» Members: 10,405
» Latest member: ll88tvcom
» Forum threads: 4,322
» Forum posts: 21,297
There are currently 593 online users.
» 1 Member(s) | 573 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bytespider, Crawl, Google, HeadlessChrome, PetalBot, bot, ll88tvcom
Today, 03:04 AM
Today, 01:34 AM
Today, 12:15 AM
KC868-A4 – Relay 1 clicks...
Yesterday, 09:42 PM
450 Hz allowed on input?
Forum: Development
Yesterday, 09:41 PM
How Do You Handle Relay C...
Yesterday, 05:41 PM
"KCS" v3.27.4 firmware BI...
Yesterday, 06:02 AM
how to check i2c extend c...
Forum: T16M
Yesterday, 12:38 AM
T16M ESPHome yaml for hom...
Forum: T16M
Yesterday, 12:35 AM
Last Post: viko
11-01-2026, 01:42 PM
» Replies: 23
  [arduino code examples for B24M]-04 RS485 communication test
Posted by: admin - 07-31-2025, 06:58 AM - Forum: B24M - No Replies
* RS485 Communication Test
* The TXD pin is defined as GPIO 16 and RXD pin is defined as GPIO 17.
#include <HardwareSerial.h>
// Define RS485 pins
#define RS485_RXD 38
#define RS485_TXD 39
  while (!Serial);
  // Send a test message
  rs485Serial.println("Hello from KinCony B24!");
  // Wait for a short period
    String receivedMessage = "";
      char c = rs485Serial.read();
      receivedMessage += c;
    // Print the received message
    Serial.print("Received: ");
  delay(2000);
arduino ino file download:
.zip   4-RS485-Test.zip (Size: 764 bytes / Downloads: 692)
.zip   4-RS485-Test.ino.merged.zip (Size: 186.53 KB / Downloads: 643)
  [arduino code examples for B24]-04 RS485 communication test
Posted by: admin - 07-31-2025, 06:58 AM - Forum: B24 - No Replies
  while (!Serial);
  delay(2000);
.zip   4-RS485-Test.zip (Size: 764 bytes / Downloads: 604)
.zip   4-RS485-Test.ino.merged.zip (Size: 186.53 KB / Downloads: 658)
  [arduino code examples for B32M]-04 RS485 communication test
Posted by: admin - 07-31-2025, 06:58 AM - Forum: B32M - No Replies
  while (!Serial);
  delay(2000);
.zip   4-RS485-Test.zip (Size: 764 bytes / Downloads: 663)
.zip   4-RS485-Test.ino.merged.zip (Size: 186.53 KB / Downloads: 684)
  [arduino code examples for B24M]-03 Read ADS1115 analog input ports value
Posted by: admin - 07-31-2025, 06:57 AM - Forum: B24M - No Replies
#define SDA_PIN 8
#define SCL_PIN 18
DFRobot_ADS1115 ads(&Wire);
void setup(void)
    Wire.begin(SDA_PIN, SCL_PIN);
    ads.setGain(eGAIN_TWOTHIRDS);
    ads.setMode(eMODE_SINGLE);
    ads.setRate(eRATE_128);
    ads.init();
void loop(void)
    if (ads.checkADS1115())
        adc0 = ads.readVoltage(0);
        Serial.print("A0:");
        Serial.print(adc0);
        adc1 = ads.readVoltage(1);
        Serial.print("A1:");
        Serial.print(adc1);
        adc2 = ads.readVoltage(2);
        Serial.print("A2:");
        Serial.print(adc2);
        adc3 = ads.readVoltage(3);
        Serial.print("A3:");
        Serial.print(adc3);
    else
.zip   3-ads1115_adc.zip (Size: 1.2 KB / Downloads: 636)
.zip   3-ads1115_adc.ino.merged.zip (Size: 192.69 KB / Downloads: 646)
  [arduino code examples for B24]-03 Read ADS1115 analog input ports value
Posted by: admin - 07-31-2025, 06:57 AM - Forum: B24 - No Replies
#define SDA_PIN 8
#define SCL_PIN 18
void setup(void)
    ads.init();
void loop(void)
        Serial.print(adc0);
        Serial.print(adc1);
        Serial.print(adc2);
        Serial.print(adc3);
    else
.zip   3-ads1115_adc.zip (Size: 1.2 KB / Downloads: 693)
.zip   3-ads1115_adc.ino.merged.zip (Size: 192.69 KB / Downloads: 672)
  [arduino code examples for B32M]-03 Read ADS1115 analog input ports value
Posted by: admin - 07-31-2025, 06:57 AM - Forum: B32M - No Replies
#define SDA_PIN 8
#define SCL_PIN 18
void setup(void)
    ads.init();
void loop(void)
        Serial.print(adc0);
        Serial.print(adc1);
        Serial.print(adc2);
        Serial.print(adc3);
    else
.zip   3-ads1115_adc.zip (Size: 1.2 KB / Downloads: 725)
.zip   3-ads1115_adc.ino.merged.zip (Size: 192.69 KB / Downloads: 662)
  [arduino code examples for B24M]-02 Read digital input ports state
Posted by: admin - 07-31-2025, 06:55 AM - Forum: B24M - No Replies
* Description:
* This Arduino program reads the state of two 16-channel PCF8575 I/O expanders
* and prints the state of all input pins (1-24) to the Serial Monitor.
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* - PCF8575 I2C Address: 0x22 for inputs 1-16, 0x25 for inputs 17-24
#include "Arduino.h"
#include "PCF8575.h"
// Define I2C pins
// Set I2C addresses
PCF8575 pcf8575_IN1(0x22); // The I2C address of the first PCF8575 (inputs 1-16)
PCF8575 pcf8575_IN2(0x25); // The I2C address of the second PCF8575 (inputs 17-24)
    // Initialize both PCF8575 modules
    pcf8575_IN1.begin();
    pcf8575_IN2.begin();
    Serial.println("KinCony B24 24 channel input state 0:ON  1:OFF");
if (pcf8575_IN1.read(8)==0) {Serial.print("DI1 state="); Serial.println("on");}
if (pcf8575_IN1.read(9)==0) {Serial.print("DI2 state="); Serial.println("on");}
if (pcf8575_IN1.read(10)==0) {Serial.print("DI3 state="); Serial.println("on");}
if (pcf8575_IN1.read(11)==0) {Serial.print("DI4 state="); Serial.println("on");}
if (pcf8575_IN1.read(12)==0) {Serial.print("DI5 state="); Serial.println("on");}
if (pcf8575_IN1.read(13)==0) {Serial.print("DI6 state="); Serial.println("on");}
if (pcf8575_IN1.read(14)==0) {Serial.print("DI7 state="); Serial.println("on");}
if (pcf8575_IN1.read(15)==0) {Serial.print("DI8 state="); Serial.println("on");}
if (pcf8575_IN1.read(0)==0) {Serial.print("DI9 state="); Serial.println("on");}
if (pcf8575_IN1.read(1)==0) {Serial.print("DI10 state="); Serial.println("on");}
if (pcf8575_IN1.read(2)==0) {Serial.print("DI11 state="); Serial.println("on");}
if (pcf8575_IN1.read(3)==0) {Serial.print("DI12 state="); Serial.println("on");}
if (pcf8575_IN1.read(4)==0) {Serial.print("DI13 state="); Serial.println("on");}
if (pcf8575_IN1.read(5)==0) {Serial.print("DI14 state="); Serial.println("on");}
if (pcf8575_IN1.read(6)==0) {Serial.print("DI15 state="); Serial.println("on");}
if (pcf8575_IN1.read(7)==0) {Serial.print("DI16 state="); Serial.println("on");}
if (pcf8575_IN2.read(0)==0) {Serial.print("DI17 state="); Serial.println("on");}
if (pcf8575_IN2.read(1)==0) {Serial.print("DI18 state="); Serial.println("on");}
if (pcf8575_IN2.read(2)==0) {Serial.print("DI19 state="); Serial.println("on");}
if (pcf8575_IN2.read(3)==0) {Serial.print("DI20 state="); Serial.println("on");}
if (pcf8575_IN2.read(4)==0) {Serial.print("DI21 state="); Serial.println("on");}
if (pcf8575_IN2.read(5)==0) {Serial.print("DI22 state="); Serial.println("on");}
if (pcf8575_IN2.read(6)==0) {Serial.print("DI23 state="); Serial.println("on");}
if (pcf8575_IN2.read(7)==0) {Serial.print("DI24 state="); Serial.println("on");}
    delay(1000); // Delay 500ms
.zip   2-digital-input.zip (Size: 880 bytes / Downloads: 646)
.zip   2-digital-input.ino.merged.zip (Size: 192.64 KB / Downloads: 642)
  [arduino code examples for B24]-02 Read digital input ports state
Posted by: admin - 07-31-2025, 06:55 AM - Forum: B24 - No Replies
* Description:
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
// Define I2C pins
.zip   2-digital-input.zip (Size: 880 bytes / Downloads: 643)
.zip   2-digital-input.ino.merged.zip (Size: 192.64 KB / Downloads: 630)
  [arduino code examples for B32M]-02 Read digital input ports state
Posted by: admin - 07-31-2025, 06:55 AM - Forum: B32M - No Replies
* Description:
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
// Define I2C pins
PCF8575 pcf8575_IN3(0x26); // The I2C address of the second PCF8575 (inputs 25-32)
    pcf8575_IN3.begin();
    Serial.println("KinCony B32 32 channel input state 0:ON  1:OFF");
if (pcf8575_IN3.read(0)==0) {Serial.print("DI25 state="); Serial.println("on");}
if (pcf8575_IN3.read(1)==0) {Serial.print("DI26 state="); Serial.println("on");}
if (pcf8575_IN3.read(2)==0) {Serial.print("DI27 state="); Serial.println("on");}
if (pcf8575_IN3.read(3)==0) {Serial.print("DI28 state="); Serial.println("on");}
if (pcf8575_IN3.read(4)==0) {Serial.print("DI29 state="); Serial.println("on");}
if (pcf8575_IN3.read(5)==0) {Serial.print("DI30 state="); Serial.println("on");}
if (pcf8575_IN3.read(6)==0) {Serial.print("DI31 state="); Serial.println("on");}
if (pcf8575_IN3.read(7)==0) {Serial.print("DI32 state="); Serial.println("on");}
.zip   2-digital-input.zip (Size: 942 bytes / Downloads: 353)
.zip   2-digital-input.ino.merged.zip (Size: 198.36 KB / Downloads: 404)
  [arduino code examples for B24M]-01 Turn ON/OFF OUTPUT
Posted by: admin - 07-31-2025, 06:54 AM - Forum: B24M - No Replies
* This program controls a 24-channel relay board via two PCF8575 I/O expanders.
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* Delay Time:
#define SDA 8            // Define the SDA pin
#define SCL 18           // Define the SCL pin
// Set I2C addresses of the PCF8575 modules
#define I2C_ADDRESS_R1 0x25 // I2C address of the first PCF8575 module
#define I2C_ADDRESS_R2 0x24 // I2C address of the second PCF8575 module
PCF8575 pcf8575_R1(I2C_ADDRESS_R1); // Create a PCF8575 object for the first module (for relays 9-24)
PCF8575 pcf8575_R2(I2C_ADDRESS_R2); // Create a PCF8575 object for the second module (for relays 1-8)
  // Initialize the PCF8575 modules
  pcf8575_R1.begin();
  pcf8575_R2.begin();
    pcf8575_R1.write(i, HIGH); // Set relays 1-8 to OFF (assuming HIGH means OFF for relays)
    pcf8575_R2.write(i, HIGH); // Set relays 9-24 to OFF (assuming HIGH means OFF for relays)
  // Sequentially turn on each relay (1-24)
  // First control the relays on the second PCF8575 (relays 1-8)
  // Then control the relays on the first PCF8575 (relays 9-24)
    pcf8575_R2.write(i, LOW);   // Turn on the relay at pin i (LOW means ON for the relay)
  // Sequentially turn off each relay (1-24)
    pcf8575_R2.write(i, HIGH);  // Turn off the relay at pin i (HIGH means OFF for the relay)
.zip   1-relay.zip (Size: 1.01 KB / Downloads: 681)
.zip   1-relay.ino.merged.zip (Size: 192.11 KB / Downloads: 639)
