» Members: 10,407
» Latest member: ghostwritingservices
» Forum threads: 4,322
» Forum posts: 21,300
There are currently 489 online users.
» 0 Member(s) | 464 Guest(s)
AhrefsBot, Amazonbot, Applebot, Baidu, Bing, Bytespider, Crawl, Google, HeadlessChrome, PetalBot, Semrush, bot
KC868-A4 – Relay 1 clicks...
48 minutes ago
5 hours ago
» Replies: 24
Yesterday, 03:04 AM
Yesterday, 01:34 AM
Yesterday, 12:15 AM
450 Hz allowed on input?
Forum: Development
11-02-2026, 09:41 PM
How Do You Handle Relay C...
11-02-2026, 05:41 PM
"KCS" v3.27.4 firmware BI...
11-02-2026, 06:02 AM
how to check i2c extend c...
Forum: T16M
11-02-2026, 12:38 AM
T16M ESPHome yaml for hom...
Forum: T16M
11-02-2026, 12:35 AM
  [arduino code examples for B16]-10 Print TEXT on SSD1306 OLED displayer
Posted by: admin - 02-22-2025, 02:10 AM - Forum: B16 - No Replies
* - SCL (clock) on pin IO18
* - SDA (data) on pin IO8
// Initialize the display using the software I2C method (SCL = IO39, SDA = IO38)
void page1() {
  u8g2.begin();
  do {
    page1();
arduino ino file download:
.zip   10-oled-ssd1306.zip (Size: 1.12 KB / Downloads: 765)
.zip   10-oled-ssd1306.ino.merged.zip (Size: 201.24 KB / Downloads: 773)
  [arduino code examples for B16]-09 how to communication with Tuya WiFi module
Posted by: admin - 02-22-2025, 02:08 AM - Forum: B16 - No Replies
* Functionality:
#include <HardwareSerial.h>
HardwareSerial tuyaSerial(1);
#define TXD_PIN 16
#define RXD_PIN 17
#define BAUD_RATE 9600
  if (tuyaSerial.available()) {
      if (bytesRead < 7) {
          if (bytesRead >= 7) break;
        return;
        Serial.print(" ");
      Serial.println();
        Serial.print(" ");
      Serial.println();
  // Delay to avoid CPU overuse
  delay(100);
    switch(packet[2]) {
      case 0x00:
        break;
      default:
        break;
    Serial.print(packet[i], HEX);
    Serial.print(" ");
  Serial.println();
.zip   9-tuya-wifi-config.zip (Size: 2 KB / Downloads: 752)
.zip   9-tuya-wifi-config.ino.merged.zip (Size: 184.93 KB / Downloads: 744)
  [arduino code examples for B16]-08 Ethernet W5500 chip work with TCP Server mode
Posted by: admin - 02-22-2025, 02:07 AM - Forum: B16 - No Replies
* received from a client.
* Hardware connections:
* - CLK: GPIO1
* - MOSI: GPIO2
* - MISO: GPIO41
* - CS: GPIO42
* - RST: GPIO44
* - INT: GPIO43
* Subnet Mask: 255.255.255.0
* Gateway: 192.168.3.1
* DNS: 192.168.3.1
#include <SPI.h>
#include <Ethernet.h>
#define W5500_CS_PIN  42
#define W5500_RST_PIN 44
#define W5500_INT_PIN 43
#define W5500_CLK_PIN 1
#define W5500_MOSI_PIN 2
#define W5500_MISO_PIN 41
EthernetServer server(4196);
  while (!Serial) {
  Ethernet.init(W5500_CS_PIN);
  Serial.print("IP Address: ");
  server.begin();
  if (client) {
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        server.write(c);
    client.stop();
.zip   8-Ethernet-W5500.ino.merged.zip (Size: 188.93 KB / Downloads: 827)
.zip   8-Ethernet-W5500.zip (Size: 1.23 KB / Downloads: 758)
  [arduino code examples for B16]-07 how to DS3231 RTC clock
Posted by: admin - 02-22-2025, 02:05 AM - Forum: B16 - No Replies
* DS3231 RTC with Arduino
* Hardware Connections:
* - SDA: GPIO 8
* - SCL: GPIO 18
#include <DS3231.h>
#include <Wire.h>
typedef struct
  byte month;
  byte day;
  byte hour;
  byte minute;
  byte second;
} MY_DATE_STR;
#define OPEN_RLY_DATA    26
#define OPEN_RLY_MONTH   4
#define CLOSE_RLY_DATA   2
#define CLOSE_RLY_MONTH  5
// Define pin connections
#define SDA_PIN   8
#define SCL_PIN   18
bool h12Flag;
bool pmFlag;
static bool bCentury = false;
static void PrintfCurTime()
  Serial.print(year);
  Serial.print("-");
  Serial.print("-");
  Serial.print(" ");
  Serial.print(":");
  Serial.print(":");
static void GetSerialCmd()
  if (Serial.available() > 0)
    delay(100);
    while (num_read--)
  else return;
  serial_cmd_rcv.trim();
    PrintfCurTime();
    return;
  Serial.print("D index: ");
  Serial.print(indexof_d);
  Serial.print(" T index: ");
  Serial.println(indexof_t);
    return;
  rtc.setDate(my_date_str.day);
  Serial.println("Time set.");
  PrintfCurTime();
  while (Serial.read() >= 0) {}
  GetSerialCmd();
.zip   7-DS3231-RTC.zip (Size: 1.56 KB / Downloads: 759)
.zip   7-DS3231-RTC.ino.merged.zip (Size: 191.08 KB / Downloads: 813)
  [arduino code examples for B16]-06 How to use SD Card
Posted by: admin - 02-22-2025, 02:04 AM - Forum: B16 - No Replies
* SD Card File Operations
* - SCK: GPIO 11
* - MISO: GPIO 12
* - MOSI: GPIO 10
* - CS: GPIO 9
#include "FS.h"
#include "SD.h"
#include "SPI.h"
#define SCK  11
#define MISO 12
#define MOSI 10
#define CS   9
  File file = fs.open(path);
  if (!file) {
    return;
  while (file.available()) {
  file.close();
  if (!file) {
    return;
  if (file.print(message)) {
  file.close();
  if (!file) {
    return;
  file.close();
  if (fs.remove(path)) {
  static uint8_t buf[512];
  size_t len = 0;
  uint32_t start = millis();
  uint32_t end = start;
  if (file) {
    len = file.size();
    size_t flen = len;
    start = millis();
    while (len) {
      size_t toRead = len;
      if (toRead > 512) {
        toRead = 512;
      file.read(buf, toRead);
      len -= toRead;
    end = millis() - start;
    file.close();
  if (!file) {
    return;
  size_t i;
  start = millis();
  for (i = 0; i < 2048; i++) {
    file.write(buf, 512);
  file.close();
  // Initialize SPI and SD card
    return;
  if (cardType == CARD_NONE) {
    return;
  if (cardType == CARD_MMC) {
    Serial.println("MMC");
    Serial.println("SDSC");
    Serial.println("SDHC");
    Serial.println("UNKNOWN");
  delay(2000);
  // Perform file operations
  deleteFile(SD, "/hello.txt");
  readFile(SD, "/hello.txt");
  testFileIO(SD, "/test.txt");
  // No operation in loop
.zip   6-SD.zip (Size: 1.53 KB / Downloads: 778)
.zip   6-SD.ino.merged.zip (Size: 221.25 KB / Downloads: 752)
  [arduino code examples for B16]-05 Read free GPIO state
Posted by: admin - 02-22-2025, 02:03 AM - Forum: B16 - No Replies
* GPIO Status Monitoring
* GPIO Pins Monitored:
* - GPIO 40
* - GPIO 7
* - GPIO 48
* - GPIO 47
* - GPIO 13
* - GPIO 14
* - GPIO 21
* - GPIO 0
* Hardware Requirements:
#define GPIO_PIN_40 40
#define GPIO_PIN_7 7
#define GPIO_PIN_48 48
#define GPIO_PIN_47 47
#define GPIO_PIN_13 13
#define GPIO_PIN_14 14
#define GPIO_PIN_21 21
#define GPIO_PIN_0 0
bool prevState[8] = {false, false, false, false, false, false, false, false};
  pinMode(GPIO_PIN_40, INPUT);
  pinMode(GPIO_PIN_7, INPUT);
  pinMode(GPIO_PIN_48, INPUT);
  pinMode(GPIO_PIN_47, INPUT);
  pinMode(GPIO_PIN_13, INPUT);
  pinMode(GPIO_PIN_14, INPUT);
  pinMode(GPIO_PIN_21, INPUT);
  pinMode(GPIO_PIN_0, INPUT);
  bool currentState[8];
  currentState[0] = digitalRead(GPIO_PIN_40);
  currentState[1] = digitalRead(GPIO_PIN_7);
  currentState[2] = digitalRead(GPIO_PIN_48);
  currentState[3] = digitalRead(GPIO_PIN_47);
  currentState[4] = digitalRead(GPIO_PIN_13);
  currentState[5] = digitalRead(GPIO_PIN_14);
  currentState[6] = digitalRead(GPIO_PIN_21);
  currentState[7] = digitalRead(GPIO_PIN_0);
  for (int i = 0; i < 8; i++) {
      Serial.print("GPIO ");
      Serial.print(i == 0 ? GPIO_PIN_40 :
                   i == 1 ? GPIO_PIN_7 :
                   i == 2 ? GPIO_PIN_48 :
                   i == 3 ? GPIO_PIN_47 :
                   i == 4 ? GPIO_PIN_13 :
                   i == 5 ? GPIO_PIN_14 :
                   i == 6 ? GPIO_PIN_21 : GPIO_PIN_0);
      Serial.print(" changed to ");
      // Update the previous state
.zip   5-free-gpio-state.zip (Size: 1.04 KB / Downloads: 674)
.zip   5-free-gpio-state.ino.merged.zip (Size: 179.57 KB / Downloads: 701)
  [arduino code examples for B16]-04 RS485 communication test
Posted by: admin - 02-22-2025, 02:01 AM - Forum: B16 - No Replies
* RS485 Communication Test
// Define RS485 pins
#define RS485_RXD 38
#define RS485_TXD 39
  while (!Serial);
  // Send a test message
  rs485Serial.println("Hello from KinCony B16!");
  // Wait for a short period
    String receivedMessage = "";
      char c = rs485Serial.read();
      receivedMessage += c;
    // Print the received message
    Serial.print("Received: ");
  delay(2000);
.zip   4-RS485-Test.zip (Size: 763 bytes / Downloads: 759)
.zip   4-RS485-Test.ino.merged.zip (Size: 184.34 KB / Downloads: 697)
  [arduino code examples for B16]-03 Read ADS1115 analog input ports value
Posted by: admin - 02-22-2025, 01:58 AM - Forum: B16 - No Replies
#define SDA_PIN 8
#define SCL_PIN 18
DFRobot_ADS1115 ads(&Wire);
void setup(void)
    Wire.begin(SDA_PIN, SCL_PIN);
    ads.setGain(eGAIN_TWOTHIRDS);
    ads.setMode(eMODE_SINGLE);
    ads.setRate(eRATE_128);
    ads.init();
void loop(void)
    if (ads.checkADS1115())
        adc0 = ads.readVoltage(0);
        Serial.print("A0:");
        Serial.print(adc0);
        adc1 = ads.readVoltage(1);
        Serial.print("A1:");
        Serial.print(adc1);
        adc2 = ads.readVoltage(2);
        Serial.print("A2:");
        Serial.print(adc2);
        adc3 = ads.readVoltage(3);
        Serial.print("A3:");
        Serial.print(adc3);
    else
.zip   3-ads1115_adc.zip (Size: 1.2 KB / Downloads: 725)
.zip   3-ads1115_adc.ino.merged.zip (Size: 190.05 KB / Downloads: 760)
  [arduino code examples for B16]-02 Read digital input ports state
Posted by: admin - 02-22-2025, 01:57 AM - Forum: B16 - No Replies
* Description:
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* - PCF8575 I2C Address: 0x24
#include "Arduino.h"
#include "PCF8575.h"
// Define I2C pins
// Set I2C address
PCF8575 pcf8575_IN1(0x24); // The I2C address of the PCF8575
    Serial.println("KinCony F16 16 channel input state 0:ON  1:OFF");
    uint16_t state = 0;
    for (int pin = 0; pin < 16; pin++) {
        if (pcf8575_IN1.read(pin)) {
    delay(500); // Delay 500ms
.zip   2-digital-input.zip (Size: 837 bytes / Downloads: 681)
.zip   2-digital-input.ino.merged.zip (Size: 189.52 KB / Downloads: 782)
  [arduino code examples for B16]-01 Turn ON/OFF OUTPUT
Posted by: admin - 02-22-2025, 01:56 AM - Forum: B16 - No Replies
* Pin Definitions:
* - SDA: GPIO 8
* - SCL: GPIO 18
* Delay Time:
#define SDA 8           // Define the SDA pin
#define SCL 18           // Define the SCL pin
#define I2C_ADDRESS 0x22 // I2C address of the PCF8575 module
  pcf8575_R1.begin();
.zip   1-output.zip (Size: 926 bytes / Downloads: 704)
.zip   1-output.ino.merged.zip (Size: 189.23 KB / Downloads: 731)
