10,184
» Latest member: derekcallahan
» Forum threads: 4,262
» Forum posts: 21,124
There are currently 117 online users.
» 0 Member(s) | 105 Guest(s)
AhrefsBot, Amazonbot, Applebot, Crawl, PetalBot, bot
remember relay state
Forum: KC868-E16T
Last Post: greeryan
1 hour ago
» Replies: 8
N30 (KCS): energy counter...
Forum: N30
8 hours ago
KC868-A16 and Tuya
8 hours ago
Bricked KC868-A16
8 hours ago
» Replies: 7
KinCony G1 ESP32-S3 SIM76...
Forum: News
8 hours ago
» Replies: 4
Current direction detecti...
Forum: N30
Last Post: dominique_manas@hotmail.com
Yesterday, 07:31 AM
» Replies: 4
KC868-A8 on Heat Pump for...
Last Post: marktuan
Yesterday, 03:17 AM
B32M maximum voltage
Last Post: felixandrea
Yesterday, 03:14 AM
It looks like it's broken...
10-07-2026, 08:36 AM
Bidirectional reading
Forum: N10
10-05-2026, 11:35 PM
  [arduino code examples for B24]-01 Turn ON/OFF OUTPUT
Posted by: admin - 07-31-2025, 06:54 AM - Forum: B24 - No Replies
* This program controls a 24-channel relay board via two PCF8575 I/O expanders.
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* Delay Time:
#define SDA 8            // Define the SDA pin
#define SCL 18           // Define the SCL pin
// Set I2C addresses of the PCF8575 modules
#define I2C_ADDRESS_R1 0x25 // I2C address of the first PCF8575 module
#define I2C_ADDRESS_R2 0x24 // I2C address of the second PCF8575 module
PCF8575 pcf8575_R1(I2C_ADDRESS_R1); // Create a PCF8575 object for the first module (for relays 9-24)
PCF8575 pcf8575_R2(I2C_ADDRESS_R2); // Create a PCF8575 object for the second module (for relays 1-8)
  // Initialize the PCF8575 modules
  pcf8575_R1.begin();
  pcf8575_R2.begin();
    pcf8575_R1.write(i, HIGH); // Set relays 1-8 to OFF (assuming HIGH means OFF for relays)
    pcf8575_R2.write(i, HIGH); // Set relays 9-24 to OFF (assuming HIGH means OFF for relays)
  // Sequentially turn on each relay (1-24)
  // First control the relays on the second PCF8575 (relays 1-8)
  // Then control the relays on the first PCF8575 (relays 9-24)
    pcf8575_R2.write(i, LOW);   // Turn on the relay at pin i (LOW means ON for the relay)
  // Sequentially turn off each relay (1-24)
    pcf8575_R2.write(i, HIGH);  // Turn off the relay at pin i (HIGH means OFF for the relay)
arduino ino file download:
.zip   1-relay.zip (Size: 1.01 KB / Downloads: 580)
.zip   1-relay.ino.merged.zip (Size: 192.11 KB / Downloads: 606)
  [arduino code examples for B32M]-01 Turn ON/OFF OUTPUT
Posted by: admin - 07-31-2025, 06:54 AM - Forum: B32M - No Replies
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* Delay Time:
#define I2C_ADDRESS_R3 0x26 // I2C address of the second PCF8575 module
PCF8575 pcf8575_R3(I2C_ADDRESS_R3); // Create a PCF8575 object for the second module (for relays 25-32)
  pcf8575_R1.begin();
  pcf8575_R2.begin();
  pcf8575_R3.begin();
    pcf8575_R3.write(i, HIGH); // Set relays 1-8 to OFF (assuming HIGH means OFF for relays)
    pcf8575_R1.write(i, HIGH); // Set relays 9-16 to OFF (assuming HIGH means OFF for relays)
    pcf8575_R2.write(i, HIGH); // Set relays 17-32 to OFF (assuming HIGH means OFF for relays)
  // control the relays on the second PCF8575 (relays 1-8)
    pcf8575_R3.write(i, LOW);   // Turn on the relay at pin i (LOW means ON for the relay)
  // First control the relays on the second PCF8575 (relays 9-16)
  // Then control the relays on the first PCF8575 (relays 17-32)
  // Then control the relays on the first PCF8575 (relays 1-8)
    pcf8575_R3.write(i, HIGH);  // Turn off the relay at pin i (HIGH means OFF for the relay)
.zip   1-relay.zip (Size: 1.08 KB / Downloads: 330)
.zip   1-relay.ino.merged.zip (Size: 197.71 KB / Downloads: 370)
  B24M ESPHome yaml for home assistant without tuya
Posted by: admin - 07-31-2025, 06:52 AM - Forum: B24M - Replies (2)
  friendly_name: b24
  board: esp32-s3-devkitc-1
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  interrupt_pin: GPIO43
  reset_pin: GPIO44
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 39
    rx_pin: 38
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
    i2c_id: bus_a
    pcf8575: true
  - id: 'pcf8574_hub_in_out_1'  # for digital input channel 17-24 & ouptut 1-8
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_out_1'  # for output channel 9-24
    i2c_id: bus_a
    pcf8575: true
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_in_out_1
##pull-up resistance on PCB
      number: 48
      number: 47
      number: 40
## without resistance on PCB
      number: 13
      inverted: false
      number: 14
      inverted:  false
      number: 21
      inverted:  false
      inverted:  false
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_1
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
  - platform: uart
    uart_id: uart_1
ads1115:
  - address: 0x48
  - platform: ads1115
    multiplexer: 'A0_GND'
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A1_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A2_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A3_GND'
    gain: 6.144
    update_interval: 5s
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "KinCony B24");
download yaml file:
.txt   B24-HA-without Tuya.txt (Size: 10.92 KB / Downloads: 493)
  B24 ESPHome yaml for home assistant without tuya
Posted by: admin - 07-31-2025, 06:52 AM - Forum: B24 - No Replies
  friendly_name: b24
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  reset_pin: GPIO44
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      after:
        timeout: 10ms
    tx_pin: 39
    rx_pin: 38
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
    i2c_id: bus_a
    pcf8575: true
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
    i2c_id: bus_a
    pcf8575: true
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      number: 48
      number: 47
      number: 40
      number: 13
      inverted: false
      number: 14
      inverted:  false
      number: 21
      inverted:  false
      inverted:  false
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
  - platform: uart
    uart_id: uart_1
ads1115:
  - address: 0x48
  - platform: ads1115
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    gain: 6.144
    update_interval: 5s
web_server:
  port: 80
font:
display:
    i2c_id: bus_a
    address: 0x3C
    lambda: |-
download yaml file:
.txt   B24-HA-without Tuya.txt (Size: 10.92 KB / Downloads: 346)
  B24M ESPHome yaml for home assistant with tuya
Posted by: admin - 07-31-2025, 06:51 AM - Forum: B24M - No Replies
  friendly_name: b24
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
external_components:
  - source:
      type: git
      ref: v1.1.0
#logger:
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  reset_pin: GPIO44
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      after:
        timeout: 10ms
    tx_pin: 39
    rx_pin: 38
  - id: tuya_mcu_uart
    tx_pin: GPIO16
    rx_pin: GPIO17
    baud_rate: 9600
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
    i2c_id: bus_a
    pcf8575: true
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
    i2c_id: bus_a
    pcf8575: true
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: vyznobv3bahs2pwl
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
      number: 8
  - platform: tuya_wifi_mcu
    dp_id: 125
    bind_binary_sensor_id: b24_input01
    internal: true
      number: 9
    dp_id: 126
    bind_binary_sensor_id: b24_input02
    internal: true
      number: 10
    dp_id: 127
    bind_binary_sensor_id: b24_input03
    internal: true
      number: 11
    dp_id: 128
    bind_binary_sensor_id: b24_input04
    internal: true
      number: 12
    dp_id: 129
    bind_binary_sensor_id: b24_input05
    internal: true
      number: 13
    dp_id: 130
    bind_binary_sensor_id: b24_input06
    internal: true
      number: 14
    dp_id: 131
    bind_binary_sensor_id: b24_input07
    internal: true
      number: 15
    dp_id: 132
    bind_binary_sensor_id: b24_input08
    internal: true
    dp_id: 133
    bind_binary_sensor_id: b24_input09
    internal: true
    dp_id: 134
    bind_binary_sensor_id: b24_input10
    internal: true
    dp_id: 135
    bind_binary_sensor_id: b24_input11
    internal: true
    dp_id: 136
    bind_binary_sensor_id: b24_input12
    internal: true
    dp_id: 137
    bind_binary_sensor_id: b24_input13
    internal: true
    dp_id: 138
    bind_binary_sensor_id: b24_input14
    internal: true
    dp_id: 139
    bind_binary_sensor_id: b24_input15
    internal: true
    dp_id: 140
    bind_binary_sensor_id: b24_input16
    internal: true
    dp_id: 141
    bind_binary_sensor_id: b24_input17
    internal: true
    dp_id: 142
    bind_binary_sensor_id: b24_input18
    internal: true
    dp_id: 143
    bind_binary_sensor_id: b24_input19
    internal: true
    dp_id: 144
    bind_binary_sensor_id: b24_input20
    internal: true
    dp_id: 145
    bind_binary_sensor_id: b24_input21
    internal: true
    dp_id: 146
    bind_binary_sensor_id: b24_input22
    internal: true
    dp_id: 147
    bind_binary_sensor_id: b24_input23
    internal: true
    dp_id: 148
    bind_binary_sensor_id: b24_input24
    internal: true
      number: 48
      number: 47
      number: 40
      number: 13
      inverted: false
      number: 14
      inverted:  false
      number: 21
      inverted:  false
      inverted:  false
      number: 8
    dp_id: 101
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "b24_output01"
      number: 9
    dp_id: 102
    internal: true
    bind_switch_id: "b24_output02"
      number: 10
    dp_id: 103
    internal: true
    bind_switch_id: "b24_output03"
      number: 11
    dp_id: 104
    internal: true
    bind_switch_id: "b24_output04"
      number: 12
    dp_id: 105
    internal: true
    bind_switch_id: "b24_output05"
      number: 13
    dp_id: 106
    internal: true
    bind_switch_id: "b24_output06"
      number: 14
    dp_id: 107
    internal: true
    bind_switch_id: "b24_output07"
      number: 15
    dp_id: 108
    internal: true
    bind_switch_id: "b24_output08"
    dp_id: 109
    internal: true
    bind_switch_id: "b24_output09"
    dp_id: 110
    internal: true
    bind_switch_id: "b24_output10"
    dp_id: 111
    internal: true
    bind_switch_id: "b24_output11"
    dp_id: 112
    internal: true
    bind_switch_id: "b24_output12"
    dp_id: 113
    internal: true
    bind_switch_id: "b24_output13"
    dp_id: 114
    internal: true
    bind_switch_id: "b24_output14"
    dp_id: 115
    internal: true
    bind_switch_id: "b24_output15"
    dp_id: 116
    internal: true
    bind_switch_id: "b24_output16"
      number: 8
    dp_id: 117
    internal: true
    bind_switch_id: "b24_output17"
      number: 9
    dp_id: 118
    internal: true
    bind_switch_id: "b24_output18"
      number: 10
    dp_id: 119
    internal: true
    bind_switch_id: "b24_output19"
      number: 11
    dp_id: 120
    internal: true
    bind_switch_id: "b24_output20"
      number: 12
    dp_id: 121
    internal: true
    bind_switch_id: "b24_output21"
      number: 13
    dp_id: 122
    internal: true
    bind_switch_id: "b24_output22"
      number: 14
    dp_id: 123
    internal: true
    bind_switch_id: "b24_output23"
      number: 15
    dp_id: 124
    internal: true
    bind_switch_id: "b24_output24"
  - platform: uart
    uart_id: uart_1
ads1115:
  - address: 0x48
  - platform: ads1115
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    gain: 6.144
    update_interval: 5s
web_server:
  port: 80
font:
display:
    i2c_id: bus_a
    address: 0x3C
    lambda: |-
download yaml file:
.txt   B24-HA-with-Tuya.txt (Size: 19.26 KB / Downloads: 427)
  B24 ESPHome yaml for home assistant with tuya
Posted by: admin - 07-31-2025, 06:51 AM - Forum: B24 - No Replies
  friendly_name: b24
  platformio_options:
  - source:
      type: git
      ref: v1.1.0
#logger:
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  reset_pin: GPIO44
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      after:
        timeout: 10ms
    tx_pin: 39
    rx_pin: 38
  - id: tuya_mcu_uart
    tx_pin: GPIO16
    rx_pin: GPIO17
    baud_rate: 9600
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
    i2c_id: bus_a
    pcf8575: true
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
    i2c_id: bus_a
    pcf8575: true
tuya_wifi_mcu:
  wifi_reset_pin: 28
  wifi_led_pin: 16
      number: 8
    dp_id: 125
    internal: true
      number: 9
    dp_id: 126
    internal: true
      number: 10
    dp_id: 127
    internal: true
      number: 11
    dp_id: 128
    internal: true
      number: 12
    dp_id: 129
    internal: true
      number: 13
    dp_id: 130
    internal: true
      number: 14
    dp_id: 131
    internal: true
      number: 15
    dp_id: 132
    internal: true
    dp_id: 133
    internal: true
    dp_id: 134
    internal: true
    dp_id: 135
    internal: true
    dp_id: 136
    internal: true
    dp_id: 137
    internal: true
    dp_id: 138
    internal: true
    dp_id: 139
    internal: true
    dp_id: 140
    internal: true
    dp_id: 141
    internal: true
    dp_id: 142
    internal: true
    dp_id: 143
    internal: true
    dp_id: 144
    internal: true
    dp_id: 145
    internal: true
    dp_id: 146
    internal: true
    dp_id: 147
    internal: true
    dp_id: 148
    internal: true
      number: 48
      number: 47
      number: 40
      number: 13
      inverted: false
      number: 14
      inverted:  false
      number: 21
      inverted:  false
      inverted:  false
      number: 8
    dp_id: 101
    internal: true
      number: 9
    dp_id: 102
    internal: true
      number: 10
    dp_id: 103
    internal: true
      number: 11
    dp_id: 104
    internal: true
      number: 12
    dp_id: 105
    internal: true
      number: 13
    dp_id: 106
    internal: true
      number: 14
    dp_id: 107
    internal: true
      number: 15
    dp_id: 108
    internal: true
    dp_id: 109
    internal: true
    dp_id: 110
    internal: true
    dp_id: 111
    internal: true
    dp_id: 112
    internal: true
    dp_id: 113
    internal: true
    dp_id: 114
    internal: true
    dp_id: 115
    internal: true
    dp_id: 116
    internal: true
      number: 8
    dp_id: 117
    internal: true
      number: 9
    dp_id: 118
    internal: true
      number: 10
    dp_id: 119
    internal: true
      number: 11
    dp_id: 120
    internal: true
      number: 12
    dp_id: 121
    internal: true
      number: 13
    dp_id: 122
    internal: true
      number: 14
    dp_id: 123
    internal: true
      number: 15
    dp_id: 124
    internal: true
  - platform: uart
    uart_id: uart_1
ads1115:
  - address: 0x48
  - platform: ads1115
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    gain: 6.144
    update_interval: 5s
web_server:
  port: 80
font:
display:
    i2c_id: bus_a
    address: 0x3C
    lambda: |-
download yaml file:
.txt   B24-HA-with-Tuya.txt (Size: 19.26 KB / Downloads: 391)
  B24M ESP32-S3 IO pins define
Posted by: admin - 07-31-2025, 06:49 AM - Forum: B24M - No Replies
IIC Bus:
SDA:GPIO8
SCL:GPIO18
PCF8575: (input1-16): i2c address:0x22 by B16-core
P8:input1
P9:input2
P10:input3
P11:input4
P12:input5
P13:input6
P14:input7
P15:input8
P0:input9
P1:input10
P2:input11
P3:input12
P4:input13
P5:input14
P6:input15
P7:input16
U4: PCF8575 i2c address:0x25
P0:input17
P1:input18
P2:input19
P3:input20
P4:input21
P5:input22
P6:input23
P7:input24
P8:output1
P9:output2
P10:output3
P11:output4
P12:output5
P13:output6
P14:output7
P15:output8
U2: PCF8575 i2c address:0x24
P0:output9
P1:output10
P2:output11
P3:output12
P4:output13
P5:output14
P6:output15
P7:output16
P8:output17
P9:output18
P10:output19
P11:output20
P12:output21
P13:output22
P14:output23
P15:output24
24C02 EPROM i2c address: 0x50
DS3231 RTC i2c address: 0x68
ADS1115 (4CH ADC) : i2c address:0x48
Analog input (A1: DC 0-5v)
Analog input (A2: DC 0-5v)
Analog input (A3: DC 4-20mA)
Analog input (A4: DC 4-20mA)
GPIO13
GPIO14
GPIO21
free GPIOs (with pull-up resistance on PCB):
GPIO40
GPIO48
GPIO47
GPIO7
Ethernet (W5500) I/O define:
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
reset_pin: GPIO44
RS485:
RXD:GPIO38
TXD:GPIO39
Tuya module:
RXD:GPIO17
TXD:GPIO16
SD Card:
SPI-MOSI:GPIO10
SPI-SCK:GPIO11
SPI-MISO:GPIO12
SPI-CS:GPIO9
  B24 ESP32-S3 IO pins define
Posted by: admin - 07-31-2025, 06:49 AM - Forum: B24 - No Replies
IIC Bus:
SDA:GPIO8
SCL:GPIO18
P8:input1
P9:input2
P10:input3
P11:input4
P12:input5
P13:input6
P14:input7
P15:input8
P0:input9
P1:input10
P2:input11
P3:input12
P4:input13
P5:input14
P6:input15
P7:input16
P0:input17
P1:input18
P2:input19
P3:input20
P4:input21
P5:input22
P6:input23
P7:input24
P8:output1
P9:output2
P10:output3
P11:output4
P12:output5
P13:output6
P14:output7
P15:output8
P0:output9
P1:output10
P2:output11
P3:output12
P4:output13
P5:output14
P6:output15
P7:output16
P8:output17
P9:output18
P10:output19
P11:output20
P12:output21
P13:output22
P14:output23
P15:output24
GPIO13
GPIO14
GPIO21
GPIO40
GPIO48
GPIO47
GPIO7
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
reset_pin: GPIO44
RS485:
RXD:GPIO38
TXD:GPIO39
Tuya module:
RXD:GPIO17
TXD:GPIO16
SD Card:
SPI-MOSI:GPIO10
SPI-SCK:GPIO11
SPI-MISO:GPIO12
SPI-CS:GPIO9
  KinCony T32M Tiny ESP32 Smart Controller released
Posted by: admin - 07-31-2025, 04:50 AM - Forum: News - Replies (4)
KinCony T32M tiny ESP32 smart controller based on ESP32-S3-WROOM-1U (N16R8) wifi chip. Support 32 channel MOSFET output, 4 channel 1-wire GPIOs, 3 channel free GPIOs. T32M have RS485 port. You can write any code by Arduino IDE / Micro Python / ESP-IDF development tool to ESP32 module. We will supply Arduino / ESP-IDF demo code for different samples. Everyone can modify and change the code for your own smart home automation system project. it support use by ESPHome for home assistant or tasmota firmware for smart home automation DIY. T64M use KCS v3 firmware, it support home assistant auto discovery function by MQTT, so without write any config code (zero code) for home assistant. KCS v3 support KinCony cloud service (official shop customer free 2 years), remote monitor and control device by webpage in anywhere. KCS v3 support KinCony board integrate to Loxone Miniserver. Support Apple HomeKit for Siri.
[Image: T32M-1.jpg]
Model No. KinCony T32M
Description: KinCony 32 Channel Tiny ESP32-S3 Smart Controller – T32M
Power supply: 12-24V DC
interfaces: Ethernet(RJ45)-LAN 100Mbps IPv4/IPv6,WiFi,RS485,Bluetooth,USB-C
Installation method: DIN RAIL
Outputs:
32CH MOSFET Outputs, every channel use MAX 4A driver IC
Inputs:
free GPIO: 3CH (connect with ESP32S3 pin directly)
[Image: T32M-2.jpg]
  Red or Green LED's
Posted by: Onepointbrewing - 07-30-2025, 03:42 AM - Forum: F16 - Replies (1)
Is there any GPIO access to the Red LED near the ethernet jack or the green power on the front panel?
