» Members: 10,139
» Latest member: gracewhite
» Forum threads: 4,259
» Forum posts: 21,097
There are currently 569 online users.
» 0 Member(s) | 549 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, PetalBot, Yandex, bot
It looks like it's broken...
Last Post: abc123
6 hours ago
Bidirectional reading
Forum: N10
8 hours ago
Update to latest esphome
Yesterday, 12:05 PM
KC868-A16 ethernet work w...
10-04-2026, 11:43 PM
» Replies: 31
B32M maximum voltage
10-04-2026, 11:52 AM
» Replies: 4
m16v2 energy meter - cali...
10-02-2026, 11:50 AM
» Replies: 15
oCBot: KC868-A6/A16 as a ...
Last Post: oCBot
10-01-2026, 01:32 PM
N20 Energy RS485 Modbus P...
Forum: N20
10-01-2026, 12:43 PM
Getting inconsistent/wron...
10-01-2026, 12:40 PM
KC868-HAv2 phantom press ...
Forum: KC868-HA /HA v2
Last Post: phrfpeixoto
09-29-2026, 01:57 AM
  Lesson16 - integrate ZigBee device to home assistant by Zigbee2MQTT
Posted by: admin - 04-13-2022, 01:42 AM - Forum: Home automation training courses - Replies (5)
1. Add the repository URL under Supervisor->Add-on store->...->Manage add-on repositories:
https://github.com/zigbee2mqtt/hassio-zigbee2mqtt
2. Zigbee2mqtt add-on Configuration for home assistant
data_path: /config/zigbee2mqtt
external_converters: []
devices: devices.yaml
groups: groups.yaml
homeassistant: true
permit_join: false
mqtt:
  base_topic: zigbee2mqtt
  server: mqtt://192.168.1.96:1883
  user: mqtt
  password: '123'
serial:
  port: /dev/ttyACM0
advanced:
  log_level: info
  pan_id: 6754
  channel: 11
  network_key:
    - 1
    - 3
    - 5
    - 7
    - 9
    - 11
    - 13
    - 15
    - 0
    - 2
    - 4
    - 6
    - 8
    - 10
    - 12
    - 13
  availability_blocklist: []
  availability_passlist: []
device_options: {}
blocklist: []
passlist: []
queue: {}
frontend:
  port: 8099
experimental: {}
socat:
  enabled: false
  master: pty,raw,echo=0,link=/tmp/ttyZ2M,mode=777
  slave: tcp-listen:8485,keepalive,nodelay,reuseaddr,keepidle=1,keepintvl=1,keepcnt=5
  options: '-d -d'
3. feedback click action mqtt message:
  1: single
  2: double
  3: triple
  4: quadruple
  5: many
4. Xiaomi zigbee switch configure for home assistant by Zigbee2mqtt
  - platform: mqtt
    state_topic: "zigbee2mqtt/0x00158d00067ec29e"
    value_template: "{{ value_json.battery }}"
    unit_of_measurement: "%"
    availability_topic: "zigbee2mqtt/bridge/state"
    payload_available: "online"
    payload_not_available: "offline"
    qos: 0
    device_class: battery
  - platform: mqtt
    value_template: "{{ value_json.linkquality }}"
    qos: 0
    device_class: signal_strength
  - platform: mqtt
    value_template: "{{ value_json.click }}"
Note: ID need replace with your device. such as '0x00158d00067ec29e'
5. create a new automation:
Trigger type: State
Entity: sensor.click
To: single
Actions:
Action type: Call service
Service: Switch:Toggle
+ Pick entity
  Lesson15 - control IR device by Infrared extender cable
Posted by: admin - 04-12-2022, 12:56 AM - Forum: Home automation training courses - No Replies
[Image: attachment.php?aid=831]
[Image: attachment.php?aid=705]
[Image: attachment.php?aid=706]
ESPHome config:
# Example configuration entry
remote_transmitter:
  pin: GPIO23
  carrier_duty_percent: 50%
climate:
  - platform: mitsubishi    # adjust to match your AC unit!
  Lesson14 - integrate DS18B20 temperature sensor to home assistant
Posted by: admin - 04-12-2022, 12:48 AM - Forum: Home automation training courses - Replies (10)
DS18B20 temperature range: -55°C to +125°C and is accurate to ±0.5°C
ESPHome config:
dallas:
  - pin: 4
    update_interval: 5s
# Individual sensors
  - platform: dallas
    address: 0x69062162d9ec4328
  KC868-Server schematic for ESP32 and raspberry pi CM4 circuit
Posted by: admin - 04-11-2022, 01:57 PM - Forum: KC868-Server Raspberry Pi4 local server - No Replies
ESP32 use serial port communication with KinCony ARM CPU. user can write any code work with KinCony ARM CPU read/write digital input, digital output and analog input.
.pdf   KC868_SERVER_OPENSOURCE_SCH.pdf (Size: 373.22 KB / Downloads: 1567)
  KC868-E16 work with Loxone system case-3
Posted by: admin - 04-08-2022, 11:48 AM - Forum: KinCony integrate with Loxone home automation - No Replies
  Loxone XML template file for KC868-H32B
Posted by: admin - 04-08-2022, 11:45 AM - Forum: KinCony integrate with Loxone home automation - No Replies
You just need to select "Virtual Outputs" and import this template. After this file is imported only the IP address as per user's ip address has to be give. There is no need to configure all the 32 relays for ON and OFF commands.
.zip   VO_KC868-H32B.zip (Size: 710 bytes / Downloads: 972)
Photo KC868-E16 work with Loxone system case-2
Posted by: admin - 04-08-2022, 11:41 AM - Forum: KinCony integrate with Loxone home automation - No Replies
Posted by: admin - 04-08-2022, 11:38 AM - Forum: KinCony integrate with Loxone home automation - No Replies
Photo KC868-G IR Loxone integration
Posted by: admin - 04-08-2022, 11:24 AM - Forum: KinCony integrate with Loxone home automation - No Replies
  KC868-A16 Loxone integration
Posted by: admin - 04-08-2022, 11:20 AM - Forum: KinCony integrate with Loxone home automation - Replies (2)
before integration you should install tasmota firmware for KC868-A16 firstly. here is link for KinCony KC868-A16's tasmota BIN file: https://www.kincony.com/forum/showthread.php?tid=1715
Integrating Kincony KC868-A16 in Loxone Config details:
.pdf   KC868-A16 Loxone integration.pdf (Size: 2.74 MB / Downloads: 1707)
