» Members: 10,452
» Forum threads: 4,326
» Forum posts: 21,312
There are currently 13 online users.
» 0 Member(s) | 7 Guest(s)
Amazonbot, Baidu, bot
kc868-a6 analog input
Yesterday, 09:56 AM
F24 ESPHome yaml for home...
Forum: F24
Yesterday, 07:25 AM
Forum: F24
Yesterday, 05:35 AM
Forum: F24
Yesterday, 05:33 AM
[Arduino source code for ...
Forum: KC868-A2
Yesterday, 05:31 AM
KC868-A4 – Relay 1 clicks...
11-03-2026, 11:58 PM
11-03-2026, 07:34 PM
» Replies: 24
11-03-2026, 03:04 AM
11-03-2026, 01:34 AM
11-03-2026, 12:15 AM
  Not able to upload arduino code to A16v3 board
Posted by: ematicenergies - 04-09-2025, 01:14 PM - Forum: KC868-A16v3 - Replies (10)
I am using a kincony A16v3 board for my project. I have tried to upload my arduino code to the board. But the code is not uploading. I have powered the board with 12v supply. And have connected the board to my pc via usb type c cable.
Chosen nodemcu 32s in boards. But its not working. How to check what have gone wrong ?. Or if any further details required, let me know
Question A16v3 low voltage inputs
Posted by: jaydubnz - 04-09-2025, 05:58 AM - Forum: KC868-A16 - Replies (8)
Hi guys,
I have PIR sensors all over the house connected to an old alarm system. The voltage on the NO contacts are between 1.5v to 3v, which I think is too low for the digital inputs 1 to 16 to register as ON.
I know I can connect to the 5 analog inputs, which does detect the low voltage, but I have ~15 sensors. Is there a way to make these low voltage PIR sensors detectable on digital inputs 1 to 16? Without using a ton of dry contact relays haha
Thank you in advance!
Photo Kilcony RS-485 SHT30 Sensor - Setting MODBUS Address
Posted by: egionet - 04-08-2025, 11:18 PM - Forum: Customer project example - Replies (2)
I tried changing the MODBUS address from MODBUS ID 1 to 15 on the RS-485 SHT30 temperature and relative humidity module through a function 6 write, disconnected the connector for 5 to 10 seconds, reconnected the connector, and polled the sensor over MODBUS. However, the device only responds to MODBUS ID 1, but I can see the updated MODBUS address in register 0x0a as 0x0F.
Is there another setting that has to be configured?
  Issues with STA mode
Posted by: DavidSzilasi - 04-07-2025, 07:53 PM - Forum: KC868-A16 - Replies (2)
Hello!
I recently purchased a KC868-a16 and Im in the process of exploring the KCS server. Yesterday I successfully downloaded the firmware onto the board and was able to scan the ethernet network of the board. I used the eth IP to sign into the website but when I switch the networks setting from AP to STA, there was no STA Wifi IP address after refresh. Can you please advise me on what I may be doing wrong.
Thank you!
Image(s)
  adding KC868-HA RS485 zo HA or ESPHome
Posted by: saymyname - 04-07-2025, 07:06 PM - Forum: KC868-HA /HA v2 - Replies (15)
i have succefully integrate board A16V3 via MQTT auto discovery to Homeassistant. But i didnt found how can i add now KC868-HAv2. If i create new device in ESPHome and copy data from github:
https://github.com/hzkincony/esphome-kc868-ha
I cant install it, ESP gives me error:
Failed config
'esphome' section missing from configuration. Please make sure your configuration has an 'esphome:' line in it.
Do i also need to add main board A16V3 to ESP home and just add those lines to config file of A16V3, or can KC868-HAv2 be add as standalone?
  M30 CT ratio
Posted by: Linus68 - 04-07-2025, 02:29 PM - Forum: KC868-M16 / M1 / MB / M30 - Replies (5)
Hi
I need to use other CT with different CT ratio.
In ESPHome I can Change IT.
But need IT in the Webpage (stand alone use).
IS IT planed to integrate IT in the UI?
Or IS the source Code available?
BR
Linus
  MB Specs - 8A per channel? variable voltage per channel?
Posted by: gregoryx - 04-07-2025, 05:24 AM - Forum: KC868-M16 / M1 / MB / M30 - Replies (8)
Looking to use an MB board (KinCony ESP32 Battery Monitor) to monitor DC circuit power.
I can't tell from the specification if it's 8A per channel or 8A for all 16 channels?
And it's unclear if it can be different voltage on every channel? Can I have 12VDC on one channel and 24VDC on another channel and have correct measurements on both?
thank you.
-Greg
  Low output voltage
Posted by: Knightrider - 04-05-2025, 01:00 PM - Forum: KC868-A16 - Replies (6)
I am trying to use one of the outputs to drive a 12v siren directly.  I have a 12v power supply, with 12v passing from the input to the 12v terminal on the output block.  If I connect my siren to the 12v and output terminal on the block, it doesn't sound properly, and if I measure the voltage across them with a multimeter I am only seeing ~10.5v.
Is this a limitation of the board, or have I wired something wrong?
  KC868-D16 firmware update
Posted by: Gazoved - 04-03-2025, 05:48 PM - Forum: KC868-HxB series Smart Controller - Replies (1)
Good day!
Dear hardware developers ( admin ), do you have any plans to update firmware for KC868-D16 controllers?
The current firmware is D16_V1.08?
  [arduino code examples for TA]-08 how to communication with Tuya WiFi module
Posted by: admin - 04-03-2025, 06:55 AM - Forum: TA - No Replies
* Functionality:
#include <HardwareSerial.h>
HardwareSerial tuyaSerial(1);
#define TXD_PIN 16
#define RXD_PIN 17
#define BAUD_RATE 9600
  if (tuyaSerial.available()) {
      if (bytesRead < 7) {
          if (bytesRead >= 7) break;
        return;
        Serial.print(" ");
      Serial.println();
        Serial.print(" ");
      Serial.println();
  // Delay to avoid CPU overuse
  delay(100);
    switch(packet[2]) {
      case 0x00:
        break;
      default:
        break;
    Serial.print(packet[i], HEX);
    Serial.print(" ");
  Serial.println();
arduino ino file download:
.zip   8-tuya-wifi-config.zip (Size: 2 KB / Downloads: 794)
.zip   8-tuya-wifi-config.ino.merged.zip (Size: 187.17 KB / Downloads: 795)
