» Members: 10,402
» Latest member: Gurselak
» Forum threads: 4,322
» Forum posts: 21,297
There are currently 416 online users.
» 0 Member(s) | 399 Guest(s)
Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, HeadlessChrome, PetalBot, bot
9 hours ago
10 hours ago
11 hours ago
KC868-A4 – Relay 1 clicks...
Yesterday, 09:42 PM
450 Hz allowed on input?
Forum: Development
Yesterday, 09:41 PM
How Do You Handle Relay C...
Yesterday, 05:41 PM
"KCS" v3.27.4 firmware BI...
Yesterday, 06:02 AM
how to check i2c extend c...
Forum: T16M
Yesterday, 12:38 AM
T16M ESPHome yaml for hom...
Forum: T16M
Yesterday, 12:35 AM
Last Post: viko
11-01-2026, 01:42 PM
» Replies: 23
  Serial Monitoring
Posted by: joe.sfeir@gmail.com - 04-30-2025, 03:03 AM - Forum: T16M - No Replies
I am using Serial.begin() and Serial.println() but I see nothing in my Serial Monitor (Platformio). What could the problem be?
I am using 115200 as monitoring speed (configured in platformio.ini) and my Serial monitor is configured with the same rate.
I am using the demo code below:
* This program reads 16 input states from a PCF8575 I/O expander and
* controls a corresponding 16-channel relay module. When an input pin
* Pin Definitions:
* - SDA: GPIO 11
* - SCL: GPIO 12
* - Input I2C Address: 0x24
* - Relay I2C Address: 0x25
#include <PCF8575.h>     // Library to control the PCF8575 I/O expander
// Define I2C pins
#define SDA 11           // SDA pin
#define SCL 12           // SCL pin
// I2C addresses
#define INPUT_I2C_ADDRESS 0x24   // I2C address for the input PCF8575 module
#define RELAY_I2C_ADDRESS 0x25   // I2C address for the relay PCF8575 module
PCF8575 pcf8575_IN(INPUT_I2C_ADDRESS);    // Create an object for the input PCF8575
PCF8575 pcf8575_RL(RELAY_I2C_ADDRESS);    // Create an object for the relay PCF8575
  Wire.begin(SDA, SCL);
  pcf8575_IN.begin();
  pcf8575_RL.begin();
  // Turn off all relays at the start
    pcf8575_RL.write(i, LOW);  // Assuming relays are LOW when OFF, setting all relays to OFF initially
  Serial.println("System started: Input state controlling 16 relays");
  uint16_t inputState = 0;
  // Read the state of 16 inputs
    if (pcf8575_IN.read(i)) {
      inputState |= (1 << i);  // If input is HIGH, set the corresponding bit
      inputState &= ~(1 << i); // Otherwise, clear the corresponding bit
  Serial.println("Test Point...");
  // Control the relays based on the input state
    if (inputState & (1 << i)) {
      pcf8575_RL.write(i, HIGH);  // If input is HIGH, turn the relay OFF
      pcf8575_RL.write(i, LOW);   // If input is LOW, turn the relay ON
  // Delay for 500 milliseconds
  delay(500);
  RF with KCS-firmware
Posted by: jve91 - 04-29-2025, 05:57 PM - Forum: F16 - Replies (1)
Tried to copy some RF-remotes i had laying around.
I go the RF-page and hit the "learn" button. all i got is a timeout.
Is there anything that needs to be done first to receive the RF-signals?
I tried this running v3.9.1.
  Does the KC868-A6 V1.4 board provide a 5V output for DS18B20 sensors?
Posted by: GetBK - 04-29-2025, 12:04 PM - Forum: KC868-A6 - Replies (1)
Hi everyone,
I'm using the Kincony KC868-A6 V1.4 board and planning to connect several DS18B20 temperature sensors. I know these sensors can work with 3.3V, but they tend to be more stable with a 5V power supply—especially when using longer cables.
Does this board provide a dedicated 5V output pin that I can use to power the DS18B20 sensors? If so, where exactly can I find it on the board?
Any help or insights would be greatly appreciated!
Thanks in advance!
Exclamation Problems wifi / ESPHome?
Posted by: S.Krans - 04-29-2025, 10:59 AM - Forum: KC868-A128 - Replies (9)
Can somebody test my code my wifi is dropping and cant connect to it after the update esphome
ESPHome Device Builder
Current version: 2025.4.1
Home Assistant
Core 2025.4.4
Supervisor 2025.04.1
Operating System 15.2
Frontend 20250411.0
Network
UniFi OS 4.2.9
Network 9.0.114
.txt   koi-rk-kincony-kc868-a128_logs.txt (Size: 12.57 KB / Downloads: 515)
.txt   default-code.txt (Size: 618 bytes / Downloads: 497)
.txt   full code.txt (Size: 40.64 KB / Downloads: 450)
  PlatformIO Programming
Posted by: joe.sfeir@gmail.com - 04-29-2025, 10:25 AM - Forum: T16M - Replies (1)
Hi, NooB Here.
Trying to program the ESP32 in PlatformIO:
1. Which ESP32 S3 chip should I configure when creating the project in PlatformIO?
2. How do I make it connect to upload? Do I need to hold a button before uploading? I tried holding the DL button but it didn't connect. Same for the RST button.
  Relay type - Can I use DC?
Posted by: polarkreis - 04-28-2025, 05:41 PM - Forum: KC868-A32/A32 Pro - Replies (1)
Can I use 24V DC instead of 230V AC on relays?
I would like to use them to activate my 24VDC activated contactor (and then contactor would let 230V AC to pass through).
  KC868-A6 PCB layout CAD file
Posted by: admin - 04-28-2025, 12:46 PM - Forum: Schematic & diagram & Dimensions of KinCony PCB layout CAD file - No Replies
.zip   KC868_A6_V104SP.zip (Size: 255.69 KB / Downloads: 1032)
  KC868-A4 PCB layout CAD file
Posted by: admin - 04-28-2025, 12:44 PM - Forum: Schematic & diagram & Dimensions of KinCony PCB layout CAD file - No Replies
.zip   KC868-A4-V1.2.6-20250410.zip (Size: 436.78 KB / Downloads: 857)
  KC868-A2 PCB layout CAD file
Posted by: admin - 04-28-2025, 12:43 PM - Forum: Schematic & diagram & Dimensions of KinCony PCB layout CAD file - No Replies
.zip   KC868-A2-V2.4.zip (Size: 174.83 KB / Downloads: 848)
  KC868-A4 power consumption
Posted by: peacemakerv - 04-28-2025, 12:09 PM - Forum: KC868-A series and Uair Smart Controller - Replies (3)
Hi, All
If to use it by default only for relay control - what is the power consumption from 12VDC source ?
Also A4 and A6 models this info is needed (default power consumption).
