» Members: 10,200
» Latest member: bsmdigital12
» Forum threads: 4,265
» Forum posts: 21,156
There are currently 559 online users.
» 0 Member(s) | 536 Guest(s)
Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, HeadlessChrome, PetalBot, Semrush, bot, owler
KC868-AI mDNS problem
Forum: KC868-AI
Last Post: Konrad
2 hours ago
IFTTT
Last Post: newdos
5 hours ago
KC868-A16 and Tuya
Last Post: newdos
11 hours ago
» Replies: 10
N30 (KCS): energy counter...
Forum: N30
Today, 05:52 AM
N60 Loss of kWh on reset
Forum: N60
Today, 05:51 AM
» Replies: 13
N60 Sensor channel label
Forum: N60
Today, 05:50 AM
» Replies: 19
Current direction detecti...
Forum: N30
Today, 05:49 AM
remember relay state
Forum: KC868-E16T
Last Post: greeryan
Today, 12:21 AM
» Replies: 10
SSD not visible for insta...
Forum: Pi5R16
Yesterday, 11:46 PM
» Replies: 11
Bricked KC868-A16
10-09-2026, 11:09 PM
» Replies: 7
  KC868 COLB MINI
Posted by: Astil - 03-10-2023, 06:00 AM - Forum: KC868-Server Raspberry Pi4 local server - Replies (13)
I have a device KC868 COLB MINI , i try to configure this by connecting power source and ethernet but i didn't find any ip address in the ip scanner and i dont have any response from the device side.... please help me to configure this
Photo esphome error timeout
Posted by: OscarW - 03-10-2023, 12:01 AM - Forum: KC868-A16 - Replies (6)
Error timeout
the screenshot
https://ibb.co/tb3Nzw2
  USING SMART HOME APP
Posted by: JuanjoG - 03-09-2023, 08:32 AM - Forum: KC868-HxB series Smart Controller - Replies (9)
Hi Kincony!
I bought the KC868-H8B. I set the device but now I have two questions:
1. Can I set the switch icoms in the SMART HOME APP to work in momentary mode? For example to open the garage door I only need a push button.
2. Can I see the state of the INPUTS in de SMART HOME APP like I can see in the PC SOFTWARE (by LAN)?
Thank you very much.
  KC868-H32B Pro work with KC868-COLB + KC868-AK
Posted by: admin - 03-09-2023, 02:22 AM - Forum: Schematic & diagram & Dimensions of KinCony PCB layout CAD file - Replies (10)
  Where to start
Posted by: benlouisv@gmail.com - 03-06-2023, 04:35 PM - Forum: KC868-A6 - Replies (11)
Hi there everyone. I see allot of amazing things you can do with the KC868-A6 but I have no Idea where to start. I want to controll the unit with Smart life APP to switch my electric appliances on and of. But I dont know where to start with this board can anyone please assist me with steps to start using this board.
Thank you
  updating firmware kc868-h32b
Posted by: w-w - 03-06-2023, 03:05 PM - Forum: KC868-HxB series Smart Controller - Replies (8)
my unit shipped with firmware version 4.13.34
I am attempting to upload version
Relay32_V437_210907.zip
OTA seams to run for only a few seconds and does not update
Using a serial cable and the Firmware Download Tool (firmware update tool download): https://www.kincony.com/download/KC868-C...loader.zip
it detects the bootloader
downloads progress 105/105
data send complete
then when I press Run
it says Download finished begin running.
I power cycle the device that the firmware version is not updated??
thanks
Tongue KC868-COLB V2.4 firmware support Tuya app
Posted by: admin - 03-06-2023, 02:05 PM - Forum: News - Replies (10)
improvement:
1. support use Tuya app for remote monitor sensor state.
2. support TCP Server, TCP Client, MQTT, Tuya different protocol at the same time by ethernet.
such as you can use Home assistant (by mqtt) in local LAN network and Tuya app for remote monitor by internet.
if you buy KC868-COLB before 2023-3-1 , you need to update your BOOTLOADER HEX file for your CPU.
Because the new firmware 2.4 is big and powerful. So you need to do two steps for update fireware.
1. update your CPU BOOTLOADER by Jlink tool.
2. update your firmware BIN file by USB-RS232 cable.
here are details:
for example, your KC868-COLB CPU chip is AT32F403AVGT7.
so download AT-link tool for flash BOOTLOADER.
.zip   Artery_ICP_Programmer_V3.0.07.zip (Size: 14.28 MB / Downloads: 938)
BOOTLOADER HEX file download
.zip   Bootloader_AD_V2_0_2_20210913.zip (Size: 4.88 KB / Downloads: 953)
open your KC868-COLB metal box
installed jlink computer driver and ready to use it.
here is pin define , connect jlink to your KC868-COLB PCB's download interface
begin download BOOTLOADER HEX file , just do as follow images:
after download BOOTLOADER completed, begin use RS232 download tool to download BIN file.
RS232 download tool:
BIN file download:
.zip   AD_COLB_V2_4_230228.zip (Size: 112.17 KB / Downloads: 967)
begin download BIN file , just do as follow images:
now all are completed, have a good timeSmile
Note: if you want to use Tuya mobile phoen app with KC868-COLB, need contact with us to buy Tuya lincence for KC868-COLB.
  Did I burn the DI s?
Posted by: tugalsan - 03-06-2023, 12:41 PM - Forum: KC868-A32/A32 Pro - Replies (5)
I accidently plug 12 Volt to GND of DI sockets.
Even though, I did not plugged any wire on DI, I am getting the below output.
When I check it with Voltmeter, DIs is giving me 12V
Does that mean, I did burn the card? Or a code error?
code:
#include "PCF8574.h"
//I2C INPUT
TwoWire I2C_0 = TwoWire(0);
PCF8574 pcf8574_I1(&I2C_0, 0x24, 4, 5);
PCF8574 pcf8574_I2(&I2C_0, 0x25, 4, 5);
PCF8574 pcf8574_I3(&I2C_0, 0x21, 4, 5);
PCF8574 pcf8574_I4(&I2C_0, 0x22, 4, 5);
//I2C RELAY
TwoWire I2C_1 = TwoWire(1);
PCF8574 pcf8574_R1(&I2C_1, 0x24, 15, 13);
PCF8574 pcf8574_R2(&I2C_1, 0x25, 15, 13);
PCF8574 pcf8574_R3(&I2C_1, 0x21, 15, 13);
PCF8574 pcf8574_R4(&I2C_1, 0x22, 15, 13);
void setup_input() {
  for(int i=0;i<=7;i++){
    pcf8574_I1.pinMode(i, INPUT);
    pcf8574_I2.pinMode(i, INPUT);
    pcf8574_I3.pinMode(i, INPUT);
    pcf8574_I4.pinMode(i, INPUT);
  pcf8574_I1.begin();
  pcf8574_I2.begin();
  pcf8574_I3.begin();
  pcf8574_I4.begin();
void setup_output() {
    pcf8574_R2.pinMode(i, OUTPUT);
    pcf8574_R3.pinMode(i, OUTPUT);
    pcf8574_R4.pinMode(i, OUTPUT);
  pcf8574_R1.begin();
  pcf8574_R2.begin();
  pcf8574_R3.begin();
  pcf8574_R4.begin();
  for(int i=0;i<=7;i++) {
    pcf8574_R2.digitalWrite(i, HIGH);
    pcf8574_R3.digitalWrite(i, HIGH);
    pcf8574_R4.digitalWrite(i, HIGH);
void setup_serial(){
  while (!Serial && (millis() < 3000));
void print_chip_arduino(){
  Serial.print(F("\n\n----------------\n\n"));
  Serial.print(F("ARDUINO_BOARD:"));
  Serial.println(String(ARDUINO_BOARD));
void refreshCurrentTime(){
    currentTime = millis();
void print_loopHeader(){
  Serial.print(F("---------"));
  Serial.print(F("t: "));
  Serial.print(String(currentTime));
  Serial.println(F(" ---------"));
void print_input(){
      bool input1 = pcf8574_I1.digitalRead(i);
      bool input2 = pcf8574_I2.digitalRead(i);
      bool input3 = pcf8574_I3.digitalRead(i);
      bool input4 = pcf8574_I4.digitalRead(i);
      Serial.print(F("i:"));
      Serial.print(String(i));
      Serial.print(F(" I1:"));
      Serial.print(String(input1));
      Serial.print(F(" I2:"));
      Serial.print(String(input2));
      Serial.print(F(" I3:"));
      Serial.print(String(input3));
      Serial.print(F(" I4:"));
      Serial.println(String(input4));
  setup_input();
  setup_output();
  setup_serial();
  print_chip_arduino();
  refreshCurrentTime();
  print_loopHeader();
  print_input();
output:
---------t: 8096 ---------
i:0 I1:1 I2:1 I3:1 I4:1
i:1 I1:1 I2:1 I3:1 I4:1
i:2 I1:1 I2:1 I3:1 I4:1
i:3 I1:1 I2:1 I3:1 I4:1
i:4 I1:1 I2:1 I3:1 I4:1
i:5 I1:1 I2:1 I3:1 I4:1
i:6 I1:1 I2:1 I3:1 I4:1
i:7 I1:1 I2:1 I3:1 I4:1
  KC868-AP
Posted by: eligijus - 03-05-2023, 07:23 PM - Forum: KC868-AP / ADR - Replies (34)
hi, maybe you can upload firmware bin file with esp KC868-AP
  Not found
Posted by: Philadam - 03-05-2023, 12:47 AM - Forum: KC868-A16 - Replies (10)
When I attach my A16 to my local network and run scan_device, nothing shows up in the list. I have let it run for over 15 minutes, but the A16 is not found.
Advice?
