» Members: 9,826
» Latest member: tahwal
» Forum threads: 4,218
» Forum posts: 20,921
There are currently 102 online users.
» 0 Member(s) | 83 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, HeadlessChrome, PetalBot, bot
KC868-H32B
2 minutes ago
No ethernet communication
Last Post: philippe
48 minutes ago
» Replies: 9
Last Post: viko
1 hour ago
» Replies: 13
N60 Loss of kWh on reset
Forum: N60
Last Post: chuyskywalker
Yesterday, 03:58 AM
» Replies: 12
CT Sensor Direction
Forum: N60
09-03-2026, 12:51 PM
Request for Type B Projec...
Last Post: lemanat
09-03-2026, 08:47 AM
KinCony CO16 ESP32S3 16 C...
Forum: News
09-02-2026, 01:51 AM
08-31-2026, 12:16 AM
08-31-2026, 12:11 AM
08-31-2026, 12:09 AM
  [Arduino source code for KC868-A256]-02 INPUT_256
Posted by: KinCony Support - 03-22-2023, 01:02 AM - Forum: KC868-A256 - No Replies
* KC868-256 INPUT CODE
  74HC165 Shift register input example
const byte latchPin = 33;
const byte clockPin = 32;
const byte dataPin = 15;
const int numBits = 8;
  pinMode(dataPin, INPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(latchPin, OUTPUT);
  digitalWrite(latchPin, LOW);
  digitalWrite(latchPin, HIGH);
  for(int j =0;j<=255;j+=8)
    for (int i = numBits; i >0; i--) {
    int bit = digitalRead(dataPin);
    if (bit == LOW) {
      Serial.printf("Input %d is DOWN\n",i+j);
    digitalWrite(clockPin, HIGH);
    digitalWrite(clockPin, LOW);
.zip   KC868-256_input_256.zip (Size: 796 bytes / Downloads: 883)
  [Arduino source code for KC868-A256]-01 ADC_INOUT
Posted by: KinCony Support - 03-22-2023, 01:01 AM - Forum: KC868-A256 - No Replies
/*ADC Code for KC868-A256*/
#include "Arduino.h"
#define ANALOG_A1   36        // IO36
#define ANALOG_A2   39        // IO39
#define ANALOG_A3   34        // IO34
#define ANALOG_A4   35        // IO35
  pinMode(ANALOG_A1,INPUT);
  pinMode(ANALOG_A2,INPUT);
  pinMode(ANALOG_A3,INPUT);
  pinMode(ANALOG_A4,INPUT);
  if(analogRead(ANALOG_A1)!=0)
    {  Serial.printf("A1 on Pin(%d)=%d\n",ANALOG_A1,analogRead(ANALOG_A1));delay(500);}
  if(analogRead(ANALOG_A2)!=0)
    {  Serial.printf("A2 on Pin(%d)=%d\n",ANALOG_A2,analogRead(ANALOG_A2));delay(500);}
  if(analogRead(ANALOG_A3)!=0)
    {  Serial.printf("A3 on Pin(%d)=%d\n",ANALOG_A3,analogRead(ANALOG_A3));delay(500);}
  if(analogRead(ANALOG_A4)!=0)
    {  Serial.printf("A4 on Pin(%d)=%d\n",ANALOG_A4,analogRead(ANALOG_A4));delay(500);}
.zip   KC868-256_ADC_INOUT.zip (Size: 681 bytes / Downloads: 856)
  [Arduino source code for KC868-AM]-05 WIFISCAN_RSSI
Posted by: KinCony Support - 03-22-2023, 12:54 AM - Forum: KC868-AM - No Replies
/*  KC868-AM wifi scan and print the RSSI*/
#include "WiFi.h"
    // Set WiFi to station mode and disconnect from an AP if it was previously connected
    WiFi.mode(WIFI_STA);
    WiFi.disconnect();
    delay(100);
    Serial.println("scan start");
    // WiFi.scanNetworks will return the number of networks found
    int n = WiFi.scanNetworks();
    Serial.println("scan done");
    if (n == 0) {
        Serial.println("no networks found");
        Serial.print(n);
        Serial.println(" networks found");
       for (int i = 0; i < n; ++i) {
          /*Print SSID and RSSI for each network found
            Serial.print(i + 1);
            Serial.print(": ");
            Serial.print(WiFi.SSID(i));
            Serial.print(" (");
            Serial.print(WiFi.RSSI(i));
            Serial.print(")");
            Serial.println((WiFi.encryptionType(i) == WIFI_AUTH_OPEN)?" ":"*");
            delay(10);*/
            if(WiFi.SSID(i)=="KinCony"){
            Serial.print(" (");
            Serial.println("db)");
            delay(100);
    Serial.println("");
    // Wait a bit before scanning again
.zip   AM_WiFiScan_RSSI.zip (Size: 852 bytes / Downloads: 788)
  [Arduino source code for KC868-AM]-04 RELAY
Posted by: KinCony Support - 03-22-2023, 12:53 AM - Forum: KC868-AM - No Replies
/*KC868-AM  relay  output*/
#define RELAY 15
  pinMode(RELAY, OUTPUT);
// the loop function runs over and over again forever
    digitalWrite(RELAY, HIGH);
    digitalWrite(RELAY, LOW);
.zip   AM_Relay.zip (Size: 485 bytes / Downloads: 745)
  [Arduino source code for KC868-AM]-03 ETHERNET
#include <ETH.h>
#include <WiFiUdp.h>
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN   18
  Serial.println();
  Serial.println("Connected");
  Serial.print("IP Address:");
    char buf[packetSize];
    Serial.println();
    Serial.print("Received: ");
    Serial.println(buf);
    Serial.print("From IP: ");
    Serial.print("From Port: ");
    Udp.print("Received: ");
.zip   AM_ETHERNET.zip (Size: 1.07 KB / Downloads: 777)
  [Arduino source code for KC868-AM]-02 DS18b20
Posted by: KinCony Support - 03-22-2023, 12:51 AM - Forum: KC868-AM - Replies (4)
#include <DS18B20.h>
DS18B20 ds1(5);
DS18B20 ds2(14);
DS18B20 ds3(13);
DS18B20 ds4(33);
Serial.printf("T1:%.2fC||T2:%.2fC||T3:%.2fC||T4:%.2fC\n",ds1.getTempC(),ds2.getTempC(),ds3.getTempC(),ds4.getTempC());
      delay(500);
.zip   AM_DS18b20.zip (Size: 491 bytes / Downloads: 812)
  [Arduino source code for KC868-AM]-01 RS485
Posted by: KinCony Support - 03-22-2023, 12:50 AM - Forum: KC868-AM - No Replies
//AM
#define AM_RS485RX  35
#define AM_RS485TX  32
  Serial2.begin(115200,SERIAL_8N1,AM_RS485RX,AM_RS485TX);
   Serial2.println("AM RS485 SEND is OK!!");
   Serial2.println("******************");
  /*print the received data of RS485 port*/
  while(Serial2.available()>0)
    Serial2.print((char)Serial2.read());//Read rs485 receive data  and print it
  delay(200);
.zip   AM_RS485.zip (Size: 562 bytes / Downloads: 771)
Question Scan Device tool considered as Trojan?!
Posted by: iwzr - 03-21-2023, 10:14 PM - Forum: "KCS" v2 firmware system - Replies (4)
I just wanted to flash the firmware of my devices and downloaded the KinCony Scan Device tool from https://www.kincony.com/download/KinCony...Device.zip but my AntiVirus thinks it is a Trojan.
Here are the screenshots:
[Image: mX8lII8UAiws.png?o=1]
[Image: VX1ast09et3E.png?o=1]
Then I let virustotal.com check the zip, https://www.virustotal.com/gui/file/035b...c236f40b38
the result is not very good. It says: 22 security vendors and no sandboxes flagged this file as malicious
This is not good. I am sure it is a false positive from vendors, but you should do something about it.
  Which Board?
Posted by: Mohd Faudzee Hamid - 03-21-2023, 08:53 AM - Forum: DIY Project - Replies (1)
Iam a newbie, I want to ask, if we want to start learning Kincony's system, a basic one, just to control ON and OFF about 8
lamps and 5 Aircon all in one room by using wifi (smart phone), which board from Kincony that you suggest?
  AJUDA PARA CRIAR UM SKETICK IDE PARA AUTOMAÇÃO
Posted by: claudio - 03-21-2023, 03:53 AM - Forum: DIY Project - Replies (13)
OLA PRECISO DE UM SKETICK PARA TRABALHAR COM 2 PLACA
vocêMA A A4 EA OUTA A A8 SENDO QUE A A4 ENVIA SINAL PARA A PACA A8 VIA REDE
OPROJETO E LER OS STATUS DOS SENSORES E COSSESPONDER NA OUTRA PLACA RECEBENDO OS STATUS FISICAMENTE E ONDE EU POSSA ABRIR A PAGINA PARA MONITORAR
SRIA MAIS OU MENOS ASSIM
onst int Sensor_1 = 2 ; // nivel em 100%
const int Sensor_2 = 3 ; // nivel em 50%
const int Sensor_3 = 4 ; // nivel em 15%
const int ledPin_Sensor_1 = 8 ; // led sem pino 8
const int ledPin_Sensor_2 = 9 ; // led sem pino 9
const int ledPin_Sensor_3 = 10 ; // led no pino 10
int estadoSensor_1; // variável para ler o status do Sensor_1
intestadoSensor_2; // variável para ler o status do Sensor_2
int estadoSensor_3; // variável para ler o status do Sensor_3
void setup () {
  pinMode (Sensor_1, INPUT); // Pino com sensor será entrada
  pinMode (Sensor_2, INPUT); // Pino com sensor será entrada
  pinMode (Sensor_3, INPUT); // Pino com sensor será entrada
  pinMode (ledPin_Sensor_1, OUTPUT); // Pino do led será saída
  pinMode (ledPin_Sensor_2, OUTPUT); // Pino do led será saída
  pinMode (ledPin_Sensor_3, OUTPUT); // O pino do led será saída
void loop () {
 Serial . começar ( 9600 );
  estadoSensor_1 = digitalRead (Sensor_1); // le o estado do Sensor_1 - HIGH OU LOW
  if (estadoSensor_1 == LOW) { // Se o sensor estiver procurando (LOW)
    digitalWrite (ledPin_Sensor_1, HIGH); // acende o led do pino 8.
  } else { // se não estiver invocado (HIGH)
    digitalWrite (ledPin_Sensor_1, LOW); // deixa o led do pino 8 apagado
  estadoSensor_2 = digitalRead (Sensor_2);// le o estado do Sensor_2 - HIGH OU LOW
  if (estadoSensor_2 == LOW) { // Se o sensor estiver ocupado (LOW)
    digitalWrite (ledPin_Sensor_2, HIGH); // acende o led do pino 9.
    digitalWrite (ledPin_Sensor_2, LOW); // deixa o led do pino 9 apagado
  estadoSensor_3 = digitalRead (Sensor_3); // le o estado do Sensor_3 - HIGH OU LOW
  if (estadoSensor_3 == LOW) { // Se o sensor estiver procurando (LOW)
    digitalWrite (ledPin_Sensor_3, HIGH); // acende o led do pino 10.
  }else { // se não estiver (HIGH)
    digitalWrite (ledPin_Sensor_3, LOW); // deixa o led do pino 10 desligado
O DESSA FORMA
PARA A PLACA KC686 A4 ESSE CODIGO JA RODA POREM SEM AS CONFIGURACOES DE ACESSO E ACRESCENTAR O QUE FOR NECESSÁRIO PARA A PLACA KC686 A8 RECEBER OS SINAAIS E ATUAL COMO SE FOSSE NELA
const int PIN_SENSOR_1 = 36;
const int PIN_SENSOR_2 = 39;
const int PIN_SENSOR_3 = 27;
const int PIN_RELAY_1 = 2;
const int PIN_RELAY_2 = 15;
const int PIN_RELAY_3 = 5;
const int PIN_RELAY_4 = 4;
const int PIN_BUZZER = 18;
const int BOTAO_4 = 14;
bool sensor_1_status = falso;
bool sensor_2_status = falso;
bool sensor_3_status = falso;
  pinMode(PIN_SENSOR_1, INPUT);
  pinMode(PIN_SENSOR_2, INPUT);
  pinMode(PIN_SENSOR_3, INPUT);
  pinMode(PIN_RELAY_1, OUTPUT);
  pinMode(PIN_RELAY_2, OUTPUT);
  pinMode(PIN_RELAY_3, OUTPUT);
  pinMode(PIN_RELAY_4, OUTPUT);
  pinMode(PIN_BUZZER, OUTPUT);
  pinMode(BOTAO_4, INPUT_PULLUP);
loop void() {
  // leitura dos sensores
  sensor_1_status = digitalRead(PIN_SENSOR_1);
  sensor_2_status = digitalRead(PIN_SENSOR_2);
  sensor_3_status = digitalRead(PIN_SENSOR_3);
  // controle do relay 4 pelo botão 4
  if (digitalRead(BOTAO_4) == BAIXO) {
    Serial.println("Botão 4 sofrido. Relé 4 ligado.");
      digitalWrite(PIN_RELAY_4, ALTO);
  } outro {
    Serial.println("Botão 4 não intoxicado. Relé 4 desligado.");
    digitalWrite(PIN_RELAY_4, BAIXO);
  // monitoramento dos níveis
  if (sensor_1_status == BAIXO) {
    Serial.println("Reservatório cheio com 100% de água!");
    digitalWrite(PIN_RELAY_1, ALTO);
  } outro {
    Serial.println("Reservatório não está cheio.");
    digitalWrite(PIN_RELAY_1, BAIXO);
  if (sensor_2_status == BAIXO) {
    Serial.println("Reservatório com mais 50% de água.");
    digitalWrite(PIN_RELAY_2, ALTO);
  } outro {
    Serial.println("Reservatório não está com 50% de água.");
    digitalWrite(PIN_RELAY_2, BAIXO);
  if (sensor_3_status == BAIXO) {
    Serial.println("Reservatório com mais de 15% de água.");
    digitalWrite(PIN_RELAY_3, ALTO);
    digitalWrite(PIN_BUZZER, BAIXO);
  } outro {
    Serial.println("Reservatório com menos de 15% de água.");
    digitalWrite(PIN_RELAY_3, BAIXO);
    digitalWrite(PIN_BUZZER, ALTO);
  atraso(5000); // aguarde 5 segundos antes de fazer a próxima leitura
