» Members: 10,399
» Latest member: charlottehayes9923
» Forum threads: 4,319
» Forum posts: 21,294
There are currently 255 online users.
» 0 Member(s) | 231 Guest(s)
Amazonbot, Applebot, AwarioBot, Baidu, Bing, Bytespider, Crawl, Semrush, bot
KC868-A4 – Relay 1 clicks...
2 hours ago
450 Hz allowed on input?
Forum: Development
2 hours ago
How Do You Handle Relay C...
6 hours ago
"KCS" v3.27.4 firmware BI...
Today, 06:02 AM
how to check i2c extend c...
Forum: T16M
Today, 12:38 AM
T16M ESPHome yaml for hom...
Forum: T16M
Today, 12:35 AM
Last Post: viko
Yesterday, 01:42 PM
» Replies: 23
Recommended Dimmer for LE...
Yesterday, 08:21 AM
KC868-A16-V3.2: exact wir...
Forum: KC868-A16v3
Yesterday, 12:31 AM
ESPHome modbus not functi...
Forum: KC868-A8S
10-30-2026, 01:02 PM
  [arduino code examples for T128M]-07 i2c scanner search online devices
Posted by: admin - 06-23-2025, 05:40 AM - Forum: T128M - No Replies
// Made by KinCony IoT: https://www.kincony.com
// This sketch scans two I2C buses and prints all detected device addresses.
// IIC Bus-1: SDA - GPIO48, SCL - GPIO47
// IIC Bus-2: SDA - GPIO12, SCL - GPIO11
#include <Wire.h>
// Create two I2C bus objects
TwoWire I2C_BUS1 = TwoWire(0);
TwoWire I2C_BUS2 = TwoWire(1);
// Scan function for a specific I2C bus
void scanI2CBus(TwoWire &bus, const char* busName) {
  Serial.println();
  Serial.print("Scanning ");
  Serial.print(busName);
  Serial.println(" at 100kHz...");
  byte error, address;
  int nDevices = 0;
  for (address = 1; address < 127; address++) {
    bus.beginTransmission(address);
    error = bus.endTransmission();
    if (error == 0) {
      Serial.print("I2C device found at address 0x");
      if (address < 16)
        Serial.print("0");
      Serial.print(address, HEX);
      Serial.println("  ✓");
      nDevices++;
    } else if (error == 4) {
      Serial.print("Unknown error at address 0x");
      if (address < 16)
        Serial.print("0");
      Serial.println(address, HEX);
  if (nDevices == 0)
    Serial.println("No I2C devices found.");
  else
    Serial.println("Scan completed.");
  delay(1000); // Wait for serial to initialize
  // Initialize IIC Bus-1 (GPIO48 = SDA, GPIO47 = SCL) at 100kHz
  I2C_BUS1.begin(48, 47);
  // Initialize IIC Bus-2 (GPIO12 = SDA, GPIO11 = SCL) at 100kHz
  I2C_BUS2.begin(12, 11);
  // Start scanning both buses
  scanI2CBus(I2C_BUS1, "IIC Bus-1");
  scanI2CBus(I2C_BUS2, "IIC Bus-2");
  // Nothing to do in the loop
arduino ino file download:
.zip   7-i2c-scanner.zip (Size: 841 bytes / Downloads: 721)
.zip   7-i2c-scanner.ino.merged.zip (Size: 192.17 KB / Downloads: 737)
  [arduino code examples for T128M]-06 digital INPUT trigger OUTPUT directly
Posted by: admin - 06-23-2025, 05:39 AM - Forum: T128M - No Replies
* This Arduino program reads 128 input channels from 8 PCF8575 modules on I2C Bus-2
* and controls 128 output channels on 8 PCF8575 modules on I2C Bus-1.
* When an input pin is pulled LOW (connected to GND), the corresponding output relay is turned ON (LOW).
* Otherwise, the relay is turned OFF (HIGH).
* I2C Bus-1 (Outputs):
* - SDA: GPIO 48
* - SCL: GPIO 47
* - Output1~16    : 0x27
* - Output17~32   : 0x26
* - Output33~48   : 0x23
* - Output49~64   : 0x22
* - Output65~80   : 0x25
* - Output81~96   : 0x24
* - Output97~112  : 0x21
* - Output113~128 : 0x20
* I2C Bus-2 (Inputs):
* - SDA: GPIO 12
* - SCL: GPIO 11
* - Input1~16     : 0x27
* - Input17~32    : 0x26
* - Input33~48    : 0x23
* - Input49~64    : 0x22
* - Input65~80    : 0x25
* - Input81~96    : 0x24
* - Input97~112   : 0x21
* - Input113~128  : 0x20
#include <Wire.h>
#include <PCF8575.h>
// Define two I2C buses for independent input/output communication
TwoWire I2C_Output = TwoWire(0); // Bus 1 - Outputs
TwoWire I2C_Input  = TwoWire(1); // Bus 2 - Inputs
// === Output PCF8575 instances ===
PCF8575 output_1(0x27, &I2C_Output);  // Output 1~16
PCF8575 output_2(0x26, &I2C_Output);  // Output 17~32
PCF8575 output_3(0x23, &I2C_Output);  // Output 33~48
PCF8575 output_4(0x22, &I2C_Output);  // Output 49~64
PCF8575 output_5(0x25, &I2C_Output);  // Output 65~80
PCF8575 output_6(0x24, &I2C_Output);  // Output 81~96
PCF8575 output_7(0x21, &I2C_Output);  // Output 97~112
PCF8575 output_8(0x20, &I2C_Output);  // Output 113~128
// === Input PCF8575 instances ===
PCF8575 input_1(0x27, &I2C_Input);  // Input 1~16
PCF8575 input_2(0x26, &I2C_Input);  // Input 17~32
PCF8575 input_3(0x23, &I2C_Input);  // Input 33~48
PCF8575 input_4(0x22, &I2C_Input);  // Input 49~64
PCF8575 input_5(0x25, &I2C_Input);  // Input 65~80
PCF8575 input_6(0x24, &I2C_Input);  // Input 81~96
PCF8575 input_7(0x21, &I2C_Input);  // Input 97~112
PCF8575 input_8(0x20, &I2C_Input);  // Input 113~128
// === Create arrays for easy loop access ===
PCF8575* inputArray[8] = {
  &input_1, &input_2, &input_3, &input_4,
  &input_5, &input_6, &input_7, &input_8
PCF8575* outputArray[8] = {
  &output_1, &output_2, &output_3, &output_4,
  &output_5, &output_6, &output_7, &output_8
  Serial.println("KinCony 128-Channel Input-Output Mapping Test");
  // Initialize both I2C buses
  I2C_Output.begin(48, 47);  // SDA: GPIO48, SCL: GPIO47
  I2C_Input.begin(12, 11);   // SDA: GPIO12, SCL: GPIO11
  // Initialize all PCF8575 chips and set initial output states
  for (int i = 0; i < 8; i++) {
    inputArray[i]->begin();   // Initialize input chip
    outputArray[i]->begin();  // Initialize output chip
    // Set all output pins HIGH (relay OFF)
    for (int j = 0; j < 16; j++) {
      outputArray[i]->write(j, HIGH);
  for (int chip = 0; chip < 8; chip++) {
    for (int pin = 0; pin < 16; pin++) {
      bool inputState = inputArray[chip]->read(pin);
      // If input is LOW (button pressed or contact closed), turn ON relay (set output LOW)
      // Otherwise, turn OFF relay (set output HIGH)
      outputArray[chip]->write(pin, inputState ? HIGH : LOW);
  delay(200); // Delay to prevent I2C bus flooding
.zip   6-input-trigger-output.zip (Size: 1.33 KB / Downloads: 685)
.zip   6-input-trigger-output.ino.merged.zip (Size: 192.36 KB / Downloads: 734)
  [arduino code examples for T128M]-05 Ethernet W5500 chip work with TCP Server mode
Posted by: admin - 06-23-2025, 05:38 AM - Forum: T128M - No Replies
* received from a client.
* Hardware connections:
* - CLK: GPIO42
* - MOSI: GPIO43
* - MISO: GPIO44
* - CS: GPIO41
* - RST: GPIO1
* - INT: GPIO2
* Subnet Mask: 255.255.255.0
* Gateway: 192.168.3.1
* DNS: 192.168.3.1
#include <SPI.h>
#include <Ethernet.h>
#define W5500_CS_PIN  41
#define W5500_RST_PIN 1
#define W5500_INT_PIN 2
#define W5500_CLK_PIN 42
#define W5500_MOSI_PIN 43
#define W5500_MISO_PIN 44
EthernetServer server(4196);
  while (!Serial) {
  Ethernet.init(W5500_CS_PIN);
  Serial.print("IP Address: ");
  server.begin();
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        server.write(c);
    client.stop();
.zip   5-Ethernet-W5500.zip (Size: 1.23 KB / Downloads: 681)
.zip   5-Ethernet-W5500.ino.merged.zip (Size: 191.08 KB / Downloads: 695)
  [arduino code examples for T128M]-04 Read free GPIO state
Posted by: admin - 06-23-2025, 05:37 AM - Forum: T128M - No Replies
* GPIO Status Monitoring
* GPIO Pins Monitored:
* - GPIO 8
* - GPIO 9
* - GPIO 10
* - GPIO 15
* - GPIO 16
* - GPIO 17
* - GPIO 18
* - GPIO 0
* Hardware Requirements:
#define GPIO_PIN_8 8
#define GPIO_PIN_9 9
#define GPIO_PIN_10 10
#define GPIO_PIN_15 15
#define GPIO_PIN_16 16
#define GPIO_PIN_17 17
#define GPIO_PIN_18 18
#define GPIO_PIN_0 0
bool prevState[8] = {false, false, false, false, false, false, false, false};
  pinMode(GPIO_PIN_8, INPUT);
  pinMode(GPIO_PIN_9, INPUT);
  pinMode(GPIO_PIN_10, INPUT);
  pinMode(GPIO_PIN_15, INPUT);
  pinMode(GPIO_PIN_16, INPUT);
  pinMode(GPIO_PIN_17, INPUT);
  pinMode(GPIO_PIN_18, INPUT);
  pinMode(GPIO_PIN_0, INPUT);
  bool currentState[8];
  currentState[0] = digitalRead(GPIO_PIN_8);
  currentState[1] = digitalRead(GPIO_PIN_9);
  currentState[2] = digitalRead(GPIO_PIN_10);
  currentState[3] = digitalRead(GPIO_PIN_15);
  currentState[4] = digitalRead(GPIO_PIN_16);
  currentState[5] = digitalRead(GPIO_PIN_17);
  currentState[6] = digitalRead(GPIO_PIN_18);
  currentState[7] = digitalRead(GPIO_PIN_0);
      Serial.print("GPIO ");
      Serial.print(i == 0 ? GPIO_PIN_8 :
                   i == 1 ? GPIO_PIN_9 :
                   i == 2 ? GPIO_PIN_10 :
                   i == 3 ? GPIO_PIN_15 :
                   i == 4 ? GPIO_PIN_16 :
                   i == 5 ? GPIO_PIN_17 :
                   i == 6 ? GPIO_PIN_18 : GPIO_PIN_0);
      Serial.print(" changed to ");
      // Update the previous state
.zip   4-free-gpio-state.zip (Size: 1.04 KB / Downloads: 704)
.zip   4-free-gpio-state.ino.merged.zip (Size: 181.77 KB / Downloads: 728)
  [arduino code examples for T128M]-03 RS485 communication test
Posted by: admin - 06-23-2025, 05:36 AM - Forum: T128M - No Replies
* RS485 Communication Test with Direction Control (SP3485EEN)
* The TXD pin is defined as GPIO 13, RXD is GPIO 21, and EN is GPIO 14.
#include <HardwareSerial.h>
// Define RS485 pins
#define RS485_RXD 21     // RS485 Receive
#define RS485_TXD 13     // RS485 Transmit
#define RS485_EN  14     // RS485 Direction control (High: Send, Low: Receive)
// Create a hardware serial object on UART1
  while (!Serial);
  // Set RS485 direction control pin
  pinMode(RS485_EN, OUTPUT);
  digitalWrite(RS485_EN, LOW); // Start in receive mode
  // Initialize RS485 serial communication
  Serial.println("RS485 Test Start (with direction control)");
  // Prepare the message to send
  String message = "Hello from KinCony T128M!";
  // Switch to transmit mode
  digitalWrite(RS485_EN, HIGH);
  delay(2); // Short delay to allow driver to switch
  // Send the message
  rs485Serial.println(message);
  rs485Serial.flush(); // Wait for transmission to complete
  // Switch back to receive mode
  Serial.println("Message sent. Waiting for response...");
  // Wait for a response (up to 1 second)
  unsigned long startTime = millis();
  while (millis() - startTime < 1000) {
      String receivedMessage = "";
        char c = rs485Serial.read();
        receivedMessage += c;
      // Print the received message
      Serial.print("Received: ");
      break;
  delay(2000);
.zip   3-RS485-Test.zip (Size: 1.02 KB / Downloads: 676)
.zip   3-RS485-Test.ino.merged.zip (Size: 186.66 KB / Downloads: 730)
  [arduino code examples for T128M]-02 Read digital input ports state
Posted by: admin - 06-23-2025, 05:35 AM - Forum: T128M - No Replies
* Description:
* This Arduino program reads the state of 128 digital inputs using 8 PCF8575 I/O expanders.
* Each PCF8575 reads 16 input channels. The input states are printed to the Serial Monitor
* as binary strings grouped by chip.
* I2C Pin Definitions:
* - SDA: GPIO 12
* - SCL: GPIO 11
* PCF8575 Addresses:
* - Input  1~16   : 0x27
* - Input 17~32  : 0x26
* - Input 33~48  : 0x23
* - Input 49~64  : 0x22
* - Input 65~80  : 0x25
* - Input 81~96  : 0x24
* - Input 97~112 : 0x21
* Input Status Legend:
* - 0: ON (Active)
* - 1: OFF (Inactive / Pulled HIGH)
#include <Wire.h>
// Define I2C pins
#define I2C_SDA 12
#define I2C_SCL 11
// Define PCF8575 I2C addresses
PCF8575 pcf_inputs[8] = {
  PCF8575(0x27), // Input 1-16
  PCF8575(0x26), // Input 17-32
  PCF8575(0x23), // Input 33-48
  PCF8575(0x22), // Input 49-64
  PCF8575(0x25), // Input 65-80
  PCF8575(0x24), // Input 81-96
  PCF8575(0x21), // Input 97-112
  PCF8575(0x20)  // Input 113-128
  Wire.begin(I2C_SDA, I2C_SCL);
  Serial.println("KinCony F128 128 channel input state  0:ON  1:OFF");
  // Initialize all PCF8575 modules
    pcf_inputs[i].begin();
  // Iterate through all 8 chips
    Serial.print("Input ");
    Serial.print((chip * 16) + 1);
    Serial.print("~");
    Serial.print((chip + 1) * 16);
    Serial.print(": ");
    // Read and print the state of all 16 pins on current chip
      int state = pcf_inputs[chip].read(pin);
      Serial.print(state);
    Serial.println();
  Serial.println("--------------------------------------------------");
  delay(1000); // Delay 1 second between reads
.zip   2-digital-input.zip (Size: 1,019 bytes / Downloads: 684)
.zip   2-digital-input.ino.merged.zip (Size: 192.36 KB / Downloads: 729)
  [arduino code examples for T128M]-01 Turn ON/OFF OUTPUT
Posted by: admin - 06-23-2025, 05:33 AM - Forum: T128M - No Replies
* This program controls 128 outputs using 8 PCF8575 I/O expanders.
* It sequentially turns on outputs 1 to 128, then turns them off from 128 to 1, in a loop.
* - SDA: GPIO 48
* - SCL: GPIO 47
* - Output  1~16   : 0x27
* - Output 17~32  : 0x26
* - Output 33~48  : 0x23
* - Output 49~64  : 0x22
* - Output 65~80  : 0x25
* - Output 81~96  : 0x24
* - Output 97~112 : 0x21
* Delay Time:
* - 200 milliseconds between switching outputs
#include <PCF8575.h>     // Include the PCF8575 library
#define SDA_PIN 48       // Define SDA pin
#define SCL_PIN 47       // Define SCL pin
#define DELAY_TIME 50   // Delay between operations in milliseconds
// Create PCF8575 objects for each chip
PCF8575 pcf_1(0x27); // output 1-16
PCF8575 pcf_2(0x26); // output 17-32
PCF8575 pcf_3(0x23); // output 33-48
PCF8575 pcf_4(0x22); // output 49-64
PCF8575 pcf_5(0x25); // output 65-80
PCF8575 pcf_6(0x24); // output 81-96
PCF8575 pcf_7(0x21); // output 97-112
PCF8575 pcf_8(0x20); // output 113-128
// Array of pointers to PCF8575 objects
PCF8575* pcfArray[8] = {
  &pcf_1, &pcf_2, &pcf_3, &pcf_4,
  &pcf_5, &pcf_6, &pcf_7, &pcf_8
  Wire.begin(SDA_PIN, SCL_PIN);  // Initialize I2C with specified pins
  Serial.println("PCF8575 128-Channel Output Control Starting...");
  // Initialize all PCF8575 modules and set all pins to HIGH (OFF)
    pcfArray[i]->begin();
      pcfArray[i]->write(j, HIGH);  // Turn off all outputs initially
  // Turn ON outputs from 1 to 128 (LOW)
  for (int channel = 0; channel < 128; channel++) {
    int chipIndex = channel / 16;        // Which PCF8575 (0 to 7)
    int pinIndex = channel % 16;         // Which pin on that PCF8575 (0 to 15)
    pcfArray[chipIndex]->write(pinIndex, LOW); // Turn ON the output
    delay(DELAY_TIME);
  // Turn OFF outputs from 128 to 1 (HIGH)
  for (int channel = 127; channel >= 0; channel--) {
    pcfArray[chipIndex]->write(pinIndex, HIGH); // Turn OFF the output
    delay(DELAY_TIME);
.zip   1-output.zip (Size: 1.12 KB / Downloads: 662)
.zip   1-output.ino.merged.zip (Size: 181.63 KB / Downloads: 717)
  T128M ESPHome yaml for home assistant
Posted by: admin - 06-23-2025, 05:32 AM - Forum: T128M - No Replies
  friendly_name: t128m
  board: esp32-s3-devkitc-1
    type: esp-idf
  type: W5500
  clk_pin: GPIO42
  mosi_pin: GPIO43
  miso_pin: GPIO44
  cs_pin: GPIO41
  interrupt_pin: GPIO2
  reset_pin: GPIO1
   - id: bus_a
     sda: 48
     scl: 47
     frequency: 400kHz
   - id: bus_b
     sda: 12
     scl: 11
     frequency: 400kHz
    i2c_id: bus_a
    address: 0x27
    pcf8575: true
  - id: 'pcf8574_hub_out_2'  # for output channel 17-32
    i2c_id: bus_a
    address: 0x26
    pcf8575: true
  - id: 'pcf8574_hub_out_3'  # for output channel 33-48
    i2c_id: bus_a
    address: 0x23
    pcf8575: true
  - id: 'pcf8574_hub_out_4'  # for output channel 49-64
    i2c_id: bus_a
    pcf8575: true
  - id: 'pcf8574_hub_out_5'  # for output channel 65-80
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_out_6'  # for output channel 81-96
    i2c_id: bus_a
    pcf8575: true
  - id: 'pcf8574_hub_out_7'  # for output channel 97-112
    i2c_id: bus_a
    address: 0x21
    pcf8575: true
  - id: 'pcf8574_hub_out_8'  # for output channel 113-128
    i2c_id: bus_a
    address: 0x20
    pcf8575: true
    i2c_id: bus_b
    address: 0x27
    pcf8575: true
  - id: 'pcf8574_hub_in_2'  # for input channel 17-32
    i2c_id: bus_b
    address: 0x26
    pcf8575: true
  - id: 'pcf8574_hub_in_3'  # for input channel 33-48
    i2c_id: bus_b
    address: 0x23
    pcf8575: true
  - id: 'pcf8574_hub_in_4'  # for input channel 49-64
    i2c_id: bus_b
    pcf8575: true
  - id: 'pcf8574_hub_in_5'  # for input channel 65-80
    i2c_id: bus_b
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_in_6'  # for input channel 81-96
    i2c_id: bus_b
    pcf8575: true
  - id: 'pcf8574_hub_in_7'  # for input channel 97-112
    i2c_id: bus_b
    address: 0x21
    pcf8575: true
  - id: 'pcf8574_hub_in_8'  # for input channel 113-128
    i2c_id: bus_b
    address: 0x20
    pcf8575: true
      pcf8574: pcf8574_hub_out_1
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_2
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_3
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_4
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_5
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_6
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_7
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_8
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_in_2
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_in_3
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_in_4
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_in_5
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_in_6
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_in_7
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_in_8
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
## pull-up resistance on PCB
      number: 15
      number: 16
      inverted: false
      number: 17
      inverted:  false
      number: 18
      inverted:  false
## without pull-up resistance on PCB
      inverted:  false
      number: 8
      inverted:  false
      number: 9
      inverted:  false
      number: 10
      inverted:  false
  - platform: adc
    pin: 7
    name: "t128m A1 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
          } else if (x <= 0.15) {
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 6
    name: "t128m A2 Voltage"
    update_interval: 5s
    attenuation: 11db
    filters:
      # - multiply: 1.51515
      - lambda:
          if (x >= 3.11) {
            return x * 1.60256;
            return 0;
            return x * 1.51;
  - platform: adc
    pin: 5
    name: "t128m A3 Current"
    update_interval: 5s
    unit_of_measurement: mA
    attenuation: 11db
    filters:
      - multiply: 6.66666666
  - platform: adc
    pin: 4
    name: "t128m A4 Current"
    update_interval: 5s
    attenuation: 11db
    filters:
web_server:
  port: 80
download yaml file:
.txt   T128M-HA.txt (Size: 45.57 KB / Downloads: 442)
  T128M ESP32-S3 IO pins define
Posted by: admin - 06-23-2025, 05:31 AM - Forum: T128M - No Replies
analog A1 (0-5v): GPIO7
analog A2 (0-5v): GPIO6
analog A3 (4-20mA): GPIO5
analog A4 (4-20mA): GPIO4
IIC Bus-1:
SDA:GPIO48
SCL:GPIO47
PCF8575: (output1-16): i2c address:0x27
PCF8575: (output17-32): i2c address:0x26
PCF8575: (output33-48): i2c address:0x23
PCF8575: (output49-64): i2c address:0x22
PCF8575: (output65-80): i2c address:0x25
PCF8575: (output81-96): i2c address:0x24
PCF8575: (output97-112): i2c address:0x21
PCF8575: (output113-128): i2c address:0x20
24C02 EPROM i2c address: 0x50
IIC Bus-2:
SDA:GPIO12
SCL:GPIO11
PCF8575: (input1-16): i2c address:0x27
PCF8575: (input17-32): i2c address:0x26
PCF8575: (input33-48): i2c address:0x23
PCF8575: (input49-64): i2c address:0x22
PCF8575: (input65-80): i2c address:0x25
PCF8575: (input81-96): i2c address:0x24
PCF8575: (input97-112): i2c address:0x21
PCF8575: (input113-128): i2c address:0x20
GPIO15
GPIO16
GPIO17
GPIO18
free GPIO:
GPIO8
GPIO9
GPIO10
Ethernet (W5500) I/O define:
clk_pin: GPIO42
mosi_pin: GPIO43
miso_pin: GPIO44
cs_pin: GPIO41
reset_pin: GPIO1
RS485:
RXD:GPIO21
TXD:GPIO13
EN:GPIO14
  [arduino code examples for T32M]-07 read analog input ports
Posted by: admin - 06-23-2025, 05:28 AM - Forum: T32M - No Replies
* Description:
* This Arduino program reads analog values from four analog input pins (A1, A2, A3, A4)
* and prints the values to the Serial Monitor. The analog inputs are defined with specific
* GPIO pins and the program reads the voltage levels from these pins every 2 seconds.
* Pin Definitions:
* - A1: GPIO 7
* - A2: GPIO 6
* - A3: GPIO 5
* - A4: GPIO 4
#define ANALOG_A1   7   // Define GPIO pin for analog input A1
#define ANALOG_A2   6   // Define GPIO pin for analog input A2
#define ANALOG_A3   5   // Define GPIO pin for analog input A3
#define ANALOG_A4   4   // Define GPIO pin for analog input A4
    delay(500); // Short delay to allow serial communication to start
    pinMode(ANALOG_A1, INPUT); // Set GPIO 5 as an input for analog signal A1
    pinMode(ANALOG_A2, INPUT); // Set GPIO 7 as an input for analog signal A2
    pinMode(ANALOG_A3, INPUT); // Set GPIO 6 as an input for analog signal A3
    pinMode(ANALOG_A4, INPUT); // Set GPIO 4 as an input for analog signal A4
    // Read and print analog values from the defined pins
    Serial.print("A1=");
    Serial.println(analogRead(ANALOG_A1)); // Read and print the value from A1
    Serial.print("A2=");
    Serial.println(analogRead(ANALOG_A2)); // Read and print the value from A2
    Serial.print("A3=");
    Serial.println(analogRead(ANALOG_A3)); // Read and print the value from A3
    Serial.print("A4=");
    Serial.println(analogRead(ANALOG_A4)); // Read and print the value from A4
    delay(2000); // Wait for 2 seconds before the next reading
.zip   7-analog-input.zip (Size: 768 bytes / Downloads: 688)
.zip   7-analog-input.ino.merged.zip (Size: 187.2 KB / Downloads: 684)
