» Members: 10,143
» Latest member: Spectrumbpo
» Forum threads: 4,259
» Forum posts: 21,098
There are currently 370 online users.
» 0 Member(s) | 350 Guest(s)
Applebot, AwarioBot, Baidu, Bing, Bytespider, Crawl, Google, PetalBot, bot
It looks like it's broken...
6 hours ago
Bidirectional reading
Forum: N10
Yesterday, 11:35 PM
Update to latest esphome
Yesterday, 12:05 PM
KC868-A16 ethernet work w...
10-04-2026, 11:43 PM
» Replies: 31
B32M maximum voltage
10-04-2026, 11:52 AM
» Replies: 4
m16v2 energy meter - cali...
10-02-2026, 11:50 AM
» Replies: 15
oCBot: KC868-A6/A16 as a ...
Last Post: oCBot
10-01-2026, 01:32 PM
N20 Energy RS485 Modbus P...
Forum: N20
10-01-2026, 12:43 PM
Getting inconsistent/wron...
10-01-2026, 12:40 PM
KC868-HAv2 phantom press ...
Forum: KC868-HA /HA v2
Last Post: phrfpeixoto
09-29-2026, 01:57 AM
  Advanced control using temperature
Posted by: balcerseb - 02-23-2025, 08:30 AM - Forum: KC868-A16 - Replies (1)
Hi is it possible through Kincony software to do such logic:
I would like to control two outputs the first output is to increase the flow of water the second to decrease the example:
temperature sensor measures the temperature of water that flows through e.g. a heater at a setting of, for example, 30 degrees it does nothing after exceeding e.g. by 3 degrees the logic turns on output ''1'' for 10 s (to increase the flow and at the same time reduce the temperature of heated water) the thermometer measurement would have to measurement of the thermometer would have to be taken at intervals, e.g. every 20 seconds (adjustable) and the principle of operation is reversed if the temperature drops after some time logic turns on output ''1'' to reduce the flow in order to equalize the temperature and so on and so forth the measurement would have to be taken at intervals due to the reaction time of cooling water.
Is it possible to set it up this way through the IFTTT website
It must work on the principle of a temperature controller only with a delay ( warm up or cool down response time)
  T16M MOSFET max current
Posted by: Mojito_dev - 02-22-2025, 03:44 PM - Forum: "KCS" v3 firmware - Replies (1)
T16M max current is max 4A per channel, and max 24V or all capacity is 4A for all channels?
  A8s v2 inputs not working when using PoE
Posted by: halt77 - 02-22-2025, 10:43 AM - Forum: KC868-A8S - Replies (5)
Dear Kincony team,
It seems to be a problem with the A8S v2 board.
I've tested the A8S v2 with the PoE board and none of the inputs work (using either the KCS or esphome firmware).
If you power the board using the 12v input, everything works as expected (the inputs work), but as soon as you power the board with the Kinkony PoE board, all inputs go down (and they stop showing the expected status).
You can easily diagnose this providing power to the board only with PoE, as you will see the inputs do not work (even using KCS firmware).
I've about 20 A8S v2 boards. How can I correct this so inputs work when using PoE power?
Regards.
  M16v2
Posted by: kr_user - 02-22-2025, 10:11 AM - Forum: KC868-M16 / M1 / MB / M30 - Replies (1)
Does the m16v2 support bidirectional currents ? => Show negative current if clamp is turned the other way?
  "KCS" v3.7.2 firmware BIN file download
Posted by: admin - 02-22-2025, 07:58 AM - Forum: "KCS" v3 firmware - No Replies
v3.7.2 improvement:
1. fixed dimmer issue in Tuya app.
.zip   KCS_A6V3_V3.7.2.zip (Size: 1 MB / Downloads: 786)
.zip   KCS_A16V3_V3.7.2.zip (Size: 1.08 MB / Downloads: 832)
.zip   KCS_A32PRO_V3.7.2.zip (Size: 1.04 MB / Downloads: 682)
.zip   KCS_AG8_V3.7.2.zip (Size: 1.03 MB / Downloads: 726)
.zip   KCS_B16M_V3.7.2.zip (Size: 1.07 MB / Downloads: 791)
.zip   KCS_F16_V3.7.2.zip (Size: 1.07 MB / Downloads: 722)
.zip   KCS_F24_V3.7.2.zip (Size: 1.07 MB / Downloads: 722)
.zip   KCS_T16M_V3.7.2.zip (Size: 1.02 MB / Downloads: 775)
  Is there a A8v3 coming with ESP32-S3? KC868-A8v3
Posted by: dbl0 - 02-22-2025, 03:28 AM - Forum: KC868-A series and Uair Smart Controller - Replies (3)
I saw the A6v3 land, but I need 8 outputs!
  [arduino code examples for B16]-11 digital INPUT trigger OUTPUT directly
Posted by: admin - 02-22-2025, 02:12 AM - Forum: B16 - No Replies
* This program reads 16 input states from a PCF8575 I/O expander and
* controls a corresponding 16-channel relay module. When an input pin
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* - Input I2C Address: 0x24
* - Relay I2C Address: 0x25
#include <PCF8575.h>     // Library to control the PCF8575 I/O expander
// Define I2C pins
#define SDA 8           // SDA pin
#define SCL 18           // SCL pin
// I2C addresses
#define INPUT_I2C_ADDRESS 0x24   // I2C address for the input PCF8575 module
#define RELAY_I2C_ADDRESS 0x22   // I2C address for the relay PCF8575 module
PCF8575 pcf8575_IN(INPUT_I2C_ADDRESS);    // Create an object for the input PCF8575
PCF8575 pcf8575_RL(RELAY_I2C_ADDRESS);    // Create an object for the relay PCF8575
  Wire.begin(SDA, SCL);
  pcf8575_IN.begin();
  pcf8575_RL.begin();
  // Turn off all relays at the start
    pcf8575_RL.write(i, LOW);  // Assuming relays are LOW when OFF, setting all relays to OFF initially
  Serial.println("System started: Input state controlling 16 relays");
  uint16_t inputState = 0;
  // Read the state of 16 inputs
    if (pcf8575_IN.read(i)) {
      inputState |= (1 << i);  // If input is HIGH, set the corresponding bit
      inputState &= ~(1 << i); // Otherwise, clear the corresponding bit
  // Control the relays based on the input state
    if (inputState & (1 << i)) {
      pcf8575_RL.write(i, HIGH);  // If input is HIGH, turn the relay OFF
      pcf8575_RL.write(i, LOW);   // If input is LOW, turn the relay ON
  // Delay for 500 milliseconds
  delay(500);
arduino ino file download:
.zip   11-input-trigger-output.zip (Size: 1.02 KB / Downloads: 756)
.zip   11-input-trigger-output.ino.merged.zip (Size: 189.4 KB / Downloads: 767)
  [arduino code examples for B16]-10 Print TEXT on SSD1306 OLED displayer
Posted by: admin - 02-22-2025, 02:10 AM - Forum: B16 - No Replies
* - SCL (clock) on pin IO18
* - SDA (data) on pin IO8
// Initialize the display using the software I2C method (SCL = IO39, SDA = IO38)
void page1() {
  u8g2.begin();
  do {
    page1();
.zip   10-oled-ssd1306.zip (Size: 1.12 KB / Downloads: 733)
.zip   10-oled-ssd1306.ino.merged.zip (Size: 201.24 KB / Downloads: 743)
  [arduino code examples for B16]-09 how to communication with Tuya WiFi module
Posted by: admin - 02-22-2025, 02:08 AM - Forum: B16 - No Replies
* Functionality:
#include <HardwareSerial.h>
HardwareSerial tuyaSerial(1);
#define TXD_PIN 16
#define RXD_PIN 17
#define BAUD_RATE 9600
  if (tuyaSerial.available()) {
      if (bytesRead < 7) {
          if (bytesRead >= 7) break;
        return;
        Serial.print(" ");
      Serial.println();
        Serial.print(" ");
      Serial.println();
  // Delay to avoid CPU overuse
  delay(100);
    switch(packet[2]) {
      case 0x00:
        break;
      default:
        break;
    Serial.print(packet[i], HEX);
    Serial.print(" ");
  Serial.println();
.zip   9-tuya-wifi-config.zip (Size: 2 KB / Downloads: 725)
.zip   9-tuya-wifi-config.ino.merged.zip (Size: 184.93 KB / Downloads: 715)
  [arduino code examples for B16]-08 Ethernet W5500 chip work with TCP Server mode
Posted by: admin - 02-22-2025, 02:07 AM - Forum: B16 - No Replies
* received from a client.
* Hardware connections:
* - CLK: GPIO1
* - MOSI: GPIO2
* - MISO: GPIO41
* - CS: GPIO42
* - RST: GPIO44
* - INT: GPIO43
* Subnet Mask: 255.255.255.0
* Gateway: 192.168.3.1
* DNS: 192.168.3.1
#include <SPI.h>
#include <Ethernet.h>
#define W5500_CS_PIN  42
#define W5500_RST_PIN 44
#define W5500_INT_PIN 43
#define W5500_CLK_PIN 1
#define W5500_MOSI_PIN 2
#define W5500_MISO_PIN 41
EthernetServer server(4196);
  while (!Serial) {
  Ethernet.init(W5500_CS_PIN);
  Serial.print("IP Address: ");
  server.begin();
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        server.write(c);
    client.stop();
.zip   8-Ethernet-W5500.ino.merged.zip (Size: 188.93 KB / Downloads: 794)
.zip   8-Ethernet-W5500.zip (Size: 1.23 KB / Downloads: 733)
