» Members: 10,383
» Latest member: sutbongtvchannel
» Forum threads: 4,315
» Forum posts: 21,284
There are currently 100 online users.
» 0 Member(s) | 82 Guest(s)
AwarioBot, Baidu, Bing, Crawl, Semrush, bot, owler
how to check i2c extend c...
Forum: T16M
2 hours ago
T16M ESPHome yaml for hom...
Forum: T16M
2 hours ago
Last Post: viko
Yesterday, 01:42 PM
» Replies: 23
Recommended Dimmer for LE...
Yesterday, 08:21 AM
KC868-A16-V3.2: exact wir...
Forum: KC868-A16v3
Yesterday, 12:31 AM
ESPHome modbus not functi...
Forum: KC868-A8S
10-30-2026, 01:02 PM
SSD not visible for insta...
Forum: Pi5R16
10-29-2026, 12:30 PM
» Replies: 20
B32M And new ESPHOME Buil...
Forum: B32M
10-29-2026, 12:29 PM
Forum: T16M
10-29-2026, 08:42 AM
Forum: T16M
10-29-2026, 08:41 AM
  T16M
Posted by: H_spadacini - 04-09-2026, 05:46 AM - Forum: News - Replies (1)
Bonjour,
j'ai reçu le T16M hier.
il a tenu 5 mm , depuis voyant PWR éteins ,ainsi que tous les autres.
tension ok aux bornes.
vérifier au contrôleur de tension présence 24 V D.C. = ok
Le Kincony AIO hybride sur le même réseau électrique 24 V D.C. lui est ok ..
 pour moi, il est hors services malheureusement
le SAV m'a demande de vous faire un  mail pour justifier l'échange sous garantie.
Cordialement.
Hervé
.bmp   tests AIO.bmp (Size: 2.75 MB / Downloads: 303)
.bmp   tests t16M.bmp (Size: 4.56 MB / Downloads: 274)
  HAv2 ESPHome
Posted by: rhinoperth - 04-07-2026, 06:46 AM - Forum: KC868-HA /HA v2 - Replies (5)
Hi Team,
I'm having trouble getting the external components working since the ESPHome changes.
I keep getting the below error when I try and compile. I have cleaned up all the build files etc and still no change.
INFO Unable to import component kc686_ha: No module named 'esphome.components.kc686_ha'
Failed config
kc686_ha: [source /config/esphome/device-191.yaml:72]
  Component not found: kc686_ha.
Below is my current config that won't compile.
  friendly_name: Switch - TR House Hub 1
  variant: esp32
    type: esp-idf
external_components:
  - source:
      type: git
      url: https://github.com/hzkincony/esphome-kc868-ha
      ref: v3.0.3
  encryption:
    key: "xxxxx"
  reboot_timeout:
    seconds: 120
ota:
  - platform: esphome
    password: "xxxxx"
wifi:
  ssid: !secret wifi_ssid
  fast_connect: on
  manual_ip:
    static_ip: 172.16.5.191
    gateway: 172.16.5.1
    subnet: 255.255.255.0
    dns1: 172.16.5.1
  ap:
    ssid: "Device-191 Fallback Hotspot"
    password: "xxxxx"
captive_portal:
web_server:
  port: 80
  - id: rs485
    tx_pin: GPIO13
    rx_pin: GPIO16
    baud_rate: 9600
  sda: GPIO4
  scl: GPIO5
  scan: True
  - id: inputs_1_8
  - id: inputs_9_16
    address: 0x21
  - id: outputs_1_8
  - id: outputs_9_16
    address: 0x25
kc686_ha:
  ### RS485 ###
  ### Master Bed INT  ###
  - platform: kc868_ha
    target_relay_controller_addr: 1 # Default value is 1, corresponds to the Target Relay Controller Addr parameter in HA485_Ctrl software
    switch_adapter_addr: 11 # Default value is 10, corresponds to the Switch Adapter Addr parameter in HA485_Ctrl software
    bind_output: 1 # Corresponds to the BindOutput parameter in HA485_Ctrl software
    name: "Master Bed Internal Button 1"
  ### Master Bed EXT  ###
    switch_adapter_addr: 12 # Default value is 10, corresponds to the Switch Adapter Addr parameter in HA485_Ctrl software
    bind_output: 7 # Corresponds to the BindOutput parameter in HA485_Ctrl software
    name: "Master Bed External Button 1"
    bind_output: 8 # Corresponds to the BindOutput parameter in HA485_Ctrl software
    name: "Master Bed External Button 2"
  ### Master WIR  ###
    switch_adapter_addr: 13 # Default value is 10, corresponds to the Switch Adapter Addr parameter in HA485_Ctrl software
    bind_output: 13 # Corresponds to the BindOutput parameter in HA485_Ctrl software
    name: "Master WIR Button 1"
  ### Master Ensuite ###
    switch_adapter_addr: 14 # Default value is 10, corresponds to the Switch Adapter Addr parameter in HA485_Ctrl software
    bind_output: 19 # Corresponds to the BindOutput parameter in HA485_Ctrl software
    name: "Master Ensuite Button 1"
    bind_output: 20 # Corresponds to the BindOutput parameter in HA485_Ctrl software
    name: "Master Ensuite Button 2"
    bind_output: 21 # Corresponds to the BindOutput parameter in HA485_Ctrl software
    name: "Master Ensuite Button 3"
  ### RS485 ###
  ### Master INT ###
    bind_output: 1
    name: "Master Bed Internal Indicator 1"
  ### Master EXT ###
    bind_output: 7
    name: "Master Bed External Indicator 1"
    bind_output: 8
    name: "Master Bed External Indicator 2"
  ### Master WIR ###
    bind_output: 13
    name: "Master WIR Indicator 1"
  ### Master Ens ###
    bind_output: 19
    name: "Master Ensuite Indicator 1"
    bind_output: 20
    name: "Master Ensuite Indicator 2"
    bind_output: 21
    name: "Master Ensuite Indicator 3"
  KC868-A16 v1.6 – relays 9–16 not working in ESPHome
Posted by: dilo@interia.eu - 04-06-2026, 08:55 PM - Forum: KC868-A series and Uair Smart Controller - Replies (1)
I use KC868-A16 (version 1.6).
I flashed ESPHome and I can control relays 1–8 correctly.
But relays 9–16 are not working.
I2C scan shows:
0x21, 0x22, 0x24, 0x25
PCF8574 at 0x24 works fine.
PCF8574 at 0x25 is detected but relays don’t respond.
I tried different pin mappings but still only first 8 relays work.
Can you provide correct ESPHome YAML for this hardware version?
Thank you.
I can provide logs or photos if needed.
  kc-868 AK
Posted by: Saif Kitany - 04-05-2026, 04:11 PM - Forum: "KCS" v3 firmware - Replies (12)
i have 2 old controlles, H32L and H32B.
i want to control them by KC-868 AK.
so the H32B controller i set as TCP SERVER, both ethernet and wifi, AND in the kc-868 ak i enabled tcp client and put the ip adress of the controller and the port, and it works well.
now my question is :
can i control the second controller H32L by UDP?
  AIO Hybrid wiring diagram
Posted by: admin - 04-05-2026, 05:45 AM - Forum: AIO Hybrid - No Replies
  false start with KC868 A16 v3
Posted by: PhVdP - 04-04-2026, 05:40 PM - Forum: KC868-A16v3 - Replies (5)
I received the KC868-A16v3; wired as documentation, powered it on, flashered it with latest firmware, changed the USB cable                     ... but it's not working : only a red led is lighting, no ethernet connection setting (green light on the board, orange light on the router). I've tried with another usb cable, pressing buttons reset/rebootable during power it on... Still impossible to connect. I've tried with Putty and serial communication with the USD cable; without success...
Any idea is welcome.
  New TA web interface unavailable
Posted by: pbouwen - 04-03-2026, 01:55 PM - Forum: TA - Replies (3)
Hi everyone,
Just received my first Kincony device; a Tiny Alarm system.
Unfortunately, I don't succeed in accessing the web interface to set it up for use with Home Assistant.
I powered it with PoE and looked up the assigned IP address in my router.
When I try accessing that IP in my browser, I get the message that the page can't be reached.
I can ping the IP however.
Rebooting the device did not help.
Holding the reset button for +10 seconds also did not change anything.
What other steps can I take to troubleshoot this?
Should I try to reflash it? I'm using a Mac so not my preferred option.
Thanks in advance for your help!
  N10 wire case diagram for 1 phase load
Posted by: admin - 04-03-2026, 12:22 AM - Forum: N10 - No Replies
  "KCS" v2.2.20 firmware BIN file download
Posted by: admin - 04-03-2026, 12:15 AM - Forum: "KCS" v2 firmware system - No Replies
v2.2.20 improvement:
Fix the issue of insufficient Tuya MQTT resources causing restarts.
.zip   KCS_KC868_A2_V2.2.20.zip (Size: 795.82 KB / Downloads: 467)
.zip   KCS_KC868_A4_V2.2.20.zip (Size: 782.95 KB / Downloads: 400)
.zip   KCS_KC868_A4S_V2.2.20.zip (Size: 806.65 KB / Downloads: 338)
.zip   KCS_KC868_A6_V2.2.20.zip (Size: 780.98 KB / Downloads: 681)
.zip   KCS_KC868_A8_V2.2.20.zip (Size: 789.82 KB / Downloads: 444)
.zip   KCS_KC868_A8M_V2.2.20.zip (Size: 806.24 KB / Downloads: 357)
.zip   KCS_KC868_A8S_V2.2.20.zip (Size: 807.64 KB / Downloads: 392)
.zip   KCS_KC868_A16_V2.2.20.zip (Size: 797.19 KB / Downloads: 720)
.zip   KCS_KC868_A16S_V2.2.20.zip (Size: 807.63 KB / Downloads: 405)
.zip   KCS_KC868_A32_V2.2.20.zip (Size: 787.42 KB / Downloads: 453)
.zip   KCS_KC868_A32M_V2.2.20.zip (Size: 805.37 KB / Downloads: 389)
.zip   KCS_KC868_A64_V2.2.20.zip (Size: 787.34 KB / Downloads: 404)
.zip   KCS_KC868_A128_V2.2.20.zip (Size: 787.19 KB / Downloads: 322)
.zip   KCS_KC868_AG_V2.2.20.zip (Size: 765.28 KB / Downloads: 349)
.zip   KCS_KC868_AI_V2.2.20.zip (Size: 789.63 KB / Downloads: 363)
.zip   KCS_KC868_AIO_V2.2.20.zip (Size: 807.05 KB / Downloads: 366)
.zip   KCS_KC868_AK_V2.2.20.zip (Size: 767.66 KB / Downloads: 329)
.zip   KCS_KC868_AM_V2.2.20.zip (Size: 783.03 KB / Downloads: 352)
.zip   KCS_KC868_AP_V2.2.20.zip (Size: 785.46 KB / Downloads: 399)
.zip   KCS_KC868_ASR_V2.2.20.zip (Size: 762.24 KB / Downloads: 382)
.zip   KCS_KC868_E16S_V2.2.20.zip (Size: 791.98 KB / Downloads: 392)
.zip   KCS_KC868_UAIR_V2.2.20.zip (Size: 768.45 KB / Downloads: 349)
  N20 wire case diagram for 1 phase load
Posted by: admin - 04-02-2026, 11:34 PM - Forum: N20 - No Replies
