» Members: 10,402
» Latest member: Gurselak
» Forum threads: 4,322
» Forum posts: 21,297
There are currently 477 online users.
» 0 Member(s) | 455 Guest(s)
Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, HeadlessChrome, PetalBot, Semrush, bot
9 hours ago
10 hours ago
11 hours ago
KC868-A4 – Relay 1 clicks...
Yesterday, 09:42 PM
450 Hz allowed on input?
Forum: Development
Yesterday, 09:41 PM
How Do You Handle Relay C...
Yesterday, 05:41 PM
"KCS" v3.27.4 firmware BI...
Yesterday, 06:02 AM
how to check i2c extend c...
Forum: T16M
Yesterday, 12:38 AM
T16M ESPHome yaml for hom...
Forum: T16M
Yesterday, 12:35 AM
Last Post: viko
11-01-2026, 01:42 PM
» Replies: 23
  More inputs please
Posted by: kbo - 04-20-2025, 11:56 AM - Forum: TA - Replies (7)
I need more inputs for my alarm central. 32 inputs should be enough.
Is there a larger (more inputs) version  planned ?
Greetings,
Kris B.
  [arduino code examples for T64M]-07 i2c scanner search online devices
Posted by: admin - 04-20-2025, 07:45 AM - Forum: T64M - No Replies
// Made by KinCony IoT: https://www.kincony.com
// This sketch scans two I2C buses and prints all detected device addresses.
// IIC Bus-1: SDA - GPIO48, SCL - GPIO47
// IIC Bus-2: SDA - GPIO12, SCL - GPIO11
#include <Wire.h>
// Create two I2C bus objects
TwoWire I2C_BUS1 = TwoWire(0);
TwoWire I2C_BUS2 = TwoWire(1);
// Scan function for a specific I2C bus
void scanI2CBus(TwoWire &bus, const char* busName) {
  Serial.println();
  Serial.print("Scanning ");
  Serial.print(busName);
  Serial.println(" at 100kHz...");
  byte error, address;
  int nDevices = 0;
  for (address = 1; address < 127; address++) {
    bus.beginTransmission(address);
    error = bus.endTransmission();
    if (error == 0) {
      Serial.print("I2C device found at address 0x");
      if (address < 16)
        Serial.print("0");
      Serial.print(address, HEX);
      Serial.println("  ✓");
      nDevices++;
    } else if (error == 4) {
      Serial.print("Unknown error at address 0x");
      if (address < 16)
        Serial.print("0");
      Serial.println(address, HEX);
  if (nDevices == 0)
    Serial.println("No I2C devices found.");
  else
    Serial.println("Scan completed.");
  delay(1000); // Wait for serial to initialize
  // Initialize IIC Bus-1 (GPIO48 = SDA, GPIO47 = SCL) at 100kHz
  I2C_BUS1.begin(48, 47);
  // Initialize IIC Bus-2 (GPIO12 = SDA, GPIO11 = SCL) at 100kHz
  I2C_BUS2.begin(12, 11);
  // Start scanning both buses
  scanI2CBus(I2C_BUS1, "IIC Bus-1");
  scanI2CBus(I2C_BUS2, "IIC Bus-2");
  // Nothing to do in the loop
arduino ino file download:
.zip   7-i2c-scanner.zip (Size: 841 bytes / Downloads: 679)
.zip   7-i2c-scanner.ino.merged.zip (Size: 192.17 KB / Downloads: 689)
  [arduino code examples for T64M]-06 digital INPUT trigger OUTPUT directly
Posted by: admin - 04-20-2025, 07:44 AM - Forum: T64M - No Replies
* This Arduino program reads 64 input channels from 4 PCF8575 modules on I2C Bus-2
* and controls 64 output channels on 4 PCF8575 modules on I2C Bus-1.
* When an input pin is pulled LOW (connected to GND), the corresponding output relay is turned ON (LOW).
* Otherwise, the relay is turned OFF (HIGH).
* I2C Bus-1 (Outputs):
* - SDA: GPIO 48
* - SCL: GPIO 47
* - Output1~16  : 0x25
* - Output17~32 : 0x24
* - Output33~48 : 0x21
* - Output49~64 : 0x20
* I2C Bus-2 (Inputs):
* - SDA: GPIO 12
* - SCL: GPIO 11
* - Input1~16   : 0x25
* - Input17~32  : 0x24
* - Input33~48  : 0x21
* - Input49~64  : 0x20
#include <Wire.h>
#include <PCF8575.h>
// === Create two independent Wire objects ===
TwoWire I2C_Output = TwoWire(0);  // I2C Bus 1 - for output control
TwoWire I2C_Input  = TwoWire(1);  // I2C Bus 2 - for reading inputs
// === Output PCF8575 modules (connected to relays) ===
PCF8575 output_1(0x25, &I2C_Output);  // Output 1-16
PCF8575 output_2(0x24, &I2C_Output);  // Output 17-32
PCF8575 output_3(0x21, &I2C_Output);  // Output 33-48
PCF8575 output_4(0x20, &I2C_Output);  // Output 49-64
// === Input PCF8575 modules ===
PCF8575 input_1(0x25, &I2C_Input);    // Input 1-16
PCF8575 input_2(0x24, &I2C_Input);    // Input 17-32
PCF8575 input_3(0x21, &I2C_Input);    // Input 33-48
PCF8575 input_4(0x20, &I2C_Input);    // Input 49-64
// === Arrays to manage all input/output modules ===
PCF8575* inputArray[4]  = { &input_1, &input_2, &input_3, &input_4 };
PCF8575* outputArray[4] = { &output_1, &output_2, &output_3, &output_4 };
  Serial.println("KinCony 64-Channel Input-Output Mapping Test");
  // Initialize I2C buses
  I2C_Output.begin(48, 47); // SDA: GPIO48, SCL: GPIO47
  I2C_Input.begin(12, 11);  // SDA: GPIO12, SCL: GPIO11
  // Initialize all PCF8575 modules
  for (int i = 0; i < 4; i++) {
    inputArray[i]->begin();
    outputArray[i]->begin();
    // Initially turn off all relays (set to HIGH)
    for (int j = 0; j < 16; j++) {
      outputArray[i]->write(j, HIGH);
  for (int chip = 0; chip < 4; chip++) {
    for (int pin = 0; pin < 16; pin++) {
      int globalPin = chip * 16 + pin;  // 0~63
      bool inputState = inputArray[chip]->read(pin);
      // 0 = Signal present (connected to GND), relay ON (output LOW)
      // 1 = No signal, relay OFF (output HIGH)
      outputArray[chip]->write(pin, inputState ? HIGH : LOW);
  delay(200); // Slight delay to avoid excessive reading
.zip   6-input-trigger-output.zip (Size: 1.17 KB / Downloads: 715)
.zip   6-input-trigger-output.ino.merged.zip (Size: 192.34 KB / Downloads: 698)
  b16m programing blinds
Posted by: Mkuzman - 04-20-2025, 07:41 AM - Forum: "KCS" v3 firmware - Replies (16)
I need help
How di I program the controller to control the blind motor?
For example
If I press the up button once, the motor rotates to the end switsh, i.e. for a certaim mumber of secends, if I hold the same switch, the motor rotates "up" for as long as I hold  it, when I release it the motor stops.
The same procedure for lowering.
but if the button for lowering the blinds is pressed, then all the signals from digital input 1 stop
button for rising  is digital input 1, button for lowering is digital input 2
  [arduino code examples for T64M]-05 Ethernet W5500 chip work with TCP Server mode
Posted by: admin - 04-20-2025, 07:40 AM - Forum: T64M - No Replies
* received from a client.
* Hardware connections:
* - CLK: GPIO42
* - MOSI: GPIO43
* - MISO: GPIO44
* - CS: GPIO41
* - RST: GPIO1
* - INT: GPIO2
* Subnet Mask: 255.255.255.0
* Gateway: 192.168.3.1
* DNS: 192.168.3.1
#include <SPI.h>
#include <Ethernet.h>
#define W5500_CS_PIN  41
#define W5500_RST_PIN 1
#define W5500_INT_PIN 2
#define W5500_CLK_PIN 42
#define W5500_MOSI_PIN 43
#define W5500_MISO_PIN 44
EthernetServer server(4196);
  while (!Serial) {
  Ethernet.init(W5500_CS_PIN);
  Serial.print("IP Address: ");
  server.begin();
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        server.write(c);
    client.stop();
.zip   5-Ethernet-W5500.zip (Size: 1.23 KB / Downloads: 734)
.zip   5-Ethernet-W5500.ino.merged.zip (Size: 191.08 KB / Downloads: 694)
  [arduino code examples for T64M]-04 Read free GPIO state
Posted by: admin - 04-20-2025, 07:38 AM - Forum: T64M - No Replies
* GPIO Status Monitoring
* GPIO Pins Monitored:
* - GPIO 8
* - GPIO 9
* - GPIO 10
* - GPIO 15
* - GPIO 16
* - GPIO 17
* - GPIO 18
* - GPIO 0
* Hardware Requirements:
#define GPIO_PIN_8 8
#define GPIO_PIN_9 9
#define GPIO_PIN_10 10
#define GPIO_PIN_15 15
#define GPIO_PIN_16 16
#define GPIO_PIN_17 17
#define GPIO_PIN_18 18
#define GPIO_PIN_0 0
bool prevState[8] = {false, false, false, false, false, false, false, false};
  pinMode(GPIO_PIN_8, INPUT);
  pinMode(GPIO_PIN_9, INPUT);
  pinMode(GPIO_PIN_10, INPUT);
  pinMode(GPIO_PIN_15, INPUT);
  pinMode(GPIO_PIN_16, INPUT);
  pinMode(GPIO_PIN_17, INPUT);
  pinMode(GPIO_PIN_18, INPUT);
  pinMode(GPIO_PIN_0, INPUT);
  bool currentState[8];
  currentState[0] = digitalRead(GPIO_PIN_8);
  currentState[1] = digitalRead(GPIO_PIN_9);
  currentState[2] = digitalRead(GPIO_PIN_10);
  currentState[3] = digitalRead(GPIO_PIN_15);
  currentState[4] = digitalRead(GPIO_PIN_16);
  currentState[5] = digitalRead(GPIO_PIN_17);
  currentState[6] = digitalRead(GPIO_PIN_18);
  currentState[7] = digitalRead(GPIO_PIN_0);
  for (int i = 0; i < 8; i++) {
      Serial.print("GPIO ");
      Serial.print(i == 0 ? GPIO_PIN_8 :
                   i == 1 ? GPIO_PIN_9 :
                   i == 2 ? GPIO_PIN_10 :
                   i == 3 ? GPIO_PIN_15 :
                   i == 4 ? GPIO_PIN_16 :
                   i == 5 ? GPIO_PIN_17 :
                   i == 6 ? GPIO_PIN_18 : GPIO_PIN_0);
      Serial.print(" changed to ");
      // Update the previous state
.zip   4-free-gpio-state.zip (Size: 1.04 KB / Downloads: 665)
.zip   4-free-gpio-state.ino.merged.zip (Size: 181.77 KB / Downloads: 695)
  [arduino code examples for T64M]-03 RS485 communication test
Posted by: admin - 04-20-2025, 07:37 AM - Forum: T64M - No Replies
* RS485 Communication Test with Direction Control (SP3485EEN)
* The TXD pin is defined as GPIO 13, RXD is GPIO 21, and EN is GPIO 14.
#include <HardwareSerial.h>
// Define RS485 pins
#define RS485_RXD 21     // RS485 Receive
#define RS485_TXD 13     // RS485 Transmit
#define RS485_EN  14     // RS485 Direction control (High: Send, Low: Receive)
// Create a hardware serial object on UART1
  while (!Serial);
  // Set RS485 direction control pin
  pinMode(RS485_EN, OUTPUT);
  digitalWrite(RS485_EN, LOW); // Start in receive mode
  // Initialize RS485 serial communication
  Serial.println("RS485 Test Start (with direction control)");
  // Prepare the message to send
  String message = "Hello from KinCony T64M!";
  // Switch to transmit mode
  digitalWrite(RS485_EN, HIGH);
  delay(2); // Short delay to allow driver to switch
  // Send the message
  rs485Serial.println(message);
  rs485Serial.flush(); // Wait for transmission to complete
  // Switch back to receive mode
  Serial.println("Message sent. Waiting for response...");
  // Wait for a response (up to 1 second)
  unsigned long startTime = millis();
  while (millis() - startTime < 1000) {
      String receivedMessage = "";
        char c = rs485Serial.read();
        receivedMessage += c;
      // Print the received message
      Serial.print("Received: ");
      break;
  delay(2000);
.zip   3-RS485-Test.zip (Size: 1.02 KB / Downloads: 695)
.zip   3-RS485-Test.ino.merged.zip (Size: 186.66 KB / Downloads: 780)
  [arduino code examples for T64M]-02 Read digital input ports state
Posted by: admin - 04-20-2025, 07:35 AM - Forum: T64M - No Replies
* Description:
* This Arduino program reads the state of 64 input channels using 4 PCF8575 I/O expanders
* and prints the state of all input pins to the Serial Monitor. Each input state is printed
* in binary (0 = ON, 1 = OFF), grouped by 16 bits per chip.
* I2C Pin Definitions:
* - SDA: GPIO 12
* - SCL: GPIO 11
* PCF8575 Addresses:
* - Input  1~16 : 0x25
* - Input 17~32: 0x24
* - Input 33~48: 0x21
* - Input 49~64: 0x20
#include <Wire.h>
// Define I2C pins
#define SDA_PIN 12
#define SCL_PIN 11
// Create PCF8575 objects
PCF8575 pcf_1(0x25); // Input  1-16
PCF8575 pcf_2(0x24); // Input 17-32
PCF8575 pcf_3(0x21); // Input 33-48
PCF8575 pcf_4(0x20); // Input 49-64
// Array of PCF8575 pointers
PCF8575* pcfArray[4] = { &pcf_1, &pcf_2, &pcf_3, &pcf_4 };
  Wire.begin(SDA_PIN, SCL_PIN); // Initialize I2C
  // Initialize each PCF8575
    pcfArray[i]->begin();
  Serial.println("KinCony F64 64 channel input state  0:ON  1:OFF");
  Serial.println("Reading Inputs...");
    uint16_t state = 0;
    // Read 16 input pins per PCF8575
      if (pcfArray[chip]->read(pin)) {
        state |= (1 << pin); // Bit = 1 means OFF (no signal), 0 means ON
    // Display result
    Serial.print("Input ");
    Serial.print(chip * 16 + 1);
    Serial.print("~");
    Serial.print((chip + 1) * 16);
    Serial.print(": ");
    for (int b = 15; b >= 0; b--) {
      Serial.print(bitRead(state, b));
    Serial.println();
  Serial.println(); // Blank line between readings
  delay(500);       // Wait 500ms before next read
.zip   2-digital-input.zip (Size: 1.01 KB / Downloads: 683)
.zip   2-digital-input.ino.merged.zip (Size: 192.41 KB / Downloads: 719)
  [arduino code examples for T64M]-01 Turn ON/OFF OUTPUT
Posted by: admin - 04-20-2025, 07:34 AM - Forum: T64M - No Replies
* This program controls 64 outputs using 4 PCF8575 I/O expanders.
* It sequentially turns on outputs 1 to 64, then turns them off from 64 to 1, in a loop.
* - SDA: GPIO 48
* - SCL: GPIO 47
* - Output  1~16 : 0x25
* - Output 17~32: 0x24
* - Output 33~48: 0x21
* - Output 49~64: 0x20
* Delay Time:
* - 200 milliseconds between switching outputs
#include <PCF8575.h>     // Include the PCF8575 library
#define SDA_PIN 48       // Define SDA pin
#define SCL_PIN 47       // Define SCL pin
#define DELAY_TIME 200   // Delay between operations in milliseconds
// Create PCF8575 objects for each chip
PCF8575 pcf_1(0x25); // output  1-16
PCF8575 pcf_2(0x24); // output 17-32
PCF8575 pcf_3(0x21); // output 33-48
PCF8575 pcf_4(0x20); // output 49-64
// Array of pointers to PCF8575 objects
  Wire.begin(SDA_PIN, SCL_PIN);  // Initialize I2C with specified pins
  Serial.println("PCF8575 64-Channel Output Control Starting...");
  // Initialize all PCF8575 modules and set all pins to HIGH (OFF)
      pcfArray[i]->write(j, HIGH);  // Turn off all outputs initially
  // Turn ON outputs from 1 to 64 (LOW)
  for (int channel = 0; channel < 64; channel++) {
    int chipIndex = channel / 16;         // Which PCF8575 (0 to 3)
    int pinIndex = channel % 16;          // Which pin on that PCF8575 (0 to 15)
    pcfArray[chipIndex]->write(pinIndex, LOW); // Turn ON the output
    delay(DELAY_TIME);
  // Turn OFF outputs from 64 to 1 (HIGH)
  for (int channel = 63; channel >= 0; channel--) {
    pcfArray[chipIndex]->write(pinIndex, HIGH); // Turn OFF the output
    delay(DELAY_TIME);
.zip   1-output.zip (Size: 1.03 KB / Downloads: 688)
.zip   1-output.ino.merged.zip (Size: 192.12 KB / Downloads: 674)
  T64M ESPHome yaml for home assistant
Posted by: admin - 04-20-2025, 07:32 AM - Forum: T64M - No Replies
* This program reads 8 input states from a PCF8575 I/O expander and
* controls a corresponding 8-channel relay module. When an input pin
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* - PCF8575 I2C Address: 0x24
#include <Wire.h>
// I2C pins
#define SDA 8
#define SCL 18
// PCF8575 I2C address
#define INPUT_I2C_ADDRESS 0x24
PCF8575 pcf8575_IN(INPUT_I2C_ADDRESS);
  Wire.begin(SDA, SCL);
  // Initialize PCF8575
  pcf8575_IN.begin();
  // Turn off all relays first (assuming LOW activates the relay)
    pcf8575_IN.write(i, HIGH);  // Set to HIGH to turn off the relay
  Serial.println("System started: Input state controlling 8 relays");
  // Read 16-bit state from PCF8575
  uint16_t inputState = pcf8575_IN.read16();
    bool state = bitRead(inputState, i); // Read digital input state
    Serial.print("DI");
    Serial.print(i + 1);
    Serial.print(" State: ");
    Serial.println(state ? "HIGH" : "LOW");
    // Control relay (LOW activates the relay)
    pcf8575_IN.write(8 + i, state ? HIGH : LOW);
  Serial.println("---------------------");
  delay(500);
yaml download:
.txt   T64M-HA.txt (Size: 23.77 KB / Downloads: 565)
