» Members: 9,997
» Latest member: 3dspaces
» Forum threads: 4,250
» Forum posts: 21,046
There are currently 209 online users.
» 0 Member(s) | 190 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bytespider, Crawl, Google, PetalBot, Yandex, bot
Disconnect loop with Home...
Forum: F16
8 hours ago
KC-868-A1 linked Home Ass...
Forum: News
8 hours ago
config modbus sensor in K...
09-19-2026, 11:52 AM
remember relay state
Forum: KC868-E16T
09-19-2026, 01:42 AM
getting the A8A inputs to...
Forum: Development
09-19-2026, 01:41 AM
Ceiling fan control not w...
09-18-2026, 07:15 AM
» Replies: 11
Output pin protection
Forum: T16M
09-17-2026, 11:44 PM
Modbus 485 extender kcs V...
Forum: N30
09-17-2026, 08:10 AM
» Replies: 11
N10 with L1 and L2 suppor...
Forum: N10
09-16-2026, 11:34 PM
KC868-A16v3 PCB layout CA...
09-16-2026, 11:33 PM
  Disappointed with this server...
Posted by: Amaral989 - 05-23-2022, 01:54 AM - Forum: KC868-Server Raspberry Pi4 local server - Replies (5)
The ESP 3.3v is 5v now.
i can not get ADC to read voltages . This unit just doesn't work like its described.  Angry
  ADC pins
Posted by: Amaral989 - 05-22-2022, 03:54 AM - Forum: KC868-Server Raspberry Pi4 local server - Replies (4)
This is all new to me and trying to learn as i go along.
I have a resistance sensor that reads water tank levels. Full level it reads 33ohms, empty level reads 240ohms.
I'm trying to understand how to hook this sensor up. I'm assuming it needs to be on ADC 0.
If it does , i dont see anything occuring .
Thank you for you help.
john
Wink 【Sensor series program】-#02-Arduino code of KC868-A6 and Laser Sensor
Posted by: KinCony Support - 05-20-2022, 09:03 AM - Forum: KC868-A6 - No Replies
#include <U8g2lib.h>
#include <Wire.h>
U8G2_SSD1306_128X64_NONAME_F_SW_I2C u8g2(U8G2_R0,  15, 4, U8X8_PIN_NONE);//SCL IO15  SDA  IO4
void page1() {
  u8g2.setFont(u8g2_font_timR14_tf);// Font 18
  u8g2.setFontPosTop();
  u8g2.setCursor(5,20);
  u8g2.print("Sending Lasers ");
void page2() {
  u8g2.print("Not Sending");
  pinMode(0,INPUT);
  pinMode(32,OUTPUT);
  u8g2.setI2CAddress(0x3C*2);
  u8g2.begin();
  u8g2.enableUTF8Print();
  if(digitalRead(0)==LOW)
   digitalWrite(32,HIGH);
   u8g2.firstPage();
    do
    page1();
     }while(u8g2.nextPage());
  else
      digitalWrite(32,LOW);
         u8g2.firstPage();
    do
       page2();
Wink 【Sensor series program】-#01-Arduino code of KC868-A6 and Hall Sensor
Posted by: KinCony Support - 05-20-2022, 03:11 AM - Forum: KC868-A6 - No Replies
/*【Sensor series program】Arduino code of KC868-A6 and Hall Sensor*/
/*When the Hall sensor is triggered, Turn on relay 1; Otherwise turn off relay1*/
#include "Wire.h"
#include"PCF8574.h"
PCF8574 pcf8574_RE(0x24,4,15);
int rawValue;
void setup(){
  pinMode(32,INPUT);
  pcf8574_RE.pinMode(P0,OUTPUT);
  pcf8574_RE.pinMode(P1,OUTPUT);
  pcf8574_RE.pinMode(P2,OUTPUT);
  pcf8574_RE.pinMode(P3,OUTPUT);
  pcf8574_RE.pinMode(P4,OUTPUT);
  pcf8574_RE.pinMode(P5,OUTPUT);
  pcf8574_RE.begin();
  for(int i=0;i<6;i++)
   pcf8574_RE.digitalWrite(i,HIGH);
void loop(){
  rawValue=analogRead(32);
  Serial.println(rawValue);
  if(rawValue==0)
      pcf8574_RE.digitalWrite(P0,LOW);
  else {
      pcf8574_RE.digitalWrite(P0,HIGH);
  KC868 H32B in node red and home assistant
Posted by: ahmedwizza - 05-19-2022, 11:52 AM - Forum: KC868-HxB series Smart Controller - Replies (1)
Hello Engineer
I faced some problem.when I active Alexa bridge and made switch .then connect Alexa node to controller by TCP out
  all okay .... the sound control by Alexa is okay ...the switch appeared in Alexa app in my phone ...but I cant find the switch in Alexa entities in home assistant to control
as attached photos
Rainbow How to use tasmota for KC868-A32 via PCF8574 IIC extend GPIO
Posted by: KinCony Support - 05-18-2022, 02:50 AM - Forum: KC868-A32/A32 Pro - Replies (10)
The Tamplate code is:
{"NAME":"KC868-A32","GPIO":[32,0,1120,0,641,609,0,0,0,608,1,640,0,0,5600,0,0,0,0,5568,0,0,0,0,0,0,0,0,1,1,0,0,1,0,0,1],"FLAG":0,"BASE":1}
Set all Device port to  "OUTPUT"
.zip   ESP-Flasher-Windows-x64.zip (Size: 16.07 MB / Downloads: 1075)
.zip   firmware-en-a32.zip (Size: 764.89 KB / Downloads: 1117)
  Lesson24 - home assistant remote access by FREE DuckDNS
Posted by: admin - 05-17-2022, 04:27 AM - Forum: Home automation training courses - Replies (5)
https://www.duckdns.org/
Thumbs Up [Arduino IDE demo source code for KC868-E16S]--#06-KC868-E16S-RS485
Posted by: KinCony Support - 05-17-2022, 01:29 AM - Forum: KC868-E16S/E16P - No Replies
/*WWW.KINCONY.COM */
/*KC868-E16S CODE OF RS485*/
void setup(){
  Serial2.begin(9600,SERIAL_8N1,13,32);// IO13 is 485RX  IO32 is 485TX
Serial2.println("abcd123456789551");// send abcd123456789551
.zip   KC868-E16S-RS485.zip (Size: 469.31 KB / Downloads: 987)
Thumbs Up [Arduino IDE demo source code for KC868-E16S]--#05-KC868-E16S-LAN8720_UDP
Posted by: KinCony Support - 05-17-2022, 01:28 AM - Forum: KC868-E16S/E16P - No Replies
/*www.kincony.com */
/* KC868-E16S CODE OF LAN8720-UDP */
#include <ETH.h>
#include <WiFiUdp.h>
#define ETH_ADDR        0
#define ETH_POWER_PIN  -1
#define ETH_MDC_PIN    23
#define ETH_MDIO_PIN   18
  Serial.println();
  Serial.println("Connected");
  Serial.print("IP Address:");
    char buf[packetSize];
    Serial.println();
    Serial.print("Received: ");
    Serial.println(buf);
    Serial.print("From IP: ");
    Serial.print("From Port: ");
    Udp.print("Received: ");
.zip   KC868-E16S-LAN8720_UDP.zip (Size: 1.11 KB / Downloads: 905)
Thumbs Up [Arduino IDE demo source code for KC868-E16S]--#04-KC868-E16S-ADC_IN
Posted by: KinCony Support - 05-17-2022, 01:25 AM - Forum: KC868-E16S/E16P - No Replies
/*www.kinocny.com */
/*KC868-E16S CODE OF ADC-IN*/
#include "Arduino.h"
#define ANALOG_A1   36
#define ANALOG_A2   35
#define ANALOG_A3   34
#define ANALOG_A4   39
    delay(500);
  pinMode(ANALOG_A1,INPUT);
  pinMode(ANALOG_A2,INPUT);
  pinMode(ANALOG_A3,INPUT);
  pinMode(ANALOG_A4,INPUT);
  if(analogRead(ANALOG_A1)!=0)  {Serial.printf("Current Reading A1 on Pin(%d)=%d\n",ANALOG_A1,analogRead(ANALOG_A1));}
  if(analogRead(ANALOG_A2)!=0)  {Serial.printf("Current Reading A2 on Pin(%d)=%d\n",ANALOG_A2,analogRead(ANALOG_A2));}
  if(analogRead(ANALOG_A3)!=0)  {Serial.printf("Current Reading A3 on Pin(%d)=%d\n",ANALOG_A3,analogRead(ANALOG_A3));}
  if(analogRead(ANALOG_A4)!=0)  {Serial.printf("Current Reading A4 on Pin(%d)=%d\n",ANALOG_A4,analogRead(ANALOG_A4));}
  delay(50);
.zip   KC868-E16S-ADC_IN.zip (Size: 674 bytes / Downloads: 858)
