» Members: 10,397
» Latest member: zolotoiflowers
» Forum threads: 4,319
» Forum posts: 21,294
There are currently 420 online users.
» 0 Member(s) | 393 Guest(s)
Amazonbot, Applebot, AwarioBot, Baidu, Bing, Bytespider, Crawl, Facebook, Google, HeadlessChrome, PetalBot, Twitter, bot, facebookexternalhit
KC868-A4 – Relay 1 clicks...
10 minutes ago
450 Hz allowed on input?
Forum: Development
11 minutes ago
How Do You Handle Relay C...
4 hours ago
"KCS" v3.27.4 firmware BI...
Today, 06:02 AM
how to check i2c extend c...
Forum: T16M
Today, 12:38 AM
T16M ESPHome yaml for hom...
Forum: T16M
Today, 12:35 AM
Last Post: viko
Yesterday, 01:42 PM
» Replies: 23
Recommended Dimmer for LE...
Yesterday, 08:21 AM
KC868-A16-V3.2: exact wir...
Forum: KC868-A16v3
Yesterday, 12:31 AM
ESPHome modbus not functi...
Forum: KC868-A8S
10-30-2026, 01:02 PM
  [arduino code examples for B32M]-07 how to DS3231 RTC clock
Posted by: admin - 07-31-2025, 07:02 AM - Forum: B32M - No Replies
* DS3231 RTC with Arduino
* Hardware Connections:
* - SDA: GPIO 8
* - SCL: GPIO 18
#include <DS3231.h>
#include <Wire.h>
typedef struct
  byte month;
  byte day;
  byte hour;
  byte minute;
  byte second;
} MY_DATE_STR;
#define OPEN_RLY_DATA    26
#define OPEN_RLY_MONTH   4
#define CLOSE_RLY_DATA   2
#define CLOSE_RLY_MONTH  5
// Define pin connections
#define SDA_PIN   8
#define SCL_PIN   18
bool h12Flag;
bool pmFlag;
static bool bCentury = false;
static void PrintfCurTime()
  Serial.print(year);
  Serial.print("-");
  Serial.print("-");
  Serial.print(" ");
  Serial.print(":");
  Serial.print(":");
static void GetSerialCmd()
  if (Serial.available() > 0)
    delay(100);
    while (num_read--)
  else return;
  serial_cmd_rcv.trim();
    PrintfCurTime();
    return;
  Serial.print("D index: ");
  Serial.print(indexof_d);
  Serial.print(" T index: ");
  Serial.println(indexof_t);
    return;
  rtc.setDate(my_date_str.day);
  Serial.println("Time set.");
  PrintfCurTime();
  while (Serial.read() >= 0) {}
  GetSerialCmd();
arduino ino file download:
.zip   7-DS3231-RTC.zip (Size: 1.51 KB / Downloads: 649)
.zip   7-DS3231-RTC.ino.merged.zip (Size: 193.66 KB / Downloads: 664)
  [arduino code examples for B24M]-06 How to use SD Card
Posted by: admin - 07-31-2025, 07:01 AM - Forum: B24M - No Replies
* SD Card File Operations
* - SCK: GPIO 11
* - MISO: GPIO 12
* - MOSI: GPIO 10
* - CS: GPIO 9
#include "FS.h"
#include "SD.h"
#include "SPI.h"
#define SCK  11
#define MISO 12
#define MOSI 10
#define CS   9
  File file = fs.open(path);
  if (!file) {
    return;
  while (file.available()) {
  file.close();
  if (!file) {
    return;
  if (file.print(message)) {
  file.close();
  if (!file) {
    return;
  file.close();
  if (fs.remove(path)) {
  static uint8_t buf[512];
  size_t len = 0;
  uint32_t start = millis();
  uint32_t end = start;
  if (file) {
    len = file.size();
    size_t flen = len;
    start = millis();
    while (len) {
      size_t toRead = len;
      if (toRead > 512) {
        toRead = 512;
      file.read(buf, toRead);
      len -= toRead;
    end = millis() - start;
    file.close();
  if (!file) {
    return;
  size_t i;
  start = millis();
  for (i = 0; i < 2048; i++) {
    file.write(buf, 512);
  file.close();
  // Initialize SPI and SD card
    return;
  if (cardType == CARD_NONE) {
    return;
  if (cardType == CARD_MMC) {
    Serial.println("MMC");
    Serial.println("SDSC");
    Serial.println("SDHC");
    Serial.println("UNKNOWN");
  delay(2000);
  // Perform file operations
  deleteFile(SD, "/hello.txt");
  readFile(SD, "/hello.txt");
  testFileIO(SD, "/test.txt");
  // No operation in loop
.zip   6-SD.zip (Size: 1.53 KB / Downloads: 643)
.zip   6-SD.ino.merged.zip (Size: 219.14 KB / Downloads: 653)
  [arduino code examples for B24]-06 How to use SD Card
Posted by: admin - 07-31-2025, 07:01 AM - Forum: B24 - No Replies
* - SCK: GPIO 11
* - MISO: GPIO 12
* - MOSI: GPIO 10
* - CS: GPIO 9
#include "FS.h"
#include "SD.h"
#include "SPI.h"
#define SCK  11
#define MISO 12
#define MOSI 10
#define CS   9
  if (!file) {
    return;
  file.close();
  if (!file) {
    return;
  file.close();
  if (!file) {
    return;
  file.close();
  size_t len = 0;
  if (file) {
    len = file.size();
    size_t flen = len;
    start = millis();
    while (len) {
      if (toRead > 512) {
        toRead = 512;
      len -= toRead;
    file.close();
  if (!file) {
    return;
  size_t i;
  start = millis();
  file.close();
    return;
    return;
  delay(2000);
.zip   6-SD.zip (Size: 1.53 KB / Downloads: 689)
.zip   6-SD.ino.merged.zip (Size: 219.14 KB / Downloads: 644)
  [arduino code examples for B32M]-06 How to use SD Card
Posted by: admin - 07-31-2025, 07:01 AM - Forum: B32M - No Replies
* - SCK: GPIO 11
* - MISO: GPIO 12
* - MOSI: GPIO 10
* - CS: GPIO 9
#include "FS.h"
#include "SD.h"
#include "SPI.h"
#define SCK  11
#define MISO 12
#define MOSI 10
#define CS   9
  if (!file) {
    return;
  file.close();
  if (!file) {
    return;
  file.close();
  if (!file) {
    return;
  file.close();
  size_t len = 0;
  if (file) {
    len = file.size();
    size_t flen = len;
    start = millis();
    while (len) {
      if (toRead > 512) {
        toRead = 512;
      len -= toRead;
    file.close();
  if (!file) {
    return;
  size_t i;
  start = millis();
  file.close();
    return;
    return;
  delay(2000);
.zip   6-SD.zip (Size: 1.53 KB / Downloads: 661)
.zip   6-SD.ino.merged.zip (Size: 219.14 KB / Downloads: 731)
  [arduino code examples for B24M]-05 Read free GPIO state
Posted by: admin - 07-31-2025, 07:00 AM - Forum: B24M - No Replies
* GPIO Status Monitoring
* GPIO Pins Monitored:
* - GPIO 13
* - GPIO 14
* - GPIO 21
* - GPIO 40
* - GPIO 48
* - GPIO 47
* - GPIO 7
* Hardware Requirements:
// Define the GPIO pins to be monitored
#define GPIO_PIN_13 13
#define GPIO_PIN_14 14
#define GPIO_PIN_21 21
#define GPIO_PIN_40 40
#define GPIO_PIN_48 48
#define GPIO_PIN_47 47
#define GPIO_PIN_7   7
// Create an array to hold the GPIO pin numbers
const int monitoredPins[] = {
  GPIO_PIN_13,
  GPIO_PIN_14,
  GPIO_PIN_21,
  GPIO_PIN_40,
  GPIO_PIN_48,
  GPIO_PIN_47,
  GPIO_PIN_7
const int pinCount = sizeof(monitoredPins) / sizeof(monitoredPins[0]);
bool prevState[pinCount] = {false};
  Serial.begin(115200);       // Initialize the serial monitor
  while (!Serial);            // Wait for serial monitor to open
  // Set each monitored pin as input
  for (int i = 0; i < pinCount; i++) {
    pinMode(monitoredPins[i], INPUT);
    bool currentState = digitalRead(monitoredPins[i]);
    if (currentState != prevState[i]) {
      Serial.print("GPIO ");
      Serial.print(monitoredPins[i]);
      Serial.print(" changed to ");
      Serial.println(currentState ? "HIGH" : "LOW");
      prevState[i] = currentState;
  delay(100); // Delay to reduce serial flooding
.zip   5-free-gpio-state.zip (Size: 924 bytes / Downloads: 645)
.zip   5-free-gpio-state.ino.merged.zip (Size: 181.63 KB / Downloads: 614)
  [arduino code examples for B24]-05 Read free GPIO state
Posted by: admin - 07-31-2025, 07:00 AM - Forum: B24 - No Replies
* - GPIO 13
* - GPIO 14
* - GPIO 21
* - GPIO 40
* - GPIO 48
* - GPIO 47
* - GPIO 7
  GPIO_PIN_13,
  GPIO_PIN_14,
  GPIO_PIN_21,
  GPIO_PIN_40,
  GPIO_PIN_48,
  GPIO_PIN_47,
  GPIO_PIN_7
.zip   5-free-gpio-state.zip (Size: 924 bytes / Downloads: 648)
.zip   5-free-gpio-state.ino.merged.zip (Size: 181.63 KB / Downloads: 601)
  [arduino code examples for B32M]-05 Read free GPIO state
Posted by: admin - 07-31-2025, 07:00 AM - Forum: B32M - No Replies
* - GPIO 13
* - GPIO 14
* - GPIO 21
* - GPIO 40
* - GPIO 48
* - GPIO 47
* - GPIO 7
  GPIO_PIN_13,
  GPIO_PIN_14,
  GPIO_PIN_21,
  GPIO_PIN_40,
  GPIO_PIN_48,
  GPIO_PIN_47,
  GPIO_PIN_7
.zip   5-free-gpio-state.zip (Size: 924 bytes / Downloads: 686)
.zip   5-free-gpio-state.ino.merged.zip (Size: 181.63 KB / Downloads: 655)
  [arduino code examples for B24M]-04 RS485 communication test
Posted by: admin - 07-31-2025, 06:58 AM - Forum: B24M - No Replies
* RS485 Communication Test
* The TXD pin is defined as GPIO 16 and RXD pin is defined as GPIO 17.
#include <HardwareSerial.h>
// Define RS485 pins
#define RS485_RXD 38
#define RS485_TXD 39
  while (!Serial);
  // Send a test message
  rs485Serial.println("Hello from KinCony B24!");
  // Wait for a short period
    String receivedMessage = "";
      char c = rs485Serial.read();
      receivedMessage += c;
    // Print the received message
    Serial.print("Received: ");
  delay(2000);
.zip   4-RS485-Test.zip (Size: 764 bytes / Downloads: 692)
.zip   4-RS485-Test.ino.merged.zip (Size: 186.53 KB / Downloads: 643)
  [arduino code examples for B24]-04 RS485 communication test
Posted by: admin - 07-31-2025, 06:58 AM - Forum: B24 - No Replies
  while (!Serial);
  delay(2000);
.zip   4-RS485-Test.zip (Size: 764 bytes / Downloads: 604)
.zip   4-RS485-Test.ino.merged.zip (Size: 186.53 KB / Downloads: 658)
  [arduino code examples for B32M]-04 RS485 communication test
Posted by: admin - 07-31-2025, 06:58 AM - Forum: B32M - No Replies
  while (!Serial);
  delay(2000);
.zip   4-RS485-Test.zip (Size: 764 bytes / Downloads: 662)
.zip   4-RS485-Test.ino.merged.zip (Size: 186.53 KB / Downloads: 684)
