» Members: 9,830
» Latest member: comhosp
» Forum threads: 4,220
» Forum posts: 20,943
There are currently 38 online users.
» 0 Member(s) | 27 Guest(s)
Amazonbot, Baidu, Bytespider, Crawl, bot
ESPHome modbus not functi...
Forum: KC868-A8S
58 minutes ago
4 hours ago
» Replies: 18
KC868-H32B
Yesterday, 10:25 AM
KC868-HA PC software V1.0...
Forum: KC868-HA /HA v2
Yesterday, 08:12 AM
» Replies: 19
Kc868ia
Forum: KC868-AI
Yesterday, 01:26 AM
HAv2 ESPHome
Yesterday, 01:24 AM
Need Help Getting Started...
Yesterday, 01:20 AM
No ethernet communication
09-05-2026, 10:56 AM
» Replies: 10
N60 Loss of kWh on reset
Forum: N60
Last Post: chuyskywalker
09-04-2026, 03:58 AM
» Replies: 12
CT Sensor Direction
Forum: N60
09-03-2026, 12:51 PM
  Which Board?
Posted by: Mohd Faudzee Hamid - 03-21-2023, 08:53 AM - Forum: DIY Project - Replies (1)
Iam a newbie, I want to ask, if we want to start learning Kincony's system, a basic one, just to control ON and OFF about 8
lamps and 5 Aircon all in one room by using wifi (smart phone), which board from Kincony that you suggest?
  AJUDA PARA CRIAR UM SKETICK IDE PARA AUTOMAÇÃO
Posted by: claudio - 03-21-2023, 03:53 AM - Forum: DIY Project - Replies (13)
OLA PRECISO DE UM SKETICK PARA TRABALHAR COM 2 PLACA
vocêMA A A4 EA OUTA A A8 SENDO QUE A A4 ENVIA SINAL PARA A PACA A8 VIA REDE
OPROJETO E LER OS STATUS DOS SENSORES E COSSESPONDER NA OUTRA PLACA RECEBENDO OS STATUS FISICAMENTE E ONDE EU POSSA ABRIR A PAGINA PARA MONITORAR
SRIA MAIS OU MENOS ASSIM
onst int Sensor_1 = 2 ; // nivel em 100%
const int Sensor_2 = 3 ; // nivel em 50%
const int Sensor_3 = 4 ; // nivel em 15%
const int ledPin_Sensor_1 = 8 ; // led sem pino 8
const int ledPin_Sensor_2 = 9 ; // led sem pino 9
const int ledPin_Sensor_3 = 10 ; // led no pino 10
int estadoSensor_1; // variável para ler o status do Sensor_1
intestadoSensor_2; // variável para ler o status do Sensor_2
int estadoSensor_3; // variável para ler o status do Sensor_3
void setup () {
  pinMode (Sensor_1, INPUT); // Pino com sensor será entrada
  pinMode (Sensor_2, INPUT); // Pino com sensor será entrada
  pinMode (Sensor_3, INPUT); // Pino com sensor será entrada
  pinMode (ledPin_Sensor_1, OUTPUT); // Pino do led será saída
  pinMode (ledPin_Sensor_2, OUTPUT); // Pino do led será saída
  pinMode (ledPin_Sensor_3, OUTPUT); // O pino do led será saída
void loop () {
 Serial . começar ( 9600 );
  estadoSensor_1 = digitalRead (Sensor_1); // le o estado do Sensor_1 - HIGH OU LOW
  if (estadoSensor_1 == LOW) { // Se o sensor estiver procurando (LOW)
    digitalWrite (ledPin_Sensor_1, HIGH); // acende o led do pino 8.
  } else { // se não estiver invocado (HIGH)
    digitalWrite (ledPin_Sensor_1, LOW); // deixa o led do pino 8 apagado
  estadoSensor_2 = digitalRead (Sensor_2);// le o estado do Sensor_2 - HIGH OU LOW
  if (estadoSensor_2 == LOW) { // Se o sensor estiver ocupado (LOW)
    digitalWrite (ledPin_Sensor_2, HIGH); // acende o led do pino 9.
    digitalWrite (ledPin_Sensor_2, LOW); // deixa o led do pino 9 apagado
  estadoSensor_3 = digitalRead (Sensor_3); // le o estado do Sensor_3 - HIGH OU LOW
  if (estadoSensor_3 == LOW) { // Se o sensor estiver procurando (LOW)
    digitalWrite (ledPin_Sensor_3, HIGH); // acende o led do pino 10.
  }else { // se não estiver (HIGH)
    digitalWrite (ledPin_Sensor_3, LOW); // deixa o led do pino 10 desligado
O DESSA FORMA
PARA A PLACA KC686 A4 ESSE CODIGO JA RODA POREM SEM AS CONFIGURACOES DE ACESSO E ACRESCENTAR O QUE FOR NECESSÁRIO PARA A PLACA KC686 A8 RECEBER OS SINAAIS E ATUAL COMO SE FOSSE NELA
const int PIN_SENSOR_1 = 36;
const int PIN_SENSOR_2 = 39;
const int PIN_SENSOR_3 = 27;
const int PIN_RELAY_1 = 2;
const int PIN_RELAY_2 = 15;
const int PIN_RELAY_3 = 5;
const int PIN_RELAY_4 = 4;
const int PIN_BUZZER = 18;
const int BOTAO_4 = 14;
bool sensor_1_status = falso;
bool sensor_2_status = falso;
bool sensor_3_status = falso;
  pinMode(PIN_SENSOR_1, INPUT);
  pinMode(PIN_SENSOR_2, INPUT);
  pinMode(PIN_SENSOR_3, INPUT);
  pinMode(PIN_RELAY_1, OUTPUT);
  pinMode(PIN_RELAY_2, OUTPUT);
  pinMode(PIN_RELAY_3, OUTPUT);
  pinMode(PIN_RELAY_4, OUTPUT);
  pinMode(PIN_BUZZER, OUTPUT);
  pinMode(BOTAO_4, INPUT_PULLUP);
loop void() {
  // leitura dos sensores
  sensor_1_status = digitalRead(PIN_SENSOR_1);
  sensor_2_status = digitalRead(PIN_SENSOR_2);
  sensor_3_status = digitalRead(PIN_SENSOR_3);
  // controle do relay 4 pelo botão 4
  if (digitalRead(BOTAO_4) == BAIXO) {
    Serial.println("Botão 4 sofrido. Relé 4 ligado.");
      digitalWrite(PIN_RELAY_4, ALTO);
  } outro {
    Serial.println("Botão 4 não intoxicado. Relé 4 desligado.");
    digitalWrite(PIN_RELAY_4, BAIXO);
  // monitoramento dos níveis
  if (sensor_1_status == BAIXO) {
    Serial.println("Reservatório cheio com 100% de água!");
    digitalWrite(PIN_RELAY_1, ALTO);
  } outro {
    Serial.println("Reservatório não está cheio.");
    digitalWrite(PIN_RELAY_1, BAIXO);
  if (sensor_2_status == BAIXO) {
    Serial.println("Reservatório com mais 50% de água.");
    digitalWrite(PIN_RELAY_2, ALTO);
  } outro {
    Serial.println("Reservatório não está com 50% de água.");
    digitalWrite(PIN_RELAY_2, BAIXO);
  if (sensor_3_status == BAIXO) {
    Serial.println("Reservatório com mais de 15% de água.");
    digitalWrite(PIN_RELAY_3, ALTO);
    digitalWrite(PIN_BUZZER, BAIXO);
  } outro {
    Serial.println("Reservatório com menos de 15% de água.");
    digitalWrite(PIN_RELAY_3, BAIXO);
    digitalWrite(PIN_BUZZER, ALTO);
  atraso(5000); // aguarde 5 segundos antes de fazer a próxima leitura
  Fatal error while uploading sketch to A16
Posted by: tanoshimi - 03-20-2023, 03:12 PM - Forum: KC868-A16 - Replies (6)
Hi,  I recently bought a KC868-A16 board but am unable to use it, since I receive a fatal error when attempting to upload any new sketches onto it Sad
I'm using the Arduino IDE v2.0.4, targetting the "NodeMCU-32s" board from the esp32 boards definitions (v2.0.7). This is the error I receive when attempting to upload any sketch:
Sketch uses 292297 bytes (22%) of program storage space. Maximum is 1310720 bytes.
Global variables use 25300 bytes (7%) of dynamic memory, leaving 302380 bytes for local variables. Maximum is 327680 bytes.
esptool.py v4.5.1
Serial port COM7
Connecting....
Chip is ESP32-D0WD-V3 (revision v3.0)
Crystal is 40MHz
MAC: 90:38:0c:a4:38:94
Uploading stub...
Running stub...
Stub running...
WARNING: Failed to communicate with the flash chip, read/write operations will fail. Try checking the chip connections or removing any other hardware connected to IOs.
Configuring flash size...
Flash will be erased from 0x00001000 to 0x00005fff...
Flash will be erased from 0x00008000 to 0x00008fff...
Flash will be erased from 0x0000e000 to 0x0000ffff...
Flash will be erased from 0x00010000 to 0x00057fff...
Compressed 17520 bytes to 12170...
Writing at 0x00001000... (100 %)
A fatal error occurred: Serial data stream stopped: Possible serial noise or corruption.
Failed uploading: uploading error: exit status 2
There is not other hardware connected to the board. I am using the power supply and USB-C cable that it was supplied with (although I have also tried swapping these for other ones, and also tried different USB ports on my laptop).
As suggested elsewhere, I have tried reducing the upload speed from the default 921600 to 115200, but that made no difference.
The board itself seemed well-packed and doesn't show any obvious signs of damage, but I'm wondering if the chip is faulty, since the error appears to suggest a problem with the flash memory?
Hopefully you can advise! Thanks,
Alastair
  KC868-H32B Pro work with KC868-COLB-Mini + KC868-AK
Posted by: admin - 03-20-2023, 05:53 AM - Forum: Schematic & diagram & Dimensions of KinCony PCB layout CAD file - No Replies
  KC868-A256 ESP32 GPIO Module Released!
Posted by: admin - 03-19-2023, 10:53 AM - Forum: News - No Replies
we have design this ESP32 GPIO board (KC868-A256) for home assistant. It use by ESP32-WROOM-32E, 256CH digial input ports + 256CH MOSFET output ports + 4CH analog input ports + RS485 + Ethernet. The output design by 74HC595 chip. The input design by 74HC165 chip. You can write your own arduino source code for home automation DIY. You can also integrate to home assistant by ESPHome.
[Image: KC868-A256-1_01.jpg]
[Image: KC868-A256-1_02.jpg]
[Image: KC868-A256-1_03.jpg]
  KC868-AM ESP32 IO Expansion Board released
Posted by: admin - 03-18-2023, 02:31 AM - Forum: News - No Replies
We have designed ESP32 IO Expansion (development) Board — KC868-AM (Mini) . it’s ESP32 module + many free GPIOs for home automation DIYer to use. 4 GPIOs in greent terminal already added pull up resistance, so that you can conveniently connect with 1-wire sensor device. some others input GPIOs on the PCB center for user. Support add to home assistant by ESPHome.
[Image: KC868-AM-1_small.jpg]
  KCS Question.
Posted by: Philadam - 03-17-2023, 04:12 AM - Forum: "KCS" v2 firmware system - Replies (7)
Two questions:
1) Is it possible to have an ADC sensor trigger an Input on an A16 with KCS?
2) Will a KC868-HA work with the A16 over RS485?
  KC868-A256 configure yaml for ESPhome
Posted by: admin - 03-16-2023, 05:46 AM - Forum: KC868-A256 - No Replies
.txt   HA_A256.txt (Size: 74.43 KB / Downloads: 1235)
  KC868-A256 ESP32 I/O pin define
Posted by: admin - 03-16-2023, 05:42 AM - Forum: KC868-A256 - Replies (2)
#define ANALOG_A1  GPIO36
#define ANALOG_A2  GPIO39
#define ANALOG_A3  GPIO34
#define ANALOG_A4  GPIO35
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN  18
RS485:
RXD:GPIO13
TXD:GPIO14
74HC595 for output:
Data: GPIO5
Clock:GPIO16
Latch:GPIO4
74HC165 for input:
Data: GPIO15
Clock: GPIO32
LD(load_pin): GPIO33
  KC868-AM configure yaml for ESPhome
Posted by: admin - 03-16-2023, 05:39 AM - Forum: KC868-AM - Replies (2)
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
    pin: 15
    inverted: False
.txt   ESPHome_KC868-AM.txt (Size: 340 bytes / Downloads: 703)
