» Members: 9,813
» Latest member: dn8886ccom
» Forum threads: 4,218
» Forum posts: 20,909
There are currently 299 online users.
» 0 Member(s) | 277 Guest(s)
Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, HeadlessChrome, PetalBot, Semrush, bot
N60 Loss of kWh on reset
Forum: N60
Last Post: chuyskywalker
7 hours ago
» Replies: 12
Yesterday, 09:03 PM
CT Sensor Direction
Forum: N60
Yesterday, 12:51 PM
Request for Type B Projec...
Last Post: lemanat
Yesterday, 08:47 AM
No ethernet communication
09-02-2026, 06:31 AM
KinCony CO16 ESP32S3 16 C...
Forum: News
09-02-2026, 01:51 AM
08-31-2026, 12:16 AM
08-31-2026, 12:11 AM
08-31-2026, 12:09 AM
08-31-2026, 12:08 AM
  [Arduino source code for KC868-AP]-05 -PWM_Output
Posted by: KinCony Support - 01-03-2023, 01:48 AM - Forum: KC868-AP / ADR - No Replies
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
#define SDA  4
#define SCL  16
// called this way, it uses the default address 0x40
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver(0x40);
int brightness = 0;
int fadeAmount = 64;
  Serial.begin(9600);
  Serial.println("16 channel PWM test!");
  Wire.begin(SDA,SCL,100000);
  pwm.begin();
  pwm.setOscillatorFrequency(27000000);
  pwm.setPWMFreq(1000);  // 1600 This is the maximum PWM frequency
  // if you want to really speed stuff up, you can go into 'fast 400khz I2C' mode
  // some i2c devices dont like this so much so if you're sharing the bus, watch
  // out for this!
  Wire.setClock(400000);
  // Drive each PWM in a 'wave'
   for (uint8_t pwmnum=0; pwmnum < 16; pwmnum++) {
      pwm.setPWM(pwmnum, 0, brightness );
    brightness = brightness + fadeAmount;
   if (brightness == 0 || brightness == 4096) {
    fadeAmount = -fadeAmount ;
  Serial.println(brightness);
   delay(20);
.zip   KC868-AP-PWM.zip (Size: 1.05 KB / Downloads: 803)
  [Arduino source code for KC868-AP]-04 _digital_input
Posted by: KinCony Support - 01-03-2023, 01:43 AM - Forum: KC868-AP / ADR - No Replies
#include "Arduino.h"
#include "PCF8574.h"
#define AP_8574_SDA 4
#define AP_8574_SCL 16
// Set i2c address
PCF8574 pcf8574_1(0x22,AP_8574_SDA,AP_8574_SCL);
PCF8574 pcf8574_2(0x21,AP_8574_SDA,AP_8574_SCL);
unsigned long timeElapsed;
pinMode(34, INPUT);// input 17
pinMode(35, INPUT);// input 18
pcf8574_1.pinMode(P0, INPUT);
pcf8574_1.pinMode(P1, INPUT);
pcf8574_1.pinMode(P2, INPUT);
pcf8574_1.pinMode(P3, INPUT);
pcf8574_1.pinMode(P4, INPUT);
pcf8574_1.pinMode(P5, INPUT);
pcf8574_1.pinMode(P6, INPUT);
pcf8574_1.pinMode(P7, INPUT);
pcf8574_2.pinMode(P0, INPUT);
pcf8574_2.pinMode(P1, INPUT);
pcf8574_2.pinMode(P2, INPUT);
pcf8574_2.pinMode(P3, INPUT);
pcf8574_2.pinMode(P4, INPUT);
pcf8574_2.pinMode(P5, INPUT);
pcf8574_2.pinMode(P6, INPUT);
pcf8574_2.pinMode(P7, INPUT);
pcf8574_1.begin();
pcf8574_2.begin();
uint8_t val1 = pcf8574_1.digitalRead(P0);
uint8_t val2 = pcf8574_1.digitalRead(P1);
uint8_t val3 = pcf8574_1.digitalRead(P2);
uint8_t val4 = pcf8574_1.digitalRead(P3);
uint8_t val5 = pcf8574_1.digitalRead(P4);
uint8_t val6 = pcf8574_1.digitalRead(P5);
uint8_t val7 = pcf8574_1.digitalRead(P6);
uint8_t val8 = pcf8574_1.digitalRead(P7);
uint8_t val9 = pcf8574_2.digitalRead(P0);
uint8_t val10 = pcf8574_2.digitalRead(P1);
uint8_t val11 = pcf8574_2.digitalRead(P2);
uint8_t val12 = pcf8574_2.digitalRead(P3);
uint8_t val13 = pcf8574_2.digitalRead(P4);
uint8_t val14 = pcf8574_2.digitalRead(P5);
uint8_t val15 = pcf8574_2.digitalRead(P6);
uint8_t val16 = pcf8574_2.digitalRead(P7);
if (val9==LOW) Serial.println("KEY9 PRESSED");
if (val10==LOW) Serial.println("KEY10 PRESSED");
if (val11==LOW) Serial.println("KEY11 PRESSED");
if (val12==LOW) Serial.println("KEY12 PRESSED");
if (val13==LOW) Serial.println("KEY13 PRESSED");
if (val14==LOW) Serial.println("KEY14 PRESSED");
if (val15==LOW) Serial.println("KEY15 PRESSED");
if (val16==LOW) Serial.println("KEY16 PRESSED");
if(digitalRead(34)== LOW) Serial2.println("KEY17 PRESSED");
if(digitalRead(35)== LOW) Serial2.println("KEY18 PRESSED");
    delay(100);
.zip   KC868-AP8574-DI.zip (Size: 886 bytes / Downloads: 768)
  [Arduino source code for KC868-AP]-03 _RS485_communication
Posted by: KinCony Support - 01-03-2023, 01:36 AM - Forum: KC868-AP / ADR - No Replies
  Serial2.begin(115200,SERIAL_8N1,33,14);
   Serial2.println("RS485 SEND is OK!!");
   Serial2.println("******************");
  /*print the received data of RS485 port*/
  while(Serial2.available()>0)
    Serial2.print((char)Serial2.read());//Read rs485 receive data  and print it
  delay(200);
.zip   KC868-AP-485.zip (Size: 855 bytes / Downloads: 783)
  [Arduino source code for KC868-AP]-02 _UDP_communication
Posted by: KinCony Support - 01-03-2023, 01:33 AM - Forum: KC868-AP / ADR - No Replies
#include <ETH.h>
#include <WiFiUdp.h>
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN   18
  Serial.println();
  Serial.println("Connected");
  Serial.print("IP Address:");
    char buf[packetSize];
    Serial.println();
    Serial.print("Received: ");
    Serial.println(buf);
    Serial.print("From IP: ");
    Serial.print("From Port: ");
    Udp.print("Received: ");
.zip   KC868-AP_LAN8720_UDP.zip (Size: 1.13 KB / Downloads: 740)
  [Arduino source code for KC868-AP]-01 _relay_control
Posted by: KinCony Support - 01-03-2023, 01:24 AM - Forum: KC868-AP / ADR - No Replies
  pinMode(13,OUTPUT);
  pinMode(2,OUTPUT);
// the loop function runs over and over again forever
  digitalWrite(2, HIGH);
  digitalWrite(13, HIGH);
  digitalWrite(2, LOW);
  digitalWrite(13, LOW);
.zip   KC868_AP_relay.zip (Size: 535 bytes / Downloads: 782)
  Kincony A16 - PIR motion sensor
Posted by: sonalikaatc@gmail.com - 01-02-2023, 03:28 PM - Forum: KC868-A16 - Replies (17)
HI,
I have used the KC686 A16 board for pir motion sensor model HC-SR501,
my config is
    device_class: motion
My output is stuck at clear and no motion is detected.
Please help ..
THANKS
  Expand
Posted by: Vulcan - 01-01-2023, 06:52 AM - Forum: KC868-A6 - Replies (1)
With the 868-A6 can you extend the number of relays through the I2C bus or by some other means? If it can be expanded what do I need? Is there a limit of sensors on the I2C? I read somewhere that with the RF module there is no limit if one is using that option. Can you explain how the RF module provides sensor expansion please?
Given the A6 has not wired Ethernet, is there any options to power it from an injector or should we consider the A4 instead?
If in our project we wish to run two A6 units can they be linked (master/slave) or are they separate? We are creating an automated garden and greenhouse system including irrigation management and monitoring, vent control, multiple water and air temps, soil moisture and acidic levels, sunlight and baro pressures. We wish to be sure the A6 relay control can be expanded and sensors quantities are not limited.
We are also trying to determine if a closed loop system with rules and thresholds can me met with Tasmota or if we need to write our own code, any advice would be greatly appreciated.
Regarding the RF module option on the A6, when its installed, how is the plastic cover meant to be installed since the RF module protrudes outside the case? It would seem I either bought the wrong case or we are expected to cut out part of the case....please advise.
  KC868-AP ESP32 PWM Dimmer Released
Posted by: admin - 12-30-2022, 08:31 AM - Forum: News - No Replies
We have designed KC868-AP. It is a ESP32 16 channel PWM dimmer board. It use PCA9685. The PCA9685 component represents a PCA9685 12-bit PWM driver. It uses I²C Bus for communication. every channel output have MAX 3A driver chip. KC868-AP support use by ESPHome in home assistant. It also have digital input and relay output.
[Image: KC868-AP-1_01.jpg]
[Image: KC868-AP-1_02.jpg]
[Image: KC868-AP-1_03.jpg]
[Image: KC868-AP-1_04.jpg]
  Upcoming house build
Posted by: bluepr0 - 12-29-2022, 01:48 PM - Forum: DIY Project - Replies (10)
Hi!
I'm in the process of researching to build a house and have a centralised place to control lights, blinds, etc.
Needs & Goals
  1. Have ESPHome Ethernet boards with relays I can control using regular light switches (momentary switches too) or through home assistants automation. This could be used for lights, blind motors, etc. Won’t need more than 16A per relay
  2. Have ESPHome Ethernet boards with PWM dimming capability for 24V analog LEDs with 3/4A Per channel. I created 1 channel mosfet board as a proof of concept dimmer with LEDC component from ESPHome and it works okay.
Questions
  1. As I understand relay boards will work with switches, but Would relay boards work also with temporary switches / push button?
  2. Are these board 0 delay when activating the relays? My main goal is to have an immediate response from the moment the switch or the command is triggered to when the relay turns on. I have seen some videos where a lot of relays are turned on at the same time and they seem slow.
  3. Is there any video of relay and dimmer board using ESPHome to see the speed? What’s the max Amp per mosfet channel?
  4. I’m honestly VERY lost on the product line. I have seen KC868-A8 could be a good fit (at least to do an initial test). A 16 relay version doesn’t seem to exist?. KC868-E16S seems another interesting one but it goes really high on price so I will need to be 100% sure about speed
  5. I’m still in research phase but I’m assuming a house will need at least 32 relays, and might or might not be all boards in the same placement. So I’m thinking it might not be a good idea to pick one big board but maybe several smaller ones?
  6. What products do you guys would recommend?
Thanks!
  KC868-H32B Pro firmware upload network tool
Posted by: admin - 12-29-2022, 02:29 AM - Forum: KC868-HxB series Smart Controller - Replies (2)
You can use this network tool update KC868-H32B Pro controller by ethernet cable.
.zip   NET_REMOTE_IAP_V1.0.zip (Size: 9.07 KB / Downloads: 1065)
