» Members: 10,452
» Forum threads: 4,326
» Forum posts: 21,315
There are currently 259 online users.
» 0 Member(s) | 231 Guest(s)
AhrefsBot, Amazonbot, AwarioBot, Baidu, Bing, Bytespider, Crawl, PetalBot, Semrush, bot
No AP appears
1 hour ago
» Replies: 8
kc868-a6 analog input
11-06-2026, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
11-06-2026, 07:25 AM
Forum: F24
11-06-2026, 05:35 AM
Forum: F24
11-06-2026, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
11-06-2026, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
  a16v3 rf433 pins/other free pins for sim800l
Posted by: rhaenx - 05-28-2025, 08:07 AM - Forum: KC868-A16v3 - Replies (1)
hi. I have just buy a16v3. I buy without the rf433 transmitter and receiver. Can I use this pins for other purpose? I want to connect to sim 800l or similar board that can send/receive sms.
the free gpio pin on the board next to esp32 chip i cannot use because i cannot use soldering due to health problem. i have to find a friend or pay someone else to help me solder, before i try this i want to ask if other free pin that do no need to solder i can use for this purpose.
thank you for your time.
  create cover buttons for two relay using MQTT
Posted by: admin - 05-27-2025, 06:28 AM - Forum: KC868-A32/A32 Pro - Replies (1)
mqtt:
  cover:
      command_topic: 'A32PRO/DCDA0C7B8568/SET'
      state_topic: 'A32PRO/DCDA0C7B8568/STATE'
     # availability:
     # - topic: "home-assistant/cover/availability"
      qos: 0
      retain: true
      payload_open: '{"output1":{"value":true}}'
      payload_close: '{"output2":{"value":true}}'
      payload_stop: '{"output1":{"value":false}, "output2":{"value":false}}'
      value_template: >
        {% if value_json.output1.value and not value_json.output5.value %}
          open
        {% elif value_json.output5.value and not value_json.output1.value %}
          closed
        {% elif not value_json.output1.value and not value_json.output5.value %}
          stopped
        {% else %}
          unknown
        {% endif %}
      state_opening: "open"
      state_closing: "closed"
      state_stopped: "stopped"
      payload_available: "online"
      payload_not_available: "offline"
      optimistic: false
   - name: 'a32pro-kcs-output-1'
     unique_id: a32pro-kcs-output-1
     state_on: true
     state_off: false
   - name: 'a32pro-kcs-output-2'
     unique_id: a32pro-kcs-output-2
     payload_on:  '{"output2":{"value":true}}'
     payload_off:  '{"output2":{"value":false}}'
     state_on: true
     state_off: false
  "KCS" v3.9.4 firmware BIN file download
Posted by: admin - 05-27-2025, 12:09 AM - Forum: "KCS" v3 firmware - Replies (8)
v3.9.4 improvement:
1. fixed bug that Tuya app can't use by 4G SIM7600 module.
2. fixed but Monitor webpage can't show correct tuya connection state when use 4G SIM7600 module.
.zip   KCS_A2V3_V3.9.4.zip (Size: 1.04 MB / Downloads: 813)
.zip   KCS_A6V3_V3.9.4.zip (Size: 1.01 MB / Downloads: 911)
.zip   KCS_A8V3_V3.9.4.zip (Size: 1.06 MB / Downloads: 812)
.zip   KCS_A16V3_V3.9.4.zip (Size: 1.08 MB / Downloads: 938)
.zip   KCS_A32PRO_V3.9.4.zip (Size: 1.05 MB / Downloads: 792)
.zip   KCS_AG8_V3.9.4.zip (Size: 1.04 MB / Downloads: 867)
.zip   KCS_B8M_V3.9.4.zip (Size: 1.08 MB / Downloads: 811)
.zip   KCS_B16_V3.9.4.zip (Size: 1.07 MB / Downloads: 815)
.zip   KCS_B16M_V3.9.4.zip (Size: 1.07 MB / Downloads: 830)
.zip   KCS_F8_V3.9.4.zip (Size: 1.06 MB / Downloads: 741)
.zip   KCS_F16_V3.9.4.zip (Size: 1.08 MB / Downloads: 812)
.zip   KCS_F24_V3.9.4.zip (Size: 1.08 MB / Downloads: 851)
.zip   KCS_G1_V3.9.4.zip (Size: 1.03 MB / Downloads: 796)
.zip   KCS_KC_TA_V3.9.4.zip (Size: 1.03 MB / Downloads: 814)
.zip   KCS_T16M_V3.9.4.zip (Size: 1.02 MB / Downloads: 796)
  16B mqtt yaml file config how to
Posted by: itzek - 05-24-2025, 09:17 PM - Forum: B16 - Replies (7)
Hello admin,
 I have the B16 ESP32-S3 controller and I want to connect it to Home Assistant using a regular mqtt configuration (not using MQTT (For Home Assistant)).
This is what I'm trying, but it's not working:
    - name: " output-1 "
      unique_id: output-1
      state_topic: ' relay16/DCDA0C8B9B5C/state'
      command_topic: ' relay16/DCDA0C8B9B5C/set'
      payload_on:  '{"relay1":{"on":1}}'
      payload_off:  '{"relay1":{"on":0}}'
      state_on: 1
      state_off: 0
Can you give me an example of the configuration?
  A32 for blinds - KCS firmware question/issues
Posted by: voyo - 05-24-2025, 01:21 AM - Forum: KC868-A series and Uair Smart Controller - Replies (3)
Hello!
So I bought A32 device, and I want it to drive my blinds. First I tried with original KCS firmware. While hardware is pretty decent, the firmware unfortunately seems to be half-baked Sad
Questions/issues I have -
1) I couldn't find any option to save/restore configuration from device. If you need to configure all relays on device with so many ports - it extremally inconvenient to re-configure everything you are trying new firmware (or just updating it). Or maybe Im just missing something ?
2) I want to configure slightly more complex behavior for this board -
I have momentary buttons (up/down), so I wanted to
a) run motor only when button is pressed
b) with long-click - open/close roller completely
c) with double-click - open/close to 50%
I tried to use rising/falling edge detection for start/stop motor, - this works, but then I cannot configure any other functions like longclick or doubleclick Sad
4) "Jogging" functionality seems not working in this firmware at all, or I just dont know how to configure it.
5) I was able to find only v2  (KCS_KC868_A32_V2.2.13.zip)  of KCS firmware for this device , maybe there is some update with fixes for my above issues ?
  KC868-A32 and EspEasy firmware
Posted by: voyo - 05-24-2025, 12:36 AM - Forum: KC868-A series and Uair Smart Controller - Replies (2)
Hello!
Does anyone have experience with EspEasy (www.letscontrolit.com) firmware running on this device ?
I recently bought A32 with intention to use it for my roller blinds, but I have some issues with KCK firmware (will create separate thread for my questions).
Anyway - I managed to upload espeasy firmware, it runs - but WiFi connection is not working. On serial console it prints:
03.872 : (265688) Info  : WIFI : Arduino wifi status: WL_STOPPED 254 ESPeasy internal wifi status: DISCONNECTED
03.885 : (260688) Info  : Webserver: start
05.229 : (260428) Info  : WD  : Uptime 0  ConnectFailures 0 FreeMem 260560 WiFiStatus: WL_STOPPED 254 ESPeasy internal wifi status: DISCONNECTED
I tried few firmware files but with no luck. So question is - is this board require some special setting to enable wifi ? Something like set some gpio or something else ?
  Custom protocols limitation
Posted by: gabi_jackass@yahoo.com - 05-23-2025, 11:00 PM - Forum: KC868-A128 - Replies (2)
I see that the number of custom protocols is limited at 64. This is not enough for a board with 128 inputs and 128 outputs.
I need at least 4 protocols per digital input (click, double click, hold ...)
Please advice,
Gabi
  KC868-a6-v1.3sp + 0.5V Analog Input
Posted by: boneless - 05-23-2025, 01:22 PM - Forum: KC868-A series and Uair Smart Controller - Replies (2)
Hello again,
I have the KC868-a6-v1.3sp and a pressure sensor (0..150 psi / 0.5..4.5 V). I noticed my values were being capped at about 40 psi / 1.5 V.
I verified with my fluke loop calibrator, and indeed have a limit at 1.5 V.
The image below shows the raw value being capped at 1.01.
I tried moving the input to the second, but I received the exact same values (capped).
Below code is used for both test with input 36 and 39.
You have any recommendations
  - platform: adc
      number: 39
    unit_of_measurement: 'psi'
    name: 'Water Pressure Sprinkler'
    update_interval: 0.5s
    filters:
      - sliding_window_moving_average:
          window_size: 10
          send_every: 10
  KC868-A16 LED Output
Posted by: cyberrailpete - 05-22-2025, 05:57 PM - Forum: KC868-A series and Uair Smart Controller - Replies (7)
Hello.
Working on a project with LED output necessary. Have loaded your firmware if I turn on any put on 9-16 LED light up...Connected to output 9
Ground of LED on 9 common on 3v.
Shocked Connection lost / cant find device
Posted by: vaarinvaliliha - 05-22-2025, 10:28 AM - Forum: KC868-A series and Uair Smart Controller - Replies (3)
Hi!
I have flashed my KC868-A6 V1 with   v2.2.12.bin file.
I can access the board through 192.168.4.1 and login.
After I change for example mqtt settings and restart I can not access the board anymore. Same thing happens when I add my Wifi-settings and restart. I cannot find the board and seems like it jams after every saved settings and have to reflash.
Any ideas?
I have purchased the board from Aliexpress (Kincony Controller Store).
BR Joonas
Image(s)
