» Members: 10,053
» Latest member: winpkrgames
» Forum threads: 4,253
» Forum posts: 21,064
There are currently 225 online users.
» 0 Member(s) | 209 Guest(s)
Amazonbot, Applebot, Baidu, Crawl, Google, PetalBot, bot, curl, owler
Best way to read from N30
Forum: N30
Last Post: ChrisNZ
4 hours ago
N60/N30/N20/N10 PC softwa...
Forum: N10
5 hours ago
» Replies: 7
getting the A8A inputs to...
Forum: Development
09-24-2026, 11:07 PM
extend KC868-A16v3
Last Post: bitet96717
09-24-2026, 06:41 AM
Las Firmware ?
09-22-2026, 11:15 PM
» Replies: 8
kc868-a6 analog input
09-21-2026, 11:38 PM
A32 pro tuya
Disconnect loop with Home...
Forum: F16
09-21-2026, 01:16 AM
KC-868-A1 linked Home Ass...
Forum: News
config modbus sensor in K...
09-19-2026, 11:52 AM
  KC868-A64 ESP32 I/O pin define
Posted by: admin - 05-12-2022, 01:03 AM - Forum: KC868-A64 - No Replies
#define ANALOG_A1  GPIO39
#define ANALOG_A2  GPIO34
#define ANALOG_A3  GPIO36
#define ANALOG_A4  GPIO35
IIC Bus-1:A
SDA-A:GPIO5
SCL-A:GPIO16
PCF8575:U143 (relay1-16): 100 100 = 0x24
PCF8575:U145 (relay17-32): 100 101 = 0x25
PCF8575:U147 (relay33-48): 100 001 = 0x21
PCF8575:U149 (relay49-64): 100 010 = 0x22
IIC Bus-2:B
SDA-B:GPIO15
SCL-B:GPIO4
PCF8575:U14 (DI1-16): 100 100 = 0x24
PCF8575:U31 (DI17-32): 100 101 = 0x25
PCF8575:U56 (DI33-48): 100 001 = 0x21
PCF8575:U57 (DI49-64): 100 010 = 0x22
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN  18
RS485:
RXD:GPIO13
TXD:GPIO14
Extend serial port (3.3v TTL level):
RXD:GPIO32
TXD:GPIO33
  KC868-UAIR ESPHOME Config for IR and RF
Posted by: dmshimself - 05-10-2022, 09:25 PM - Forum: KC868-Uair - Replies (34)
I've recently received a bare board for a KC868-UAIR as the original shipped with the tower case didn't work.  I've got the new board working with ESPHOME and Home Assistant using the config I was given and that works fine.  But the config didn't cover the buzzer, the IR receiver/transmitter and RF receiver/transmitter.  These are advertised features, so I want to make sure the new board works.  I got the buzzer working ok, but I'm struggling with the IR and RF.
I've been asked by the supplier to make a post here, so here it is :-)
What I've done so far is to try to read IR codes using the guide is ESPHOME located here:
https://esphome.io/components/remote_tra...p-infrared
Using the tech info on the KC868-UAIR I've added the following to my ESPHOME confg given the data located here:
https://www.kincony.com/forum/showthread.php?tid=1438
remote_receiver:
  pin: GPIO19
  dump: all
With that, the ESPHOME log says that the pin is high initially and that I should invert it.  Anyway, I placed the TV remote close the front of the board where the IR receiver is next to the USB ports and no data was received.  The TV did receive them as I have the TV directly behind the board and the TV worked (volume up/down)
So I inverted the pin with
remote_receiver:
    number: GPIO19
  dump: all
and while ESPHOME no longer suggested I needed to invert the pin, I still do not get any data being dumped out to the console.  I can see other messages like the temperature changes just fine.
Has anyone got a config that works for these extra devices as access to these was an important reason for my purchase?
  [Arduino IDE demo source code for KC868-SERVER]--#05-WS2812B LED_code
Posted by: KinCony Support - 05-06-2022, 03:28 AM - Forum: KC868-Server Raspberry Pi4 local server - No Replies
#include <Adafruit_NeoPixel.h>
Adafruit_NeoPixel rgb_display_4 = Adafruit_NeoPixel(5,4,NEO_GRB + NEO_KHZ800);
// LED numbers is 5    led connect to IO4
void setup(){
  rgb_display_4.begin();
void loop(){
  rgb_display_4.setPixelColor((1)-1, (0xff0000)); //LED 1 RED
  rgb_display_4.setPixelColor((2)-1, (0x3333ff)); //LED 2 BLUE
  rgb_display_4.setPixelColor((3)-1, (0xffff33)); //LED 3 YELLOW
  rgb_display_4.setPixelColor((4)-1, (0x33ff33)); //LED 4 GREEN
  rgb_display_4.setPixelColor((5)-1, (0xcc33cc)); //LED 5 PURPLE
  rgb_display_4.show();
Install "Adafruit_NeoPixel"first
  KC868-D8
Posted by: Dm81 - 05-05-2022, 09:22 PM - Forum: KC868-HxB series Smart Controller - Replies (10)
Hello
I have a question about KC868-D8 in server mode
Is it correct that I don't receive command if I close any digital input on the board?
I think that a client connected to the KC868-D8 should be receive a command (or string) about output variation
thank you
  KC868-COLB/BS/Mini V1.12 new firmware and PC software update
Posted by: admin - 05-05-2022, 02:00 AM - Forum: News - Replies (2)
improvement:
1. support one KC868-COLB/COLBS/COLB-Mini control multi relay board by "HTTP" command.
2. support create customsize command by "HTTP command".
3. translate "DEBUG" mode window to English language.
KC868-COLB V1.12 firmware download:
.zip   AD_COLB_V1_1_12_220503.zip (Size: 41.92 KB / Downloads: 957)
New PC software Kincony_SCB_V1.0.410.504 download:
.zip   Kincony_SCB_V1.0.410.504.zip (Size: 7.3 MB / Downloads: 1117)
  [Arduino demo source code for KC868-A4]-13 work with KBOX phone app
Posted by: admin - 05-04-2022, 11:40 AM - Forum: KC868-A4 - Replies (6)
use for "KBOX" phone app in local network , without internet.
.zip   KBOX.zip (Size: 837 bytes / Downloads: 1019)
  Kc868-A4 KBOX App Code
Posted by: ahmedwizza - 05-04-2022, 11:12 AM - Forum: KC868-A4 - Replies (1)
please send me the code that give me ability to control A4 by KBOX app without internet.
As showmen as attached.
  A4 fault code
Posted by: ahmedwizza - 05-04-2022, 04:03 AM - Forum: KC868-A4 - Replies (1)
            I follow the vedio stipe by stipe . but I see my code different
after changed the pine number
like in attached photos
so send me the code in the vedio
  KC868-H32B V4.44 new firmware update
Posted by: admin - 05-03-2022, 04:29 AM - Forum: News - Replies (9)
improvement:
add HTTP multi control relay command ( you can use one http command turn ON/OFF/toggle any relay) :
http command format:
http: //ip/sw_ctl.cgi?RealyMulSet=A8A7A6A5A4A3A2A1,B8B7B6B5B4B3B2B1,C8C7C6C5C4C3C2C1&postpwd=postpassword
A8A7A6A5A4A3A2A1 use for "TURN ON" 32 channel relay, every channel bit "1" means enable, bit "0" means disable
B8B7B6B5B4B3B2B1 use for "TURN OFF" 32 channel relay, every channel bit "1" means enable, bit "0" means disable
C8C7C6C5C4C3C2C1 use for "TOGGLE" 32 channel relay, every channel bit "1" means enable, bit "0" means disable
every Ax or Bx or Cx use by HEX format data.
For example:
if you want to
                 TURN ON  RELAY 32 31 30 29  (F0000000)
                 TURN OFF  RELAY 04 03 02 01  (0000000F)
                 TOGGLE  RELAY 24 23 22 21  (00F00000)
if your relay controller IP address is 192.168.1.200
if your post password is 12345
At last the HTTP command is :  http://192.168.1.200/sw_ctl.cgi?RealyMulSet=F0000000,0000000F,00F00000&postpwd=12345
After send this command: Relay32,31,30,29 will be ON,  Relay4,3,2,1 will be OFF,  Relay24,23,22,21 will be TOGGLE.
.zip   Relay32_V444_220503.zip (Size: 47.3 KB / Downloads: 1044)
.pdf   KC868-H32B-http-command-2022-05-05.pdf (Size: 890.76 KB / Downloads: 1245)
  COLB and RFID reader
Posted by: hentes - 05-02-2022, 03:14 PM - Forum: DIY Project - Replies (4)
Hello. Is it possible to connect and use the Dahua ASR1100A ASR1100A (13.56MHz) RFID reader with COLB module? The RFIS reader has an RS485 connection. Thank you.
