» Members: 10,281
» Latest member: vicstarmetals
» Forum threads: 4,287
» Forum posts: 21,217
There are currently 466 online users.
» 0 Member(s) | 443 Guest(s)
Applebot, Baidu, Bing, Bytespider, Crawl, Facebook, Google, PetalBot, Semrush, Twitter, bot, facebookexternalhit
Which KinCony board for a...
Last Post: Kiwoneka
4 hours ago
KC868-AP – max current pe...
Forum: KC868-AP / ADR
Yesterday, 11:50 AM
KC868-HAv2: TS sensor on ...
Forum: KC868-HA /HA v2
Last Post: swisstmack25
Yesterday, 07:00 AM
» Replies: 4
MT4v2 Driver Board Web To...
Forum: MT4v2
Yesterday, 03:37 AM
ARM CPU Modbus communicat...
Forum: MT4v2
Yesterday, 03:36 AM
Forum: MT4v2
Yesterday, 03:35 AM
Forum: MT4v2
Yesterday, 03:33 AM
Forum: MT4v2
Yesterday, 03:32 AM
Forum: MT4v2
Yesterday, 03:31 AM
Forum: MT4v2
Yesterday, 03:30 AM
  Can i use PC computer to control relay Controller?
Posted by: admin - 10-28-2020, 04:13 AM - Forum: KC868-HxB series Smart Controller - No Replies
Yes, support, we have windows program with two work mode.
not only for local network control , but also can remote control by internet.
  what's UDP,TCP Server,TCP Client means in network setting?
Posted by: admin - 10-28-2020, 04:06 AM - Forum: KC868-HxB series Smart Controller - No Replies
UDP: Controller power on will auto connect to KinCony's cloud server. This is use for "KinCony Smart Home" phone app. work need internet.
TCP Server: Controller is a server running on local network . This is use for "KBOX" phone app. work without internet.
TCP Client: Controller power on will auto connect to your server (can be local network server or cloud server), just according server IP and port. This is use for make your own server and control by own phone app. It need develop software.
  why relay controller can't add to phone app again?
Posted by: admin - 10-28-2020, 04:00 AM - Forum: KC868-HxB series Smart Controller - Replies (4)
One relay controller only can add to one phone app account, if you want to add to another phone account, you need "delete host" in phone app "Host Manager" menu firstly. If you want to more people use one controller, you can use account authorization function set by administrator. How to do this, you can see our YouTube channel video.
  DIY smart home video tour for beginner - Wireless solution
Posted by: admin - 10-28-2020, 03:54 AM - Forum: DIY Project - No Replies
  DIY smart home video tour for beginner - Wired solution
Posted by: admin - 10-28-2020, 03:52 AM - Forum: DIY Project - No Replies
The video introduces some of the main concerns of smart home DIY for beginner.
Wink if you want to DIY smart home,how to do plan?
Posted by: admin - 10-28-2020, 03:46 AM - Forum: DIY Project - Replies (2)
[b]1. What function do you want?[/b]
[b]A. Light[/b]
[Image: KC868-H32-diagram-light.jpg]
How to Diagram:
  1. KC868-Hx relay controller output series connect with light.
  2. Wall switch panel connect with switch terminal board.Set the switch terminal board work mode for “light”.
  3. Switch terminal board connect with KC868-Hx relay controller by RS232 cable.
  4. Such as you can use any two line button, there have two line, when short , light will be ON, short again, light will be OFF, just repeat. If short K1 two line, turn ON/OFF light1, if short K2 two line, turn ON/OFF light2…. If use a 4 key switch panel, you need connect 4+1=5 line from wall swith panel with switch terminal board. If use a 6 key switch panel, you need connect 7+1=8 line from wall swith panel with switch terminal board. +1 line means “COM” line. So you can use CAT5 network cable for wall switch use, wall switch panel not need power supply.
[b]B. Curtain or blind[/b]
[Image: KC868-H32-diagram-motor.jpg]
How to Diagram:
  1. KC868-Hx relay controller output connect with curtain or blind motor. The motor should be work with AC220V. Every curtain motor need two relay output port used. Such as curtain1 use relay1 and relay2, curtain2 use relay3 and relay4…..
  2. Wall switch panel connect with switch terminal board.Set the switch terminal board work mode for “curtain”.
  4. You can define one button for curtain “UP”, another button for curtain “DOWN”
[b]C. Garage[/b]
[b]D. Air conditioner[/b]
[b]E. TV, DVD,STB and other multimedia equipment[/b]
[b]F. Power socket[/b]
[b]G. Fountain water flow[/b]
[b]H. Swimming pool[/b]
[b]I. Water pump[/b]
[b]J. high-power device (like water heater, air conditioner)[/b]
[b]K. CCTV IPCameras[/b]
[b]L. Security sensor[/b]
[b]2. Which products to chose?[/b]
https://www.kincony.com/how-to-diy-your-smart-home.html
  KC868-H32B V3.1 new firmware released
Posted by: admin - 10-28-2020, 01:30 AM - Forum: News - Replies (1)
improvement:
1. Integration WiFi network and Ethernet network setting in one webpage,easy to set.
2. automatically switch the Ethernet / WiFi line to keep the communication with the cloud server smooth.
3. add Ethernet TCP Server and TCP Client work mode auto connect function when disconnected.
If you want to update your firmware of KC868-H32B, you can leave Email, we will send firmware file.
  NodeRed Disconnected Randomly
Posted by: subas - 10-27-2020, 01:45 PM - Forum: Development - Replies (2)
Dear Support.
Is the away to ensure that NodeRed is running at all time?
Is there any changes i need to make on my laptop that will re-connect the NodeRed when it disconnect?
This is because once NodeRed stops the nodes are not able to update the IOS devices until the NodeRed is up and running again?
I have created a task schedule to automatically run NodeRed when the laptops starts but I notice once NodeRed disconnect it does not want to reconnect until i go into the schedule and re-run the task.
Will it be more stable if  I use Raspberry Pi?
  Unable to Turn "Off" or "ON" via KC868 CON and 32 Relay board Controller via RS232
Posted by: subas - 10-27-2020, 12:30 PM - Forum: Development - Replies (11)
Dear Sir.
I need some help.
The videos shown on all the YouTube are connected directly to either Relay Board Controller Hx or Directly to The KC868 CON.
I have connected the H32 Relay Controller via a RS232 to the KC868 CON. When I use your Application as per below screenshot and click the Relay it works well as it turns on the relay at the Relay Board H32.
But when I use NodeRed and connect it and follow your video on how to control a switch to switch on a light or off it does not work. I have set the NodeRed based on the YouTube video. When I press the button on the iPhone I can see that on the debug message shows  payload "On" or "Of" are sent and I have placed the debug after the "Function" node to see if the payloads get to the TCP OUT node.
Based on the Debug after the "Function" node, there are payloads coming but it does not turn the Relay "On" or "Off" via the KC868 CON to the 32 Relay Controller Board via RS232.
The difference is I have a KC868 Controller connected to the 32 relay board via a RS232 cable compared to your video where you only have the RedNode connected to the 32 Relay Controller Board.
Please advise why I cannot connect to the 32 Relay Controller via the KC868 CON controlling from RedNode?
Regards
Subas
  NodeRed for Android Phone
Posted by: subas - 10-27-2020, 09:05 AM - Forum: Development - Replies (2)
Dear All.
If i wanted to create a Node based on IOS I need to load "node-red contrib-homekit" and this is meant for IOS devices.
What do I need to load if I want to use Android phone to control a switch or read a sensor using NodeRed?
Thank You
