» Members: 9,072
» Latest member: marisasowell
» Forum threads: 3,988
» Forum posts: 20,241
There are currently 59 online users.
» 0 Member(s) | 43 Guest(s)
Amazonbot, Applebot, Baidu, Bytespider, Semrush, bot
CRC Errors with ESP Home ...
Forum: N60
3 hours ago
KC868-A8 ethernet work wi...
Forum: KC868-A8
10 hours ago
» Replies: 9
RS485
10 hours ago
» Replies: 4
Cant flash esphom
Forum: B16M
05-19-2026, 10:23 PM
N30 no Energy (kWh)
05-19-2026, 10:21 PM
» Replies: 13
Questions about KinCony F...
Forum: F16
05-19-2026, 12:12 PM
"KCS" v3.25.0 firmware BI...
05-19-2026, 12:03 PM
Energy calculation for ne...
Forum: N30
Last Post: GWS
05-19-2026, 06:23 AM
» Replies: 4
Las Firmware ?
05-19-2026, 12:07 AM
AIO Hybrid ESP32-S3 IO pi...
Forum: AIO Hybrid
05-19-2026, 12:06 AM
  Multiple KC868-HxB actuators in one scene
Posted by: eladn - 10-09-2021, 10:30 AM - Forum: KC868-HxB series Smart Controller - Replies (4)
Is it possible to connect multiple KC868-HxB actuators in serial communication with a KC868-COLB unit? Let's say I want to formulate a logic rule that changes the state of relays from multiple actuator units - is it possible?
Thanks.
  Lesson19- how to use PCF8574 IIC extend GPIO for ESP32 multi relay
Posted by: admin - 10-09-2021, 04:54 AM - Forum: KC868-A series and Uair Smart Controller - Replies (5)
Arduino IDE source code:
.zip   PCF8574-DO.zip (Size: 771 bytes / Downloads: 1398)
  KC868-A8 schematic diagram download
Posted by: admin - 10-08-2021, 11:57 AM - Forum: KC868-A8 - No Replies
https://www.kincony.com/download/KC868-A8-schematic.pdf
  KC868-A4 schematic diagram download
Posted by: admin - 10-08-2021, 11:56 AM - Forum: KC868-A4 - No Replies
https://www.kincony.com/download/KC868-A4-schematic.pdf
  Lesson18- how to use UDP communication with KC868-A8 by ethernet
Posted by: admin - 10-08-2021, 11:53 AM - Forum: KC868-A series and Uair Smart Controller - Replies (4)
.zip   LAN8720_UDP.zip (Size: 902 bytes / Downloads: 1457)
  MQTT set issue
Posted by: gek1925 - 10-07-2021, 02:21 PM - Forum: KC868-HxB series Smart Controller - Replies (4)
Hi
I'm trying to set two relays at once, but only one changed.
I publish via Home Assistant MQTT:
relay32/xxxxxxxxxxxxx/set
{"relay17":{"on":1},"relay18":{"on":1}}
but only relay17 state is changed
please answer
Is it possible to set more than one relay by one MQTT publish command?
with regards,
Gene
  KC868-A4 and A8 plastic enclosure 3D printer stl file
Posted by: admin - 10-07-2021, 05:29 AM - Forum: KC868-A series and Uair Smart Controller - No Replies
thanks for "Calin Mihai Cioci" from UK, the 3D stl file design by him. more details about his KC868-A4 project, see this link:
http://calincioci.uk/kinconya4/
3D print files for Base:
[Image: 3D_base_printed-pix800.jpg]
[Image: A4_board_temp_humidity_air_soil_sensor-pix800.jpg]
https://www.kincony.com/images/KC868-A4/...ase_A4.stl
https://www.kincony.com/images/KC868-A4/...se_A4.step
Posted by: admin - 10-07-2021, 05:29 AM - Forum: KC868-A4 - Replies (7)
Posted by: admin - 10-07-2021, 05:29 AM - Forum: KC868-A8 - Replies (7)
  Lesson21- KC868-A8 ethernet work with home assistant by ESP home
Posted by: admin - 10-05-2021, 11:34 AM - Forum: KC868-A series and Uair Smart Controller - No Replies
here is ESP home config file work with KC868-A8 by ethernet static IP:
  platform: ESP32
  sda: 4
  scl: 5
# Example configuration entry
  type: LAN8720
  mdc_pin: GPIO23
  mdio_pin: GPIO18
  clk_mode: GPIO17_OUT
  phy_addr: 0
  # Optional manual IP
  manual_ip:
    static_ip: 192.168.2.199
    gateway: 192.168.2.1
    subnet: 255.255.255.0
  - id: 'pcf8574_hub'
# Individual outputs
      pcf8574: pcf8574_hub
      # Use pin number 0
      # One of INPUT or OUTPUT
      inverted: false
