» Members: 10,452
» Forum threads: 4,326
» Forum posts: 21,315
There are currently 422 online users.
» 0 Member(s) | 406 Guest(s)
Amazonbot, Applebot, AwarioBot, Baidu, Bing, Crawl, Google, bot
No AP appears
24 minutes ago
» Replies: 8
kc868-a6 analog input
11-06-2026, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
11-06-2026, 07:25 AM
Forum: F24
11-06-2026, 05:35 AM
Forum: F24
11-06-2026, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
11-06-2026, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
  [arduino code examples for B24]-02 Read digital input ports state
Posted by: admin - 07-31-2025, 06:55 AM - Forum: B24 - No Replies
* Description:
* This Arduino program reads the state of two 16-channel PCF8575 I/O expanders
* and prints the state of all input pins (1-24) to the Serial Monitor.
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* - PCF8575 I2C Address: 0x22 for inputs 1-16, 0x25 for inputs 17-24
#include "Arduino.h"
#include "PCF8575.h"
// Define I2C pins
// Set I2C addresses
PCF8575 pcf8575_IN1(0x22); // The I2C address of the first PCF8575 (inputs 1-16)
PCF8575 pcf8575_IN2(0x25); // The I2C address of the second PCF8575 (inputs 17-24)
    // Initialize both PCF8575 modules
    pcf8575_IN1.begin();
    pcf8575_IN2.begin();
    Serial.println("KinCony B24 24 channel input state 0:ON  1:OFF");
if (pcf8575_IN1.read(8)==0) {Serial.print("DI1 state="); Serial.println("on");}
if (pcf8575_IN1.read(9)==0) {Serial.print("DI2 state="); Serial.println("on");}
if (pcf8575_IN1.read(10)==0) {Serial.print("DI3 state="); Serial.println("on");}
if (pcf8575_IN1.read(11)==0) {Serial.print("DI4 state="); Serial.println("on");}
if (pcf8575_IN1.read(12)==0) {Serial.print("DI5 state="); Serial.println("on");}
if (pcf8575_IN1.read(13)==0) {Serial.print("DI6 state="); Serial.println("on");}
if (pcf8575_IN1.read(14)==0) {Serial.print("DI7 state="); Serial.println("on");}
if (pcf8575_IN1.read(15)==0) {Serial.print("DI8 state="); Serial.println("on");}
if (pcf8575_IN1.read(0)==0) {Serial.print("DI9 state="); Serial.println("on");}
if (pcf8575_IN1.read(1)==0) {Serial.print("DI10 state="); Serial.println("on");}
if (pcf8575_IN1.read(2)==0) {Serial.print("DI11 state="); Serial.println("on");}
if (pcf8575_IN1.read(3)==0) {Serial.print("DI12 state="); Serial.println("on");}
if (pcf8575_IN1.read(4)==0) {Serial.print("DI13 state="); Serial.println("on");}
if (pcf8575_IN1.read(5)==0) {Serial.print("DI14 state="); Serial.println("on");}
if (pcf8575_IN1.read(6)==0) {Serial.print("DI15 state="); Serial.println("on");}
if (pcf8575_IN1.read(7)==0) {Serial.print("DI16 state="); Serial.println("on");}
if (pcf8575_IN2.read(0)==0) {Serial.print("DI17 state="); Serial.println("on");}
if (pcf8575_IN2.read(1)==0) {Serial.print("DI18 state="); Serial.println("on");}
if (pcf8575_IN2.read(2)==0) {Serial.print("DI19 state="); Serial.println("on");}
if (pcf8575_IN2.read(3)==0) {Serial.print("DI20 state="); Serial.println("on");}
if (pcf8575_IN2.read(4)==0) {Serial.print("DI21 state="); Serial.println("on");}
if (pcf8575_IN2.read(5)==0) {Serial.print("DI22 state="); Serial.println("on");}
if (pcf8575_IN2.read(6)==0) {Serial.print("DI23 state="); Serial.println("on");}
if (pcf8575_IN2.read(7)==0) {Serial.print("DI24 state="); Serial.println("on");}
    delay(1000); // Delay 500ms
arduino ino file download:
.zip   2-digital-input.zip (Size: 880 bytes / Downloads: 649)
.zip   2-digital-input.ino.merged.zip (Size: 192.64 KB / Downloads: 632)
  [arduino code examples for B32M]-02 Read digital input ports state
Posted by: admin - 07-31-2025, 06:55 AM - Forum: B32M - No Replies
* Description:
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
// Define I2C pins
PCF8575 pcf8575_IN3(0x26); // The I2C address of the second PCF8575 (inputs 25-32)
    pcf8575_IN3.begin();
    Serial.println("KinCony B32 32 channel input state 0:ON  1:OFF");
if (pcf8575_IN3.read(0)==0) {Serial.print("DI25 state="); Serial.println("on");}
if (pcf8575_IN3.read(1)==0) {Serial.print("DI26 state="); Serial.println("on");}
if (pcf8575_IN3.read(2)==0) {Serial.print("DI27 state="); Serial.println("on");}
if (pcf8575_IN3.read(3)==0) {Serial.print("DI28 state="); Serial.println("on");}
if (pcf8575_IN3.read(4)==0) {Serial.print("DI29 state="); Serial.println("on");}
if (pcf8575_IN3.read(5)==0) {Serial.print("DI30 state="); Serial.println("on");}
if (pcf8575_IN3.read(6)==0) {Serial.print("DI31 state="); Serial.println("on");}
if (pcf8575_IN3.read(7)==0) {Serial.print("DI32 state="); Serial.println("on");}
.zip   2-digital-input.zip (Size: 942 bytes / Downloads: 355)
.zip   2-digital-input.ino.merged.zip (Size: 198.36 KB / Downloads: 408)
  [arduino code examples for B24M]-01 Turn ON/OFF OUTPUT
Posted by: admin - 07-31-2025, 06:54 AM - Forum: B24M - No Replies
* This program controls a 24-channel relay board via two PCF8575 I/O expanders.
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* Delay Time:
#define SDA 8            // Define the SDA pin
#define SCL 18           // Define the SCL pin
// Set I2C addresses of the PCF8575 modules
#define I2C_ADDRESS_R1 0x25 // I2C address of the first PCF8575 module
#define I2C_ADDRESS_R2 0x24 // I2C address of the second PCF8575 module
PCF8575 pcf8575_R1(I2C_ADDRESS_R1); // Create a PCF8575 object for the first module (for relays 9-24)
PCF8575 pcf8575_R2(I2C_ADDRESS_R2); // Create a PCF8575 object for the second module (for relays 1-8)
  // Initialize the PCF8575 modules
  pcf8575_R1.begin();
  pcf8575_R2.begin();
    pcf8575_R1.write(i, HIGH); // Set relays 1-8 to OFF (assuming HIGH means OFF for relays)
    pcf8575_R2.write(i, HIGH); // Set relays 9-24 to OFF (assuming HIGH means OFF for relays)
  // Sequentially turn on each relay (1-24)
  // First control the relays on the second PCF8575 (relays 1-8)
  // Then control the relays on the first PCF8575 (relays 9-24)
    pcf8575_R2.write(i, LOW);   // Turn on the relay at pin i (LOW means ON for the relay)
  // Sequentially turn off each relay (1-24)
    pcf8575_R2.write(i, HIGH);  // Turn off the relay at pin i (HIGH means OFF for the relay)
.zip   1-relay.zip (Size: 1.01 KB / Downloads: 686)
.zip   1-relay.ino.merged.zip (Size: 192.11 KB / Downloads: 647)
  [arduino code examples for B24]-01 Turn ON/OFF OUTPUT
Posted by: admin - 07-31-2025, 06:54 AM - Forum: B24 - No Replies
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* Delay Time:
  pcf8575_R1.begin();
  pcf8575_R2.begin();
.zip   1-relay.zip (Size: 1.01 KB / Downloads: 600)
.zip   1-relay.ino.merged.zip (Size: 192.11 KB / Downloads: 635)
  [arduino code examples for B32M]-01 Turn ON/OFF OUTPUT
Posted by: admin - 07-31-2025, 06:54 AM - Forum: B32M - No Replies
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* Delay Time:
#define I2C_ADDRESS_R3 0x26 // I2C address of the second PCF8575 module
PCF8575 pcf8575_R3(I2C_ADDRESS_R3); // Create a PCF8575 object for the second module (for relays 25-32)
  pcf8575_R1.begin();
  pcf8575_R2.begin();
  pcf8575_R3.begin();
    pcf8575_R3.write(i, HIGH); // Set relays 1-8 to OFF (assuming HIGH means OFF for relays)
    pcf8575_R1.write(i, HIGH); // Set relays 9-16 to OFF (assuming HIGH means OFF for relays)
    pcf8575_R2.write(i, HIGH); // Set relays 17-32 to OFF (assuming HIGH means OFF for relays)
  // control the relays on the second PCF8575 (relays 1-8)
    pcf8575_R3.write(i, LOW);   // Turn on the relay at pin i (LOW means ON for the relay)
  // First control the relays on the second PCF8575 (relays 9-16)
  // Then control the relays on the first PCF8575 (relays 17-32)
  // Then control the relays on the first PCF8575 (relays 1-8)
    pcf8575_R3.write(i, HIGH);  // Turn off the relay at pin i (HIGH means OFF for the relay)
.zip   1-relay.zip (Size: 1.08 KB / Downloads: 363)
.zip   1-relay.ino.merged.zip (Size: 197.71 KB / Downloads: 396)
  B24M ESPHome yaml for home assistant without tuya
Posted by: admin - 07-31-2025, 06:52 AM - Forum: B24M - Replies (2)
  friendly_name: b24
  board: esp32-s3-devkitc-1
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  interrupt_pin: GPIO43
  reset_pin: GPIO44
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      dummy_receiver: true
      after:
        timeout: 10ms
    tx_pin: 39
    rx_pin: 38
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
    i2c_id: bus_a
    pcf8575: true
  - id: 'pcf8574_hub_in_out_1'  # for digital input channel 17-24 & ouptut 1-8
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
  - id: 'pcf8574_hub_out_1'  # for output channel 9-24
    i2c_id: bus_a
    pcf8575: true
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_in_out_1
##pull-up resistance on PCB
      number: 48
      number: 47
      number: 40
## without resistance on PCB
      number: 13
      inverted: false
      number: 14
      inverted:  false
      number: 21
      inverted:  false
      inverted:  false
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      pcf8574: pcf8574_hub_out_1
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
  - platform: uart
    uart_id: uart_1
ads1115:
  - address: 0x48
  - platform: ads1115
    multiplexer: 'A0_GND'
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A1_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A2_GND'
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    multiplexer: 'A3_GND'
    gain: 6.144
    update_interval: 5s
web_server:
  port: 80
font:
  - file: "gfonts://Roboto"
display:
  - platform: ssd1306_i2c
    i2c_id: bus_a
    model: "SSD1306 128x64"
    address: 0x3C
    lambda: |-
      it.printf(0, 0, id(roboto), "KinCony B24");
download yaml file:
.txt   B24-HA-without Tuya.txt (Size: 10.92 KB / Downloads: 510)
  B24 ESPHome yaml for home assistant without tuya
Posted by: admin - 07-31-2025, 06:52 AM - Forum: B24 - No Replies
  friendly_name: b24
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  reset_pin: GPIO44
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      after:
        timeout: 10ms
    tx_pin: 39
    rx_pin: 38
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
    i2c_id: bus_a
    pcf8575: true
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
    i2c_id: bus_a
    pcf8575: true
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      number: 48
      number: 47
      number: 40
      number: 13
      inverted: false
      number: 14
      inverted:  false
      number: 21
      inverted:  false
      inverted:  false
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
      number: 8
      number: 9
      number: 10
      number: 11
      number: 12
      number: 13
      number: 14
      number: 15
  - platform: uart
    uart_id: uart_1
ads1115:
  - address: 0x48
  - platform: ads1115
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    gain: 6.144
    update_interval: 5s
web_server:
  port: 80
font:
display:
    i2c_id: bus_a
    address: 0x3C
    lambda: |-
download yaml file:
.txt   B24-HA-without Tuya.txt (Size: 10.92 KB / Downloads: 375)
  B24M ESPHome yaml for home assistant with tuya
Posted by: admin - 07-31-2025, 06:51 AM - Forum: B24M - No Replies
  friendly_name: b24
  platformio_options:
    board_build.extra_flags:
      # WIFI_CONTROL_SELF_MODE = 0
      # WIFI_CONTROL_SELF_MODE = 1
external_components:
  - source:
      type: git
      ref: v1.1.0
#logger:
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  reset_pin: GPIO44
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      after:
        timeout: 10ms
    tx_pin: 39
    rx_pin: 38
  - id: tuya_mcu_uart
    tx_pin: GPIO16
    rx_pin: GPIO17
    baud_rate: 9600
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
    i2c_id: bus_a
    pcf8575: true
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
    i2c_id: bus_a
    pcf8575: true
tuya_wifi_mcu:
  # tuya mcu product id
  product_id: vyznobv3bahs2pwl
  uart_id: tuya_mcu_uart
  wifi_reset_pin: 28
  wifi_led_pin: 16
      number: 8
  - platform: tuya_wifi_mcu
    dp_id: 125
    bind_binary_sensor_id: b24_input01
    internal: true
      number: 9
    dp_id: 126
    bind_binary_sensor_id: b24_input02
    internal: true
      number: 10
    dp_id: 127
    bind_binary_sensor_id: b24_input03
    internal: true
      number: 11
    dp_id: 128
    bind_binary_sensor_id: b24_input04
    internal: true
      number: 12
    dp_id: 129
    bind_binary_sensor_id: b24_input05
    internal: true
      number: 13
    dp_id: 130
    bind_binary_sensor_id: b24_input06
    internal: true
      number: 14
    dp_id: 131
    bind_binary_sensor_id: b24_input07
    internal: true
      number: 15
    dp_id: 132
    bind_binary_sensor_id: b24_input08
    internal: true
    dp_id: 133
    bind_binary_sensor_id: b24_input09
    internal: true
    dp_id: 134
    bind_binary_sensor_id: b24_input10
    internal: true
    dp_id: 135
    bind_binary_sensor_id: b24_input11
    internal: true
    dp_id: 136
    bind_binary_sensor_id: b24_input12
    internal: true
    dp_id: 137
    bind_binary_sensor_id: b24_input13
    internal: true
    dp_id: 138
    bind_binary_sensor_id: b24_input14
    internal: true
    dp_id: 139
    bind_binary_sensor_id: b24_input15
    internal: true
    dp_id: 140
    bind_binary_sensor_id: b24_input16
    internal: true
    dp_id: 141
    bind_binary_sensor_id: b24_input17
    internal: true
    dp_id: 142
    bind_binary_sensor_id: b24_input18
    internal: true
    dp_id: 143
    bind_binary_sensor_id: b24_input19
    internal: true
    dp_id: 144
    bind_binary_sensor_id: b24_input20
    internal: true
    dp_id: 145
    bind_binary_sensor_id: b24_input21
    internal: true
    dp_id: 146
    bind_binary_sensor_id: b24_input22
    internal: true
    dp_id: 147
    bind_binary_sensor_id: b24_input23
    internal: true
    dp_id: 148
    bind_binary_sensor_id: b24_input24
    internal: true
      number: 48
      number: 47
      number: 40
      number: 13
      inverted: false
      number: 14
      inverted:  false
      number: 21
      inverted:  false
      inverted:  false
      number: 8
    dp_id: 101
    # hide from homeassistant ui
    internal: true
    bind_switch_id: "b24_output01"
      number: 9
    dp_id: 102
    internal: true
    bind_switch_id: "b24_output02"
      number: 10
    dp_id: 103
    internal: true
    bind_switch_id: "b24_output03"
      number: 11
    dp_id: 104
    internal: true
    bind_switch_id: "b24_output04"
      number: 12
    dp_id: 105
    internal: true
    bind_switch_id: "b24_output05"
      number: 13
    dp_id: 106
    internal: true
    bind_switch_id: "b24_output06"
      number: 14
    dp_id: 107
    internal: true
    bind_switch_id: "b24_output07"
      number: 15
    dp_id: 108
    internal: true
    bind_switch_id: "b24_output08"
    dp_id: 109
    internal: true
    bind_switch_id: "b24_output09"
    dp_id: 110
    internal: true
    bind_switch_id: "b24_output10"
    dp_id: 111
    internal: true
    bind_switch_id: "b24_output11"
    dp_id: 112
    internal: true
    bind_switch_id: "b24_output12"
    dp_id: 113
    internal: true
    bind_switch_id: "b24_output13"
    dp_id: 114
    internal: true
    bind_switch_id: "b24_output14"
    dp_id: 115
    internal: true
    bind_switch_id: "b24_output15"
    dp_id: 116
    internal: true
    bind_switch_id: "b24_output16"
      number: 8
    dp_id: 117
    internal: true
    bind_switch_id: "b24_output17"
      number: 9
    dp_id: 118
    internal: true
    bind_switch_id: "b24_output18"
      number: 10
    dp_id: 119
    internal: true
    bind_switch_id: "b24_output19"
      number: 11
    dp_id: 120
    internal: true
    bind_switch_id: "b24_output20"
      number: 12
    dp_id: 121
    internal: true
    bind_switch_id: "b24_output21"
      number: 13
    dp_id: 122
    internal: true
    bind_switch_id: "b24_output22"
      number: 14
    dp_id: 123
    internal: true
    bind_switch_id: "b24_output23"
      number: 15
    dp_id: 124
    internal: true
    bind_switch_id: "b24_output24"
  - platform: uart
    uart_id: uart_1
ads1115:
  - address: 0x48
  - platform: ads1115
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    gain: 6.144
    update_interval: 5s
web_server:
  port: 80
font:
display:
    i2c_id: bus_a
    address: 0x3C
    lambda: |-
download yaml file:
.txt   B24-HA-with-Tuya.txt (Size: 19.26 KB / Downloads: 449)
  B24 ESPHome yaml for home assistant with tuya
Posted by: admin - 07-31-2025, 06:51 AM - Forum: B24 - No Replies
  friendly_name: b24
  platformio_options:
  - source:
      type: git
      ref: v1.1.0
#logger:
  type: W5500
  clk_pin: GPIO1
  mosi_pin: GPIO2
  miso_pin: GPIO41
  cs_pin: GPIO42
  reset_pin: GPIO44
  - id: uart_1    #RS485
    baud_rate: 9600
    debug:
      direction: BOTH
      after:
        timeout: 10ms
    tx_pin: 39
    rx_pin: 38
  - id: tuya_mcu_uart
    tx_pin: GPIO16
    rx_pin: GPIO17
    baud_rate: 9600
   - id: bus_a
     sda: 8
     scl: 18
     frequency: 400kHz
    i2c_id: bus_a
    pcf8575: true
    i2c_id: bus_a
    address: 0x25
    pcf8575: true
    i2c_id: bus_a
    pcf8575: true
tuya_wifi_mcu:
  wifi_reset_pin: 28
  wifi_led_pin: 16
      number: 8
    dp_id: 125
    internal: true
      number: 9
    dp_id: 126
    internal: true
      number: 10
    dp_id: 127
    internal: true
      number: 11
    dp_id: 128
    internal: true
      number: 12
    dp_id: 129
    internal: true
      number: 13
    dp_id: 130
    internal: true
      number: 14
    dp_id: 131
    internal: true
      number: 15
    dp_id: 132
    internal: true
    dp_id: 133
    internal: true
    dp_id: 134
    internal: true
    dp_id: 135
    internal: true
    dp_id: 136
    internal: true
    dp_id: 137
    internal: true
    dp_id: 138
    internal: true
    dp_id: 139
    internal: true
    dp_id: 140
    internal: true
    dp_id: 141
    internal: true
    dp_id: 142
    internal: true
    dp_id: 143
    internal: true
    dp_id: 144
    internal: true
    dp_id: 145
    internal: true
    dp_id: 146
    internal: true
    dp_id: 147
    internal: true
    dp_id: 148
    internal: true
      number: 48
      number: 47
      number: 40
      number: 13
      inverted: false
      number: 14
      inverted:  false
      number: 21
      inverted:  false
      inverted:  false
      number: 8
    dp_id: 101
    internal: true
      number: 9
    dp_id: 102
    internal: true
      number: 10
    dp_id: 103
    internal: true
      number: 11
    dp_id: 104
    internal: true
      number: 12
    dp_id: 105
    internal: true
      number: 13
    dp_id: 106
    internal: true
      number: 14
    dp_id: 107
    internal: true
      number: 15
    dp_id: 108
    internal: true
    dp_id: 109
    internal: true
    dp_id: 110
    internal: true
    dp_id: 111
    internal: true
    dp_id: 112
    internal: true
    dp_id: 113
    internal: true
    dp_id: 114
    internal: true
    dp_id: 115
    internal: true
    dp_id: 116
    internal: true
      number: 8
    dp_id: 117
    internal: true
      number: 9
    dp_id: 118
    internal: true
      number: 10
    dp_id: 119
    internal: true
      number: 11
    dp_id: 120
    internal: true
      number: 12
    dp_id: 121
    internal: true
      number: 13
    dp_id: 122
    internal: true
      number: 14
    dp_id: 123
    internal: true
      number: 15
    dp_id: 124
    internal: true
  - platform: uart
    uart_id: uart_1
ads1115:
  - address: 0x48
  - platform: ads1115
    gain: 6.144
    resolution: 16_BITS
    update_interval: 5s
  - platform: ads1115
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    gain: 6.144
    update_interval: 5s
  - platform: ads1115
    gain: 6.144
    update_interval: 5s
web_server:
  port: 80
font:
display:
    i2c_id: bus_a
    address: 0x3C
    lambda: |-
download yaml file:
.txt   B24-HA-with-Tuya.txt (Size: 19.26 KB / Downloads: 412)
  B24M ESP32-S3 IO pins define
Posted by: admin - 07-31-2025, 06:49 AM - Forum: B24M - No Replies
IIC Bus:
SDA:GPIO8
SCL:GPIO18
PCF8575: (input1-16): i2c address:0x22 by B16-core
P8:input1
P9:input2
P10:input3
P11:input4
P12:input5
P13:input6
P14:input7
P15:input8
P0:input9
P1:input10
P2:input11
P3:input12
P4:input13
P5:input14
P6:input15
P7:input16
U4: PCF8575 i2c address:0x25
P0:input17
P1:input18
P2:input19
P3:input20
P4:input21
P5:input22
P6:input23
P7:input24
P8:output1
P9:output2
P10:output3
P11:output4
P12:output5
P13:output6
P14:output7
P15:output8
U2: PCF8575 i2c address:0x24
P0:output9
P1:output10
P2:output11
P3:output12
P4:output13
P5:output14
P6:output15
P7:output16
P8:output17
P9:output18
P10:output19
P11:output20
P12:output21
P13:output22
P14:output23
P15:output24
24C02 EPROM i2c address: 0x50
DS3231 RTC i2c address: 0x68
ADS1115 (4CH ADC) : i2c address:0x48
Analog input (A1: DC 0-5v)
Analog input (A2: DC 0-5v)
Analog input (A3: DC 4-20mA)
Analog input (A4: DC 4-20mA)
GPIO13
GPIO14
GPIO21
free GPIOs (with pull-up resistance on PCB):
GPIO40
GPIO48
GPIO47
GPIO7
Ethernet (W5500) I/O define:
clk_pin: GPIO1
mosi_pin: GPIO2
miso_pin: GPIO41
cs_pin: GPIO42
reset_pin: GPIO44
RS485:
RXD:GPIO38
TXD:GPIO39
Tuya module:
RXD:GPIO17
TXD:GPIO16
SD Card:
SPI-MOSI:GPIO10
SPI-SCK:GPIO11
SPI-MISO:GPIO12
SPI-CS:GPIO9
