» Members: 9,094
» Latest member: ethanhawkins
» Forum threads: 4,004
» Forum posts: 20,314
There are currently 92 online users.
» 0 Member(s) | 76 Guest(s)
AhrefsBot, Amazonbot, Baidu, Bytespider, Google, PetalBot, bot
Forum: F24
6 minutes ago
Cant flash esphom
Forum: B16M
6 hours ago
» Replies: 23
Request for firmware H32
11 hours ago
how to use KC868-A8 with ...
Forum: KC868-A8
11 hours ago
MODBUS
Forum: KC868-A2v3
Today, 10:05 AM
problem with kc868 has v2
Forum: News
Today, 08:08 AM
» Replies: 13
KC868-HA v2 firmware V200...
Forum: KC868-HA /HA v2
Today, 12:37 AM
» Replies: 8
KC868-HA RS485 INPUT & OU...
Today, 12:36 AM
» Replies: 55
automations yaml for read...
Forum: Pi5R16
Yesterday, 11:22 PM
home assistant configurat...
Forum: Pi5R16
Yesterday, 11:19 PM
Star [Arduino IDE demo source code for KC868-A8]--#02-RF_receive
Posted by: KinCony Support - 01-05-2022, 06:28 AM - Forum: KC868-A8 - No Replies
Code 1: //The demo code is RF-receive    You can copy the code to your Arduino IDE
#include <RCSwitch.h>  //Install library "rcswitch"
  Serial.begin(9600);
  mySwitch.enableReceive(digitalPinToInterrupt(15));  //receive PIN IO15
  if (mySwitch.available()) {
    Serial.print("Received ");
    Serial.print(" / ");
    Serial.print("bit ");
    Serial.print("Protocol: ");
    mySwitch.resetAvailable();
Star [Arduino IDE demo source code for KC868-A8]--#01-config Arduino IDE for ESP32 module
Posted by: KinCony Support - 01-05-2022, 05:26 AM - Forum: KC868-A8 - No Replies
  Before using KC868-A8, you need to set the parameters of the preference
Copy the following URL: https://dl.espressif.com/dl/package_esp32_index.json
Select the Board "NodeMCU -32S"
#define ANALOG_A1  34  updated in PCB V1.4
#define ANALOG_A2  35  updated in PCB V1.4
IIC SDA:4
IIC SCL:5
Relay_IIC_address 0x24
Relay1 = pcf8574.pinMode(P0, OUTPUT);
Relay2 = pcf8574.pinMode(P1, OUTPUT);
Relay3 = pcf8574.pinMode(P2, OUTPUT);
Relay4 = pcf8574.pinMode(P3, OUTPUT);
Relay5 = pcf8574.pinMode(P4, OUTPUT);
Relay6 = pcf8574.pinMode(P5, OUTPUT);
Relay7 = pcf8574.pinMode(P6, OUTPUT);
Relay8 = pcf8574.pinMode(P7, OUTPUT);
Input_IIC_address 0x22
Input1 = pcf8574.pinMode(P0, INPUT);
Input2 = pcf8574.pinMode(P1, INPUT);
Input3 = pcf8574.pinMode(P2, INPUT);
Input4 = pcf8574.pinMode(P3, INPUT);
Input5 = pcf8574.pinMode(P4, INPUT);
Input6 = pcf8574.pinMode(P5, INPUT);
Input7 = pcf8574.pinMode(P6, INPUT);
Input8 = pcf8574.pinMode(P7, INPUT);
DS18B20/DHT11/DHT21/LED strip -1: 14
DS18B20/DHT11/DHT21/LED strip -2: 13
DS18B20/DHT11/DHT21/LED strip -3: 32   updated in PCB V1.4
DS18B20/DHT11/DHT21/LED strip -4: 33   updated in PCB V1.4
RF433MHz wireless receiver: 15
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN  18
  [arduino source code for KC868-Uair-9] Send RF 433MHz wireless signal
Posted by: admin - 01-05-2022, 12:47 AM - Forum: KC868-Uair - No Replies
  Serial.begin(9600);
  mySwitch.enableTransmit(digitalPinToInterrupt(2));
  mySwitch.switchOn("11111", "00010");
  mySwitch.switchOff("11111", "00010");
  mySwitch.send(5393, 24);
  mySwitch.send(5396, 24);
  mySwitch.send("000000000001010100010001");
  mySwitch.send("000000000001010100010100");
  mySwitch.sendTriState("00000FFF0F0F");
  mySwitch.sendTriState("00000FFF0FF0");
download arduino IDE source code file:
.zip   433-sender-code.zip (Size: 407 bytes / Downloads: 735)
Note: install "rcswitch" library online firstly.
[Image: attachment.php?aid=462]
  [arduino source code for KC868-Uair-8] RF 433MHz wireless remoter decode
Posted by: admin - 01-04-2022, 01:16 AM - Forum: KC868-Uair - No Replies
  Serial.begin(9600);
  mySwitch.enableReceive(digitalPinToInterrupt(13));
.zip   RF-receiver.zip (Size: 393 bytes / Downloads: 804)
  [arduino source code for KC868-Uair-7] send IR code signal
Posted by: admin - 01-03-2022, 05:41 AM - Forum: KC868-Uair - No Replies
#include "PinDefinitionsAndMore.h"
#include <IRremote.h>
  Serial.begin(9600);
  IrSender.begin(IR_SEND_PIN, ENABLE_LED_FEEDBACK);
  uint16_t sAddress = 0x78;
  uint8_t sCommand = 0xCD;
  uint8_t sRepeats = 0;
  IrSender.sendNEC(sAddress, sCommand, sRepeats);
.zip   Uair_IR_send.zip (Size: 388 bytes / Downloads: 752)
Note: install "IRremote" library online firstly.
[Image: attachment.php?aid=456]
set IR sender and receiver GPIO pins define as below image:
[Image: attachment.php?aid=459]
  [arduino source code for KC868-Uair-6] IR remoter button decode
Posted by: admin - 01-02-2022, 04:15 AM - Forum: KC868-Uair - No Replies
  Serial.begin(9600);
  IrReceiver.begin(IR_RECEIVE_PIN, ENABLE_LED_FEEDBACK, USE_DEFAULT_FEEDBACK_LED_PIN);
    if (IrReceiver.decode()) {
        IrReceiver.printIRResultShort(&Serial);
        if (IrReceiver.decodedIRData.protocol == UNKNOWN) {
            IrReceiver.printIRResultRawFormatted(&Serial, true);
        Serial.println();
    IrReceiver.resume();
.zip   Uair_IR_receive.zip (Size: 569 bytes / Downloads: 749)
  KC868-A Pins to HomeSpan HomeKit
Posted by: glock4101 - 12-31-2021, 10:43 AM - Forum: KC868-A series and Uair Smart Controller - Replies (1)
Hello, I would like to use my controller for homekit control. I found out from the instructional videos that Relay 3 and 4 are on pins 2 and 15.
I would like to use more relays, and configure digital inputs as switches.
In further configuration I would like to use analog inputs and a temperature sensor.
  [arduino source code for KC868-Uair-5] read DS18B20 temperature sensor
Posted by: admin - 12-31-2021, 02:15 AM - Forum: KC868-Uair - No Replies
#include <DS18B20.h>
DS18B20 ds(27);
    Serial.begin(9600);
    Serial.print(ds.getTempC());
    Serial.print("℃");
    Serial.println();
.zip   temperature.zip (Size: 286 bytes / Downloads: 768)
Note: install "DallasTemperature" library online firstly.
edit IR send and receiver GPIO pin define in "PinDefinitionsAndMore.h"
  RC snubber wiring
Posted by: bigramon - 12-30-2021, 07:19 PM - Forum: KC868-HxB series Smart Controller - Replies (10)
Can you please confirm the following wiring of the RC snubber with a KC868-H32B for a furnace valve is OK ?
[Image: kincony-rc-snubber.jpg]
  H32B and 32 input panel stops communicating
Posted by: uvrtar - 12-30-2021, 03:05 PM - Forum: KC868-HxB series Smart Controller - Replies (5)
Hi, I have a problem with one of my setups. H32B and input panel stops communicating after 6-10 tries.
After deset it is ok gor 6-10 tries and then stops.
We changed the input panel and it is the same problem. Communicating with Home assistant and mode red is working, Just the connection with panel and contoller.
H32B was not replaced.
Any suggestions?
