» Members: 10,397
» Latest member: zolotoiflowers
» Forum threads: 4,318
» Forum posts: 21,290
There are currently 51 online users.
» 0 Member(s) | 37 Guest(s)
Amazonbot, AwarioBot, PetalBot, Yandex, bot
How Do You Handle Relay C...
2 hours ago
450 Hz allowed on input?
Forum: Development
6 hours ago
"KCS" v3.27.4 firmware BI...
Today, 06:02 AM
how to check i2c extend c...
Forum: T16M
Today, 12:38 AM
T16M ESPHome yaml for hom...
Forum: T16M
Today, 12:35 AM
Last Post: viko
Yesterday, 01:42 PM
» Replies: 23
Recommended Dimmer for LE...
Yesterday, 08:21 AM
KC868-A16-V3.2: exact wir...
Forum: KC868-A16v3
Yesterday, 12:31 AM
ESPHome modbus not functi...
Forum: KC868-A8S
10-30-2026, 01:02 PM
SSD not visible for insta...
Forum: Pi5R16
10-29-2026, 12:30 PM
» Replies: 20
  "KCS" v3.11.3 firmware BIN file download
Posted by: admin - 08-04-2025, 12:43 AM - Forum: "KCS" v3 firmware - Replies (2)
v3.11.3 improvement:
1. added support for Z1,N60,T32M,T64M,T128M.
2. IFTTT support DO as IF condition.
3. support copy learned IR signal for new IR button.
4. tuya license support new "Singapore" server location.
5. fixed bug with HAv2 board when RisingEdge/FallingEdge= EvtTog control DO wrongly.
6. Optimize G1 SIM7600 suspension speed.
7. Fix the issue of DS18B20 occasionally reading incorrect data.
8. Fix the issue where Tuya license can't communicate through the SIM7600E 4G module.
9. Fix Monitor page does not display Tuya connectivity status correctly when using 4G communication.
10. support Tuya module select different product ID.
new board first time downloaded firmware, start up need about 10--30 seconds. next time start up about 5 seconds.
.zip   KCS_A2V3_V3.11.3.zip (Size: 1.06 MB / Downloads: 710)
.zip   KCS_A6V3_V3.11.3.zip (Size: 1.03 MB / Downloads: 753)
.zip   KCS_A8V3_V3.11.3.zip (Size: 1.09 MB / Downloads: 709)
.zip   KCS_A16V3_V3.11.3.zip (Size: 1.11 MB / Downloads: 815)
.zip   KCS_A32PRO_V3.11.3.zip (Size: 1.07 MB / Downloads: 698)
.zip   KCS_AG8_V3.11.3.zip (Size: 1.06 MB / Downloads: 754)
.zip   KCS_ALR_V3.11.3.zip (Size: 1.02 MB / Downloads: 671)
.zip   KCS_B8M_V3.11.3.zip (Size: 1.1 MB / Downloads: 695)
.zip   KCS_B16_V3.11.3.zip (Size: 1.1 MB / Downloads: 717)
.zip   KCS_B16M_V3.11.3.zip (Size: 1.1 MB / Downloads: 716)
.zip   KCS_F8_V3.11.3.zip (Size: 1.09 MB / Downloads: 712)
.zip   KCS_F16_V3.11.3.zip (Size: 1.1 MB / Downloads: 778)
.zip   KCS_F24_V3.11.3.zip (Size: 1.1 MB / Downloads: 685)
.zip   KCS_G1_V3.11.3.zip (Size: 1.06 MB / Downloads: 744)
.zip   KCS_KC_TA_V3.11.3.zip (Size: 1.05 MB / Downloads: 749)
.zip   KCS_N60_V3.11.3.zip (Size: 1.09 MB / Downloads: 671)
.zip   KCS_T16M_V3.11.3.zip (Size: 1.05 MB / Downloads: 675)
.zip   KCS_T32M_V3.11.3.zip (Size: 1.07 MB / Downloads: 715)
.zip   KCS_T64M_V3.11.3.zip (Size: 1.07 MB / Downloads: 702)
.zip   KCS_T128M_V3.11.3.zip (Size: 1.07 MB / Downloads: 781)
.zip   KCS_Z1_V3.11.3.zip (Size: 1.21 MB / Downloads: 678)
  [Help] KC868-A16 stopped working with ESPhome
Posted by: johnsmith8439 - 08-03-2025, 05:44 PM - Forum: KC868-A16 - Replies (10)
My KC868-A16 stopped working with ESPHome. There is power, but there is no network connection. I can still flash directly with USB-C port.
Here is the esphome logs:
.txt   logs.txt (Size: 60.45 KB / Downloads: 553)
.txt   logs (1).txt (Size: 28.23 KB / Downloads: 412)
  N60 N30 N20 N10 firmware BL0910 energy chip register RAW data structure
Posted by: admin - 08-03-2025, 03:31 AM - Forum: N60 - Replies (2)
Posted by: admin - 08-03-2025, 03:31 AM - Forum: N10 - Replies (2)
Posted by: admin - 08-03-2025, 03:31 AM - Forum: N20 - Replies (2)
Posted by: admin - 08-03-2025, 03:31 AM - Forum: N30 - Replies (2)
  [arduino code examples for N60]-05 collect N60 all data demo
Posted by: admin - 08-03-2025, 03:27 AM - Forum: N60 - No Replies
* Demo Program for Reading Data from KinCony N60 Energy Meter (60-channel version)
* via RS485 Modbus using ESP32 and NonBlockingModbusMaster library.
* This example:
* - Initializes RS485 Modbus communication
* - Reads current, power, energy, voltage, frequency, temperature, power factor from 6 chips
* - Prints all data to Serial Monitor
* - Uses TaskScheduler to run periodic tasks
#include "TaskScheduler.h"
#include "HardwareSerial.h"
//#include "modbus-rtu.h"
#include "NonBlockingModbusMaster.h"  // Include non-blocking Modbus master library
/////defined anything here====================
#define MAX_U16DATA_LEN  68  // Number of 16-bit registers to read per chip
// Define RS485 serial and control pins
#define TX_PIN 8
#define DE_PIN 3
#define RX_PIN 18
// Define Modbus function codes
typedef enum{
  FC_READ_COIL = 1,
  FC_READ_HOLDREG = 3,
  FC_READ_INPUTREG = 4,
  FC_FORCE_COIL = 5,
  FC_FORCE_COILS = 15,
  FC_WRITE_REG = 6,
  FC_WRITE_REGS = 16,
}FC_DEF;
// Define structure to hold all the electrical parameters per chip
typedef struct
    uint32_t RMS_1;        //0    //XX.XXX    A        0.001A/LSB
    uint32_t RMS_2;
    uint32_t RMS_3;
    uint32_t RMS_4;
    uint32_t RMS_5;
    uint32_t RMS_6;
    uint32_t RMS_7;
    uint32_t RMS_8;
    uint32_t RMS_9;
    uint32_t RMS_10;
    uint32_t WATT_1;        //20 XXXX.X    W        0.1W/LSB
    uint32_t WATT_2;
    uint32_t WATT_3;
    uint32_t WATT_4;
    uint32_t WATT_5;
    uint32_t WATT_6;
    uint32_t WATT_7;
    uint32_t WATT_8;
    uint32_t WATT_9;
    uint32_t WATT_10;//
    uint32_t Energy_1;        //40 XXXXXX    kWh   1kWh/LSB,MAX:65535kWh
    uint32_t Energy_2;
    uint32_t Energy_3;
    uint32_t Energy_4;
    uint32_t Energy_5;
    uint32_t Energy_6;
    uint32_t Energy_7;
    uint32_t Energy_8;
    uint32_t Energy_9;
    uint32_t Energy_10; //
    uint32_t Energy_Sum; //60
    uint16_t RMS_V;            //62 XXX.X    V            0.01V/LSB
    uint16_t Period;        //63 XX.XX    Hz        0.01Hz/LSB
    float TPS1;            //64 XX.XX ℃            0.1℃/LSB
    float PF;  //66
}Elect_StructDef_JKE;
typedef union{
  Elect_StructDef_JKE jke_n60_str[6]; ////6 chips each have MAX_STRU_LEN data
  ushort read_regs_arr[6][MAX_U16DATA_LEN];
}COLLECT_UNION;
////define instance here================================================================
COLLECT_UNION jke_n60_data_union = {0};
HardwareSerial collectSerial(2);
Scheduler ts;   // Task scheduler
NonBlockingModbusMaster nbModbusMaster;
////define macros here===================
static void collectAllChipData();
static void PrintfInfo();
////define my work task==================================
Task collectDataTask(200,TASK_FOREVER,[]()
Task heartBeatTask(1000,TASK_FOREVER,[]()
  ////do anything in heartBeatTask to make sense for anyone or other.
  Serial.println("heartbeat task is running.");
  // Open serial communications and wait for port to open:
    collectSerial.begin(115200,SERIAL_8N1,9,10);///RX & TX
    float bitduration = 1.f / 115200;
    float charlen = 10.0f; // 8 bits + 1 stop, parity ?
    float preDelayBR = bitduration * charlen * 3.5f * 1e6  + 1; // in us
    float postDelayBR = bitduration * charlen * 3.5f * 1e6 + 1; // in us
    nbModbusMaster.initialize(collectSerial, preDelayBR, postDelayBR,1000);
  ////add task to scheduler
  ts.addTask(collectDataTask);
  ts.addTask(heartBeatTask);
  ////start task
  collectDataTask.enable(); ///start task
  heartBeatTask.enable();
bool isMbConnect = false;
int cnt_chip = 0;
  static int retryCount = 0;
  ts.execute();
  if (nbModbusMaster.justFinished())
    // check for errors
    int err = nbModbusMaster.getError(); // 0 for OK
    if (err) {
      Serial.print("Error: "); nbModbusMaster.printHex(err, Serial); Serial.println();
      if ((err == nbModbusMaster.ku8MBResponseTimedOut) ) {
        retryCount++;
        Serial.println("Mbtask Retry");
        nbModbusMaster.retry(); // send same cmd again
      retryCount = 0; // success
    if (err == 0) {
      isMbConnect = true;
      if(cnt_chip==5)
        PrintfInfo();
      for (int i = 0; i < nbModbusMaster.getResponseBufferLength(); i++) {
        jke_n60_data_union.read_regs_arr[cnt_chip][i] = nbModbusMaster.getResponseBuffer(i);
        //nbModbusMaster.printHex(nbModbusMaster.getResponseBuffer(i), Serial); Serial.print(" ");
      cnt_chip++;
      if(cnt_chip >= 6) cnt_chip = 0;
  char send_buf[100] = {0};
  uint32_t *ptr;
  uint16_t *ptr2;
  float *ptr3;
  memset(send_buf,0,100);
    ///// PRINTF ALL DATA READ FROM CHIP REGISTER.
    for(int j=0;j<6;j++)
    sprintf(send_buf,">>chip/socket : %d Info:",j+1);
    Serial.println(send_buf);
    ptr= &jke_n60_data_union.jke_n60_str[j].RMS_1;
    ptr2 = &jke_n60_data_union.jke_n60_str[j].RMS_V;
    ptr3 = &jke_n60_data_union.jke_n60_str[j].TPS1;
    for(int i=0;i<35;i++)
      if(i < 10)
        sprintf(send_buf,"RMS_%d:    %.2f A,",i+1,*(ptr+i) * 0.001);
      else if(i < 20)
        sprintf(send_buf,"WATT_%d:    %.2f W,",i+1-10,*(ptr+i) * 0.1);
      else if(i < 30)
        sprintf(send_buf,"Energy_%d:    %d kWh,",i+1-20,*(ptr+i) );
      else if(i == 30)
        sprintf(send_buf,"Energy_sum:    %d kWh,",*(ptr+i) );
      else if(i == 31)
        sprintf(send_buf,"RMS_V:    %.2f V,",*ptr2 *0.01); ///62
      else if(i == 32)
        sprintf(send_buf,"Period:    %.2f Hz,",*(ptr2+1) *0.01);
      else if(i == 33)
        sprintf(send_buf,"Chip_Temp:    %.1f ^C,",*ptr3  );
      else if(i == 34)
        sprintf(send_buf,"PF:    %.4f .",*(ptr3+1) );
    if(j==5)
      Serial.println(">>Data Finished!>>");
  int read_addr_start = (cnt_chip+1) * 100;
  String str = "";
  uint16_t size = MAX_U16DATA_LEN;
  nbModbusMaster.readHoldingRegisters(1, read_addr_start, size);
arduino ino file download:
.zip   collect_n60_data_demo.zip (Size: 2.45 KB / Downloads: 626)
.zip   collect_n60_data_demo.ino.merged.zip (Size: 189.94 KB / Downloads: 676)
before run the code, you need to install NonBlockingModbusMaster arduino library.
modify library .h file replace the number as photo.
after running code, will print all data by USB port:
y_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
RMS_V:    233.58 V,
Period:    49.70 Hz,
Chip_Temp:    25.5 ^C,
PF:    0.0000 .
>>Data Finished!>>
>>chip/socket : 1 Info:
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    24.4 ^C,
PF:    0.0000 .
>>chip/socket : 2 Info:
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    23.8 ^C,
PF:    0.0000 .
>>chip/socket : 3 Info:
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    25.0 ^C,
PF:    0.0000 .
>>chip/socket : 4 Info:
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    23.8 ^C,
PF:    0.0000 .
>>chip/socket : 5 Info:
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    25.5 ^C,
PF:    0.0000 .
>>chip/socket : 6 Info:
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    3.20 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    233.50 V,
Period:    49.71 Hz,
Chip_Temp:    25.7 ^C,
PF:    0.0000 .
>>Data Finished!>>
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    24.2 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    23.8 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    25.0 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    23.6 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    24.8 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    1.50 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    233.57 V,
Period:    49.71 Hz,
Chip_Temp:    25.5 ^C,
PF:    0.0000 .
>>Data Finished!>>
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    24.0 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    23.8 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    25.3 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    23.6 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    25.3 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    1.50 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    233.49 V,
Period:    49.71 Hz,
Chip_Temp:    25.7 ^C,
PF:    0.0000 .
>>Data Finished!>>
  [arduino code examples for N10]-05 collect N10 all data demo
Posted by: admin - 08-03-2025, 03:27 AM - Forum: N10 - No Replies
* This example:
#define TX_PIN 8
#define DE_PIN 3
#define RX_PIN 18
typedef enum{
  FC_READ_COIL = 1,
  FC_FORCE_COIL = 5,
  FC_WRITE_REG = 6,
  FC_WRITE_REGS = 16,
}FC_DEF;
typedef struct
    uint32_t RMS_2;
    uint32_t RMS_3;
    uint32_t RMS_4;
    uint32_t RMS_5;
    uint32_t RMS_6;
    uint32_t RMS_7;
    uint32_t RMS_8;
    uint32_t RMS_9;
    uint32_t RMS_10;
    uint32_t WATT_2;
    uint32_t WATT_3;
    uint32_t WATT_4;
    uint32_t WATT_5;
    uint32_t WATT_6;
    uint32_t WATT_7;
    uint32_t WATT_8;
    uint32_t WATT_9;
    uint32_t WATT_10;//
    uint32_t Energy_2;
    uint32_t Energy_3;
    uint32_t Energy_4;
    uint32_t Energy_5;
    uint32_t Energy_6;
    uint32_t Energy_7;
    uint32_t Energy_8;
    uint32_t Energy_9;
    float PF;  //66
typedef union{
}COLLECT_UNION;
  ////start task
int cnt_chip = 0;
  ts.execute();
    // check for errors
    if (err) {
        retryCount++;
    if (err == 0) {
      isMbConnect = true;
      if(cnt_chip==5)
        PrintfInfo();
      cnt_chip++;
  uint32_t *ptr;
  uint16_t *ptr2;
  float *ptr3;
      if(i < 10)
      else if(i < 20)
      else if(i < 30)
      else if(i == 30)
      else if(i == 31)
      else if(i == 32)
      else if(i == 33)
      else if(i == 34)
    if(j==5)
  String str = "";
.zip   collect_n60_data_demo.zip (Size: 2.45 KB / Downloads: 727)
.zip   collect_n60_data_demo.ino.merged.zip (Size: 189.94 KB / Downloads: 732)
y_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
RMS_V:    233.58 V,
Period:    49.70 Hz,
Chip_Temp:    25.5 ^C,
PF:    0.0000 .
>>Data Finished!>>
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    24.4 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    23.8 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    25.0 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    23.8 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    25.5 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    3.20 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    233.50 V,
Period:    49.71 Hz,
Chip_Temp:    25.7 ^C,
PF:    0.0000 .
>>Data Finished!>>
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    24.2 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    23.8 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    25.0 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    23.6 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    24.8 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    1.50 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    233.57 V,
Period:    49.71 Hz,
Chip_Temp:    25.5 ^C,
PF:    0.0000 .
>>Data Finished!>>
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    24.0 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    23.8 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    25.3 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    23.6 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    25.3 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    1.50 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    233.49 V,
Period:    49.71 Hz,
Chip_Temp:    25.7 ^C,
PF:    0.0000 .
>>Data Finished!>>
  [arduino code examples for N20]-05 collect N20 all data demo
Posted by: admin - 08-03-2025, 03:27 AM - Forum: N20 - No Replies
* This example:
#define TX_PIN 8
#define DE_PIN 3
#define RX_PIN 18
typedef enum{
  FC_READ_COIL = 1,
  FC_FORCE_COIL = 5,
  FC_WRITE_REG = 6,
  FC_WRITE_REGS = 16,
}FC_DEF;
typedef struct
    uint32_t RMS_2;
    uint32_t RMS_3;
    uint32_t RMS_4;
    uint32_t RMS_5;
    uint32_t RMS_6;
    uint32_t RMS_7;
    uint32_t RMS_8;
    uint32_t RMS_9;
    uint32_t RMS_10;
    uint32_t WATT_2;
    uint32_t WATT_3;
    uint32_t WATT_4;
    uint32_t WATT_5;
    uint32_t WATT_6;
    uint32_t WATT_7;
    uint32_t WATT_8;
    uint32_t WATT_9;
    uint32_t WATT_10;//
    uint32_t Energy_2;
    uint32_t Energy_3;
    uint32_t Energy_4;
    uint32_t Energy_5;
    uint32_t Energy_6;
    uint32_t Energy_7;
    uint32_t Energy_8;
    uint32_t Energy_9;
    float PF;  //66
typedef union{
}COLLECT_UNION;
  ////start task
int cnt_chip = 0;
  ts.execute();
    // check for errors
    if (err) {
        retryCount++;
    if (err == 0) {
      isMbConnect = true;
      if(cnt_chip==5)
        PrintfInfo();
      cnt_chip++;
  uint32_t *ptr;
  uint16_t *ptr2;
  float *ptr3;
      if(i < 10)
      else if(i < 20)
      else if(i < 30)
      else if(i == 30)
      else if(i == 31)
      else if(i == 32)
      else if(i == 33)
      else if(i == 34)
    if(j==5)
  String str = "";
.zip   collect_n60_data_demo.zip (Size: 2.45 KB / Downloads: 679)
.zip   collect_n60_data_demo.ino.merged.zip (Size: 189.94 KB / Downloads: 724)
y_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
RMS_V:    233.58 V,
Period:    49.70 Hz,
Chip_Temp:    25.5 ^C,
PF:    0.0000 .
>>Data Finished!>>
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    24.4 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    23.8 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    25.0 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    23.8 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    25.5 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    3.20 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    233.50 V,
Period:    49.71 Hz,
Chip_Temp:    25.7 ^C,
PF:    0.0000 .
>>Data Finished!>>
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    24.2 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    23.8 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    25.0 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    23.6 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    24.8 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    1.50 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    233.57 V,
Period:    49.71 Hz,
Chip_Temp:    25.5 ^C,
PF:    0.0000 .
>>Data Finished!>>
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    24.0 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    23.8 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    25.3 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    23.6 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    25.3 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    1.50 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    233.49 V,
Period:    49.71 Hz,
Chip_Temp:    25.7 ^C,
PF:    0.0000 .
>>Data Finished!>>
  [arduino code examples for N30]-05 collect N30 all data demo
Posted by: admin - 08-03-2025, 03:27 AM - Forum: N30 - No Replies
* This example:
#define TX_PIN 8
#define DE_PIN 3
#define RX_PIN 18
typedef enum{
  FC_READ_COIL = 1,
  FC_FORCE_COIL = 5,
  FC_WRITE_REG = 6,
  FC_WRITE_REGS = 16,
}FC_DEF;
typedef struct
    uint32_t RMS_2;
    uint32_t RMS_3;
    uint32_t RMS_4;
    uint32_t RMS_5;
    uint32_t RMS_6;
    uint32_t RMS_7;
    uint32_t RMS_8;
    uint32_t RMS_9;
    uint32_t RMS_10;
    uint32_t WATT_2;
    uint32_t WATT_3;
    uint32_t WATT_4;
    uint32_t WATT_5;
    uint32_t WATT_6;
    uint32_t WATT_7;
    uint32_t WATT_8;
    uint32_t WATT_9;
    uint32_t WATT_10;//
    uint32_t Energy_2;
    uint32_t Energy_3;
    uint32_t Energy_4;
    uint32_t Energy_5;
    uint32_t Energy_6;
    uint32_t Energy_7;
    uint32_t Energy_8;
    uint32_t Energy_9;
    float PF;  //66
typedef union{
}COLLECT_UNION;
  ////start task
int cnt_chip = 0;
  ts.execute();
    // check for errors
    if (err) {
        retryCount++;
    if (err == 0) {
      isMbConnect = true;
      if(cnt_chip==5)
        PrintfInfo();
      cnt_chip++;
  uint32_t *ptr;
  uint16_t *ptr2;
  float *ptr3;
      if(i < 10)
      else if(i < 20)
      else if(i < 30)
      else if(i == 30)
      else if(i == 31)
      else if(i == 32)
      else if(i == 33)
      else if(i == 34)
    if(j==5)
  String str = "";
.zip   collect_n60_data_demo.zip (Size: 2.45 KB / Downloads: 662)
.zip   collect_n60_data_demo.ino.merged.zip (Size: 189.94 KB / Downloads: 655)
y_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
RMS_V:    233.58 V,
Period:    49.70 Hz,
Chip_Temp:    25.5 ^C,
PF:    0.0000 .
>>Data Finished!>>
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    24.4 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    23.8 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    25.0 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    23.8 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    25.5 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    3.20 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    233.50 V,
Period:    49.71 Hz,
Chip_Temp:    25.7 ^C,
PF:    0.0000 .
>>Data Finished!>>
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    24.2 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    23.8 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    25.0 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    23.6 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    24.8 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    1.50 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    233.57 V,
Period:    49.71 Hz,
Chip_Temp:    25.5 ^C,
PF:    0.0000 .
>>Data Finished!>>
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    24.0 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    23.8 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    25.3 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    23.6 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    0.00 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    0.00 V,
Period:    9.53 Hz,
Chip_Temp:    25.3 ^C,
PF:    0.0000 .
RMS_1:    0.00 A,
RMS_2:    0.00 A,
RMS_3:    0.00 A,
RMS_4:    0.00 A,
RMS_5:    0.00 A,
RMS_6:    0.00 A,
RMS_7:    0.00 A,
RMS_8:    0.00 A,
RMS_9:    0.00 A,
RMS_10:    0.00 A,
WATT_1:    0.00 W,
WATT_2:    1.50 W,
WATT_3:    0.00 W,
WATT_4:    0.00 W,
WATT_5:    0.00 W,
WATT_6:    0.00 W,
WATT_7:    0.00 W,
WATT_8:    0.00 W,
WATT_9:    0.00 W,
WATT_10:    0.00 W,
Energy_1:    0 kWh,
Energy_2:    0 kWh,
Energy_3:    0 kWh,
Energy_4:    0 kWh,
Energy_5:    0 kWh,
Energy_6:    0 kWh,
Energy_7:    0 kWh,
Energy_8:    0 kWh,
Energy_9:    0 kWh,
Energy_10:    0 kWh,
Energy_sum:    0 kWh,
RMS_V:    233.49 V,
Period:    49.71 Hz,
Chip_Temp:    25.7 ^C,
PF:    0.0000 .
>>Data Finished!>>
